Forum Header
unable to get step motors to move at all??
- submicro
15 May 2011 19:07 - 15 May 2011 20:35 #9829
by submicro
unable to get step motors to move at all?? was created by submicro
Hello
I'm running an Ubuntu box with 10.04 Lucid 2.6.32-122-rtai kernel. I'm using a Keling 3 Axis kit which includes, 3 keling 4030 stepper drivers, 2 270 oz in motors and one 385 oz in motor, a c10 parallel breakout board, and a 36v 9a power supply.
I wired it up according to the keling documentation.
I've tried the Stepconf Wizard many times using many configurations with no joy!
I have no idea what to try next............ If anyone can help it would appreciated, if more info is needed just ask I'll get it!
I just noticed that the Y axis motor locks up as soon as I power everything up. I mean it won't budge either way! but the X axis motor stays loose? I'm lost
SubMicro
SubMicro
Last edit: 15 May 2011 20:35 by submicro.
- BigJohnT
- Thank you received: 1176
15 May 2011 22:38 #9835
by BigJohnT
Replied by BigJohnT on topic Re:unable to get step motors to move at all??
Sounds like the Y has power and the X does not...
Do your drives need an enable?
Did you configure you output pins to match your wiring?
- submicro
16 May 2011 00:08 - 16 May 2011 00:34 #9837
by submicro
Replied by submicro on topic Re:unable to get step motors to move at all??
yes i setup the pins and wiring to match.
no the driver does not require an enable, it does have one but if left unconnected then it defaults to enabled.
Also How can I verify that my parallel port is working and seen by EMC2??
Last edit: 16 May 2011 00:34 by submicro.
- Rick G
- Thank you received: 155
16 May 2011 07:59 #9839
by Rick G
Replied by Rick G on topic Re:unable to get step motors to move at all??
You might want to look here...
wiki.linuxcnc.org/emcinfo.pl?TroubleShoo...arallel_Port_Outputs
Rick G
Rick G
- PKM
- Thank you received: 3
16 May 2011 08:17 #9841
by PKM
Replied by PKM on topic Re:unable to get step motors to move at all??
Some breakout boards invert signals. I have such a board and it took a long time to get it working.
Just try to invert step pins at stepconf.
- submicro
16 May 2011 14:23 - 16 May 2011 14:55 #9845
by submicro
Yes the board inverts the signsls and I did invert them in stepconf
This is really frustrating, I refuse to go back to Windows.....
Last edit: 16 May 2011 14:55 by submicro.
- Thank you received: 5271
16 May 2011 14:52 #9847
Replied by PCW on topic Re:unable to get step motors to move at all??
"I just noticed that the Y axis motor locks up as soon as I power everything up. I mean it won't budge either way! but the X axis motor stays loose? I'm lost"
If the X axis motor doesn't lock up, this is a drive, power wiring, motor wiring, or motor problem, nothing to do with EMC.
If the drives are enabled by default, connecting nothing but the motor to the drive and supplying the drive with power should get you a "locked" step motor...
- BigJohnT
16 May 2011 15:01 #9848
by BigJohnT
You may have blown an opto on the C10, I've done that before on mine. Swap steppers at the C10 and see if the X will move and the Y will not...
- submicro
17 May 2011 19:12 - 17 May 2011 19:13 #9874
by submicro
I double checked the wiring and yes one motor was wrong but I fixed that and now both lock up when powered. Is this a problem do I need an enable line?
I went and got a parallel port card today, gonna see if it was the port.
If the opto is blown I can just replace one of the three chips right?
Thanks 4 the advice..
Last edit: 17 May 2011 19:13 by submicro.
- BigJohnT
17 May 2011 20:15 #9875
by BigJohnT
If you don't have the C10 enabled you don't get any outputs to your drives!
Time to create page: 0.126 seconds
