Please help, I need some addvise
- allenwg2005
- Thank you received: 4
:~$ dmesg
[ 0.000000] Linux version 2.6.24-16-rtai (root@hardy) (gcc version 4.2.3 (Ubuntu 4.2.3-2ubuntu7)) #1 Tue Sep 30 22:54:33 EEST 2008 (Ubuntu 2.6.24-12.22-generic)
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: 0000000000000000 - 000000000009f800 (usable)
[ 0.000000] BIOS-e820: 000000000009f800 - 00000000000a0000 (reserved)
[ 0.000000] BIOS-e820: 00000000000f0000 - 0000000000100000 (reserved)
[ 0.000000] BIOS-e820: 0000000000100000 - 000000003bff0000 (usable)
[ 0.000000] BIOS-e820: 000000003bff0000 - 000000003bff3000 (ACPI NVS)
[ 0.000000] BIOS-e820: 000000003bff3000 - 000000003c000000 (ACPI data)
[ 0.000000] BIOS-e820: 00000000fec00000 - 00000000fec01000 (reserved)
[ 0.000000] BIOS-e820: 00000000fee00000 - 00000000fee01000 (reserved)
[ 0.000000] BIOS-e820: 00000000ffff0000 - 0000000100000000 (reserved)
[ 0.000000] 63MB HIGHMEM available.
[ 0.000000] 896MB LOWMEM available.
[ 0.000000] Entering add_active_range(0, 0, 245744) 0 entries of 256 used
[ 0.000000] Zone PFN ranges:
[ 0.000000] DMA 0 -> 4096
[ 0.000000] Normal 4096 -> 229376
[ 0.000000] HighMem 229376 -> 245744
[ 0.000000] Movable zone start PFN for each node
[ 0.000000] early_node_map[1] active PFN ranges
[ 0.000000] 0: 0 -> 245744
[ 0.000000] On node 0 totalpages: 245744
[ 0.000000] DMA zone: 32 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 4064 pages, LIFO batch:0
[ 0.000000] Normal zone: 1760 pages used for memmap
[ 0.000000] Normal zone: 223520 pages, LIFO batch:31
[ 0.000000] HighMem zone: 127 pages used for memmap
[ 0.000000] HighMem zone: 16241 pages, LIFO batch:3
[ 0.000000] Movable zone: 0 pages used for memmap
[ 0.000000] DMI 2.3 present.
[ 0.000000] Allocating PCI resources starting at 40000000 (gap: 3c000000:c2c00000)
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 243825
[ 0.000000] Kernel command line: root=UUID=2762f095-6cfd-4ebc-ba48-993706533ed4 ro quiet splash
[ 0.000000] Enabling fast FPU save and restore... done.
[ 0.000000] Enabling unmasked SIMD FPU exception support... done.
[ 0.000000] Initializing CPU#0
[ 0.000000] PID hash table entries: 4096 (order: 12, 16384 bytes)
[ 0.000000] Detected 2200.099 MHz processor.
[ 19.314734] I-pipe 2.0-04: pipeline enabled.
[ 19.315929] Console: colour VGA+ 80x25
[ 19.315933] console [tty0] enabled
[ 19.316979] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 19.317676] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 19.348445] Memory: 964596k/982976k available (1440k kernel code, 17704k reserved, 573k data, 228k init, 65472k highmem)
[ 19.348455] virtual kernel memory layout:
[ 19.348456] fixmap : 0xfffed000 - 0xfffff000 ( 72 kB)
[ 19.348457] pkmap : 0xff800000 - 0xffc00000 (4096 kB)
[ 19.348459] vmalloc : 0xf8800000 - 0xff7fe000 ( 111 MB)
[ 19.348460] lowmem : 0xc0000000 - 0xf8000000 ( 896 MB)
[ 19.348462] .init : 0xc02fa000 - 0xc0333000 ( 228 kB)
[ 19.348463] .data : 0xc026836d - 0xc02f77ec ( 573 kB)
[ 19.348464] .text : 0xc0100000 - 0xc026836d (1440 kB)
[ 19.348468] Checking if this processor honours the WP bit even in supervisor mode... Ok.
