Deckel Retrofit FP4A
5 years 7 months ago #202958 by MrSpeaky
Replied by MrSpeaky on topic Deckel Retrofit FP4A
not on this forum and i dont wanna name him
he doesnt wanna share it, which i can understand so i will try to edit
Marks (RotarySMP) C component which is thankfully fully commented
5 years 7 months ago #203534 by MrSpeaky
So quick update
i manages to hook up the tool clamping to the mesa card
Wuhuuu
Well but i noticed something on my machine
and i cant get rid of the feeling that something is missing there
does somebody know?
5 years 7 months ago #203536 by db1981
Replied by db1981 on topic Deckel Retrofit FP4A
can you post an picture with more environment please,
i'm not shure from which point of view this is..
5 years 7 months ago #203549 by RotarySMP
Replied by RotarySMP on topic Deckel Retrofit FP4A
It is missing a mess of coolant stains, dried up oil and swarf. Ever CNC has that.
Mark
5 years 7 months ago - 5 years 7 months ago #203591 by db1981
this hole is normal. they have used the same steelcast for many versions, on manual or machines with only on axis motor or additional Handwheels there have been bearings and gears mounted.
If you look through this hole, you should see the Y axis Ballscrew.
Pay attention to the oil levels, theses are for the transmission and the spindle bearings.
Do you own an maintance manual?
Last edit: 5 years 7 months ago by db1981.
The following user(s) said Thank You: MrSpeaky
5 years 7 months ago #203595 by J Green
Replied by J Green on topic Deckel Retrofit FP4A
db 1981
Have you seen the IC Haus Chips for converting 11 micro amp analog to digital ? Just put a Heidenhain 600 EXE series PDF on Marks - Maho thread - might be of some use for what they sold . Interesting you are thinking of making your own converters - could you describe more of what you are trying to come up with ? Do you make your own circuit boards ?
Gear change ---- There was a web site ( Westleys project ? ) where he was converting DECKEL to newer control , which had his matrix for gear changing . But I can't find it any more . I will keep looking though .
If you write the code for gear change could you consider making it configurable for 1 - 2 - 3 gear shifting motors ?
Mr Speaky --- Thank You for for all of the Phots and your continued progress reports !
Bob
