MrGreg wrote: Hello Gene & all
Reporting back
Firstly by way of indicative comparison....
glxgears & browser circa 20mins duration
Ran latency-test period on my existing Pi2 4.4.4RT setup.
Came in at ~ 160
Re ran using rt-tests with:
cyclictest -n -p 90 -i 1000
Came in at 147
Similar enough to be indicative in that example at least. I will re test with the lcnc latency test in due course.
Tried the/your newer kernel on Pi4 with cmdline & config from your link.
Extraction seemed to run OK.
Hangs at boot ! Suspect it is something in your modified cmdline.txt ?
Edit
Prob not cmdline or config ? put stock ones back in with a kernel=kernel7i-rt.img
Still hangs at boot
Cheers
MrGreg
Reporting back
Came in at ~ 160
Came in at 147
Edit
Still hangs at boot
Cheers
MrGreg
MrGreg wrote: Hello
Well that's better, it's working
In fact I'm responding from it atm to give it a little different to do while the latency test is running.
So at the moment after about 10mins ish, I have, using:
glxgears at 1080p circa 60fps & active browser
rt-tests
sudo cyclictest -n -p 90 -i 1000
326uS
Started off initially at 96uS
Thats awfull slow and its indicative of running chromium too.
Still a bit on the high side of expectations. Yes it depends on how you view the validity of the latency test. TBD / TBA ?
Lower (so far) by ~20% ish than the guysoft RT ( also 4.19.71 )
I'm rather seeing it as a comparative / indicative measure rather than an absolute specific directly related to lcnc.
Perhaps if someone could/would run the cyclic test from debian rt-tests on a more optimised stripped out setup that might yield a useful comparison for general information?
Where can I get it?
@ Gene
is there a suitable working linuxcnc deb in your collection to plonk in this so I can do a latency-test period on it?
Yes, all of those on my site were built from master 4 or 5 days ago. Should just put those in a separate dir, cd to it and "sudo dpkg -i *"
Thanks for your everything
Cheers
MrGreg