[ 19.348518] SLUB: Genslabs=11, HWalign=32, Order=0-1, MinObjects=4, CPUs=1, Nodes=1
[ 19.428469] Calibrating delay using timer specific routine.. 4402.20 BogoMIPS (lpj=8804403)
[ 19.428506] Security Framework initialized
[ 19.428514] SELinux: Disabled at boot.
[ 19.428532] AppArmor: AppArmor initialized
[ 19.428537] Failure registering capabilities with primary security module.
[ 19.428545] Mount-cache hash table entries: 512
[ 19.428706] CPU: After generic identify, caps: 0383fbff c1c3fbff 00000000 00000000 00000000 00000000 00000000 00000000
[ 19.428715] CPU: L1 I Cache: 64K (64 bytes/line), D cache 64K (64 bytes/line)
[ 19.428718] CPU: L2 Cache: 512K (64 bytes/line)
[ 19.428720] CPU: After all inits, caps: 0383fbff c1c3fbff 00000000 00000420 00000000 00000000 00000000 00000000
[ 19.428733] Compat vDSO mapped to ffffe000.
[ 19.428746] CPU: AMD Athlon(tm) XP 3200+ stepping 00
[ 19.428753] Checking 'hlt' instruction... OK.
[ 19.444635] Freeing SMP alternatives: 0k freed
[ 19.444886] net_namespace: 64 bytes
[ 19.445321] NET: Registered protocol family 16
[ 19.445526] EISA bus registered
[ 19.453082] PCI: PCI BIOS revision 2.10 entry at 0xfbd40, last bus=1
[ 19.453085] PCI: Using configuration type 1
[ 19.453087] Setting up standard PCI resources
[ 19.463193] Linux Plug and Play Support v0.97 (c) Adam Belay
[ 19.463438] PCI: Probing PCI hardware
[ 19.463448] PCI: Probing PCI hardware (bus 00)
[ 19.463979] PCI: enabled onboard AC97/MC97 devices
[ 19.465367] PCI: Using IRQ router VIA [1106/3227] at 0000:00:11.0
[ 19.465381] PCI: setting IRQ 10 as level-triggered
[ 19.465385] PCI: Found IRQ 10 for device 0000:00:08.0
[ 19.465404] PCI: Sharing IRQ 10 with 0000:00:10.0
[ 19.465409] PCI: Sharing IRQ 10 with 0000:00:10.1
[ 19.465429] PCI: Sharing IRQ 10 with 0000:00:12.0
[ 19.465436] PCI: setting IRQ 11 as level-triggered
[ 19.465440] PCI: Found IRQ 11 for device 0000:00:09.0
[ 19.465464] PCI: Sharing IRQ 11 with 0000:00:10.2
[ 19.465469] PCI: Sharing IRQ 11 with 0000:00:10.3
[ 19.465500] PCI: setting IRQ 5 as level-triggered
[ 19.465503] PCI: Found IRQ 5 for device 0000:00:10.4
[ 19.465537] PCI: Sharing IRQ 5 with 0000:00:11.5
[ 19.465541] PCI: Sharing IRQ 5 with 0000:00:11.6
[ 19.496481] AppArmor: AppArmor Filesystem Enabled
[ 19.496818] PCI: Bridge: 0000:00:01.0
[ 19.496821] IO window: disabled.
[ 19.496825] MEM window: e8000000-e9ffffff
[ 19.496828] PREFETCH window: e4000000-e7ffffff
[ 19.496842] PCI: Setting latency timer of device 0000:00:01.0 to 64
[ 19.496852] NET: Registered protocol family 2
[ 19.500406] Time: tsc clocksource has been installed.
