Thanks for the info Robert.
Its kind amazing how many different models Hurco must have had. I don't think I've seen a picture of one that looks quite like the one I've got.
I did measure the quill wiggle. Came up with about 0.0008. Not sure what a good number would be, but this seems a bit high. When I run the quill, there seems to be some visibly noticeable wonkiness. Hopefully, that's mostly in the Kwik Switch collar and not the quill itself.
I got the oiler working, or at least mostly working. Its hard to tell if all the lube points are actually receiving oil. Couldn't find any data on what to set the oiler air pressure at. Any advice?
The head has a two speed transmission. Hi gear seems to be OK. But low gear makes some unhappy noises. Hoping the oiler will fix this, but I'm not so optimistic.
The brake cylinder works, but doesn't seem to have much impact on the quill.
We had picked up a 0.750 kwik switch tools holder off Ebay. When I measure the diameter, I get 0.835 inches. Its got a Universal part number that corresponds to a 0.750 tool holder. I measure about 0.008 out of centricity. I doubt Universal would sell such a thing. Hard to say what happened. Perhaps somebody bored it out... poorly. We've had this holder for a couple months, its hard to send it back. In the future I think we'll measure soon after we get a new tool.
At this point I'm thinking a head rebuild might be in order. My guess is the head weighs about 300 pounds. Don't have an easy way to safely hoist such a thing off and on the machine. We'll see.
I have pretty much full functionality on the machine now. But its in sort of a prototype phase. See attached photos for the entertainment value.
Currently working on mapping the Hurco control paradigm to the LinuxCNC. This is a challenge because I've never used either. Some of the finer points will probably go missing. But I think I'm just going to take my best shot at it and then use the machine and fix what doesn't work out.
I think one of my first projects will be to build some mounting bracket for the air regulator. Its currently ty-wrapped to the back of the machine. Make it out of easily machined aluminum. Doesn't need to look good or be very accurate.
