Retrofitting a TOS FNG 32 NC
4 years 2 months ago #248836 by Kevin_Pawlus
I have been tuning all axis now, they move really smooth and its a nice feeling to see that the machine is finally moving again.
I've been trying to get the spindle running. I see that there is some values you can change inside LinuxCNC calibration, similar to the XYZ. Don't know how to set those up correctly. I dont get the spindle to run at all. Is there something more then to press F9/F10 in Axis?
I have wired from pin 7 -> Enable on Mesa -> 63,64 & 80. My +-10V is beteween 56 & 14.
4 years 2 months ago #248854 by tommylight
After F9/F10, F11 and F12 will raise or lower the speed.
4 years 2 months ago - 4 years 2 months ago #248856 by Kevin_Pawlus
I got the spindle running.
I changed P value from 0 -> 50 and the spindle is running. But very slow.
I can measure that I have 10V between 56 & 14. So it should be at max speed right?
What function does LF and EP1 have?
Last edit: 4 years 2 months ago by Kevin_Pawlus.
4 years 2 months ago #248901 by Henk
Replied by Henk on topic Retrofitting a TOS FNG 32 NC
Have you checked the motor field voltage. Is it supplied by the siemens drive?
4 years 2 months ago - 4 years 2 months ago #248923 by Kevin_Pawlus
I'm not sure why but the field voltage is not supplied by the Siemens drive, I do have about 60V on the "ANKER" circuit
pin 123, 124, 31, 32 is connected like the schedule.
4 years 2 months ago #248940 by andypugh
Does the spindle motor have a tachometer? Possibly it is running in closed-loop velocity mode and there is a problem with the feedback?
Time to create page: 0.267 seconds