[ 19.532430] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 19.532827] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[ 19.534911] TCP bind hash table entries: 65536 (order: 6, 262144 bytes)
[ 19.535455] TCP: Hash tables configured (established 131072 bind 65536)
[ 19.535458] TCP reno registered
[ 19.544566] checking if image is initramfs... it is
[ 20.060658] Freeing initrd memory: 6517k freed
[ 20.061187] audit: initializing netlink socket (disabled)
[ 20.061206] audit(1367186919.716:1): initialized
[ 20.061363] highmem bounce pool size: 64 pages
[ 20.063101] VFS: Disk quotas dquot_6.5.1
[ 20.063129] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 20.063256] io scheduler noop registered
[ 20.063258] io scheduler anticipatory registered
[ 20.063261] io scheduler deadline registered
[ 20.063271] io scheduler cfq registered (default)
[ 20.063283] PCI: VIA PCI bridge detected. Disabling DAC.
[ 20.063345] Boot video device is 0000:01:00.0
[ 20.063559] isapnp: Scanning for PnP cards...
[ 20.416873] isapnp: No Plug & Play device found
[ 20.444061] Real Time Clock Driver v1.12ac
[ 20.444066] Serial: 8250/16550 driver $Revision: 1.90 $ 4 ports, IRQ sharing enabled
[ 20.444183] serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 20.445166] RAMDISK driver initialized: 16 RAM disks of 65536K size 1024 blocksize
[ 20.445257] input: Macintosh mouse button emulation as /devices/virtual/input/input0
[ 20.445381] PNP: No PS/2 controller found. Probing ports directly.
[ 20.445722] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 20.445727] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 20.447855] mice: PS/2 mouse device common for all mice
[ 20.447968] EISA: Probing bus 0 at eisa.0
[ 20.448000] Cannot allocate resource for EISA slot 8
[ 20.448002] EISA: Detected 0 cards.
[ 20.448104] NET: Registered protocol family 1
[ 20.448115] Using IPI Shortcut mode
[ 20.448248] BIOS EDD facility v0.16 2004-Jun-25, 0 devices found
[ 20.448250] EDD information not available.
[ 20.448620] Freeing unused kernel memory: 228k freed
[ 21.649626] fuse init (API version 7.9)
[ 21.870605] SCSI subsystem initialized
[ 21.896293] PCI: setting IRQ 3 as level-triggered
[ 21.896300] PCI: Found IRQ 3 for device 0000:00:0b.0
[ 21.949086] ohci1394: fw-host0: OHCI-1394 1.0 (PCI): IRQ=[3] MMIO=[ea000000-ea0007ff] Max Packet=[2048] IR/IT contexts=[4/8]
[ 21.959637] usbcore: registered new interface driver usbfs
[ 21.959681] usbcore: registered new interface driver hub
[ 21.970279] usbcore: registered new device driver usb
[ 21.971252] USB Universal Host Controller Interface driver v3.0
[ 21.990214] libata version 3.00 loaded.
[ 22.029194] via-rhine.c:v1.10-LK1.4.3 2007-03-06 Written by Donald Becker
[ 22.068966] PCI: Found IRQ 10 for device 0000:00:10.0
[ 22.068975] PCI: Sharing IRQ 10 with 0000:00:08.0
