With the PC for the mill sorted for now I could focus on the build again continuing with a small control panel for the physical buttons.
My plans were to use a few physical buttons for the most essential stuff like e-stop and jogging. But after using the Axis UI to get my HAL file setup and trying all the various features I realized that physical buttons which can be felt and pressed without having to look at them is going to add a lot of value on a machine like mine which still has a quill and probably well be used in semi manual mode at least to some degree.
So I scaled up my plans for physical buttons and decided to make a sturdy panel to be mounted underneath the monitor and which can be safely operated with dirty gloves without causing any issues.
I did a rough sketch in Visio as I haven't had time to fully master FreeCAD yet.
Next I purchased an 60x80 mm aluminum extrusion with 3 mm thick walls and milled it to length
I then used double sided floor tape to glue a leftover piece of 2 mm stainless I had laying around from my previous milling machine table extension.
With the stainless faceplate temporarily fixed in place I drilled out the mounting holes and all other important features.
I then pried of the stainless faceplate and milled out a pocket in the aluminum extrusion so that the backside of the Eaton M22 buttons would have enough clearance.
Once that was done I threaded the mounting holes in the aluminum extrusion and bolted on the faceplate so that I could mill the sides.
