Forum Header
unable to get step motors to move at all??
- submicro
17 May 2011 20:28 - 17 May 2011 20:30 #9876
by submicro
Replied by submicro on topic Re:unable to get step motors to move at all??
Ok i'm confused I wired it according to keling docs?
So i have bto enable it how?
I hace a jumper from +5v to en on the right side of the board, looking at it from the back side
Last edit: 17 May 2011 20:30 by submicro.
- BigJohnT
- Thank you received: 1176
17 May 2011 20:30 #9877
by BigJohnT
Replied by BigJohnT on topic Re:unable to get step motors to move at all??
Is it a CNC4PC C10 breakout board? that's what I thought you had...
- submicro
17 May 2011 20:48 #9879
by submicro
I don't think so, it's this one
www.kelinginc.net/BreakoutBoards.html
The one at top left
Also how can I find the address of my parallel ports in linux?
The one at top left
- BigJohnT
17 May 2011 21:10 - 17 May 2011 21:18 #9880
by BigJohnT
That is a CNC4PC C10 even the pdf is branded with CNC4PC.
After you boot you can open up a terminal and put
dmesg|grep parport
and you might get something like this
[ 7.305717] parport0: PC-style at 0x378, irq 7 [PCSPP,TRISTATE,EPP]
When you try and jog can you see the direction pin come on? It will be on one way and off the other. When you try and jog will the stepper move one step? That usually means you have step and direction backwards.
dmesg|grep parport
Last edit: 17 May 2011 21:18 by BigJohnT.
- submicro
17 May 2011 21:18 - 17 May 2011 21:29 #9882
by submicro
I'm not getting any movement at all. The motors are getting warm but not hot.
this is what I get using that command, which address should I use?
[ 10.357066] parport_pc 00:0b: reported by Plug and Play ACPI
[ 10.357136] parport0: PC-style at 0x378 (0x778), irq 7, dma 3 [PCSPP,TRISTATE,COMPAT,ECP,DMA]
[ 10.468290] lp0: using parport0 (interrupt-driven).
[ 10.880388] parport_serial 0000:00:0a.0: PCI INT A -> GSI 17 (level, low) -> IRQ 17
[ 10.880417] parport1: PC-style at 0xc000 [PCSPP,TRISTATE,EPP]
[ 10.985461] lp1: using parport1 (polling).
Last edit: 17 May 2011 21:29 by submicro.
- BigJohnT
17 May 2011 21:28 #9883
by BigJohnT
Also, you can open up Show Hal Configuration window and turn on an unused out pin.
The syntax for that is:
setp parport.0.pin...
You will have to look at the pins for the parallel port and pick one.
- submicro
17 May 2011 21:36 - 17 May 2011 21:40 #9884
by submicro
Ok I tried that but got an error "Invalid Argument"
I may be wrong but while running a test file I can watch the values change in HAL so maybe it's in the wiring or the parallel cable??
Last edit: 17 May 2011 21:40 by submicro.
- BigJohnT
17 May 2011 21:55 #9886
by BigJohnT
Did you finish the pin number?
It's setp for set pin then the name of the pin like parport.0.pin-10-out or something like that...
- BigJohnT
17 May 2011 21:56 #9887
by BigJohnT
What your looking for is the led on the C10 board to come on...
- submicro
17 May 2011 22:06 #9888
by submicro
NO I tried setp parport.0.pin-10-out and got error invalid argument
Invalid argument
Invalid argument
while executing
"hal setp parport.0.pin-10-out"
("eval" body line 1)
invoked from within
"eval hal $what"
(procedure "showEx" line 3)
invoked from within
"showEx $halcommand"
invoked from within
".main.note.fps.b.execute invoke"
("uplevel" body line 1)
invoked from within
"uplevel #0
Invalid argument
Invalid argument
while executing
invoked from within
"eval hal $what"
invoked from within
invoked from within
invoked from within
"uplevel #0
(procedure "tk::ButtonUp" line 22)
invoked from within
"tk::ButtonUp .main.note.fps.b.execute"
(command bound to event)
