Intel cpu on board motherboard suggestion
- ArcEye
- Thank you received: 240
30 Sep 2015 17:33 - 30 Sep 2015 18:08 #63277
by ArcEye
Replied by ArcEye on topic Intel cpu on board motherboard suggestion
According to other ASRock docs, it is a debug header
Whilst you can theoretically use as a limited printer port, they may have already assigned to something else
The docs for your board do not say anything about a parport, they usually have a 26 pin header
Last edit: 30 Sep 2015 18:08 by ArcEye.
- cncbasher
- Thank you received: 202
30 Sep 2015 17:51 #63282
by cncbasher
Replied by cncbasher on topic Intel cpu on board motherboard suggestion
you can't use a lpc port as a printer port , at least not in the context of linuxcnc , in fact iv'e never seen a printer adapter that fit's
most use them for audio only or specific use cards .
- eFalegname
- Thank you received: 30
30 Sep 2015 20:08 #63295
by eFalegname
Replied by eFalegname on topic Intel cpu on board motherboard suggestion
At this point I'll better start over looking for a new motherboard. Thank you all, I wish someone would cancel this model entry from the Latency Test page to avoid any future confusion.
30 Sep 2015 20:17 #63296
Maybe it should mention that there is no Parallel port, but for anyone using PCIe or Ethernet peripherals to run LinuxCNC it might still be a good choice.
Why is buying a new motherboard preferable to fitting a PCIe parallel port card?
Replied by andypugh on topic Intel cpu on board motherboard suggestion
The following user(s) said Thank You: eFalegname
- eFalegname
30 Sep 2015 21:40 #63299
by eFalegname
Hi Andypugh, what do you think? this one may work with LinuxCNC: www.ebay.it/itm/Scheda-PCI-E-2-seriali-1...?hash=item35d397cc5e
2 Serial 1 Parallel PCI-e Controller Card 3 Port PCI Express Card
Specification:
Fully Compliant with PCI-e Base Specification, Revision 1.0a
PCI-e Multi Function Peripheral Controller with x1 Lane Interface
Support for D1, D2, D3hot and D3cold
Utilizes 100-Mhz Differential PCI-e Common Reference Clock
Supports PCI-e Power Management
Serial Port:
2 16c450/550/Extended 550 Compatible UARTs
Supports RS232 Modes
Bi-directional Speeds from 50bps to 16Mbps/Port
Full Serial Modem Control
Supports Hardware, Software Flow Control
5, 6, 7, 8 and 9-bit Serial Format Support
Support MODEM Modem Signals CTS, DSR, RI, DCD, the DTR, RTS, Convert RS232 Level
Even, Odd, None, Space & Mark Parity Supported
Custom BAUD Rates Supported with External Clock or by Programming Internal PLL
On Chip 256 Byte Depth FIFOs in Transmit, Receive Path of Each Serial Port
Support Remote Wakeup and Power management Features
Serial Port Transceiver Shutdown Support
Support Slow IrDA on all Serial Ports
IEEE1284 Parallel Port:
Multi-mode IEEE 1284 Compliant COntroller (SPP, Nibble, Byte, PS/2, EPP, ECP)
Faster Data Rates up to 1.5Mbps for Parallel Port
Package Included:
1 x PCIe 2 Serial&1 Parallel card
1 x Driver CD
Specification:
Serial Port:
Package Included:
1 x Driver CD
30 Sep 2015 21:47 #63301
If it meets the specifications given, then it ought to work.
- eFalegname
13 Oct 2015 21:28 - 14 Oct 2015 20:34 #63760
by eFalegname
I bought the parallel adapter, but to my misfortune
is not recognized by ubuntu, do you have any advice for me, please...
Here's the output for sudo cat /proc/ioports:
sudo dmesg|grep parport doesn't give me any output.
0000-001f : dma1
0020-0021 : pic1
0040-0043 : timer0
0050-0053 : timer1
0060-0060 : keyboard
0064-0064 : keyboard
0070-0071 : rtc0
0080-008f : dma page reg
00a0-00a1 : pic2
00c0-00df : dma2
00f0-00ff : fpu
0170-0177 : 0000:00:14.1
0170-0177 : pata_atiixp
01f0-01f7 : 0000:00:14.1
01f0-01f7 : pata_atiixp
0290-029f : pnp 00:03
0376-0376 : 0000:00:14.1
0376-0376 : pata_atiixp
03c0-03df : vga+
03f6-03f6 : 0000:00:14.1
03f6-03f6 : pata_atiixp
040b-040b : pnp 00:02
04d0-04d1 : pnp 00:07
04d6-04d6 : pnp 00:02
0800-089f : pnp 00:02
0800-0803 : ACPI PM1a_EVT_BLK
0804-0805 : ACPI PM1a_CNT_BLK
0808-080b : ACPI PM_TMR
0820-0827 : ACPI GPE0_BLK
0900-090f : pnp 00:02
0910-091f : pnp 00:02
0b00-0b07 : piix4_smbus
0b20-0b3f : pnp 00:02
0c00-0c01 : pnp 00:02
0c14-0c14 : pnp 00:02
0c50-0c51 : pnp 00:02
0c52-0c52 : pnp 00:02
0c6c-0c6c : pnp 00:02
0c6f-0c6f : pnp 00:02
0cd0-0cd1 : pnp 00:02
0cd2-0cd3 : pnp 00:02
0cd4-0cd5 : pnp 00:02
0cd6-0cd7 : pnp 00:02
0cd8-0cdf : pnp 00:02
0cf8-0cff : PCI conf1
d000-dfff : PCI Bus 0000:04
d000-d0ff : 0000:04:00.0
d000-d0ff : r8169
e000-efff : PCI Bus 0000:01
e000-e0ff : 0000:01:00.0
e100-e103 : 0000:01:00.0
f000-f0ff : 0000:00:01.0
f100-f10f : 0000:00:14.1
f100-f10f : pata_atiixp
f150-f15f : 0000:00:11.0
f150-f15f : ahci
f160-f163 : 0000:00:11.0
f160-f163 : ahci
f170-f177 : 0000:00:11.0
f170-f177 : ahci
f180-f183 : 0000:00:11.0
f180-f183 : ahci
f190-f197 : 0000:00:11.0
f190-f197 : ahci
fe00-fefe : pnp 00:02sudo dmesg|grep parport doesn't give me any output.
Last edit: 14 Oct 2015 20:34 by BigJohnT. Reason: add code tags
- eFalegname
13 Oct 2015 21:32 - 14 Oct 2015 20:36 #63761
by eFalegname
This is the ouput for dmesg > bootmsg.txt:
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Linux version 2.6.32-122-rtai (root@moses-6core) (gcc version 4.4.3 (Ubuntu 4.4.3-4ubuntu5) ) #rtai SMP Tue Jul 27 12:44:07 CDT 2010 (Ubuntu 2.6.32-122.35.rtai-rtai 2.6.32.11+drm33.2)
[ 0.000000] KERNEL supported cpus:
[ 0.000000] Intel GenuineIntel
[ 0.000000] AMD AuthenticAMD
[ 0.000000] NSC Geode by NSC
[ 0.000000] Cyrix CyrixInstead
[ 0.000000] Centaur CentaurHauls
[ 0.000000] Transmeta GenuineTMx86
[ 0.000000] Transmeta TransmetaCPU
[ 0.000000] UMC UMC UMC UMC
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: 0000000000000000 - 000000000009fc00 (usable)
[ 0.000000] BIOS-e820: 000000000009fc00 - 00000000000a0000 (reserved)
[ 0.000000] BIOS-e820: 00000000000e0000 - 0000000000100000 (reserved)
[ 0.000000] BIOS-e820: 0000000000100000 - 00000000dc73c000 (usable)
[ 0.000000] BIOS-e820: 00000000dc73c000 - 00000000dca4e000 (reserved)
[ 0.000000] BIOS-e820: 00000000dca4e000 - 00000000dd478000 (ACPI NVS)
[ 0.000000] BIOS-e820: 00000000dd478000 - 00000000dd879000 (reserved)
[ 0.000000] BIOS-e820: 00000000dd879000 - 00000000dd87a000 (usable)
[ 0.000000] BIOS-e820: 00000000dd87a000 - 00000000dd881000 (ACPI NVS)
[ 0.000000] BIOS-e820: 00000000dd881000 - 00000000ddc95000 (usable)
[ 0.000000] BIOS-e820: 00000000ddc95000 - 00000000ddef3000 (reserved)
[ 0.000000] BIOS-e820: 00000000ddef3000 - 00000000ddf00000 (usable)
[ 0.000000] BIOS-e820: 00000000fec00000 - 00000000fec01000 (reserved)
[ 0.000000] BIOS-e820: 00000000fec10000 - 00000000fec11000 (reserved)
[ 0.000000] BIOS-e820: 00000000fed00000 - 00000000fed01000 (reserved)
[ 0.000000] BIOS-e820: 00000000fed61000 - 00000000fed71000 (reserved)
[ 0.000000] BIOS-e820: 00000000fed80000 - 00000000fed90000 (reserved)
[ 0.000000] BIOS-e820: 00000000fef00000 - 0000000100000000 (reserved)
[ 0.000000] BIOS-e820: 0000000100001000 - 0000000120000000 (usable)
[ 0.000000] DMI 2.7 present.
[ 0.000000] AMI BIOS detected: BIOS may corrupt low RAM, working around it.