[ 22.068995] PCI: Sharing IRQ 10 with 0000:00:10.1
[ 22.069018] PCI: Sharing IRQ 10 with 0000:00:12.0
[ 22.069024] PCI: VIA VLink IRQ fixup for 0000:00:10.0, from 255 to 10
[ 22.069051] uhci_hcd 0000:00:10.0: UHCI Host Controller
[ 22.069412] uhci_hcd 0000:00:10.0: new USB bus registered, assigned bus number 1
[ 22.069441] uhci_hcd 0000:00:10.0: irq 10, io base 0x0000d000
[ 22.069602] usb usb1: configuration #1 chosen from 1 choice
[ 22.069626] hub 1-0:1.0: USB hub found
[ 22.069633] hub 1-0:1.0: 2 ports detected
[ 22.170183] PCI: Found IRQ 10 for device 0000:00:10.1
[ 22.170193] PCI: Sharing IRQ 10 with 0000:00:08.0
[ 22.170210] PCI: Sharing IRQ 10 with 0000:00:10.0
[ 22.170237] PCI: Sharing IRQ 10 with 0000:00:12.0
[ 22.170243] PCI: VIA VLink IRQ fixup for 0000:00:10.1, from 255 to 10
[ 22.170271] uhci_hcd 0000:00:10.1: UHCI Host Controller
[ 22.170297] uhci_hcd 0000:00:10.1: new USB bus registered, assigned bus number 2
[ 22.170321] uhci_hcd 0000:00:10.1: irq 10, io base 0x0000d400
[ 22.170450] usb usb2: configuration #1 chosen from 1 choice
[ 22.170480] hub 2-0:1.0: USB hub found
[ 22.170487] hub 2-0:1.0: 2 ports detected
[ 22.274535] PCI: Found IRQ 11 for device 0000:00:10.2
[ 22.274547] PCI: Sharing IRQ 11 with 0000:00:09.0
[ 22.274573] PCI: Sharing IRQ 11 with 0000:00:10.3
[ 22.274594] PCI: VIA VLink IRQ fixup for 0000:00:10.2, from 255 to 11
[ 22.274622] uhci_hcd 0000:00:10.2: UHCI Host Controller
[ 22.274648] uhci_hcd 0000:00:10.2: new USB bus registered, assigned bus number 3
[ 22.274675] uhci_hcd 0000:00:10.2: irq 11, io base 0x0000d800
[ 22.274800] usb usb3: configuration #1 chosen from 1 choice
[ 22.274824] hub 3-0:1.0: USB hub found
[ 22.274831] hub 3-0:1.0: 2 ports detected
[ 22.378016] PCI: Found IRQ 11 for device 0000:00:10.3
[ 22.378028] PCI: Sharing IRQ 11 with 0000:00:09.0
[ 22.378050] PCI: Sharing IRQ 11 with 0000:00:10.2
[ 22.378073] PCI: VIA VLink IRQ fixup for 0000:00:10.3, from 255 to 11
[ 22.378101] uhci_hcd 0000:00:10.3: UHCI Host Controller
[ 22.378127] uhci_hcd 0000:00:10.3: new USB bus registered, assigned bus number 4
[ 22.378151] uhci_hcd 0000:00:10.3: irq 11, io base 0x0000dc00
[ 22.378280] usb usb4: configuration #1 chosen from 1 choice
[ 22.378304] hub 4-0:1.0: USB hub found
[ 22.378310] hub 4-0:1.0: 2 ports detected
[ 22.482117] sata_via 0000:00:0f.0: version 2.3
[ 22.482201] sata_via 0000:00:0f.0: routed to hard irq line 11
[ 22.483820] scsi0 : sata_via
[ 22.484291] scsi1 : sata_via
[ 22.484334] ata1: SATA max UDMA/133 cmd 0xb400 ctl 0xb800 bmdma 0xc400 irq 11
[ 22.484338] ata2: SATA max UDMA/133 cmd 0xbc00 ctl 0xc000 bmdma 0xc408 irq 11
[ 22.537714] usb 1-2: new full speed USB device using uhci_hcd and address 2
[ 22.685546] ata1: SATA link down 1.5 Gbps (SStatus 0 SControl 300)
[ 22.709834] usb 1-2: configuration #1 chosen from 1 choice
[ 22.714770] hub 1-2:1.0: USB hub found
