HURCO KMB-1 Control Update
1 year 8 months ago - 1 year 8 months ago #320478 by NT4Boy
Replied by NT4Boy on topic HURCO KMB-1 Control Update
The video
Caught up on my education last night. skunkworks video is a revelation.
Understanding how to use the halcmd, and halmeter to choose correct hal syntax and then use halmeter to confirm what you've written works was just fantastic.
So much so, that I think my estop circuit problem may be a 7i77D versus 7i77 issue.
Mine is supposedly a 7i77D, but when an output terminal is true, it outputs 24volts, where I was expecting it to sink.
Last edit: 1 year 8 months ago by NT4Boy. Reason: word missed
1 year 8 months ago - 1 year 8 months ago #320488 by NT4Boy
Turns out its a 7i77 with a 7i77D (d for digital)  quality sticker  on the underside rather than a 7i77D type.which has that written in the artwork on the topside.
ULN2003AN array has been my solution until the 7i77U become available.
1 year 8 months ago #320929 by NT4Boy
The 5v limits switches, (connected to the 7i77 spare encoder terminals QA3,QB3,IDX3 etc), are registering in linuxcnc randomly. Even though the machine is parked mid stroke, the Y axis min is always true, and I can trigger the X max with a wrench from false to true, but it stays that way with the wrench removed.
Looking at the original control there is a 470ohm resistor to 5v holding the signal to the MUX chip high, and when the limit is triggered, this gets grounded.
Do I need to do something else electrically to gets this working?
1 year 8 months ago #320932 by PCW
Replied by PCW on topic HURCO KMB-1 Control Update
Are the encoder inputs for the limit switches jumpered for single ended use?
1 year 8 months ago #320935 by NT4Boy
Aha, no they weren't.
But they are now.
Can now toggle them all to change state, but oddly y-min is inverted, and cannot quite see what I have done wrong there.
Thanks again.
1 year 8 months ago #320938 by PCW
Actually the A/B inputs are inverted (which is what you want for an active low home switch input)
But the index input is not inverted.
options:
1. If you have more spare encoder inputs, just use A,B
2. Add 1 or  more  "not" components to invert the polarity of the input-index pin
Time to create page: 0.152 seconds
