Retrofitting a 1986 Maho MH400E
7 years 6 months ago - 7 years 6 months ago #130356 by hanmon
Replied by hanmon on topic Retrofitting a 1986 Maho MH400E
Hi
it can be seen in my config file "MAHO_MH400E_postgui.hal":
#central lubrication
loadusr -W /etc/linuxcnc/MAHO_MH400E/lube
net lube-run lube.run => hm2_5i25.0.7i84.1.3.output-14
net machine-is-enabled lube.machine_status <= motion.motion-enabled
net spindle-on lube.spindle_status <= motion.spindle-on
net lube-ps-float-sw lube.pressuresw_floatsw <= hm2_5i25.0.7i84.1.3.input-21
All you have to do is change the path "/etc/linuxcnc/MAHO_MH400E/lube" according to where you put "lube" and, of course,
wire up the lubrication pump. If you connect it to different input and/or output pins, you have to adapt that, too.
Hanno
Last edit: 7 years 6 months ago by hanmon.
7 years 6 months ago #130523 by Glemigobles
Replied by Glemigobles on topic Retrofitting a 1986 Maho MH400E
Hey guys,
Small update from me - got LinuxCNC installed on a dedicated ITX motherboard with an Intel i3 CPU. Just combed through this thread and Mark's instructions to make a detailed list of all the necessary components I'll have to get from the nearby electronics store tomorrow. Then I'll connect all the Mesa parts to the PC and see if they communicate with each other before moving on to tampering with the mill.
Ashamed to admit this, but I'd been working under the assumption that the PCIe port is backwards compatible with a regular PCI port :)
I bought parts for an AMD Ryzen machine at first, realized my mistake and went out and bought the used i3 parts at a service point. Mobos with new chipsets don't really have PCI slots it turns out. Had I known that, I'd have gotten a Mesa PCIe FPGA card (6i25) or an Ethernet one (7i92). Does the Ethernet option have any particular downsides?
One thing that came to my mind, which someone else might use in the future, is that you could easily mount the PC behind a flatscreen monitor in place of the original CRT display. There's plenty of room to fit in an ITX board and a PSU (provided some kind of custom mounting plates, which is what you have to make anyway if the PC is in the back) in that chassis.
With the 7i92, you'd only need to run one Ethernet cable through the original conduit, say, replacing the video cable, from the pulpit to the electric cabinet. IMO, that would make for an elegant solution where you have all the PC parts in the control panel and all the Mesa cards in the electric cabinet. You wouldn't have to worry about USB or Ethernet ports b/c the MoBo would be easily accessible. That could also save a lot of room for additional servo drives (4th/5th axis) and a VFD in the cabinet if you're smart with crafting mounting plates for the Mesa chips.
You could use the pulpit to fit your own control panel. This solution obviously also comes with the downside of the panel having certain dimensions which you might find suboptimal for controlling LinuxCNC.
One question, probably a stupid one: how is the PC powered on? If the main switch is still used, do you connect anything to the PWR pins on the motherboard to make it start when you turn the switch? Do you turn on the PC separately? I'm rather an electronics noob I'm afraid, it just seems to me that a PC won't power on just because the PSU is energized and I have to jumper the PWR pins to start the machine now.
7 years 6 months ago #130533 by tommylight
Replied by tommylight on topic Retrofitting a 1986 Maho MH400E
Glemigobles wrote: One question, probably a stupid one: how is the PC powered on? If the main switch is still used, do you connect anything to the PWR pins on the motherboard to make it start when you turn the switch? Do you turn on the PC separately? I'm rather an electronics noob I'm afraid, it just seems to me that a PC won't power on just because the PSU is energized and I have to jumper the PWR pins to start the machine now.
That can be set in BIOS so it turns on automatically when power is present . Takes about 20 seconds to do, just press DEL or F2 or F10 immediately after pressing the power button, then look for power options and there should be something like power on after power failure and set it to ON.
7 years 6 months ago #130544 by J Green
Replied by J Green on topic Retrofitting a 1986 Maho MH400E
Glemigobles
Sorry, but I forgot which Maho you have. Think it may be a MH500e. Anyway , to muddy the water so to say
" Ethernet one (7i92). Does the Ethernet option have any particular downsides? " .
From Linuxcnc Logs 4-2-19 about 8:24 AM , noticed a comment from pcw / Mesa .
" pcw_home: Ethernet is a bit harder to setup and requires the uspace version of LinuxCNC
pcw_home: if you have something exotic to control that needs a fast servo thread (faster than 1 KHz) PCI/PCIE is better
pcw_home: but at the default 1 KHz, Ethernet is fine and has the added benefit of electrical isolation and the ability to work with mini-pcs that have no slots " He also makes a comment referring to the current Trajectory Planner component of LinuxCNC which I thought was referring to Mother Board speed if a "Jerk" component is added in the future.
What I have never seen discussed is
what ( servo thread -1KHz or more ) is needed for a Maho MH?00?? such that the conversion will result in equal or greater performance of the final MH?00?? version. I think the final MH?00?? version used a 5?? series processor --but it only had to run the machine and no Wi-Fi ,hard drive,really nice graphic display,probe,tool setter, thread milling,You-Tube,etc. I am referring to using the existing servo motors (DC or later permanent magnet type) and their Indrament motor drive - the later variable speed spindle motor and it's Indramet motor drive - plus 2 more axis. So it would be a 6 axis control-- XYZ = 3 and spindle =1 and B an C axis = 2 . Plus a 20 tool tool changer for me!
Not too clear to me is your question of powering up the PC via the Main switch. " tommylight " has described changing the Bios . Or are you wanting to power the PC but not power the rest of the machine? Powering just the PC and/or the Mesa boards could be useful for maintenance.
Like your thought about reusing the existing operator consul / pulpit .Hope that is what you end up doing! Now if someone would write a "component" so the existing keyboard and hand controller could be used -It would be just peachy . Do you know how to program in "C or C+ or C++"?
Hope to read an see more of your conversion--
Bob
PS Thank you Mark for all you have done/doing
PPS R2AIV what is the latest ?
7 years 6 months ago #130546 by drimaropoylos
Replied by drimaropoylos on topic Retrofitting a 1986 Maho MH400E
You need to power off the pc from the bouton before closing the main switch, so you need a bouton from the motherboard to control panel face.
7 years 6 months ago #130547 by drimaropoylos
In the original control cabinet I will mace a slot like in the has control panel, and put there the pc power bouton (probably a key switch) and the usb ports .
Time to create page: 0.254 seconds