[ 0.000000] e820 update range: 0000000000000000 - 0000000000010000 (usable) ==> (reserved)
[ 0.000000] last_pfn = 0xddf00 max_arch_pfn = 0x100000
[ 0.000000] MTRR default type: uncachable
[ 0.000000] MTRR fixed ranges enabled:
[ 0.000000] 00000-9FFFF write-back
[ 0.000000] A0000-BFFFF write-through
[ 0.000000] C0000-CEFFF write-protect
[ 0.000000] CF000-EBFFF uncachable
[ 0.000000] EC000-FFFFF write-protect
[ 0.000000] MTRR variable ranges enabled:
[ 0.000000] 0 base 000000000 mask F00000000 write-back
[ 0.000000] 1 base 0DDF00000 mask FFFF00000 uncachable
[ 0.000000] 2 base 0DE000000 mask FFE000000 uncachable
[ 0.000000] 3 base 0E0000000 mask FE0000000 uncachable
[ 0.000000] 4 disabled
[ 0.000000] 5 disabled
[ 0.000000] 6 disabled
[ 0.000000] 7 disabled
[ 0.000000] x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106
[ 0.000000] Scanning 0 areas for low memory corruption
[ 0.000000] modified physical RAM map:
[ 0.000000] modified: 0000000000000000 - 0000000000010000 (reserved)
[ 0.000000] modified: 0000000000010000 - 000000000009fc00 (usable)
[ 0.000000] modified: 000000000009fc00 - 00000000000a0000 (reserved)
[ 0.000000] modified: 00000000000e0000 - 0000000000100000 (reserved)
[ 0.000000] modified: 0000000000100000 - 00000000dc73c000 (usable)
[ 0.000000] modified: 00000000dc73c000 - 00000000dca4e000 (reserved)
[ 0.000000] modified: 00000000dca4e000 - 00000000dd478000 (ACPI NVS)
[ 0.000000] modified: 00000000dd478000 - 00000000dd879000 (reserved)
[ 0.000000] modified: 00000000dd879000 - 00000000dd87a000 (usable)
[ 0.000000] modified: 00000000dd87a000 - 00000000dd881000 (ACPI NVS)
[ 0.000000] modified: 00000000dd881000 - 00000000ddc95000 (usable)
[ 0.000000] modified: 00000000ddc95000 - 00000000ddef3000 (reserved)
[ 0.000000] modified: 00000000ddef3000 - 00000000ddf00000 (usable)
[ 0.000000] modified: 00000000fec00000 - 00000000fec01000 (reserved)
[ 0.000000] modified: 00000000fec10000 - 00000000fec11000 (reserved)
[ 0.000000] modified: 00000000fed00000 - 00000000fed01000 (reserved)
[ 0.000000] modified: 00000000fed61000 - 00000000fed71000 (reserved)
[ 0.000000] modified: 00000000fed80000 - 00000000fed90000 (reserved)
[ 0.000000] modified: 00000000fef00000 - 0000000100000000 (reserved)
[ 0.000000] modified: 0000000100001000 - 0000000120000000 (usable)
[ 0.000000] initial memory mapped : 0 - 00c00000
[ 0.000000] init_memory_mapping: 0000000000000000-00000000377fe000
[ 0.000000] Using x86 segment limits to approximate NX protection
[ 0.000000] 0000000000 - 0000400000 page 4k
[ 0.000000] 0000400000 - 0037400000 page 2M
[ 0.000000] 0037400000 - 00377fe000 page 4k
[ 0.000000] kernel direct mapping tables up to 377fe000 @ 10000-15000
[ 0.000000] RAMDISK: 37368000 - 37fef619
[ 0.000000] Allocated new RAMDISK: 008b5000 - 0153c619
[ 0.000000] Move RAMDISK from 0000000037368000 - 0000000037fef618 to 008b5000 - 0153c618
[ 0.000000] ACPI: RSDP 000f0490 00024 (v02 ALASKA)
[ 0.000000] ACPI: XSDT dd469070 00064 (v01 ALASKA A M I 01072009 AMI 00010013)
[ 0.000000] ACPI: FACP dd46e9b0 000F4 (v04 ALASKA A M I 01072009 AMI 00010013)
[ 0.000000] ACPI Warning: Optional field Pm2ControlBlock has zero address or length: 0000000000000000/1 (20090903/tbfadt-557)
[ 0.000000] ACPI: DSDT dd469170 0583F (v02 ALASKA A M I 00000000 INTL 20051117)
[ 0.000000] ACPI: FACS dd476f80 00040
[ 0.000000] ACPI: APIC dd46eaa8 00062 (v03 ALASKA A M I 01072009 AMI 00010013)
[ 0.000000] ACPI: FPDT dd46eb10 00044 (v01 ALASKA A M I 01072009 AMI 00010013)
[ 0.000000] ACPI: MCFG dd46eb58 0003C (v01 ALASKA A M I 01072009 MSFT 00010013)
[ 0.000000] ACPI: AAFT dd46eb98 00042 (v01 ALASKA OEMAAFT 01072009 MSFT 00000097)
[ 0.000000] ACPI: HPET dd46ebe0 00038 (v01 ALASKA A M I 01072009 AMI 00000005)
[ 0.000000] ACPI: SSDT dd46ec18 0168E (v02 AMD ALIB 00000001 MSFT 04000000)
[ 0.000000] ACPI: BGRT dd4702a8 00038 (v00 ALASKA A M I 01072009 AMI 00010013)
[ 0.000000] ACPI: Local APIC address 0xfee00000
[ 0.000000] 2663MB HIGHMEM available.
[ 0.000000] 887MB LOWMEM available.
[ 0.000000] mapped low ram: 0 - 377fe000
[ 0.000000] low ram: 0 - 377fe000
[ 0.000000] node 0 low ram: 00000000 - 377fe000
[ 0.000000] node 0 bootmap 00011000 - 00017f00
[ 0.000000] (9 early reservations) ==> bootmem [0000000000 - 00377fe000]
[ 0.000000] #0 [0000000000 - 0000001000] BIOS data page ==> [0000000000 - 0000001000]
[ 0.000000] #1 [0000001000 - 0000002000] EX TRAMPOLINE ==> [0000001000 - 0000002000]
[ 0.000000] #2 [0000006000 - 0000007000] TRAMPOLINE ==> [0000006000 - 0000007000]
[ 0.000000] #3 [0000100000 - 00008b0db8] TEXT DATA BSS ==> [0000100000 - 00008b0db8]
[ 0.000000] #4 [000009fc00 - 0000100000] BIOS reserved ==> [000009fc00 - 0000100000]
[ 0.000000] #5 [00008b1000 - 00008b415c] BRK ==> [00008b1000 - 00008b415c]
[ 0.000000] #6 [0000010000 - 0000011000] PGTABLE ==> [0000010000 - 0000011000]
[ 0.000000] #7 [00008b5000 - 000153c619] NEW RAMDISK ==> [00008b5000 - 000153c619]
[ 0.000000] #8 [0000011000 - 0000018000] BOOTMAP ==> [0000011000 - 0000018000]
[ 0.000000] found SMP MP-table at [c00fd710] fd710
[ 0.000000] Zone PFN ranges:
[ 0.000000] DMA 0x00000010 -> 0x00001000
[ 0.000000] Normal 0x00001000 -> 0x000377fe
[ 0.000000] HighMem 0x000377fe -> 0x000ddf00
[ 0.000000] Movable zone start PFN for each node
[ 0.000000] early_node_map[5] active PFN ranges
[ 0.000000] 0: 0x00000010 -> 0x0000009f
[ 0.000000] 0: 0x00000100 -> 0x000dc73c
[ 0.000000] 0: 0x000dd879 -> 0x000dd87a
[ 0.000000] 0: 0x000dd881 -> 0x000ddc95
[ 0.000000] 0: 0x000ddef3 -> 0x000ddf00
[ 0.000000] On node 0 totalpages: 903917
[ 0.000000] free_area_init_node: node 0, pgdat c07470e0, node_mem_map c153e200
[ 0.000000] DMA zone: 32 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 3951 pages, LIFO batch:0
[ 0.000000] Normal zone: 1744 pages used for memmap
[ 0.000000] Normal zone: 221486 pages, LIFO batch:31
[ 0.000000] HighMem zone: 5327 pages used for memmap
[ 0.000000] HighMem zone: 671377 pages, LIFO batch:31
[ 0.000000] Using APIC driver default
[ 0.000000] ACPI: PM-Timer IO Port: 0x808
[ 0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x00] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x02] lapic_id[0x01] enabled)
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
[ 0.000000] ACPI: IOAPIC (id[0x00] address[0xfec00000] gsi_base[0])
[ 0.000000] IOAPIC[0]: apic_id 0, version 33, address 0xfec00000, GSI 0-23
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 low level)
[ 0.000000] ACPI: IRQ0 used by override.
[ 0.000000] ACPI: IRQ2 used by override.
[ 0.000000] ACPI: IRQ9 used by override.
[ 0.000000] Using ACPI (MADT) for SMP configuration information
[ 0.000000] SMP: Allowing 2 CPUs, 0 hotplug CPUs
[ 0.000000] nr_irqs_gsi: 24
[ 0.000000] Allocating PCI resources starting at ddf00000 (gap: ddf00000:20d00000)
[ 0.000000] NR_CPUS:8 nr_cpumask_bits:8 nr_cpu_ids:2 nr_node_ids:1
[ 0.000000] PERCPU: Embedded 24 pages/cpu @c3400000 s74936 r0 d23368 u2097152
[ 0.000000] pcpu-alloc: s74936 r0 d23368 u2097152 alloc=1*4194304
[ 0.000000] pcpu-alloc: [0] 0 1
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 896814
[ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-2.6.32-122-rtai root=UUID=1d89a724-0ecc-49e4-837a-9f35fe051887 ro quiet splash
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Enabling fast FPU save and restore... done.
[ 0.000000] Enabling unmasked SIMD FPU exception support... done.
