Raspberry Pi 4
6 years 8 months ago #158272 by tjtr33
Replied by tjtr33 on topic Raspberry Pi 4
Gene heelo
I downloaded the kernel img...
oops it changed again on 22 feb so my original thought is not up-to-date
anyway
I think you should supply the config.txt and cmdline.txt
so other users can duplicate your setup.
Because I already got the previous incarnattion (~4days ago )
and supplied what i thought were like your config.txt cmdline.txt
( which wsa isolcpus-3, no mention of idle=poll ..
thats as close as i can guess from your posts ..)
and got > 54uS right away, 4 tests,
no time to add any other processes for extra load,
and 4 cold boot retires)
so, i think there is something missing,
something outide of geneslinuxbox.net:6309/gene/lathe-stf/li...c4pi4b/rt-kernel.tgz
May be you have a low rez monitor? mine is 1380x??? not on rpinow ;-9
I appreciate your work, i just dont get the expected results.
thx
tomp
6 years 8 months ago #158273 by tjtr33
Hello,
I also used PiCNC on an rpi3b.
What problems do you find using it for rpi4/buster?
Its a great idea but the SPI is limited to thread speed
so its like the speed issues of the parallel port.
thx
tomp
6 years 8 months ago #158281 by Gene1934
Replied by Gene1934 on topic Raspberry Pi 4
tjtr33 wrote: Gene heelo
Its not, its all root:root internally now
anyway
thx
tomp
Done, and I also updated the sha512sum for rt-kernel.tgz And I should emphasize that this is for an rpi4b and likely will perform poorly on an rpi3b, and that I don't have a latency-test other than the one that comes with LinuxCNC My monitor is a 1920x1080
Since I am not running LCNC with a base thread, use
'latency-test period'
which will complain about the missing variable, but it will run it without a useless base thread. Here its the servo-thread that counts, but be aware in this $config, there is a 200 hertz slow thread that runs the jogging stuff.
I should pack up the linuxcnc/$config dir and post it so others might see what sort of gingerbread I have added to axis, the gui, and maybe put up a screenshot in case it won't just run on your hardware. So look for those additions later tonight. Since apache2 runs in a sandbox, I have to chown it all to me while I'm making those additions, them put it back.
Take care TomP.
Cheers, Gene Heskett
"There are four boxes to be used in defense of liberty:
soap, ballot, jury, and ammo. Please use in that order."
-Ed Howdershelt (Author)
Genes Web page < geneslinuxbox.net:6309/gene >
6 years 8 months ago #158283 by Gene1934
the spi transmits 32 bit packets at about 40 megabits/sec and rx's the 32 bit packets at 25 megabits/second. Running a 1 kilohertz servo thread, there's time to sendand rx more than 1 packet per thread execution. That's why my 26 pin cable is under 2" long, the pi is mounted upside down with a small fan under it. No twists in a cable that is actually a transmission line that way. It reports those clocking rates as its starting up linuxcnc
As for picnc, I've not heard of it till tonight, describe it please.
The config and a screen snapshot.png are now pull-able.
Take care TomP
6 years 8 months ago #158291 by tjtr33
Hi Gene,
will try your newest asap.
re PiCNC
its a hdwr stepgen for linuxcnc using a simple (hahah) chip
here's the original 3 axis version
github.com/kinsamanka/PICnc-V2/wiki
and here's a 5 axis branch
github.com/Wireb/PICnc-5axis
I talked about using it here
wiki.linuxcnc.org/cgi-bin/wiki.pl?RPi3BPreemptRT
thx Gene
6 years 8 months ago - 6 years 8 months ago #158294 by MrGreg
Replied by MrGreg on topic Raspberry Pi 4
Hello again
I'll try out your latest, on a Pi4 ( and Pi3 ) later today.
Will report back
Re Picnc:
Originally developed on Linuxcnc circa 2012.
I think it is OK on Lcnc 2.7 but not 2.9.
As a bare bones on stripboard, comes in at under £10
See
And a mighty long thread here
www.raspberrypi.org/forums/viewtopic.php...d17afefffe677405a0ba
Cheers
MrGreg
Edit
Beat me to TJ
Last edit: 6 years 8 months ago by MrGreg. Reason: update
Time to create page: 0.155 seconds
