Raspberry Pi 4
01 Sep 2019 04:37 #143757 by skunkworks
Replied by skunkworks on topic Raspberry Pi 4
using andy's image..
01 Sep 2019 10:23 #143769 by Mike_Eitel
Replied by Mike_Eitel on topic Raspberry Pi 4
For cooling
Not yet found time to test.
de.aliexpress.com/item/4000001902776.html
de.aliexpress.com/item/4000035147489.html
Bought the active one and assembly was easy together with controler:
de.aliexpress.com/item/4000051492209.html
This is interesting device, not yet run successfully myself, but using the p3 ssd version.
01 Sep 2019 11:08 #143770 by Gene1934
Replied by Gene1934 on topic Raspberry Pi 4
For cooling
Would be nice if I could find the English pages. But the last time I ordered from alliexpress, my card was charged, but a small backorder hasn't arrived in something like 3 years. No attempt to contact has been successfull. Banggod OTOH has worked well. But they don't have a working search.
Since I already have a fan on the pi3, that passive kit looks good, as does the sata adaptor and the mini-hdmi. What button do I click to get english?
Thanks.
Cheers, Gene Heskett
"There are four boxes to be used in defense of liberty:
soap, ballot, jury, and ammo. Please use in that order."
-Ed Howdershelt (Author)
Genes Web page <geneslinuxbox.net:6309/gene>
01 Sep 2019 11:40 #143771 by Mike_Eitel
On the right top corner I can choose the country.
I've done lots of orders and had few problems. Opening dispute solved all.
This shop until now, was always reliable and fast.. To Switzerland. ;-)
01 Sep 2019 11:43 #143772 by Gene1934
Those patches won't copy/paste here.
Can you fwd them to <This email address is being protected from spambots. You need JavaScript enabled to view it.>, or post them in a downloadable format?
Thanks.
01 Sep 2019 12:01 #143773 by Mike_Eitel
Patches?
In case you meant me:
Here a link on the global www
www.aliexpress.com/item/4000051492209.html
01 Sep 2019 12:06 #143774 by Gene1934
gah, can't get it out of German, nor can I find the add to cart button.
Thanks Mike.
01 Sep 2019 12:11 #143776 by svanteg
Replied by svanteg on topic Raspberry Pi 4
Just to report back that the rpi4 is now hooked up and driving the mill. Made a bridge card between the rpi4 and the 7i90 and it’s happy and stable at 31.25MHz. Have made a few parts and no hm2 issues...but some due to running latest linuxcnc master and some due to the rt kernel. Most annoying is that usb seems slightly wonky and can glitch. Hung up once when jogging down... :ohmy:
I’d say it’s ok if you know what you’re doing. I’ll get a pendant hardwired into the 7i90 which will reduce the need to use mouse & keyboard.
01 Sep 2019 12:15 #143777 by Mike_Eitel
Just search geekworm.com
01 Sep 2019 12:33 #143778 by Gene1934
Its still 90% German here. FF problem? Likely
Thanks Mike
Time to create page: 0.492 seconds
