Forum Header
Please help, I need some addvise
- allenwg2005
- Thank you received: 4
05 May 2013 06:47 #33629
by allenwg2005
Replied by allenwg2005 on topic Please help, I need some addvise
I don't have the line:
setp parport.0.pin-02-out-reset 1
as the second line, is that an issue ?
The rest is as it should be.
- allenwg2005
05 May 2013 07:48 #33632
by allenwg2005
I don't see the following in the HAL:
net min-home -Z <= parport.0.pin-10-in (pins for max and so forth)
I don't see the following either, I have one for Y axis and for this one:
net min home -X=> axis.1.home-sw-in
net min home -X=> axis.1. Neg-lim-sw-in
net max =>axis.1.pos-lim-sw-in
Should I have these?
I'm going to include the message I get when trying to do a test run on Z, it may help.
When I click “Test run” in Z axis configuration:
File “/usr/bin/stepconf”, line 1740, in on_axistest_clicked def on_axis_clicked (self *args): self.test_axis('z')
File “usr/bin/stepconf”, line 2175, in test_axis 'scale': data [axis+”scale”]
TypeError: int argument required
Back in the weeds again.
- Thank you received: 4994
05 May 2013 07:54 #33633
That's interesting.
It may not matter, and the explanation of what that line does is rather complicated.
"reset" is a special HAL function that runs last in the real-time "base" thread. What it does is set any pin back to zero after a set time.
What this means is that you can have a step pulse every time the base thread runs. Without the reset function it takes two thread cycles, the first turning the pin on, the second off.
I possibly need to explain what a "thread" is. It is a list of bits of code that are run regularly by the realtime system. Every "base thread" cycle LinuxCNC stops everything else the computer might be doing and runs the base thread code (which typically makes step pulses). Every servo thread cycle it does the same for the more high-level code that calculates positions and velocities for LinuxCNC. The base thread can, and does, interrupt the servo-thread.
If your step time set in Stepconf is quite long, then I suspect that Stepconf won't bother with the Reset function.
Replied by andypugh on topic Please help, I need some addvise
That's interesting.
05 May 2013 08:08 #33634
That's interesting.
That's interesting.
- Thank you received: 1467
05 May 2013 10:52 #33638
Replied by Todd Zuercher on topic Please help, I need some addvise
Sorry I thought that Stepconfig would give a 2nd port configuring window and it doesn't. Sorry, you will have to set that up by hand.
The following user(s) said Thank You: allenwg2005
- allenwg2005
05 May 2013 21:05 #33656
by allenwg2005
Thanks Todd, no worries.
I found a “custom.hal” file in the folder with the configuration file, it had no text in it for commands and it stated this file would not be over written when changes were made to the base configuration file, so I used it.
Z still sent the message I shared earlier.
So Linuxcnc uses both the config file and custom hal file together to run a part program?
I would have thought you could just edit the config file and go with that, all though I suppose it could be over writted if you change the file. Is that the thinking here?
I think I'm stuck here, any thoughts?
05 May 2013 21:58 #33658
Stepconfig is just covering its self when it says that the config file could be overwritten. What it means is that if you open the config with Stepconfig after you have made any manual changes those changes you made manually will be over written. Just make backups of manual changes by saving to a different named file as a backup (or never reopen it with Stepconfig).
- allenwg2005
06 May 2013 02:08 #33661
by allenwg2005
Below is a copy of the step config hal.
As Andy pointed out, I have no port/pin assignments for Z.
I don't see any limits listed either, shouldn't they be added?
Why can't I just add to these to this hal, instead of writing to the custom hal?
Or can I, with precautions?
Here is the custom.hal, did I do something wrong on this?