[ 0.000000] Initializing CPU#0
[ 0.000000] allocated 18180800 bytes of page_cgroup
[ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[ 0.000000] Initializing HighMem for node 0 (000377fe:000ddf00)
[ 0.000000] Memory: 3546808k/3636224k available (4539k kernel code, 67956k reserved, 1928k data, 620k init, 2706816k highmem)
[ 0.000000] virtual kernel memory layout:
[ 0.000000] fixmap : 0xfff1e000 - 0xfffff000 ( 900 kB)
[ 0.000000] pkmap : 0xff800000 - 0xffc00000 (4096 kB)
[ 0.000000] vmalloc : 0xf7ffe000 - 0xff7fe000 ( 120 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xf77fe000 ( 887 MB)
[ 0.000000] .init : 0xc0751000 - 0xc07ec000 ( 620 kB)
[ 0.000000] .data : 0xc056ecbc - 0xc0750e68 (1928 kB)
[ 0.000000] .text : 0xc0100000 - 0xc056ecbc (4539 kB)
[ 0.000000] Checking if this processor honours the WP bit even in supervisor mode...Ok.
[ 0.000000] SLUB: Genslabs=13, HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] NR_IRQS:2304 nr_irqs:424
[ 0.000000] Extended CMOS year: 2000
[ 0.000000] I-pipe 2.6-03: pipeline enabled.
[ 0.000000] spurious 8259A interrupt: IRQ7.
[ 0.000000] Console: colour VGA+ 80x25
[ 0.000000] console [tty0] enabled
[ 0.000000] Fast TSC calibration using PIT
[ 0.000000] Detected 1599.960 MHz processor.
[ 0.008007] Calibrating delay loop (skipped), value calculated using timer frequency.. 3199.92 BogoMIPS (lpj=6399840)
[ 0.008034] Security Framework initialized
[ 0.008064] AppArmor: AppArmor initialized
[ 0.008076] Mount-cache hash table entries: 512
[ 0.008249] Initializing cgroup subsys ns
[ 0.008255] Initializing cgroup subsys cpuacct
[ 0.008261] Initializing cgroup subsys memory
[ 0.008272] Initializing cgroup subsys devices
[ 0.008276] Initializing cgroup subsys freezer
[ 0.008279] Initializing cgroup subsys net_cls
[ 0.008308] CPU: L1 I Cache: 32K (64 bytes/line), D cache 32K (64 bytes/line)
[ 0.008312] CPU: L2 Cache: 512K (64 bytes/line)
[ 0.008316] CPU: Physical Processor ID: 0
[ 0.008319] CPU: Processor Core ID: 0
[ 0.008325] mce: CPU supports 6 MCE banks
[ 0.008344] Performance Events: AMD PMU driver.
[ 0.008354] ... version: 0
[ 0.008357] ... bit width: 48
[ 0.008360] ... generic registers: 4
[ 0.008363] ... value mask: 0000ffffffffffff
[ 0.008367] ... max period: 00007fffffffffff
[ 0.008370] ... fixed-purpose events: 0
[ 0.008373] ... event mask: 000000000000000f
[ 0.008380] Checking 'hlt' instruction... OK.
[ 0.025571] ACPI: Core revision 20090903
[ 0.040024] ftrace: converting mcount calls to 0f 1f 44 00 00
[ 0.040032] ftrace: allocating 21003 entries in 42 pages
[ 0.054774] Enabling APIC mode: Flat. Using 1 I/O APICs
[ 0.055077] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.056001] ..MP-BIOS bug: 8254 timer not connected to IO-APIC
[ 0.056001] ...trying to set up timer (IRQ0) through the 8259A ...
[ 0.056001] ..... (found apic 0 pin 2) ...
[ 0.098498] ....... works.
[ 0.098501] CPU0: AMD E-350 Processor stepping 00
[ 0.100001] Booting processor 1 APIC 0x1 ip 0x6000
[ 0.012000] Initializing CPU#1
[ 0.012000] CPU: L1 I Cache: 32K (64 bytes/line), D cache 32K (64 bytes/line)
[ 0.012000] CPU: L2 Cache: 512K (64 bytes/line)
[ 0.012000] CPU: Physical Processor ID: 0
[ 0.012000] CPU: Processor Core ID: 1
[ 0.184104] CPU1: AMD E-350 Processor stepping 00
[ 0.184119] checking TSC synchronization [CPU#0 -> CPU#1]: passed.
[ 0.188020] Brought up 2 CPUs
[ 0.188025] Total of 2 processors activated (6400.08 BogoMIPS).
[ 0.188168] CPU0 attaching sched-domain:
[ 0.188173] domain 0: span 0-1 level MC
[ 0.188178] groups: 0 1
[ 0.188187] CPU1 attaching sched-domain:
[ 0.188191] domain 0: span 0-1 level MC
[ 0.188195] groups: 1 0
[ 0.188314] devtmpfs: initialized
[ 0.188350] regulator: core version 0.5
[ 0.188350] NET: Registered protocol family 16
[ 0.188350] Trying to unpack rootfs image as initramfs...
[ 0.188350] EISA bus registered
[ 0.188350] ACPI: bus type pci registered
[ 0.188433] PCI: MCFG configuration 0: base e0000000 segment 0 buses 0 - 255
[ 0.188439] PCI: Not using MMCONFIG.
[ 0.202487] PCI: Using configuration type 1 for base access
[ 0.202490] PCI: Using configuration type 1 for extended access
[ 0.203718] bio: create slab <bio-0> at 0
[ 0.204894] ACPI: EC: Look up EC in DSDT
[ 0.208346] ACPI: Executed 2 blocks of module-level executable AML code
[ 0.215474] ACPI: Interpreter enabled
[ 0.215479] ACPI: (supports S0 S5)
[ 0.215497] ACPI: Using IOAPIC for interrupt routing
[ 0.215578] PCI: MCFG configuration 0: base e0000000 segment 0 buses 0 - 255
[ 0.215759] PCI: MCFG area at e0000000 reserved in ACPI motherboard resources
[ 0.215763] PCI: Using MMCONFIG for extended config space
[ 0.222662] [Firmware Bug]: ACPI: ACPI brightness control misses _BQC function
[ 0.225172] ACPI: No dock devices found.
[ 0.225721] ACPI: PCI Root Bridge [PCI0] (0000:00)
[ 0.225846] pci 0000:00:01.0: reg 10 32bit mmio pref: [0xfc000000-0xfdffffff]
[ 0.225856] pci 0000:00:01.0: reg 14 io port: [0xf000-0xf0ff]
[ 0.225865] pci 0000:00:01.0: reg 18 32bit mmio: [0xfeb00000-0xfeb3ffff]
[ 0.225905] pci 0000:00:01.0: supports D1 D2
[ 0.225981] pci 0000:00:04.0: PME# supported from D0 D3hot D3cold
[ 0.225988] pci 0000:00:04.0: PME# disabled
[ 0.226063] pci 0000:00:11.0: reg 10 io port: [0xf190-0xf197]
[ 0.226074] pci 0000:00:11.0: reg 14 io port: [0xf180-0xf183]
[ 0.226084] pci 0000:00:11.0: reg 18 io port: [0xf170-0xf177]
[ 0.226094] pci 0000:00:11.0: reg 1c io port: [0xf160-0xf163]
[ 0.226104] pci 0000:00:11.0: reg 20 io port: [0xf150-0xf15f]
[ 0.226114] pci 0000:00:11.0: reg 24 32bit mmio: [0xfeb47000-0xfeb473ff]
[ 0.226138] pci 0000:00:11.0: set SATA to AHCI mode
[ 0.226196] pci 0000:00:12.0: reg 10 32bit mmio: [0xfeb46000-0xfeb46fff]
[ 0.226286] pci 0000:00:12.2: reg 10 32bit mmio: [0xfeb45000-0xfeb450ff]
[ 0.226349] pci 0000:00:12.2: supports D1 D2
[ 0.226353] pci 0000:00:12.2: PME# supported from D0 D1 D2 D3hot
[ 0.226360] pci 0000:00:12.2: PME# disabled
[ 0.226400] pci 0000:00:13.0: reg 10 32bit mmio: [0xfeb44000-0xfeb44fff]
[ 0.226489] pci 0000:00:13.2: reg 10 32bit mmio: [0xfeb43000-0xfeb430ff]
[ 0.226552] pci 0000:00:13.2: supports D1 D2
[ 0.226556] pci 0000:00:13.2: PME# supported from D0 D1 D2 D3hot
[ 0.226562] pci 0000:00:13.2: PME# disabled
[ 0.226663] pci 0000:00:14.1: reg 10 io port: [0xf140-0xf147]
[ 0.226673] pci 0000:00:14.1: reg 14 io port: [0xf130-0xf133]
[ 0.226683] pci 0000:00:14.1: reg 18 io port: [0xf120-0xf127]
[ 0.226693] pci 0000:00:14.1: reg 1c io port: [0xf110-0xf113]
[ 0.226702] pci 0000:00:14.1: reg 20 io port: [0xf100-0xf10f]
[ 0.226847] pci 0000:00:14.5: reg 10 32bit mmio: [0xfeb42000-0xfeb42fff]
[ 0.226969] pci 0000:00:15.0: supports D1 D2
[ 0.227062] pci 0000:00:15.1: supports D1 D2
[ 0.227153] pci 0000:00:15.2: supports D1 D2
[ 0.227200] pci 0000:00:16.0: reg 10 32bit mmio: [0xfeb41000-0xfeb41fff]
[ 0.227289] pci 0000:00:16.2: reg 10 32bit mmio: [0xfeb40000-0xfeb400ff]
[ 0.227352] pci 0000:00:16.2: supports D1 D2
[ 0.227356] pci 0000:00:16.2: PME# supported from D0 D1 D2 D3hot
[ 0.227362] pci 0000:00:16.2: PME# disabled
[ 0.227779] pci 0000:01:00.0: reg 10 io port: [0xe000-0xe0ff]
[ 0.227791] pci 0000:01:00.0: reg 14 32bit mmio pref: [0xfe100000-0xfe107fff]
[ 0.227804] pci 0000:01:00.0: reg 18 io port: [0xe100-0xe103]
