Retrofitting a TOS FNG 32 NC
3 years 9 months ago #263105 by Kevin_Pawlus
Not sure why my video didn't load but anyway here it is on Youtube.
youtube.com/shorts/aqoCS_az_js?feature=share
3 years 9 months ago #263268 by Kevin_Pawlus
Today I tried to swap the driver cards around and switch places on X and Y. I get the same result so I believe that the servo drives are ok...
It's like the machine has become super sensitive or something. If I jog a little bit up the table goes +100mm and I get a joint f error.
I'm out ideas, please help
3 years 9 months ago #263293 by Henk
Replied by Henk on topic Retrofitting a TOS FNG 32 NC
I would suspect that the drive is not getting feedback from the tacho on the motor.
You can make the P in your tuning 0 and only use Ff1 so that linuxcnc doesn't correct the position loop and see if the motor wants to run away. That normally means that there is tacho issues.
Be carefull though. It can run away and crash. Make sure that the following error will disable the drive. Better to take the motor or belt off before doing this.
The following user(s) said Thank You: Kevin_Pawlus
Time to create page: 0.060 seconds