# Include your customized HAL commands here
# This file will not be overwritten when you run stepconf again
net zstep => parport.2.pin-02-out
net zdir => parport.2.pin-03-out
# Generated by stepconf at Mon May 6 07:41:15 2013
# overwritten when you run stepconf again
loadrt trivkins
loadrt [EMCMOT]EMCMOT base_period_nsec=[EMCMOT]BASE_PERIOD servo_period_nsec=[EMCMOT]SERVO_PERIOD num_joints=[TRAJ]AXES
loadrt probe_parport
loadrt hal_parport cfg="0x378 out 0x8800 out 0xa000 out"
loadrt stepgen step_type=0,0,0
addf parport.1.read base-thread
addf parport.2.read base-thread
addf parport.1.write base-thread
addf parport.2.write base-thread
addf stepgen.update-freq servo-thread
net spindle-cmd <= motion.spindle-speed-out
setp parport.0.pin-01-out-invert 1
net estop-out => parport.0.pin-01-out
net xstep => parport.0.pin-02-out
net xdir => parport.0.pin-03-out
net xenable => parport.0.pin-05-out
net ystep => parport.0.pin-06-out
net ydir => parport.0.pin-07-out
net xenable => parport.0.pin-09-out
net min-home-x <= parport.0.pin-10-in
net max-x <= parport.0.pin-11-in
net min-home-y <= parport.0.pin-12-in
net max-y <= parport.0.pin-13-in
setp stepgen.0.position-scale [AXIS_0]SCALE
setp stepgen.0.steplen 1
setp stepgen.0.stepspace 1
setp stepgen.0.dirhold 41971
setp stepgen.0.dirsetup 41971
setp stepgen.0.maxaccel [AXIS_0]STEPGEN_MAXACCEL
net xpos-cmd axis.0.motor-pos-cmd => stepgen.0.position-cmd
net xpos-fb stepgen.0.position-fb => axis.0.motor-pos-fb
net xstep <= stepgen.0.step
net xdir <= stepgen.0.dir
net xenable axis.0.amp-enable-out => stepgen.0.enable
net min-home-x => axis.0.home-sw-in
net min-home-x => axis.0.neg-lim-sw-in
net max-x => axis.0.pos-lim-sw-in
setp stepgen.1.position-scale [AXIS_1]SCALE
setp stepgen.1.steplen 1
setp stepgen.1.stepspace 1
setp stepgen.1.dirhold 41971
setp stepgen.1.dirsetup 41971
setp stepgen.1.maxaccel [AXIS_1]STEPGEN_MAXACCEL
net ypos-cmd axis.1.motor-pos-cmd => stepgen.1.position-cmd
net ypos-fb stepgen.1.position-fb => axis.1.motor-pos-fb
net ystep <= stepgen.1.step
net ydir <= stepgen.1.dir
net yenable axis.1.amp-enable-out => stepgen.1.enable
net min-home-y => axis.1.home-sw-in
net min-home-y => axis.1.neg-lim-sw-in
net max-y => axis.1.pos-lim-sw-in
setp stepgen.2.position-scale [AXIS_2]SCALE
setp stepgen.2.steplen 1
setp stepgen.2.stepspace 1
setp stepgen.2.dirhold 41971
setp stepgen.2.dirsetup 41971
setp stepgen.2.maxaccel [AXIS_2]STEPGEN_MAXACCEL
net zpos-cmd axis.2.motor-pos-cmd => stepgen.2.position-cmd
net zpos-fb stepgen.2.position-fb => axis.2.motor-pos-fb
net zstep <= stepgen.2.step
net zdir <= stepgen.2.dir
net zenable axis.2.amp-enable-out => stepgen.2.enable
net estop-out => iocontrol.0.emc-enable-in
net tool-change iocontrol.0.tool-change => hal_manualtoolchange.change
net tool-changed iocontrol.0.tool-changed <= hal_manualtoolchange.changed
- allenwg2005
07 May 2013 00:15 #33684
by allenwg2005
Hello forum friends,
The website really is struggling these past few days, makes you wounder what is causing this.
I have some minor results to share, I still haven't been able to get a test to run on Z axis.
I followed the error message /usr/bin/stepconf line 1740 and 2175 using Gedit.
Line 1740 reads:
def on_zaxistest_clicked (self, *args): self.test_axis ('Z')
This line reads just as the X axis with the exception of the Z's, X axis works just fine.
I don't know what this means exactly, can someone let me know? (*args????? what's that)?
Line 2175 reads:
'scale': data[axis+ 'scale'],
I must have something entered wrong so scaling isn't working properly?
I think if I can fix this I will have Z working.
Please advise.
Line 1740 reads:
Line 2175 reads:
Please advise.
07 May 2013 20:00 #33720
What is the Z-scale in the INI [AXIS_2]SCALE ?
If that is zero, then there my be problems.
I think if I can fix this I will have Z working..