[ 0.227838] pci 0000:01:00.0: reg 30 32bit mmio pref: [0xfea00000-0xfea07fff]
[ 0.227883] pci 0000:01:00.0: PME# supported from D0 D3hot D3cold
[ 0.227890] pci 0000:01:00.0: PME# disabled
[ 0.227973] pci 0000:00:04.0: bridge io port: [0xe000-0xefff]
[ 0.227979] pci 0000:00:04.0: bridge 32bit mmio: [0xfea00000-0xfeafffff]
[ 0.227988] pci 0000:00:04.0: bridge 64bit mmio pref: [0xfe100000-0xfe1fffff]
[ 0.228065] pci 0000:00:14.4: transparent bridge
[ 0.228200] pci 0000:04:00.0: reg 10 io port: [0xd000-0xd0ff]
[ 0.228228] pci 0000:04:00.0: reg 18 64bit mmio pref: [0xfe004000-0xfe004fff]
[ 0.228248] pci 0000:04:00.0: reg 20 64bit mmio pref: [0xfe000000-0xfe003fff]
[ 0.228306] pci 0000:04:00.0: supports D1 D2
[ 0.228310] pci 0000:04:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.228317] pci 0000:04:00.0: PME# disabled
[ 0.228401] pci 0000:00:15.1: bridge io port: [0xd000-0xdfff]
[ 0.228412] pci 0000:00:15.1: bridge 64bit mmio pref: [0xfe000000-0xfe0fffff]
[ 0.228479] pci 0000:05:00.0: reg 10 64bit mmio: [0xfe900000-0xfe907fff]
[ 0.228557] pci 0000:05:00.0: supports D1 D2
[ 0.228561] pci 0000:05:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.228568] pci 0000:05:00.0: PME# disabled
[ 0.228644] pci 0000:00:15.2: bridge 32bit mmio: [0xfe900000-0xfe9fffff]
[ 0.228680] pci_bus 0000:00: on NUMA node 0
[ 0.228689] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
[ 0.229008] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PE20._PRT]
[ 0.229107] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PE21._PRT]
[ 0.229205] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PE22._PRT]
[ 0.229317] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PCE4._PRT]
[ 0.240117] ACPI: PCI Interrupt Link [LNKA] (IRQs *10 11 14 15)
[ 0.240372] ACPI: PCI Interrupt Link [LNKB] (IRQs *10 11 14 15)
[ 0.240631] ACPI: PCI Interrupt Link [LNKC] (IRQs 10 *11 14 15)
[ 0.240889] ACPI: PCI Interrupt Link [LNKD] (IRQs 10 *11 14 15)
[ 0.241114] ACPI: PCI Interrupt Link [LNKE] (IRQs 10 11 14 15) *0
[ 0.241289] ACPI: PCI Interrupt Link [LNKF] (IRQs 10 11 14 15) *0
[ 0.241463] ACPI: PCI Interrupt Link [LNKG] (IRQs 10 11 14 15) *0
[ 0.241638] ACPI: PCI Interrupt Link [LNKH] (IRQs 10 11 14 15) *0
[ 0.241801] vgaarb: device added: PCI:0000:00:01.0,decodes=io+mem,owns=io+mem,locks=none
[ 0.241822] vgaarb: loaded
[ 0.242006] SCSI subsystem initialized
[ 0.242167] libata version 3.00 loaded.
[ 0.242295] usbcore: registered new interface driver usbfs
[ 0.242324] usbcore: registered new interface driver hub
[ 0.242372] usbcore: registered new device driver usb
[ 0.242578] ACPI: WMI: Mapper loaded
[ 0.242582] PCI: Using ACPI for IRQ routing
[ 0.242845] NetLabel: Initializing
[ 0.242849] NetLabel: domain hash size = 128
[ 0.242851] NetLabel: protocols = UNLABELED CIPSOv4
[ 0.242873] NetLabel: unlabeled traffic allowed by default
[ 0.242922] Switching to clocksource tsc
[ 0.243155] AppArmor: AppArmor Filesystem Enabled
[ 0.243155] pnp: PnP ACPI init
[ 0.243155] ACPI: bus type pnp registered
[ 0.246557] pnp: PnP ACPI: found 11 devices
[ 0.246562] ACPI: ACPI bus type pnp unregistered
[ 0.246568] PnPBIOS: Disabled by ACPI PNP
[ 0.246587] system 00:01: iomem range 0xe0000000-0xefffffff has been reserved
[ 0.246598] system 00:02: ioport range 0x40b-0x40b has been reserved
[ 0.246604] system 00:02: ioport range 0x4d6-0x4d6 has been reserved
[ 0.246609] system 00:02: ioport range 0xc00-0xc01 has been reserved
[ 0.246614] system 00:02: ioport range 0xc14-0xc14 has been reserved
[ 0.246619] system 00:02: ioport range 0xc50-0xc51 has been reserved
[ 0.246624] system 00:02: ioport range 0xc52-0xc52 has been reserved
[ 0.246629] system 00:02: ioport range 0xc6c-0xc6c has been reserved
[ 0.246634] system 00:02: ioport range 0xc6f-0xc6f has been reserved
[ 0.246639] system 00:02: ioport range 0xcd0-0xcd1 has been reserved
[ 0.246644] system 00:02: ioport range 0xcd2-0xcd3 has been reserved
[ 0.246648] system 00:02: ioport range 0xcd4-0xcd5 has been reserved
[ 0.246653] system 00:02: ioport range 0xcd6-0xcd7 has been reserved
[ 0.246658] system 00:02: ioport range 0xcd8-0xcdf has been reserved
[ 0.246662] system 00:02: ioport range 0x800-0x89f has been reserved
[ 0.246668] system 00:02: ioport range 0xb20-0xb3f has been reserved
[ 0.246672] system 00:02: ioport range 0x900-0x90f has been reserved
[ 0.246677] system 00:02: ioport range 0x910-0x91f has been reserved
[ 0.246682] system 00:02: ioport range 0xfe00-0xfefe has been reserved
[ 0.246689] system 00:02: iomem range 0xfec00000-0xfec00fff could not be reserved
[ 0.246694] system 00:02: iomem range 0xfee00000-0xfee00fff has been reserved
[ 0.246700] system 00:02: iomem range 0xfed80000-0xfed8ffff has been reserved
[ 0.246705] system 00:02: iomem range 0xfed61000-0xfed70fff has been reserved
[ 0.246711] system 00:02: iomem range 0xfec10000-0xfec10fff has been reserved
[ 0.246716] system 00:02: iomem range 0xfed00000-0xfed00fff has been reserved
[ 0.246721] system 00:02: iomem range 0xffc00000-0xffffffff has been reserved
[ 0.246730] system 00:03: ioport range 0x290-0x29f has been reserved
[ 0.246741] system 00:07: ioport range 0x4d0-0x4d1 has been reserved
[ 0.246754] system 00:0a: iomem range 0xde000000-0xdfffffff could not be reserved
[ 0.281600] pci 0000:00:04.0: PCI bridge, secondary bus 0000:01
[ 0.281606] pci 0000:00:04.0: IO window: 0xe000-0xefff
[ 0.281614] pci 0000:00:04.0: MEM window: 0xfea00000-0xfeafffff
[ 0.281621] pci 0000:00:04.0: PREFETCH window: 0x000000fe100000-0x000000fe1fffff
[ 0.281630] pci 0000:00:14.4: PCI bridge, secondary bus 0000:02
[ 0.281633] pci 0000:00:14.4: IO window: disabled
[ 0.281641] pci 0000:00:14.4: MEM window: disabled
[ 0.281647] pci 0000:00:14.4: PREFETCH window: disabled
[ 0.281657] pci 0000:00:15.0: PCI bridge, secondary bus 0000:03
[ 0.281660] pci 0000:00:15.0: IO window: disabled
[ 0.281667] pci 0000:00:15.0: MEM window: disabled
[ 0.281673] pci 0000:00:15.0: PREFETCH window: disabled
[ 0.281682] pci 0000:00:15.1: PCI bridge, secondary bus 0000:04
[ 0.281687] pci 0000:00:15.1: IO window: 0xd000-0xdfff
[ 0.281694] pci 0000:00:15.1: MEM window: disabled
[ 0.281700] pci 0000:00:15.1: PREFETCH window: 0x000000fe000000-0x000000fe0fffff
[ 0.281709] pci 0000:00:15.2: PCI bridge, secondary bus 0000:05
[ 0.281713] pci 0000:00:15.2: IO window: disabled
[ 0.281720] pci 0000:00:15.2: MEM window: 0xfe900000-0xfe9fffff
[ 0.281726] pci 0000:00:15.2: PREFETCH window: disabled
[ 0.281747] alloc irq_desc for 16 on node -1
[ 0.281751] alloc kstat_irqs on node -1
[ 0.281761] pci 0000:00:04.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[ 0.281769] pci 0000:00:04.0: setting latency timer to 64
[ 0.281787] pci 0000:00:15.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[ 0.281794] pci 0000:00:15.0: setting latency timer to 64
[ 0.281806] pci 0000:00:15.1: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[ 0.281812] pci 0000:00:15.1: setting latency timer to 64
[ 0.281824] pci 0000:00:15.2: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[ 0.281831] pci 0000:00:15.2: setting latency timer to 64
[ 0.281839] pci_bus 0000:00: resource 0 io: [0x00-0xffff]
[ 0.281844] pci_bus 0000:00: resource 1 mem: [0x000000-0xffffffff]
[ 0.281849] pci_bus 0000:01: resource 0 io: [0xe000-0xefff]
