ISO for a sysvinit distribution
  • phillc54
  • phillc54's Avatar Topic Author
  • Platinum Member
  • Platinum Member
07 Feb 2020 01:36 - 31 Mar 2020 18:26 #156679 by phillc54
ISO for a sysvinit distribution was created by phillc54
These images have been removed
These images will be removed at the end of March
The Devuan distribution is based on Debian without systemd
Devuan uses sysvinit as the default init system although other init systems are available
A network connection is not required during installation as all required files are in each image. An assortment of non-free network packages are pre-installed so network connection should be possible after the installation
Common to all images:
  • 64 bit
  • Boot from Legacy Bios rather than UEFI
  • All dependencies required to build LinuxCNC
  • All dependencies required for displaying QtVCP screens
  • All dependencies required for building QtVCP screens with Qt Designer
Two distro versions, Devuan2 or Devuan3:
  • Devuan2 (ASCII) is based on Debian9 (Stretch)
  • Devuan3 (Beowulf) is based on Debian10 (Buster)
Two desktops, Cinnamon or XFCE
Two kernel flavours, PREEMPT_RT or RTAI:
  • PREEMPT_RT images have a package installation of LinuxCNC 2.9 from the Buildbot
  • RTAI images have a run in place installation of LinuxCNC 2.9
Kernel versions:
  • Devuan2 PREEMPT_RT kernel is 4.19.67-2
  • Devuan3 PREEMPT_RT kernel is 4.19.98-1
  • Devuan2 RTAI kernel is 4.14.148
  • Devuan3 RTAI kernel is 4.14.148
Default root password is 1234
Default user is lcnc with 1234 as the password, this is set for automatic login
You can install directly from the running Live CD by clicking Menu - Administration - Refracta Installer
Default swap is an inbuilt 1Gb swap file so you can create a single partition on your drive if you prefer, otherwise create a swap partition during install and select that rather than a swap file
Passwords may be changed during the installation
The default user name may be changed during the installation. This will delete the existing user (lcnc) and the new user will start with a default profile and manual login
Tested on a VmWare virtual machine and on a baremetal machine booting from a 8Gb USB thumb drive burnt with Balena Etcher on a iMac
The RTAI images do not fully utilise all display adapters. The baremetal machine with Intel 915 graphics was restricted to 1024 x 768 and software 3D
Available here
Last edit: 31 Mar 2020 18:26 by phillc54. Reason: closing down sale
The following user(s) said Thank You: tommylight, emilvv
  • BeagleBrainz
  • BeagleBrainz's Avatar
  • Visitor
  • Visitor
07 Feb 2020 01:51 #156680 by BeagleBrainz
Replied by BeagleBrainz on topic ISO for a sysvinit distribution
Well done sir
Was having a look at that the other day.
Hope you’re ready to start explaining the diff between the 2 inits ;)
Will download and have a look and let you know how it goes.
  • BeagleBrainz
  • Visitor
  • Visitor
07 Feb 2020 02:39 #156686 by BeagleBrainz
Ran a Live session in VBox, wondering if apache will start up when installed to hdd ?
  • phillc54
  • Platinum Member
  • Platinum Member
07 Feb 2020 03:38 #156687 by phillc54
Replied by phillc54 on topic ISO for a sysvinit distribution
Nah, I think I'll stay well away from that...
Did it boot up ok in VBox, I only have VMware Fusion
Does it have Apache?
TBH all I tried was networking and LinuxCNC
  • BeagleBrainz
  • Visitor
  • Visitor
07 Feb 2020 04:07 #156689 by BeagleBrainz
Vbox was ok, Cinnamon crashed but restarted ok, has a message about running in software rendering mode.
Yep runs apache from boot, accessible in firefox @ 127.0.0.1.
Haven't installed on baremetal yet, still working on a Mint 19.2 iso, not enough free space for extra partitions on my hdd.
Ran through a few sims, issue with PyQt5 but neither here nor there really.
  • phillc54
  • Platinum Member
  • Platinum Member
07 Feb 2020 04:42 #156691 by phillc54
I should check that out, I want to do a QtVCP GUI.
07 Feb 2020 05:07 #156692 by tommylight
Replied by tommylight on topic ISO for a sysvinit distribution
Downloading now, report later.
Thank you.
  • phillc54
  • Platinum Member
  • Platinum Member
08 Feb 2020 02:22 #156746 by phillc54
QtVCP screens now display plus you can create/edit screens with Qt Designer.
  • twoflowers
  • twoflowers's Avatar
  • Visitor
  • Visitor
12 Feb 2020 02:35 #157139 by twoflowers
Replied by twoflowers on topic ISO for a sysvinit distribution
Would it be possible to include the RTAI kernel from www.linuxcnc.org/temp/ too? That has ~5-10 times better latency.
  • phillc54
  • Platinum Member
  • Platinum Member
12 Feb 2020 02:56 #157143 by phillc54
I will have a look.
Time to create page: 0.677 seconds
