HURCO KMB-1 Control Update
1 year 9 months ago #319779 by PCW
Replied by PCW on topic HURCO KMB-1 Control Update
For a 7I77 and a 7I92:
7i92_7i77x2D.bit
For a 7I77 and a 7I92T:
7i92t_7i77x2d.bin
7I77 digital I/O pins will now appear without field power.
Sserial expansion card (like the 7I73 or 7I84) do not require specific
firmware.
The following user(s) said Thank You: NT4Boy
1 year 9 months ago #319781 by NT4Boy
Replied by NT4Boy on topic HURCO KMB-1 Control Update
Marvellous, all present and correct now.
(I've a 7i92T)
Many thanks
1 year 9 months ago - 1 year 9 months ago #319821 by NT4Boy
I've failed to work out how to use a spare encoder input on the 7i77 as a Limit switch input.
I've started out by telling PNCConf that the switches are connected to the I/O Field inputs so I can see the syntax, for instance
net min-x     <=  hm2_7i92.0.7i77.0.0.input-00     for the X limit minus.
Was planning then to edit this line to match an encoder.
But when I study the hal file posted here, I cannot see how the encoder input pins are called. I was expecting there to be similar 7i92..7i77 references in the Joint 0 section for instance and there are for the analogue outputs, but not against the encoders.
Can you help please.
Last edit: 1 year 9 months ago by NT4Boy.
1 year 9 months ago #319825 by PCW
The raw encoder pins have names like:
hm2_7i92.0.encoder.03.input-a
hm2_7i92.0.encoder.03.input-b
hm2_7i92.0.encoder.03.input-index
1 year 9 months ago #319826 by NT4Boy
I guess that's the bit I am missing.
In the hal file, there are no "input-a" anything for the X,Y and Z encoders so I don't get how lcnc knows what anything is connected to.
Sorry.
1 year 9 months ago - 1 year 9 months ago #319828 by PCW
The hal file is what connects things (it does not show all possible pins) ,
so to use an encoder input, you would do something like this:
net min-x <= hm2_7i92.0.encoder.01.input-a
You can use halshow to browse pins and parameters:
or list all pins/parameters by running this command:
halcmd show all
from a terminal window when LinuxCNC is running.
You can also
halcmd show all > all.txt
to create a copy/paste donor file when editing hal files
if you just want hardware pins/parameters
halcmd show all hm2
will do
If you just want encoder pins/parameters.
halcmd show all *encoder*
or
halcmd show pin *encoder*
if you just want to see encoder pins.
Last edit: 1 year 9 months ago by PCW.
Time to create page: 0.078 seconds
