Forum Header
unable to get step motors to move at all??
- BigJohnT
- Thank you received: 1176
17 May 2011 23:36 #9899
by BigJohnT
Replied by BigJohnT on topic Re:unable to get step motors to move at all??
setp parport.1.pin-17-out 1
- BigJohnT
17 May 2011 23:38 #9900
by BigJohnT
setp parport.1.pin-17-out 0
for off use a 0 zero.
- submicro
17 May 2011 23:41 #9901
by submicro
Replied by submicro on topic Re:unable to get step motors to move at all??
ok it works now
- submicro
17 May 2011 23:42 #9902
by submicro
so now what?
- BigJohnT
17 May 2011 23:42 #9903
by BigJohnT
So now you can unlink the pins and test them, referring to the link earlier to read up on unlink.
Sorry about forgetting to tell you about 1 and 0.
- submicro
17 May 2011 23:44 #9904
by submicro
No worries
Ok so now I unlink and test the pins how exactly? I'm a bit lost
- BigJohnT
17 May 2011 23:49 #9905
by BigJohnT
Ok unlink is like setp except you don't use the 1 or 0 just unlink any pins that are linked and test them.
unlink parport.0.pin-02-out
then
for on
setp pinname 1
for off
setp pinname 0
then you can turn that one on and see if the led lights on the C10. As I recall the C10 has 3 or 4 optos, so if one is blown you can sort that out by which pins work and which ones don't work.
When you start your config the pins you unlinked will be back to normal.
then
for on
setp pinname 1
for off
setp pinname 0
- submicro
17 May 2011 23:55 #9906
by submicro
There is only one led and it stays on constantly
- BigJohnT
18 May 2011 00:17 #9907
by BigJohnT
I thought there was an led for each pin on the C10... oh only on the C1 do they have a led for each one.
Can you test each one as you turn them on and off?
- submicro
18 May 2011 00:19 #9908
by submicro
Yes but I'll have to build a test board with led's to make it easier. I'll make one tonight
But right now I can't test them
Time to create page: 0.076 seconds