[ 22.715745] hub 1-2:1.0: 4 ports detected
[ 22.897235] ata2: SATA link down 1.5 Gbps (SStatus 0 SControl 300)
[ 22.909292] pata_via 0000:00:0f.1: version 0.3.3
[ 22.910246] scsi2 : pata_via
[ 22.910737] scsi3 : pata_via
[ 22.910769] ata3: PATA max UDMA/133 cmd 0x1f0 ctl 0x3f6 bmdma 0xcc00 irq 14
[ 22.910773] ata4: PATA max UDMA/133 cmd 0x170 ctl 0x376 bmdma 0xcc08 irq 15
[ 23.129508] ata3.00: ATA-6: ST3160021A, 3.08, max UDMA/100
[ 23.129513] ata3.00: 312581808 sectors, multi 16: LBA48
[ 23.145317] ata3.00: configured for UDMA/100
[ 23.344887] ieee1394: Host added: ID:BUS[0-00:1023] GUID[00e01800007b7699]
[ 23.580529] usb 4-1: new full speed USB device using uhci_hcd and address 2
[ 23.629066] ata4.00: ATAPI: HP DVD Writer 400, FH04, max UDMA/33
[ 23.629084] ata4.01: ATAPI: SAMSUNG CD-ROM SC-148A, B401, max UDMA/33
[ 23.753474] usb 4-1: configuration #1 chosen from 1 choice
[ 23.800761] ata4.00: configured for UDMA/33
[ 23.972136] ata4.01: configured for UDMA/33
[ 23.972282] scsi 2:0:0:0: Direct-Access ATA ST3160021A 3.08 PQ: 0 ANSI: 5
[ 23.974576] scsi 3:0:0:0: CD-ROM HP DVD Writer 400c FH04 PQ: 0 ANSI: 5
[ 23.974914] scsi 3:0:1:0: CD-ROM SAMSUNG CD-ROM SC-148A B401 PQ: 0 ANSI: 5
[ 23.975419] PCI: Found IRQ 5 for device 0000:00:10.4
[ 23.975457] PCI: Sharing IRQ 5 with 0000:00:11.5
[ 23.975462] PCI: Sharing IRQ 5 with 0000:00:11.6
[ 23.975472] PCI: VIA VLink IRQ fixup for 0000:00:10.4, from 255 to 5
[ 23.975505] ehci_hcd 0000:00:10.4: EHCI Host Controller
[ 23.975537] ehci_hcd 0000:00:10.4: new USB bus registered, assigned bus number 5
[ 23.975585] ehci_hcd 0000:00:10.4: irq 5, io mem 0xea001000
[ 23.981875] hub 1-2:1.0: hub_port_status failed (err = -71)
[ 23.981882] hub 1-2:1.0: connect-debounce failed, port 4 disabled
[ 23.982857] hub 1-2:1.0: cannot disable port 4 (err = -71)
[ 23.982919] usbcore: registered new interface driver libusual
[ 23.987216] Initializing USB Mass Storage driver...
[ 23.987278] ehci_hcd 0000:00:10.4: USB 2.0 started, EHCI 1.00, driver 10 Dec 2004
[ 23.987419] usb usb5: configuration #1 chosen from 1 choice
[ 23.987444] hub 5-0:1.0: USB hub found
[ 23.987453] hub 5-0:1.0: 8 ports detected
[ 23.988694] scsi4 : SCSI emulation for USB Mass Storage devices
[ 23.989354] usbcore: registered new interface driver usb-storage
[ 23.989359] USB Mass Storage support registered.
[ 23.989459] usb-storage: device found at 2
[ 23.989462] usb-storage: waiting for device to settle before scanning
[ 24.088275] PCI: Found IRQ 10 for device 0000:00:12.0
[ 24.088285] PCI: Sharing IRQ 10 with 0000:00:08.0
[ 24.088301] PCI: Sharing IRQ 10 with 0000:00:10.0
[ 24.088306] PCI: Sharing IRQ 10 with 0000:00:10.1
[ 24.088572] eth0: VIA Rhine II at 0xea002000, 00:11:2f:12:85:18, IRQ 10.
[ 24.089282] eth0: MII PHY found at address 1, status 0x7849 advertising 05e1 Link 0000.
