Hurco KMB-IS CNC update
6 years 3 weeks ago #185173 by PCW
Replied by PCW on topic Hurco KMB-IS CNC update
The manual pinout is correct
TB5 pin1 (bottom pin) is ENA0-
6 years 1 week ago #186639 by _big_
Replied by _big_ on topic Hurco KMB-IS CNC update
Looking to get the spindle going.
Using an Allen Bradley 1336 Plus VFD. This VFD takes 0-10V for speed and a separate signal for reverse.
When I look at HAL pin ANALOGOUT5, initially its zero. If I click the spindle clockwise it goes to 1. If I click the other spindle button it goes to -1.
That all makes sense except I need a 0-10V (I can fix the scaling) magnitude signal and a separate forward reverse digital signal.
Looked through pncconf and don't see any options for this. Tried Googling and didn't find an answer either.
Is there a way to convince LinuxCNC and the 7i77 card to play with my VFD?
6 years 1 week ago #186670 by tommylight
Replied by tommylight on topic Hurco KMB-IS CNC update
In hal:
-wire the analog out value to the ABS component in
-wire the ABS out to physical analog out.
That way you get only 0-10V on the output.
The following user(s) said Thank You: _big_
6 years 1 week ago #186820 by _big_
Found something cool I wanted to make a record of.
I was planning on taking the original Hurco control panel and cutting out the existing CRT and tape drive holes for sort of LinuxCNC display panel. The owner of the machine wants to preserve the original Hurco control panel.
OK, so now probably I think we should use the existing Hurco swing arm and replace the control panel with a display/keyboard/mouse. But at the very least, we still require a hardwired E-Stop.
Lots of CNC pendants out there. Most of them USB based. USB will not provide a hardwire E-Stop and the MPG will be subject to "GUI delays" which are quite common with the RPi4.
Ran across this: wapl.es/cnc/2020/02/23/linuxcnc-jog-wheel-setup.html
Hard wired E-Stop and MPG :) Ordered one from Aliexpress.
6 years 1 week ago #187045 by _big_
Found the spot in pncconf to get a 0-10V output.
On the spindle page, in the upper left corner, there is a box where you can select +- voltage for forward and reverse.
Un checked this and I get a 0-10 on the analogout5 for both directions. There are also spindle CW and CCW signals.
No HAL hacking necessary.
6 years 1 week ago #187156 by CORBETT
Replied by CORBETT on topic Hurco KMB-IS CNC update
Hey Leith,
I have been tied up and not on here at all for a bit. Looks like you are coming along well on your retrofit. I have been super busy with work and working on 2 other EtherCAT controllers. Sorry I was not around for the encoder wiring as I had pics and the TB8 connection numbers. Anyway, will be on along and along hopefully... just have had lot of semi-emergency work calls. Plus been wanting to tinker with the new SilverDragon GUI.
Hope all is going well.
Robert
Time to create page: 0.397 seconds
