1. I tried to check the parallel port of my computer.
The input are all on when the 7i90 is power on.
And only the input 10 is on when the 7i90 is power off.
Is that normal?
2. I tried to communicate with the card using LINUXCNC.
So I select the 7i90 on the LINUXCNC UI.
The error shows as follows
root@LinuxCNC-terry:/home/atech# linuxcnc
LINUXCNC - 2.7.14
Machine configuration directory is '/usr/share/doc/linuxcnc/examples/sample-configs/by_interface/mesa/hm2-stepper'
Machine configuration file is '7i90.ini'
Starting LinuxCNC...
Found file(REL): ./hm2-stepper.hal
Error: could not insert module /usr/realtime-3.4-9-rtai-686-pae/modules/linuxcnc/hm2_7i90.ko: Input/output error
./hm2-stepper.hal:38: exit value: 1
./hm2-stepper.hal:38: insmod for hm2_7i90 failed, returned -1
See the output of 'dmesg' for more information.
LinuxCNC terminated with an error. You can find more information in the log:
/root/linuxcnc_debug.txt
and
/root/linuxcnc_print.txt
as well as in the output of the shell command 'dmesg' and in the terminal
Do anyone know what is wrong by 1&2 ?
Or what can I test to find what is wrong during the operation.
