ISO for a sysvinit distribution
  • BeagleBrainz
  • BeagleBrainz's Avatar
  • Visitor
  • Visitor
22 Feb 2020 22:31 #158246 by BeagleBrainz
Replied by BeagleBrainz on topic ISO for a sysvinit distribution
Ran through a HTML doc build there is about 30MB of stuff.
One thing that needs attention is that when clicking the links on the gcode.html (local) they link to linuxcnc.org/docs/devel/html/gcode/g-code.html .......unless the gcode.html page is edited.
  • phillc54
  • phillc54's Avatar Topic Author
  • Platinum Member
  • Platinum Member
22 Feb 2020 22:37 - 22 Feb 2020 23:12 #158247 by phillc54
Replied by phillc54 on topic ISO for a sysvinit distribution
Thanks for that, I could probably squeeze them in in a pinch..
Edit: It is 300Mb, not 300Kb of remaining space.
Kinda makes you wonder whether it's worth doing. I am sure if there are broken links someone will complain.
Last edit: 22 Feb 2020 23:12 by phillc54.
The following user(s) said Thank You: BeagleBrainz
  • BeagleBrainz
  • Visitor
  • Visitor
22 Feb 2020 23:43 #158252 by BeagleBrainz
I'm not good at JS but the issue appears here (in FF anyway):
if(document.location.protocol == "file:") {
    try {
        var x = document.implementation.createDocument("", "", null);
        x.load("gcode/g-code.html");
        x.onerror = fixup_urls;
    } catch(err) {
        fixup_urls();
  • phillc54
  • Platinum Member
  • Platinum Member
22 Feb 2020 23:57 #158255 by phillc54
A grep of the docs source folder shows a lot of direct links to linuxcnc.org so I don't think it would be possible to eliminate them all.
  • BeagleBrainz
  • Visitor
  • Visitor
23 Feb 2020 00:33 - 23 Feb 2020 00:35 #158259 by BeagleBrainz
That snippet comes from doc/html/gcode.html
If firefox that snippet
Changing that snippet to
    try {
    } catch(err) {
        fixup_urls();
        alert (err);
I get "TypeError: x.load is not a function" message using fire fox.
It only happens if the protocol is file://
Only my local weberserver it works fine.
Last edit: 23 Feb 2020 00:35 by BeagleBrainz.
  • phillc54
  • Platinum Member
  • Platinum Member
22 Mar 2020 04:25 #161069 by phillc54
I really don't have time to support these images and I intend to remove them at the end of March so if anyone wants them the time is now.
I am going to follow the crowd and move to Rob's Mint images and hopefully they will end up being the official LinuxCNC images.
  • BeagleBrainz
  • Visitor
  • Visitor
22 Mar 2020 05:04 #161072 by BeagleBrainz
Well phill you work hard enough as it giving back to the community.
And what happens when I finish fighting with my employer and either get back onsite or have to start looking for work.:laugh: :laugh: :laugh: :laugh:
Apparently I'm not fit enough to get assigned jobs but fit enough to be left on the books. Hopefully FairWork comes up with a solution.
  • phillc54
  • Platinum Member
  • Platinum Member
22 Mar 2020 08:00 #161075 by phillc54
Crikey, the way things are going at the moment we won't be allowed out to go to work. I guess the'll have Corona Cops on every corner.
  • twoflowers
  • twoflowers's Avatar
  • Visitor
  • Visitor
24 Mar 2020 17:20 #161356 by twoflowers
Replied by twoflowers on topic ISO for a sysvinit distribution
It's a pitty that you stop on the images. Did you nutld them with devuan sdk? Any nifty config to be done?
  • phillc54
  • Platinum Member
  • Platinum Member
24 Mar 2020 22:26 #161373 by phillc54
Nothing fancy, I just used the Refracta Tools
Time to create page: 0.105 seconds