[ 24.094615] Uniform Multi-Platform E-IDE driver Revision: 7.00alpha2
[ 24.094622] ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
[ 24.102364] Driver 'sd' needs updating - please use bus_type methods
[ 24.102482] sd 2:0:0:0: [sda] 312581808 512-byte hardware sectors (160042 MB)
[ 24.102498] sd 2:0:0:0: [sda] Write Protect is off
[ 24.102502] sd 2:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 24.102520] sd 2:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 24.102572] sd 2:0:0:0: [sda] 312581808 512-byte hardware sectors (160042 MB)
[ 24.102582] sd 2:0:0:0: [sda] Write Protect is off
[ 24.102585] sd 2:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 24.102599] sd 2:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 24.102603] sda:<4>Driver 'sr' needs updating - please use bus_type methods
[ 24.112323] sda1 sda2 < sda5 >
[ 24.135817] sd 2:0:0:0: [sda] Attached SCSI disk
[ 24.140613] sd 2:0:0:0: Attached scsi generic sg0 type 0
[ 24.140636] sr 3:0:0:0: Attached scsi generic sg1 type 5
[ 24.140663] scsi 3:0:1:0: Attached scsi generic sg2 type 5
[ 24.152269] sr0: scsi3-mmc drive: 40x/40x writer cd/rw xa/form2 cdda tray
[ 24.152276] Uniform CD-ROM driver Revision: 3.20
[ 24.152345] sr 3:0:0:0: Attached scsi CD-ROM sr0
[ 24.156312] sr1: scsi3-mmc drive: 1x/48x cd/rw xa/form2 cdda tray
[ 24.156373] sr 3:0:1:0: Attached scsi CD-ROM sr1
[ 24.476249] kjournald starting. Commit interval 5 seconds
[ 24.476267] EXT3-fs: mounted filesystem with ordered data mode.
[ 24.567372] usb 1-2: USB disconnect, address 2
[ 24.807040] usb 1-2: new full speed USB device using uhci_hcd and address 3
[ 24.970681] usb 1-2: configuration #1 chosen from 1 choice
[ 24.976588] hub 1-2:1.0: USB hub found
[ 24.977557] hub 1-2:1.0: 4 ports detected
[ 25.089410] usb 4-1: USB disconnect, address 2
[ 25.326380] usb 4-1: new full speed USB device using uhci_hcd and address 3
[ 25.497937] usb 4-1: configuration #1 chosen from 1 choice
[ 25.500916] scsi5 : SCSI emulation for USB Mass Storage devices
[ 25.501038] usb-storage: device found at 3
[ 25.501041] usb-storage: waiting for device to settle before scanning
[ 25.707200] usb 1-2.4: new low speed USB device using uhci_hcd and address 4
[ 25.844942] usb 1-2.4: configuration #1 chosen from 1 choice
[ 30.587152] usb-storage: device scan complete
[ 30.590792] scsi 5:0:0:0: Direct-Access Generic USB SD Reader 1.00 PQ: 0 ANSI: 0
[ 30.593798] scsi 5:0:0:1: Direct-Access Generic USB CF Reader 1.01 PQ: 0 ANSI: 0
[ 30.596781] scsi 5:0:0:2: Direct-Access Generic USB SM Reader 1.02 PQ: 0 ANSI: 0
[ 30.599768] scsi 5:0:0:3: Direct-Access Generic USB MS Reader 1.03 PQ: 0 ANSI: 0
[ 30.644755] sd 5:0:0:0: [sdb] Attached SCSI removable disk
[ 30.644802] sd 5:0:0:0: Attached scsi generic sg3 type 0
[ 30.668324] Linux agpgart interface v0.102
[ 30.688743] sd 5:0:0:1: [sdc] Attached SCSI removable disk
[ 30.688791] sd 5:0:0:1: Attached scsi generic sg4 type 0
[ 30.688990] agpgart: Detected VIA KM400/KM400A chipset
[ 30.694212] agpgart: AGP aperture is 64M @ 0xe0000000
[ 30.732669] sd 5:0:0:2: [sdd] Attached SCSI removable disk
[ 30.732719] sd 5:0:0:2: Attached scsi generic sg5 type 0
[ 30.771563] input: PC Speaker as /devices/platform/pcspkr/input/input1
[ 30.776651] sd 5:0:0:3: [sde] Attached SCSI removable disk
[ 30.776700] sd 5:0:0:3: Attached scsi generic sg6 type 0
