Thanks for your patience.
I get that I can find all the available pins using the methods above.
What I don't get is that when I use mesaCT or PNCConf to create ini and .hal files and have selected say channel 0 for the X encoder, The physical pins that will be used don't show up the hal file.
Its to me like when you make the selection in the gui, some things are automatically known like the pins, and the hal file doesn't need to show all of them, just ones you might need to edit.
So the hal file isn't the place to look for the full details of a setup right back to pins.
I will learn this system...
Failed on an image paste here, so trying again with an attachment.
I'd like to confirm that I'm connecting up my 7i77D correctly.
The I-J3-2 terminal here went originally to an optical isolator that was kept switched on by a watchdog timer that only runs when the operating system is loaded and running. The COR relay is enabled by the On switch, and until this happens, nothing on the machine works, eg the servos relay cannot be enabled etc.
I am proposing to connect this same terminal to IO Output pin 0
mesact has written io.hal line as saying
net estop-loopback => hm2_7i92.0.7i77.0.0.output-00
From my reading of the manual, the 7i77 will only enable this pin, when linuxcnc is up and running.ie the same as the original system.
Does this all look good?
Last edit: 1 year 9 months ago by NT4Boy. Reason: Pasted Image showing as text?
I have connected the boards to the machine, powered it, and got the encoders working and calibrated. Probably ought to throw in a smiley here.
However, moving on, I cannot get the emergency stop system to work as I expected.
When I setup a Output 0 with
Confused myself for a while by not having the field power connected, but now it is I expected that after linuxcnc was launched, and the soft EStop button on the screen was clicked followed by the soft power button, I'd be able to latch the COR relay (In the diagram above and yes the air is on) by pressing the power button on the machine panel. But it doesn't.
I guess I am missing something again.
