Retrofitting a 1986 Maho MH400E
7 years 7 months ago #128526 by andypugh
Replied by andypugh on topic Retrofitting a 1986 Maho MH400E
I _think_ that the Smart Serial cards will work with either straight or crossover cables.
7 years 7 months ago - 7 years 7 months ago #128529 by RotarySMP
Doesn't he need that DB25 connection on the 5i25 for the 7i77? The 5i25 has a second DIL26 pinhead, for connecting a 7i44.
Or will the 7i77 work if it you connect
7i77 through TB6-> 7i74 , then 7i74 --> 5i25 through the DB25 cable?
Mark
Last edit: 7 years 7 months ago by RotarySMP.
7 years 7 months ago #128530 by PCW
Replied by PCW on topic Retrofitting a 1986 Maho MH400E
Alas, SSerial cards cannot have their RX/TX pairs swapped.
The interfaces are designed for straight through cables.
You might be confused Ethernet, our Ethernet cards will work with straight
through or crossover cables (this is a common Ethernet feature known as MDIX)
7 years 7 months ago #128531 by PCW
PCW wrote: Alas, SSerial cards cannot have their RX/TX pairs swapped.
You might be confused with Ethernet, our Ethernet cards will work with straight
7 years 7 months ago - 7 years 7 months ago #128532 by andypugh
RotarySMP wrote: Doesn't he need that DB25 connection on the 5i25 for the 7i77? The 5i25 has a second DIL26 pinhead, for connecting a 7i44.
The extra port on the 5i25 is DIL26. This needs a DIL26 to DB25 adaptor, then a DB25 cable to connect to a 7i74.
www.amazon.co.uk/Female-Motherboard-Brac...s-show/dp/B07M64X6LS
(Or you could make your own DI26 to DB25 connector.)
The 7i44 connects to the _50_ pin cards (such as the 5i20 or 5i24)
Last edit: 7 years 7 months ago by andypugh. Reason: Got 7i74 / 7i44 mixed up
7 years 7 months ago #128533 by RotarySMP
Oh. Thanks for picking that up.
Time to create page: 1.154 seconds
