Can Asus Tinker Board run LINUXCNC
6 years 11 months ago #149691 by tommylight
That has to be compiled and installed before use, did you do that?
The following user(s) said Thank You: terry1992
6 years 11 months ago #149700 by terry1992
I have do the halcompile command before.
The result are
atech@tinkerboard:~/linuxcnc-dev/src$ halcompile --install ./hm2_tkboard.c Compiling realtime hm2_tkboard.c Linking hm2_tkboard.so cp hm2_tkboard.so /home/atech/linuxcnc-dev/rtlib/
Do it means the compile is already done? Or there are something I have to do before I tried to do the loadrt command?
6 years 11 months ago #149758 by andypugh
No, that has installed and compiled.
It has also, fairly clearly, run. It has got as far as talking to the Mesa card but has not seen the response expected. I would suspect an issue with physical wiring, or possibly the SPI needs enabling in firmware? This certainly needs to be done with the Pi.
6 years 11 months ago #149759 by andypugh
Reading between the lines here: tinkerboarding.co.uk/forum/thread-85-post-1285.html
You may need to edit /boot/hw_intf.conf
6 years 11 months ago #149760 by andypugh
Has anyone tried the Tinkerboard with the 7C80 or 7C81?
6 years 11 months ago #149772 by PCW
The 7C80 or 7C81 should be identical in behavior to a 7I90 as far as the SPI interface goes, The fact that mesaflash works suggest you have the correct SPI wiring (unless the driver uses a different port)
Are you sure the driver is a hal component? That seems a bit odd
Time to create page: 0.093 seconds