[ 0.281853] pci_bus 0000:01: resource 1 mem: [0xfea00000-0xfeafffff]
[ 0.281858] pci_bus 0000:01: resource 2 pref mem [0xfe100000-0xfe1fffff]
[ 0.281863] pci_bus 0000:02: resource 3 io: [0x00-0xffff]
[ 0.281867] pci_bus 0000:02: resource 4 mem: [0x000000-0xffffffff]
[ 0.281872] pci_bus 0000:04: resource 0 io: [0xd000-0xdfff]
[ 0.281877] pci_bus 0000:04: resource 2 pref mem [0xfe000000-0xfe0fffff]
[ 0.281881] pci_bus 0000:05: resource 1 mem: [0xfe900000-0xfe9fffff]
[ 0.281945] NET: Registered protocol family 2
[ 0.282084] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.282539] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.283153] TCP bind hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.283464] TCP: Hash tables configured (established 131072 bind 65536)
[ 0.283470] TCP reno registered
[ 0.283615] NET: Registered protocol family 1
[ 0.283647] pci 0000:00:01.0: Boot video device
[ 0.385284] Scanning for low memory corruption every 60 seconds
[ 0.385418] audit: initializing netlink socket (disabled)
[ 0.385437] type=2000 audit(1444759242.384:1): initialized
[ 0.396038] highmem bounce pool size: 64 pages
[ 0.396050] HugeTLB registered 4 MB page size, pre-allocated 0 pages
[ 0.398395] VFS: Disk quotas dquot_6.5.2
[ 0.398490] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.399404] fuse init (API version 7.13)
[ 0.399537] msgmni has been set to 1642
[ 0.399891] alg: No test for stdrng (krng)
[ 0.399978] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 0.399983] io scheduler noop registered
[ 0.399987] io scheduler anticipatory registered
[ 0.399990] io scheduler deadline registered
[ 0.400058] io scheduler cfq registered (default)
[ 0.400281] alloc irq_desc for 24 on node -1
[ 0.400285] alloc kstat_irqs on node -1
[ 0.400302] pcieport 0000:00:04.0: irq 24 for MSI/MSI-X
[ 0.400314] pcieport 0000:00:04.0: setting latency timer to 64
[ 0.400478] alloc irq_desc for 25 on node -1
[ 0.400481] alloc kstat_irqs on node -1
[ 0.400494] pcieport 0000:00:15.0: irq 25 for MSI/MSI-X
[ 0.400505] pcieport 0000:00:15.0: setting latency timer to 64
[ 0.400652] alloc irq_desc for 26 on node -1
[ 0.400656] alloc kstat_irqs on node -1
[ 0.400668] pcieport 0000:00:15.1: irq 26 for MSI/MSI-X
[ 0.400679] pcieport 0000:00:15.1: setting latency timer to 64
[ 0.400825] alloc irq_desc for 27 on node -1
[ 0.400829] alloc kstat_irqs on node -1
[ 0.400845] pcieport 0000:00:15.2: irq 27 for MSI/MSI-X
[ 0.400856] pcieport 0000:00:15.2: setting latency timer to 64
[ 0.400974] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 0.401075] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[ 0.401197] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0
[ 0.401203] ACPI: Power Button [PWRB]
[ 0.401273] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input1
[ 0.401277] ACPI: Power Button [PWRF]
[ 0.403405] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.403830] serial 0000:01:00.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[ 0.403841] serial 0000:01:00.0: PCI INT A disabled
[ 0.405398] brd: module loaded
[ 0.406126] loop: module loaded
[ 0.406272] input: Macintosh mouse button emulation as /devices/virtual/input/input2
[ 0.406479] alloc irq_desc for 17 on node -1
[ 0.406484] alloc kstat_irqs on node -1
[ 0.406496] pata_acpi 0000:00:14.1: PCI INT B -> GSI 17 (level, low) -> IRQ 17
[ 0.407012] Fixed MDIO Bus: probed
[ 0.407066] PPP generic driver version 2.4.2
[ 0.407123] tun: Universal TUN/TAP device driver, 1.6
[ 0.407127] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 0.407249] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.407274] ehci_hcd 0000:00:12.2: PCI INT B -> GSI 17 (level, low) -> IRQ 17
[ 0.407301] ehci_hcd 0000:00:12.2: EHCI Host Controller
[ 0.407349] ehci_hcd 0000:00:12.2: new USB bus registered, assigned bus number 1
[ 0.407393] ehci_hcd 0000:00:12.2: debug port 1
[ 0.407424] ehci_hcd 0000:00:12.2: irq 17, io mem 0xfeb45000
[ 0.407517] isapnp: Scanning for PnP cards...
[ 0.456646] ehci_hcd 0000:00:12.2: USB 2.0 started, EHCI 1.00
[ 0.456779] usb usb1: configuration #1 chosen from 1 choice
[ 0.456828] hub 1-0:1.0: USB hub found
[ 0.456842] hub 1-0:1.0: 5 ports detected
[ 0.456941] ehci_hcd 0000:00:13.2: PCI INT B -> GSI 17 (level, low) -> IRQ 17
[ 0.456959] ehci_hcd 0000:00:13.2: EHCI Host Controller
[ 0.457012] ehci_hcd 0000:00:13.2: new USB bus registered, assigned bus number 2
[ 0.457051] ehci_hcd 0000:00:13.2: debug port 1
[ 0.457068] ehci_hcd 0000:00:13.2: irq 17, io mem 0xfeb43000
[ 0.500690] ehci_hcd 0000:00:13.2: USB 2.0 started, EHCI 1.00
[ 0.500801] usb usb2: configuration #1 chosen from 1 choice
[ 0.500842] hub 2-0:1.0: USB hub found
[ 0.500853] hub 2-0:1.0: 5 ports detected
[ 0.500933] ehci_hcd 0000:00:16.2: PCI INT B -> GSI 17 (level, low) -> IRQ 17
[ 0.500949] ehci_hcd 0000:00:16.2: EHCI Host Controller
[ 0.501001] ehci_hcd 0000:00:16.2: new USB bus registered, assigned bus number 3
[ 0.501036] ehci_hcd 0000:00:16.2: debug port 1
[ 0.501052] ehci_hcd 0000:00:16.2: irq 17, io mem 0xfeb40000
[ 0.544672] ehci_hcd 0000:00:16.2: USB 2.0 started, EHCI 1.00
[ 0.544779] usb usb3: configuration #1 chosen from 1 choice
[ 0.544819] hub 3-0:1.0: USB hub found
[ 0.544830] hub 3-0:1.0: 4 ports detected
[ 0.544917] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 0.544936] alloc irq_desc for 18 on node -1
[ 0.544939] alloc kstat_irqs on node -1
[ 0.544948] ohci_hcd 0000:00:12.0: PCI INT A -> GSI 18 (level, low) -> IRQ 18
[ 0.544964] ohci_hcd 0000:00:12.0: OHCI Host Controller
[ 0.545014] ohci_hcd 0000:00:12.0: new USB bus registered, assigned bus number 4
[ 0.545046] ohci_hcd 0000:00:12.0: irq 18, io mem 0xfeb46000
[ 0.636382] usb usb4: configuration #1 chosen from 1 choice
[ 0.636422] hub 4-0:1.0: USB hub found
[ 0.636436] hub 4-0:1.0: 5 ports detected
[ 0.636502] ohci_hcd 0000:00:13.0: PCI INT A -> GSI 18 (level, low) -> IRQ 18
[ 0.636518] ohci_hcd 0000:00:13.0: OHCI Host Controller
[ 0.636574] ohci_hcd 0000:00:13.0: new USB bus registered, assigned bus number 5
[ 0.636596] ohci_hcd 0000:00:13.0: irq 18, io mem 0xfeb44000
[ 0.717252] Freeing initrd memory: 12829k freed
[ 0.727655] usb usb5: configuration #1 chosen from 1 choice
[ 0.727694] hub 5-0:1.0: USB hub found
[ 0.727707] hub 5-0:1.0: 5 ports detected
[ 0.727778] ohci_hcd 0000:00:14.5: PCI INT C -> GSI 18 (level, low) -> IRQ 18
[ 0.727794] ohci_hcd 0000:00:14.5: OHCI Host Controller
[ 0.727840] ohci_hcd 0000:00:14.5: new USB bus registered, assigned bus number 6
[ 0.727863] ohci_hcd 0000:00:14.5: irq 18, io mem 0xfeb42000
[ 0.771547] isapnp: No Plug & Play device found
[ 0.785022] usb usb6: configuration #1 chosen from 1 choice
[ 0.785065] hub 6-0:1.0: USB hub found
[ 0.785078] hub 6-0:1.0: 2 ports detected
[ 0.785141] ohci_hcd 0000:00:16.0: PCI INT A -> GSI 18 (level, low) -> IRQ 18
[ 0.785155] ohci_hcd 0000:00:16.0: OHCI Host Controller
[ 0.785209] ohci_hcd 0000:00:16.0: new USB bus registered, assigned bus number 7
[ 0.785233] ohci_hcd 0000:00:16.0: irq 18, io mem 0xfeb41000
[ 0.845023] usb usb7: configuration #1 chosen from 1 choice
[ 0.845062] hub 7-0:1.0: USB hub found
[ 0.845075] hub 7-0:1.0: 4 ports detected
[ 0.845150] uhci_hcd: USB Universal Host Controller Interface driver
[ 0.845267] PNP: No PS/2 controller found. Probing ports directly.
