Raspberry Pi 4
6 years 8 months ago #158220 by MrGreg
Replied by MrGreg on topic Raspberry Pi 4
Hello Gene
Tried the self installing RT, initially on a Pi3 and then on a Pi4. on a new 32GB SD ( don't have a 64 )
The extract failed ( due to problems of previous errors? it said) There was a massive amount of output so I could not scroll back far enough to identify what the errors were.
Guess it is possible I have a corrupted file? Do you have a sha or md I can check with?
Cheers
MrGreg
6 years 8 months ago #158223 by Gene1934
Replied by Gene1934 on topic Raspberry Pi 4
MrGreg wrote: Hello Gene
Cheers
MrGreg
You can add to the shells history from one of its pull-downs, 10k ought to be enough.
sha512sum is of rt-kernel.tgz is
7a8c62a171bd2a24f87635dd0b910a49acc9b99e0878698fabbab57b2f9aebd771911851599dd84e44eec55a973b5d02075eb0a4379136a868d09fa991638ded
I hope this helps
Cheers, Gene Heskett
"There are four boxes to be used in defense of liberty:
soap, ballot, jury, and ammo. Please use in that order."
-Ed Howdershelt (Author)
Genes Web page < geneslinuxbox.net:6309/gene >
6 years 8 months ago #158232 by MrGreg
Hello again
The sha is good.
Hitting a permissions issue:
Lots of......
boot/bcm2708-rpi-b.dtb
tar: boot/bcm2708-rpi-b.dtb: Cannot change ownership to uid 1000, gid 1000: Operation not permitted
boot/bcm2708-rpi-b-plus.dtb
Did a chmod 755 on it but still get the same extraction error even when root@
Cheers
MrGreg
6 years 8 months ago #158245 by Gene1934
MrGreg wrote: Hello again
The sha is good.
Lots of......
Cheers
MrGreg
My install was from the big image, done by a root session of mc. So everything in /boot is marked root:root.
boot itself as we see it, is a fat32 filesystem hiding behind an ext4 directory structure. And the fat32 has no facility for changing ownerships. So while its not jack sh-- to the pi, ownership is moot. So while it was all built here as the user pi, let me try something, as in making the unpacked tree, there are 2 in that tgz, /boot/, and /lib/ all owned by root, and regenerate the .tgz.
I had zero such problems installing it from the 2.5Gig archive. All of which was built by the user pi, so its all owned by pi. So, will it unpack if placed in /tmp?
if so, then you might try "sudo chown -R root:root boot" and repeat for lib.. If that works then cd boot;
sudo cp -rd * /boot/
cd ../lib
sudo cp -dr * /lib/
cd ../overlays
sudo cp -d * /boot/overlays/
cd ..
sudo cp -d bcm* /boot/
add the following entry to /boot/config.txt useing nano as root:
cd /boot
nano config.txt and add:
kernel=kernel7i-rt.img
ctrl+x,y to save and exit nano
This last isn't done by my package, I'd forgotten that detail. I'll put that in the README
Now you should be able to reboot the pi,, and a uname -a should print something like:
Linux rpi4.coyote.den 4.19.71-rt24-v7l+ #1 SMP PREEMPT RT Thu Feb 6 07:09:18 EST 2020 armv7l GNU/Linux
Let me know if this fails. In the meantime I'll see if I can fix the .tgz and rebuild it.
6 years 8 months ago #158249 by MrGreg
Hello again
This on Pi3, Pi4 is busy atm
I sort of jumped the gun a bit... :)
I extracted locally and copied / overwrote contents to boot & lib (modules) back in to RFS
Also checked out config.txt and put ( the only rt obviously available)
(As the orig 4.19.9x was still the default boot)
It booted up OK with the 4.19.71RT reported by uname -a
Re ran the rt-tests with
cyclictest -n -p 90 -i 1000
Rather disappointing results. Got latency of circa 480uS after heavy loading of over 30 mins or so.
I will wipe, start over and re run according to your suggestion/instruction Might well be missing some of the optimisation detail given my quick and dirty kludge ?
Cheers & thanks
MrGreg
6 years 8 months ago #158268 by Gene1934
Where do I get that? I use latency-test from the linuxcnc package. And lightly loaded on an rpi4, I am getting less than 10 u-secs.
Cheers & thanks
MrGreg
Did you run raspi-config and enable the new video? I think it lowers latency even on the pi3. But this kernel is built for a pi4, not a pi3, which I've not tried with this kernel.
Take care now, MrGreg
Time to create page: 0.415 seconds
