× Forum Header
unable to get step motors to move at all??
17 May 2011 22:12 #9889 by BigJohnT
Replied by BigJohnT on topic Re:unable to get step motors to move at all??
It has to be one that is not in use and an out pin... I just guessed at 10.
17 May 2011 22:13 #9890 by BigJohnT
I just looked and 10 is an in pin...
17 May 2011 22:31 #9891 by submicro
Replied by submicro on topic Re:unable to get step motors to move at all??
It don't matter what number I et the same message
Man this is frustrating. I know it's prob something simple
17 May 2011 22:41 #9892 by BigJohnT
What exactly did you type? and did you see that when you clicked on it nothing was connected to that pin?
If it says something like parport.0.pin-02-out <= xstep then you can't do a setp on that one unless you unlink it from xstep.
www.linuxcnc.org/docview/html/hal_basic_hal.html
17 May 2011 22:50 #9893 by submicro
I typed setp parport.0.pin-23-out and changed the number a few times
17 May 2011 23:09 #9894 by BigJohnT
There is no pin 23... on the list to the left in Show Hal Configuration you see Pins... drill down to the parallel port and see what pins you have. Hint try 16 or 17...
17 May 2011 23:16 - 17 May 2011 23:30 #9895 by submicro
Ok I tried 16, 17, 18 , 19, 7, 8, 9 etc... they alll say invalid argument!
I type in the area that says test hal command setp parport.0.pin-number here-out
Well it accepts unlink commands but not setp even using same pin??
Last edit: 17 May 2011 23:30 by submicro.
17 May 2011 23:30 #9896 by BigJohnT
CRAP, I forgot to tell you to set it to 1 for on... sorry.
setp pinname 1
17 May 2011 23:32 #9897 by BigJohnT
Sorry, my mind is on break it seems...
17 May 2011 23:34 - 17 May 2011 23:39 #9898 by submicro
setp parport.1.pin-17-out invalid argument!
unlinkp parport.0.pin-17-out works
followed by
setp parport.0.pin-17-out invalid argument
Last edit: 17 May 2011 23:39 by submicro.