[ 0.847700] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 0.847712] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 0.847899] mice: PS/2 mouse device common for all mice
[ 0.848078] rtc_cmos 00:05: RTC can wake from S4
[ 0.848136] rtc_cmos 00:05: rtc core: registered rtc_cmos as rtc0
[ 0.848161] rtc0: alarms up to one month, y3k, 114 bytes nvram
[ 0.848321] device-mapper: uevent: version 1.0.3
[ 0.848517] device-mapper: ioctl: 4.15.0-ioctl (2009-04-01) initialised: dm-devel@redhat.com
[ 0.848670] device-mapper: multipath: version 1.1.0 loaded
[ 0.848675] device-mapper: multipath round-robin: version 1.0.0 loaded
[ 0.848869] EISA: Probing bus 0 at eisa.0
[ 0.848911] EISA: Detected 0 cards.
[ 0.848915] cpuidle: using governor ladder
[ 0.848921] cpuidle: using governor menu
[ 0.849540] TCP cubic registered
[ 0.849794] NET: Registered protocol family 10
[ 0.850438] lo: Disabled Privacy Extensions
[ 0.850900] NET: Registered protocol family 17
[ 0.850947] Using IPI No-Shortcut mode
[ 0.851081] registered taskstats version 1
[ 0.851658] rtc_cmos 00:05: setting system clock to 2015-10-13 18:00:43 UTC (1444759243)
[ 0.851664] BIOS EDD facility v0.16 2004-Jun-25, 0 devices found
[ 0.851667] EDD information not available.
[ 0.851802] Freeing unused kernel memory: 620k freed
[ 0.852293] Write protecting the kernel text: 4540k
[ 0.852344] Write protecting the kernel read-only data: 1668k
[ 0.881692] udev: starting version 151
[ 0.930800] vga16fb: initializing
[ 0.930809] vga16fb: mapped to 0xc00a0000
[ 0.930894] fb0: VGA16 VGA frame buffer device
[ 1.052404] r8169 Gigabit Ethernet driver 2.3LK-NAPI loaded
[ 1.052436] r8169 0000:04:00.0: PCI INT A -> GSI 17 (level, low) -> IRQ 17
[ 1.052499] r8169 0000:04:00.0: setting latency timer to 64
[ 1.052507] r8169 0000:04:00.0: unknown MAC, using family default
[ 1.052560] alloc irq_desc for 28 on node -1
[ 1.052564] alloc kstat_irqs on node -1
[ 1.052586] r8169 0000:04:00.0: irq 28 for MSI/MSI-X
[ 1.053596] eth0: RTL8168b/8111b at 0xf8078000, bc:5f:f4:09:e2:79, XID 0c200000 IRQ 28
[ 1.059228] scsi0 : pata_atiixp
[ 1.059523] scsi1 : pata_atiixp
[ 1.061657] ata1: PATA max UDMA/100 cmd 0x1f0 ctl 0x3f6 bmdma 0xf100 irq 14
[ 1.061663] ata2: PATA max UDMA/100 cmd 0x170 ctl 0x376 bmdma 0xf108 irq 15
[ 1.063017] [Firmware Bug]: ACPI: ACPI brightness control misses _BQC function
[ 1.063284] ahci 0000:00:11.0: version 3.0
[ 1.063302] alloc irq_desc for 19 on node -1
[ 1.063307] modprobe:186 freeing invalid memtype fffff000-0
[ 1.063314] alloc kstat_irqs on node -1
[ 1.063326] ahci 0000:00:11.0: PCI INT A -> GSI 19 (level, low) -> IRQ 19
[ 1.063585] ahci 0000:00:11.0: AHCI 0001.0200 32 slots 4 ports 6 Gbps 0xf impl SATA mode
[ 1.063593] ahci 0000:00:11.0: flags: 64bit ncq sntf ilck pm led clo pmp pio slum part sxs
[ 1.063974] acpi device:1a: registered as cooling_device0
[ 1.064178] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input3
[ 1.064313] ACPI: Video Device [VGA] (multi-head: yes rom: no post: no)
[ 1.065124] scsi2 : ahci
[ 1.065358] scsi3 : ahci
[ 1.065514] scsi4 : ahci
[ 1.065666] scsi5 : ahci
[ 1.066389] ata3: SATA max UDMA/133 abar m1024@0xfeb47000 port 0xfeb47100 irq 19
[ 1.066396] ata4: SATA max UDMA/133 abar m1024@0xfeb47000 port 0xfeb47180 irq 19
[ 1.066402] ata5: SATA max UDMA/133 abar m1024@0xfeb47000 port 0xfeb47200 irq 19
[ 1.066407] ata6: SATA max UDMA/133 abar m1024@0xfeb47000 port 0xfeb47280 irq 19
[ 1.212988] usb 5-2: new low speed USB device using ohci_hcd and address 2
[ 1.364055] ata6: SATA link down (SStatus 0 SControl 300)
[ 1.364097] ata4: SATA link down (SStatus 0 SControl 300)
[ 1.364155] ata5: SATA link down (SStatus 0 SControl 300)
[ 1.367821] usb 5-2: configuration #1 chosen from 1 choice
[ 1.504044] usb 4-3: new low speed USB device using ohci_hcd and address 2
[ 1.529999] ata3: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 1.577046] ata3.00: ATA-8: WDC WD3200BEVT-22ZCT0, 11.01A11, max UDMA/133
[ 1.577057] ata3.00: 625142448 sectors, multi 16: LBA48 NCQ (depth 31/32), AA
[ 1.578177] ata3.00: configured for UDMA/133
[ 1.592249] scsi 2:0:0:0: Direct-Access ATA WDC WD3200BEVT-2 11.0 PQ: 0 ANSI: 5
[ 1.592511] sd 2:0:0:0: Attached scsi generic sg0 type 0
[ 1.592667] sd 2:0:0:0: [sda] 625142448 512-byte logical blocks: (320 GB/298 GiB)
[ 1.592762] sd 2:0:0:0: [sda] Write Protect is off
[ 1.592768] sd 2:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 1.592850] sd 2:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 1.593129] sda: sda1 sda2 < sda5 sda6 >
[ 1.613211] sd 2:0:0:0: [sda] Attached SCSI disk
[ 1.629935] usbcore: registered new interface driver hiddev
[ 1.634001] input: Logitech Optical USB Mouse as /devices/pci0000:00/0000:00:13.0/usb5/5-2/5-2:1.0/input/input4
[ 1.634147] generic-usb 0003:046D:C016.0001: input,hidraw0: USB HID v1.10 Mouse [Logitech Optical USB Mouse] on usb-0000:00:13.0-2/input0
[ 1.634185] usbcore: registered new interface driver usbhid
[ 1.634189] usbhid: v2.6:USB HID core driver
[ 1.674526] usb 4-3: configuration #1 chosen from 1 choice
[ 1.681771] input: DELL DELL USB Keyboard as /devices/pci0000:00/0000:00:12.0/usb4/4-3/4-3:1.0/input/input5
[ 1.681911] generic-usb 0003:413C:2005.0002: input,hidraw1: USB HID v1.10 Keyboard [DELL DELL USB Keyboard] on usb-0000:00:12.0-3/input0
[ 1.730143] Console: switching to colour frame buffer device 80x30
[ 1.944048] usb 4-4: new full speed USB device using ohci_hcd and address 3
[ 2.109523] usb 4-4: configuration #1 chosen from 1 choice
[ 2.118584] generic-usb 0003:10CE:EB70.0003: hiddev96,hidraw2: USB HID v1.10 Device [KTURT.LTD] on usb-0000:00:12.0-4/input0
[ 2.226597] xor: automatically using best checksumming function: pIII_sse
[ 2.244010] pIII_sse : 3181.000 MB/sec
[ 2.244014] xor: using function: pIII_sse (3181.000 MB/sec)
[ 2.248534] device-mapper: dm-raid45: initialized v0.2594b
[ 2.459391] EXT4-fs (sda1): mounted filesystem with ordered data mode
[ 10.454393] udev: starting version 151
[ 10.521326] Adding 7825400k swap on /dev/sda5. Priority:-1 extents:1 across:7825400k
[ 10.655192] piix4_smbus 0000:00:14.0: SMBus Host Controller at 0xb00, revision 0
[ 10.704580] lp: driver loaded but no devices found
[ 10.727349] xhci_hcd 0000:05:00.0: PCI INT A -> GSI 18 (level, low) -> IRQ 18
[ 10.727404] xhci_hcd 0000:05:00.0: setting latency timer to 64
[ 10.727411] xhci_hcd 0000:05:00.0: xHCI Host Controller
[ 10.727514] xhci_hcd 0000:05:00.0: new USB bus registered, assigned bus number 8
[ 10.727629] xhci_hcd 0000:05:00.0: irq 18, io mem 0xfe900000
[ 10.727676] usb usb8: config 1 interface 0 altsetting 0 endpoint 0x81 has no SuperSpeed companion descriptor
[ 10.727799] usb usb8: configuration #1 chosen from 1 choice
[ 10.727806] xHCI xhci_add_endpoint called for root hub
[ 10.727810] xHCI xhci_check_bandwidth called for root hub
[ 10.727859] hub 8-0:1.0: USB hub found
[ 10.727882] hub 8-0:1.0: 4 ports detected
[ 10.951632] type=1505 audit(1444759253.597:2): operation="profile_load" pid=629 name="/sbin/dhclient3"
[ 10.951661] type=1505 audit(1444759253.597:3): operation="profile_replace" pid=627 name="/sbin/dhclient3"
[ 10.952128] type=1505 audit(1444759253.600:4): operation="profile_load" pid=627 name="/usr/lib/NetworkManager/nm-dhcp-client.action"
[ 10.952378] type=1505 audit(1444759253.600:5): operation="profile_load" pid=627 name="/usr/lib/connman/scripts/dhclient-script"
[ 10.953281] type=1505 audit(1444759253.600:6): operation="profile_replace" pid=629 name="/usr/lib/NetworkManager/nm-dhcp-client.action"
[ 10.953557] type=1505 audit(1444759253.600:7): operation="profile_replace" pid=629 name="/usr/lib/connman/scripts/dhclient-script"
[ 11.264669] EXT4-fs (sda6): mounted filesystem with ordered data mode
[ 11.699163] type=1505 audit(1444759254.344:8): operation="profile_load" pid=752 name="/usr/share/gdm/guest-session/Xsession"
[ 11.699309] type=1505 audit(1444759254.344:9): operation="profile_replace" pid=753 name="/sbin/dhclient3"
[ 11.699837] type=1505 audit(1444759254.344:10): operation="profile_replace" pid=753 name="/usr/lib/NetworkManager/nm-dhcp-client.action"
[ 11.700256] type=1505 audit(1444759254.348:11): operation="profile_replace" pid=753 name="/usr/lib/connman/scripts/dhclient-script"
[ 11.843790] r8169: eth0: link down
[ 11.844228] ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 12.066886] ppdev: user-space parallel port driver
Last edit: 14 Oct 2015 20:36 by BigJohnT. Reason: add code tags
14 Oct 2015 20:51 - 14 Oct 2015 20:51 #63763
lspci -vv
TryHere's the output for sudo cat /proc/ioports:
lspci -vv
Last edit: 14 Oct 2015 20:51 by andypugh.
