- Thank you received: 167
gtt38 wrote: Nobody told which version of the RPI4 (size of memory used) and cooling.
There is a huge difference between the RPI4 with 1Go and 4Go of RAM.
Due to thermal throttling i've seen a huge difference when i installed a fan with a heater.
I don't care about latency since i'm using an FPGA. The raspberry is not the Beaglebone, there is no PRU. So using RPI GPIO for Fast I/O is limited i think.
The cheapest way to have fast I/O on RPI could be a STM32 in SPI using the Hostmot2 RPSPI driver as start.
github.com/LinuxCNC/linuxcnc/blob/master...hostmot2/hm2_rpspi.c
I made this for the de10-nano running mksocfpgaBeagleBrainz wrote: I was using MK on a BeagleBoneBlack with a homemade cape and 3.3v to 5v translator boards. The slow graphics on the backplot never seemed to be too much of an issue. The PRU step & direction was pretty good.....but Linuxcnc has better support and seems to have more active development.
