- Thank you received: 9
Replacing Advanced Motion Controls "brush type 12A8 with "Axcent" amplifier
- new2linux
5 years 11 months ago - 5 years 11 months ago #190136
by new2linux
Replied by new2linux on topic Replacing Advanced Motion Controls "brush type 12A8 with "Axcent" amplifier
I have tried the new diagram, now no motion at all. If you try "jog" the velocity in DRO shows correctly the feed rate, but no motion. The yellow "shows the tool movement on DRO screen" does show motion, but table does not move.
Edit: SW1-6 OFF or ON = no effect
Edit: After conversation with AMC the diagram recommended is attached (I worked with this for a while) and after continuity checking for my piece of mind all checked ok, with this 1 question. The shield around the leads going to encoder are grounded to case of encoder on that end, but in the electrical control box (do not connect to 7i77 card), they stop after connecting to GND inside el cabinet. Should they go under screw 3 (GND) on TB3? see attached diagram.
many thanks
many thanks
Last edit: 5 years 11 months ago by new2linux. Reason: sw1-6; asked question, and clearified
- Thank you received: 1480
5 years 11 months ago #190205
Replied by Todd Zuercher on topic Replacing Advanced Motion Controls "brush type 12A8 with "Axcent" amplifier
The cable shield should only be connected at one end. (normally to a frame ground or central ground bolt at the control cabinet.) And should not be connected to any of the ground wires or terminals of the control wiring.
The above wiring diagram looks correct to me with the possible exception of there may need to be a ground reference connection between the drive and encoder/7i77.
- new2linux
5 years 11 months ago #190206
by new2linux
Todd, Many thanks!! As per your suggestion I have made the changes as to add lead from under screw at TB3 contact 3; to TB5 contact 1. If SW1-6 is OFF; red LED on drives; green blink on 7i77; F1 down or up DRO works; F2 down x motor osculates and y axis motor "runs away".
If SW1-6 is ON; red LED on drives, except green while in "runs away"; green blink on 7i77; F1 down or up DRO works; F2 down "x" motor no motion (does not resist motion, ether) and y axis motor "runs away".
I have contact with AMC what should I be asking? Many thanks!
5 years 11 months ago - 5 years 11 months ago #190210
Are you certain of your pin numbering on the drives? I believe that Pin #1 should be the furthest one away from the motor plug.
I don't have any idea why your x is osculating the way it is. (It is almost as if the encoder signal is connected to the Hall inputs of the drive, and why I asked if you might have the plug numbering backwards.)
Believe it or not the Y running away actually may be less mystifying than what is happening with the X. (Although it can be very frightening when it happens.) It means that a feedback signal is wrong, missing or opposite of the command (At least on a system that is mostly connected correctly.) What happens is the control says to move one way but it (or the drive) sees it moving the other way (or not moving at all), so It tells it to go faster or push harder to correct for the wrong (or missing) movement and the motor "runs away" at it's max velocity.
I don't think I can do much more diagnosis of this remotely. I can't think of what to check next. You might be better off having someone who knows what they are doing look at it in person.
Last edit: 5 years 11 months ago by Todd Zuercher.
- new2linux
5 years 11 months ago - 5 years 11 months ago #190218
by new2linux
Todd, Many thanks for your continued support, you are a true gentleman, all the way through. The drives are using the full width plug with only the necessary leads, inserted & soldered to leads, so it only goes one way. I am in contact with AMC about the diagram. As per AMC was suggested to leave leads from encoder and drive (those leads stay with each other) and change out the position on the TB3 plug, (as to change the direction of controller in relation to encoder. I think was how it was explained) on 7i77 card. With that change this is how it functions: No motion at all. If you use "jog" to move table, the velocity increases to match the posted feed rate as it is set by the slider, but no motion from motors.
many thanks!
many thanks!
5 years 11 months ago - 5 years 11 months ago #190221
What leads did you move where on which axis' drive? It is impossible for us to keep track of what you are changing because you never precisely say what you are changing. Just swapping things willy nilly is going to lead to blown up components.
Can you snap a photo of the drive with the leads plugged in, so that we might see what is going where?
(and if possible the same for the 7i77)
Time to create page: 0.570 seconds