- eFalegname
15 Oct 2015 22:53 #63791
by eFalegname
Sorry for delay, I continued to get the "403 Error" and couldn't to access to linuxcnc.org
efalegname@eF-900:~$ sudo lspci -vv
[sudo] password for efalegname:
00:00.0 Host bridge: Advanced Micro Devices [AMD] Device 1510
Subsystem: ASRock Incorporation Device 1510
Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Status: Cap- 66MHz+ UDF- FastB2B- ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 0
00:01.0 VGA compatible controller: ATI Technologies Inc Device 9802
Subsystem: ASRock Incorporation Device 9802
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 0, Cache Line Size: 64 bytes
Interrupt: pin A routed to IRQ 11
Region 0: Memory at c0000000 (32-bit, prefetchable) [size=256M]
Region 1: I/O ports at f000 [size=256]
Region 2: Memory at feb00000 (32-bit, non-prefetchable) [size=256K]
Capabilities: [50] Power Management version 3
Flags: PMEClk- DSI- D1+ D2+ AuxCurrent=0mA PME(D0-,D1-,D2-,D3hot-,D3cold-)
Status: D0 PME-Enable- DSel=0 DScale=0 PME-
Capabilities: [58] Express (v2) Root Complex Integrated Endpoint, MSI 00
DevCap: MaxPayload 128 bytes, PhantFunc 0, Latency L0s <4us, L1 unlimited
ExtTag+ RBE+ FLReset-
DevCtl: Report errors: Correctable- Non-Fatal- Fatal- Unsupported-
RlxdOrd+ ExtTag- PhantFunc- AuxPwr- NoSnoop+
MaxPayload 128 bytes, MaxReadReq 128 bytes
DevSta: CorrErr- UncorrErr- FatalErr- UnsuppReq- AuxPwr- TransPend-
LnkCap: Port #0, Speed unknown, Width x0, ASPM unknown, Latency L0 <64ns, L1 <1us
ClockPM- Suprise- LLActRep- BwNot-
LnkCtl: ASPM Disabled; Disabled- Retrain- CommClk-
ExtSynch- ClockPM- AutWidDis- BWInt- AutBWInt-
LnkSta: Speed unknown, Width x0, TrErr- Train- SlotClk- DLActive- BWMgmt- ABWMgmt-
Capabilities: [a0] Message Signalled Interrupts: Mask- 64bit+ Queue=0/0 Enable-
Address: 0000000000000000 Data: 0000
Capabilities: [100] Vendor Specific Information <?>
00:01.1 Audio device: ATI Technologies Inc Device 1314
Subsystem: ASRock Incorporation Device 1314
Interrupt: pin B routed to IRQ 19
Region 0: Memory at feb44000 (32-bit, non-prefetchable) [size=16K]
Kernel driver in use: HDA Intel
Kernel modules: snd-hda-intel
00:04.0 PCI bridge: Advanced Micro Devices [AMD] Device 1512
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
I/O behind bridge: 0000e000-0000efff
Memory behind bridge: fea00000-feafffff
Prefetchable memory behind bridge: 00000000d0100000-00000000d01fffff
Secondary status: 66MHz- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- <SERR- <PERR-
BridgeCtl: Parity- SERR- NoISA- VGA- MAbort- >Reset- FastB2B-
PriDiscTmr- SecDiscTmr- DiscTmrStat- DiscTmrSERREn-
Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0+,D1-,D2-,D3hot+,D3cold+)
Capabilities: [58] Express (v2) Root Port (Slot+), MSI 00
DevCap: MaxPayload 128 bytes, PhantFunc 0, Latency L0s <64ns, L1 <1us
RlxdOrd- ExtTag- PhantFunc- AuxPwr- NoSnoop+
MaxPayload 128 bytes, MaxReadReq 512 bytes
LnkCap: Port #1, Speed 5GT/s, Width x4, ASPM L0s L1, Latency L0 <64ns, L1 <1us
ClockPM- Suprise- LLActRep+ BwNot+
LnkCtl: ASPM Disabled; RCB 64 bytes Disabled- Retrain- CommClk+
LnkSta: Speed 2.5GT/s, Width x1, TrErr- Train- SlotClk+ DLActive+ BWMgmt+ ABWMgmt-
SltCap: AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug+ Surpise-
Slot # 4, PowerLimit 75.000000; Interlock- NoCompl+
SltCtl: Enable: AttnBtn- PwrFlt- MRL- PresDet- CmdCplt- HPIrq- LinkChg-
Control: AttnInd Unknown, PwrInd Unknown, Power- Interlock-
SltSta: Status: AttnBtn- PowerFlt- MRL- CmdCplt- PresDet+ Interlock-
Changed: MRL- PresDet- LinkState-
RootCtl: ErrCorrectable- ErrNon-Fatal- ErrFatal- PMEIntEna- CRSVisible-
RootCap: CRSVisible-
RootSta: PME ReqID 0000, PMEStatus- PMEPending-
Capabilities: [a0] Message Signalled Interrupts: Mask- 64bit+ Queue=0/0 Enable+
Address: 00000000fee0300c Data: 4151
Capabilities: [b0] Subsystem: ASRock Incorporation Device 1512
Capabilities: [b8] HyperTransport: MSI Mapping Enable+ Fixed+
Kernel driver in use: pcieport
Kernel modules: shpchp
00:11.0 SATA controller: ATI Technologies Inc SB700/SB800 SATA Controller [IDE mode] (rev 40) (prog-if 01)
Subsystem: ASRock Incorporation Device 4390
Status: Cap+ 66MHz+ UDF- FastB2B- ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 32
Interrupt: pin A routed to IRQ 19
Region 0: I/O ports at f190 [size=8]
Region 1: I/O ports at f180 [size=4]
Region 2: I/O ports at f170 [size=8]
Region 3: I/O ports at f160 [size=4]
Region 4: I/O ports at f150 [size=16]
Region 5: Memory at feb4f000 (32-bit, non-prefetchable) [size=1K]
Capabilities: [70] SATA HBA <?>
Capabilities: [a4] PCIe advanced features <?>
Kernel driver in use: ahci
Kernel modules: ahci
00:12.0 USB Controller: ATI Technologies Inc SB700/SB800 USB OHCI0 Controller (prog-if 10)
Subsystem: ASRock Incorporation Device 4397
Status: Cap- 66MHz+ UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 32, Cache Line Size: 64 bytes
Interrupt: pin A routed to IRQ 18
Region 0: Memory at feb4e000 (32-bit, non-prefetchable) [size=4K]
Kernel driver in use: ohci_hcd
00:12.2 USB Controller: ATI Technologies Inc SB700/SB800 USB EHCI Controller (prog-if 20)
Subsystem: ASRock Incorporation Device 4396
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV+ VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Status: Cap+ 66MHz+ UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Interrupt: pin B routed to IRQ 17
Region 0: Memory at feb4d000 (32-bit, non-prefetchable) [size=256]
Capabilities: [c0] Power Management version 2
Flags: PMEClk- DSI- D1+ D2+ AuxCurrent=0mA PME(D0+,D1+,D2+,D3hot+,D3cold-)
Status: D0 PME-Enable- DSel=0 DScale=0 PME+
Bridge: PM- B3+
Capabilities: [e4] Debug port: BAR=1 offset=00e0
Kernel driver in use: ehci_hcd
00:13.0 USB Controller: ATI Technologies Inc SB700/SB800 USB OHCI0 Controller (prog-if 10)
Region 0: Memory at feb4c000 (32-bit, non-prefetchable) [size=4K]
00:13.2 USB Controller: ATI Technologies Inc SB700/SB800 USB EHCI Controller (prog-if 20)
Region 0: Memory at feb4b000 (32-bit, non-prefetchable) [size=256]
Bridge: PM- B3+
00:14.0 SMBus: ATI Technologies Inc SBx00 SMBus Controller (rev 42)
Subsystem: ASRock Incorporation Device 4385
Control: I/O+ Mem+ BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
Kernel driver in use: piix4_smbus
Kernel modules: i2c-piix4
00:14.1 IDE interface: ATI Technologies Inc SB700/SB800 IDE Controller (rev 40) (prog-if 8a [Master SecP PriP])
Subsystem: ASRock Incorporation Device 439c
Latency: 32
Region 0: I/O ports at 01f0 [size=8]
Region 1: I/O ports at 03f4 [size=1]
Region 2: I/O ports at 0170 [size=8]
Region 3: I/O ports at 0374 [size=1]
Region 4: I/O ports at f100 [size=16]
Kernel driver in use: pata_atiixp
Kernel modules: pata_atiixp
00:14.2 Audio device: ATI Technologies Inc SBx00 Azalia (Intel HDA) (rev 40)
Subsystem: ASRock Incorporation Device 1892
