Raspberry Pi 4
- Gene1934
- Thank you received: 13
16 Sep 2019 20:32 #145340
by Gene1934
Cheers, Gene Heskett
"There are four boxes to be used in defense of liberty:
soap, ballot, jury, and ammo. Please use in that order."
-Ed Howdershelt (Author)
Genes Web page <geneslinuxbox.net:6309/gene>
Replied by Gene1934 on topic Raspberry Pi 4
maybe true, Peter, but the terminal strips on the 7i42TA's sure make hookup a lot easier.
But I was reading switching noises from the motor drivers in excess of 40 volts, on a gigahertz sampler scope and that toasted more than one 7i90HD. I'm on my 3rd one now, In fact I'm down to 2 working stepper drivers on the 7i90HD I have at the bottom of that stack of 7i42TA's now.
But in installing the 7i42TA's, something changed and those noises are only a few hundred millivolts now.
Thanks Peter.
Thanks Peter.
- Spacehitchhiker42
17 Sep 2019 02:52 - 17 Sep 2019 02:59 #145369
by Spacehitchhiker42
Replied by Spacehitchhiker42 on topic Raspberry Pi 4
Good to know about the input protection. I just got finished getting my fpga board to communicate with linuxcnc.
As far as my touchscreen goes, I'm using a NCR RealPos ( rather unfortunate name) monitor. It cost me $25 on ebay plus about $5 for the parts on the adapter board for breaking out usb on the monitor and power for the monitor, RPi and fpga
Last edit: 17 Sep 2019 02:59 by Spacehitchhiker42.
- Spacehitchhiker42
17 Sep 2019 03:02 - 17 Sep 2019 03:08 #145370
Last edit: 17 Sep 2019 03:08 by Spacehitchhiker42.
- cakeslob
- Thank you received: 278
21 Sep 2019 18:41 - 21 Sep 2019 18:42 #145774
by cakeslob
Replied by cakeslob on topic Raspberry Pi 4
Can you guys please help me out with this?
I have
an Rpi4,
the premade image from andy loaded on it running the preempt kernel 4.19.58-rt22-v7l
a mesa 7c81 card
peter sent me updated drivers for hm2_rpspi.c , spi_common_rpspi, and an updated pins.c (attatched)
the drivers are updated for the 2 new rpi boards and for the rpi4 bcm_2711
i can connect to the card in mesaflsh and get a bunch of info from it, but with my limited knowledge/understanding of the mesaflash syntax i really only know how to do readhmid and get the pins
my config file is just the 7i90 file but i changed driver:hm2_rpspi and board:7c81
Im at the point where im stuck and i dont know what im doing wrong. the rpspi driver is updated to include the 7c81 but i still cant get it to recognize the board. I have included the report/info along with the updated drivers. if anyone could point me in the right direction that would be a big help
linuxcncsvr
Found file(REL): ./hm2-stepper.hal
hm2: unloading
Debug file information:
Note: Using POSIX realtime
hm2_rpspi: Unknown board at SPI0/CE0: MESA7C81
hm2_rpspi: rtapi_app_main: Operation not permitted (-1)
./hm2-stepper.hal:38: waitpid failed /home/pi/linuxcnc-rp10/bin/rtapi_app hm2_rpspi
./hm2-stepper.hal:38: /home/pi/linuxcnc-rp10/bin/rtapi_app exited without becoming ready
./hm2-stepper.hal:38: insmod for hm2_rpspi failed, returned -1
17664
Stopping realtime threads
Unloading hal components
hm2_rpspi: not loaded
<commandline>:0: exit value: 255
I have
an Rpi4,
a mesa 7c81 card
linuxcncsvr
hm2: unloading
17664
Last edit: 21 Sep 2019 18:42 by cakeslob.
- Thank you received: 5274
21 Sep 2019 19:09 #145780
Replied by PCW on topic Raspberry Pi 4
Are you sure you are running the newly compiled LinuxCNC version?
Is this a RIP installation?
Here's what I get with a 7C81 on a RPI3:
- Thank you received: 4642
21 Sep 2019 21:39 #145793
Replied by andypugh on topic Raspberry Pi 4
It looks like master only knows about the 7i90:
github.com/LinuxCNC/linuxcnc/blob/master...ot2/hm2_rpspi.c#L860
are you using hm2_rpspi or hm2_spi ?
21 Sep 2019 23:24 #145798
I have a patched hm2_rpspi.c that adds support for the 7C80 and 7C81
22 Sep 2019 00:25 #145802
Is there any reason not to have that merged to the main distribution?
- Gene1934
22 Sep 2019 00:33 #145804
by Gene1934
I have sources from Bertho that should run on a pi4. But I just now emailed him with the thought of renaming them to hm2_rp3spi.ko for the pi3's, and hm2_rp4spi.ko for the rpi4's. AIUI, the diff is the base address of the gpio array. Perhaps you and Bertho could get together and we'd then have a driver for all 3 cards, in both rpi3 and rpi4 flavors.
Thanks PCW
Thanks PCW
22 Sep 2019 01:35 #145808
It probably should be be merged along with some other changes I've made to support 7C80,7C81,7I94,7I95,7I97
Time to create page: 0.222 seconds