[ 31.168836] PCI: Enabling device 0000:00:11.6 (0000 -> 0001)
[ 31.168848] PCI: Found IRQ 5 for device 0000:00:11.6
[ 31.168882] PCI: Sharing IRQ 5 with 0000:00:10.4
[ 31.168888] PCI: Sharing IRQ 5 with 0000:00:11.5
[ 31.168901] PCI: VIA VLink IRQ fixup for 0000:00:11.6, from 0 to 5
[ 31.651437] usbcore: registered new interface driver hiddev
[ 31.665066] input: Ideazon Zboard as /devices/pci0000:00/0000:00:10.0/usb1/1-2/1-2.4/1-2.4:1.0/input/input2
[ 31.690423] input,hidraw0: USB HID v1.10 Keyboard [Ideazon Zboard] on usb-0000:00:10.0-2.4
[ 31.710759] usbcore: registered new interface driver usbhid
[ 31.710767] /home/juve/hardy-packages/linux-git/ubuntu-hardy/debian/build/custom-source-rtai/drivers/hid/usbhid/hid-core.c: v2.6:USB HID core driver
[ 31.795386] input: ImPS/2 Generic Wheel Mouse as /devices/platform/i8042/serio1/input/input3
[ 31.918089] PCI: Setting latency timer of device 0000:00:11.6 to 64
[ 32.421888] VIA 82xx Modem: probe of 0000:00:11.6 failed with error -13
[ 32.422059] PCI: Found IRQ 5 for device 0000:00:11.5
[ 32.422093] PCI: Sharing IRQ 5 with 0000:00:10.4
[ 32.422101] PCI: Sharing IRQ 5 with 0000:00:11.6
[ 32.422232] PCI: Setting latency timer of device 0000:00:11.5 to 64
[ 33.694151] parport0: PC-style at 0x378 (0x778) [PCSPP,TRISTATE,EPP]
[ 33.694177] parport0: irq 7 detected
[ 33.788706] lp0: using parport0 (polling).
[ 33.957068] Adding 2843464k swap on /dev/sda5. Priority:-1 extents:1 across:2843464k
[ 34.489537] EXT3 FS on sda1, internal journal
[ 35.678105] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 36.937592] ppdev: user-space parallel port driver
[ 37.169279] audit(1367186937.612:2): type=1503 operation="inode_permission" requested_mask="a::" denied_mask="a::" name="/dev/tty" pid=4342 profile="/usr/sbin/cupsd" namespace="default"
[ 38.128022] eth0: link down
[ 38.198792] Bluetooth: Core ver 2.11
[ 38.201043] NET: Registered protocol family 31
[ 38.201048] Bluetooth: HCI device and connection manager initialized
[ 38.201053] Bluetooth: HCI socket layer initialized
[ 38.221907] Bluetooth: L2CAP ver 2.9
[ 38.221913] Bluetooth: L2CAP socket layer initialized
[ 38.236220] Bluetooth: RFCOMM socket layer initialized
[ 38.236244] Bluetooth: RFCOMM TTY layer initialized
[ 38.236246] Bluetooth: RFCOMM ver 1.8
[ 39.262438] [drm] Initialized drm 1.1.0 20060810
[ 39.272170] [drm] Initialized via 2.11.1 20070202 on minor 0
[ 39.310466] agpgart: Found an AGP 3.5 compliant device at 0000:00:00.0.
[ 39.310487] agpgart: Device is in legacy mode, falling back to 2.x
[ 39.310493] agpgart: Putting AGP V2 device at 0000:00:00.0 into 4x mode
[ 39.310544] agpgart: Putting AGP V2 device at 0000:01:00.0 into 4x mode
[ 47.552852] NET: Registered protocol family 10
[ 47.553766] lo: Disabled Privacy Extensions
[ 47.554674] ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 215.755273] I-pipe: Domain RTAI registered.
[ 215.755286] RTAI[hal]: <3.6.1> mounted over IPIPE-NOTHREADS 2.0-04.
[ 215.755288] RTAI[hal]: compiled with gcc version 4.2.4 (Ubuntu 4.2.4-1ubuntu3).
[ 215.755294] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 215.755296] PIPELINE layers:
[ 215.755299] f8cb1000 9ac15d93 RTAI 200
[ 215.755301] c0383180 0 Linux 100
[ 215.773958] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 215.774463] RTAI[sched]: loaded (IMMEDIATE, UP, USER/KERNEL SPACE: <with RTAI OWN KTASKs>, kstacks pool size = 524288 bytes.
