- Thank you received: 18
Retrofitting a 1986 Maho MH400E
- Glemigobles
7 years 7 months ago #128310
by Glemigobles
Replied by Glemigobles on topic Retrofitting a 1986 Maho MH400E
Looking good Mark, though after milling that pocket and outer contour I'd use your large facemill to take off the top. Take advantage of that hydraulic-assisted tool changing
By the way, I finally ordered all the Mesa parts for the retrofit over the weekend. I ended up buying them from Portugal because they had everything in stock apart from the DB25M to IDC26 cable. Since I have to make the cable myself, do you maybe know what the pinout is between the two connectors?
Gonna have to finally buy that soldering 3rd arm for this project, otherwise I'm likely to kill myself with my iron
7 years 7 months ago #128313
Maybe use a IDC to DB25F back-panel then a DB25M-M cable?
www.amazon.co.uk/Nacpy-Parallel-Header-A...acket/dp/B07BQ2KJDQ/
Replied by andypugh on topic Retrofitting a 1986 Maho MH400E
Glemigobles wrote: everything in stock apart from the DB25M to IDC26 cable.)
The following user(s) said Thank You: Glemigobles
- Glemigobles
7 years 7 months ago #128316
by Glemigobles
That's a good idea!
- RotarySMP
- Thank you received: 595
7 years 7 months ago - 7 years 7 months ago #128319
by RotarySMP
I used the face mill on the other side, but was playing around and decided to see what the finish looked like with that 8mm carbide. I need to set up a tool table and the manual tool changing comp, so I don't have to touch off after changing tools.
I bought Mesa's IDC26 - IDC26 cable to connect the 5i25 with the 7i77. Not the most practice solution, especially since I have the ITX MoBo edge connectors pointing left and far to close to the cable tunnel, so the conenctors end up crammed into the tunnel. Rotating the MoBo to put the edge connectors down would have made for easier access.
This link is a photo I previously posted in this thread showing my MoBo and 7i77 layout.
Mark
Mark
Last edit: 7 years 7 months ago by RotarySMP.
- pl7i92
- Thank you received: 358
7 years 7 months ago #128432
by pl7i92
Replied by pl7i92 on topic Retrofitting a 1986 Maho MH400E
Question why dident you add a 7i92 so it is all of the eternet
and you can go with the newest software OS and Aplication guis
- RotarySMP
7 years 7 months ago - 7 years 7 months ago #128442
by RotarySMP
Good question. Because I had no clue what I was doing back then and didn't know the 7i92 existed
The Plug'n'go 5i25+7i77 kit from Mesa was well known on the forum and works. I dont think the choice between 5i25 or 7i92 makes much of a difference. The connection between the FPGA (whether 5i25 or 7i92) to the 7i77 is DB25, and that is the bulky cable which is more differcult to fit into cable channel. My MoBo has a PCI slot, so it saves space to use the 5i25 rather than a remote mounted 7i92.
I didn't really under stand the why the Mesa Lego fits together. I did think it was weird that they had me cut the end off a CAT 5E cable from the 7i84 and terminate it in screw connections on the 7i77. That section of the 7i77 manual could be improved with a note that the 7i44 exists.
I think Hanno was the first to point out the 7i44 to me. If I did it today, I'd use the 5i25+7i77+7i84 again, but add the 7i73 at the user interface, and tie the Ethernet cards to the 5i25 with a 7i44 through a ribbon cable.
Mark
Mark
Time to create page: 0.974 seconds