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=slow >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Interrupt: pin ? routed to IRQ 16
Region 0: Memory at feb40000 (64-bit, non-prefetchable) [size=16K]
Capabilities: [50] Power Management version 2
Flags: PMEClk- DSI- D1- D2- AuxCurrent=55mA PME(D0+,D1-,D2-,D3hot+,D3cold+)
00:14.3 ISA bridge: ATI Technologies Inc SB700/SB800 LPC host controller (rev 40)
Subsystem: ASRock Incorporation Device 439d
Control: I/O+ Mem+ BusMaster+ SpecCycle+ MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Latency: 0
00:14.4 PCI bridge: ATI Technologies Inc SBx00 PCI to PCI Bridge (rev 40) (prog-if 01)
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop+ ParErr- Stepping- SERR- FastB2B- DisINTx-
Latency: 64
Bus: primary=00, secondary=02, subordinate=02, sec-latency=64
Secondary status: 66MHz- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort+ <SERR- <PERR-
00:14.5 USB Controller: ATI Technologies Inc SB700/SB800 USB OHCI2 Controller (prog-if 10)
Subsystem: ASRock Incorporation Device 4399
Interrupt: pin C routed to IRQ 18
Region 0: Memory at feb4a000 (32-bit, non-prefetchable) [size=4K]
00:15.0 PCI bridge: ATI Technologies Inc Device 43a0
Bus: primary=00, secondary=03, subordinate=03, sec-latency=0
Capabilities: [58] Express (v2) Root Port (Slot-), MSI 00
LnkCap: Port #247, Speed 2.5GT/s, Width x1, ASPM L0s L1, Latency L0 <64ns, L1 <1us
LnkCtl: ASPM Disabled; RCB 64 bytes Disabled- Retrain- CommClk-
LnkSta: Speed unknown, Width x16, TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
Address: 00000000fee0300c Data: 4159
Capabilities: [b0] Subsystem: ATI Technologies Inc Device 0000
00:15.1 PCI bridge: ATI Technologies Inc Device 43a1
Bus: primary=00, secondary=04, subordinate=04, sec-latency=0
I/O behind bridge: 0000d000-0000dfff
Prefetchable memory behind bridge: 00000000d0000000-00000000d00fffff
Secondary status: 66MHz- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort+ <SERR- <PERR-
LnkCap: Port #1, Speed 5GT/s, Width x1, ASPM L0s L1, Latency L0 <64ns, L1 <1us
Address: 00000000fee0300c Data: 4161
00:15.2 PCI bridge: ATI Technologies Inc Device 43a2
Bus: primary=00, secondary=05, subordinate=05, sec-latency=0
Memory behind bridge: fe900000-fe9fffff
LnkCap: Port #2, Speed 5GT/s, Width x1, ASPM L0s L1, Latency L0 <64ns, L1 <1us
LnkSta: Speed 5GT/s, Width x1, TrErr- Train- SlotClk+ DLActive+ BWMgmt+ ABWMgmt+
Address: 00000000fee0300c Data: 4169
00:16.0 USB Controller: ATI Technologies Inc SB700/SB800 USB OHCI0 Controller (prog-if 10)
Region 0: Memory at feb49000 (32-bit, non-prefetchable) [size=4K]
00:16.2 USB Controller: ATI Technologies Inc SB700/SB800 USB EHCI Controller (prog-if 20)
Region 0: Memory at feb48000 (32-bit, non-prefetchable) [size=256]
Bridge: PM- B3+
00:18.0 Host bridge: Advanced Micro Devices [AMD] Device 1700 (rev 43)
Control: I/O- Mem- BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
00:18.1 Host bridge: Advanced Micro Devices [AMD] Device 1701
Status: Cap- 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
00:18.2 Host bridge: Advanced Micro Devices [AMD] Device 1702
00:18.3 Host bridge: Advanced Micro Devices [AMD] Device 1703
Capabilities: [f0] Secure device <?>
00:18.4 Host bridge: Advanced Micro Devices [AMD] Device 1704
00:18.5 Host bridge: Advanced Micro Devices [AMD] Device 1718
00:18.6 Host bridge: Advanced Micro Devices [AMD] Device 1716
00:18.7 Host bridge: Advanced Micro Devices [AMD] Device 1719
01:00.0 Serial controller: Device 1c00:3250 (rev 10) (prog-if 05)
Subsystem: Device 1c00:3250
Control: I/O+ Mem+ BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Interrupt: pin A routed to IRQ 16
Region 0: I/O ports at e000 [size=256]
Region 1: Memory at d0100000 (32-bit, prefetchable) [size=32K]
Region 2: I/O ports at e100 [size=4]
Expansion ROM at fea00000 [disabled] [size=32K]
Capabilities: [60] Power Management version 3
Flags: PMEClk- DSI- D1- D2- AuxCurrent=375mA PME(D0+,D1-,D2-,D3hot+,D3cold+)
Capabilities: [68] Message Signalled Interrupts: Mask+ 64bit+ Queue=0/5 Enable-
Masking: 00000000 Pending: 00000000
Capabilities: [80] Express (v2) Legacy Endpoint, MSI 00
DevCap: MaxPayload 256 bytes, PhantFunc 0, Latency L0s <2us, L1 <32us
ExtTag- AttnBtn- AttnInd- PwrInd- RBE+ FLReset-
DevSta: CorrErr+ UncorrErr- FatalErr- UnsuppReq+ AuxPwr+ TransPend-
LnkCap: Port #0, Speed 2.5GT/s, Width x1, ASPM L0s L1, Latency L0 unlimited, L1 unlimited
ClockPM+ Suprise- LLActRep- BwNot-
LnkSta: Speed 2.5GT/s, Width x1, TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
Capabilities: [100] Advanced Error Reporting <?>
04:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168B PCI Express Gigabit Ethernet controller (rev 06)
Subsystem: ASRock Incorporation Device 8168
Interrupt: pin A routed to IRQ 28
Region 0: I/O ports at d000 [size=256]
Region 2: Memory at d0004000 (64-bit, prefetchable) [size=4K]
Region 4: Memory at d0000000 (64-bit, prefetchable) [size=16K]
Capabilities: [40] Power Management version 3
Flags: PMEClk- DSI- D1+ D2+ AuxCurrent=375mA PME(D0+,D1+,D2+,D3hot+,D3cold+)
Capabilities: [50] Message Signalled Interrupts: Mask- 64bit+ Queue=0/0 Enable+
Address: 00000000fee0100c Data: 4189
Capabilities: [70] Express (v2) Endpoint, MSI 01
DevCap: MaxPayload 256 bytes, PhantFunc 0, Latency L0s <512ns, L1 <64us
RlxdOrd- ExtTag- PhantFunc- AuxPwr- NoSnoop-
MaxPayload 128 bytes, MaxReadReq 4096 bytes
LnkCap: Port #0, Speed 2.5GT/s, Width x1, ASPM L0s L1, Latency L0 <512ns, L1 <64us
Capabilities: [b0] MSI-X: Enable- Mask- TabSize=4
Vector table: BAR=4 offset=00000000
PBA: BAR=4 offset=00000800
Capabilities: [d0] Vital Product Data <?>
Capabilities: [140] Virtual Channel <?>
Capabilities: [160] Device Serial Number 00-e0-4c-68-00-00-00-01
Kernel driver in use: r8169
Kernel modules: r8169
05:00.0 USB Controller: Device 1b6f:7023 (rev 01) (prog-if 30)
Subsystem: ASRock Incorporation Device 7023
Region 0: Memory at fe900000 (64-bit, non-prefetchable) [size=32K]
Flags: PMEClk- DSI- D1+ D2+ AuxCurrent=0mA PME(D0+,D1+,D2+,D3hot+,D3cold+)
Capabilities: [70] Message Signalled Interrupts: Mask+ 64bit+ Queue=0/2 Enable-
Capabilities: [a0] Express (v2) Endpoint, MSI 00
DevCap: MaxPayload 1024 bytes, PhantFunc 0, Latency L0s <64ns, L1 <1us
ExtTag+ AttnBtn- AttnInd- PwrInd- RBE+ FLReset+
RlxdOrd- ExtTag- PhantFunc- AuxPwr- NoSnoop+ FLReset-
DevSta: CorrErr- UncorrErr- FatalErr- UnsuppReq- AuxPwr+ TransPend-
LnkCap: Port #0, Speed 5GT/s, Width x1, ASPM L0s L1, Latency L0 <1us, L1 <64us
LnkSta: Speed 5GT/s, Width x1, TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
Capabilities: [190] Device Serial Number 01-01-01-01-01-01-01-01
Kernel driver in use: xhci_hcd
Kernel modules: xhciPlease Log in or Create an account to join the conversation.
Time to create page: 0.635 seconds