[ 215.774468] RTAI[sched]: hard timer type/freq = 8254-PIT/1193180(Hz); default timing: periodic; linear timed lists.
[ 215.774472] RTAI[sched]: Linux timer freq = 250 (Hz), CPU freq = 2200099000 hz.
[ 215.774475] RTAI[sched]: timer setup = 2010 ns, resched latency = 2688 ns.
[ 215.858094] RTAI[math]: loaded.
[ 215.874287] rtapi: no version for "nano2count" found: kernel tainted.
[ 216.040680] config string '0 out 1 out 2 out 3 out'
[ 216.040887] PARPORT: ERROR: linux parport 1 not found
[ 216.461827] RTAI[math]: unloaded.
[ 216.521701] SCHED releases registered named ALIEN RTGLBH
[ 216.535218] RTAI[malloc]: unloaded.
[ 216.634624] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 216.636534] I-pipe: Domain RTAI unregistered.
[ 216.636544] RTAI[hal]: unmounted.
- allenwg2005
I have no idea how I did that.
Please let me know the technique so I can cut down on the length of some of these posts.
- Thank you received: 4994
Earlier in this thread I posted something and it loaded in a yellow box that scrolled.
I might have done it for you
You need to put the text in "code" tags. You can either select all the text you want to put in the box then click the icon above that is 16 along, with the <> characters on it, or just type (code) at the beginning and (/code) at the end.
Except you need to use square brackets, not the curved ones. I couldn't use the square ones above, as then they would have been interpreted as code tags, and not been visible.
- allenwg2005
- ArcEye
- Thank you received: 758
Well that shows the ports could not be automagically divined, shame, so back to trial and error
What should I do next?
Find out if the port address is real, if not try the next one from the lspci print and so on ...........
www.linuxcnc.org/index.php/english/forum...parallel-port-tester
- BigJohnT
- Thank you received: 1176
This is a sample of code tags
notice it preserves any indenting and spacing you have
- allenwg2005
Can I conclude that the earlier questions copied below that have not been answered means that they are superfluous and unimportant, or??????
Am I being anal in this fog of ignorance?
The commands from Arceye's link have not been entered yet.
From what I know they are needed.
I need to understand exactly were to type the following:
addf parport.1.read base-thread
addf parport.1.write base-thread
addf parport.2.read base-thread
addf parport.2.write base-thread
Or do I need these command at this time?
I know I need them in any case, so nailing this down now rather than later seems worthwhile.
The section in the Hal Manual on “addf” is brief, I know it adds a real time function to a thread, and it is done prior to loading net commands creating connections between a signal (a virtual wire) and the pins we are trying to make changes to eventually. (A pin, something physical, finally).
But is there a sequence or order to where these commands are added?
Please let me know the following.
When running John T's tester, I expect the best way to confirm the address and port are functioning correctly is to use the “Resistor to Gnd” method. The proximity or limit switch method (for my part) seems ambiguous at the moment. Is there any other method to use the “Testport Meter”?
Or, can I just toggle the buttons for now and get the results we need and use the resistor when we try and test for output at a pins?
(I am experimenting with the forum option, I'm not sure this will appear correctly).
- ArcEye
This is an extract from one of my configs, example being the best form of instruction
loadrt probe_parport
## SUN1888 pci parport card 0x6800 main socket 0x6000 low profile - not currently used
loadrt hal_parport cfg="0x378 out 0x6800 in"
setp parport.0.reset-time 1000
Note that there is no parport.2 at present because we are only defining 2 parports (0 and 1)
- allenwg2005
I couldn't agree with you more, example is a profound method of instruction.
Quick question, on the “Port Tester”, When I click and hold the button on the out puts the colour changes, but returns to red when I release the mouse button.
Is this the result we are looking for?
Or should it remain green after release?
I'm curious, why is there no command for step pule generation step type in your file and I have one in mine?
Back to you.
- allenwg2005
I went to hal configure and showed pins, they show xenabled!
This is at address 0x8000.
