ISO for a sysvinit distribution
- phillc54
- Thank you received: 2100
15 Feb 2020 04:03 #157395
by phillc54
Replied by phillc54 on topic ISO for a sysvinit distribution
- Thank you received: 4151
15 Feb 2020 06:16 #157397
Replied by rodw on topic ISO for a sysvinit distribution
So where do we download from? I could not see any links in the first post...
- phillc54
15 Feb 2020 06:22 #157398
by phillc54
Oops, my over zealous editing.So where do we download from? I could not see any links in the first post...
15 Feb 2020 07:02 #157399
That looks better. Thanks Phill
- twoflowers
- Visitor
17 Feb 2020 10:10 - 17 Feb 2020 10:11 #157575
by twoflowers
Replied by twoflowers on topic ISO for a sysvinit distribution
So I tested the RTAI beowulf image - as expected latency is 1/5th of RT, so perfect. And the GUI looks really nice
There are some rough edges for beginners - but I'm sure they will be ired out: No CNC menu, so latency-histogram needs to be started from commandline "~/linuxcnc-dev/scripts/rip-environment latency-histogram". Same for stepconfwizard etc.
Overall a pleasent thing to work with. Good job!
Last edit: 17 Feb 2020 10:11 by twoflowers.
- phillc54
17 Feb 2020 10:36 #157577
by phillc54
I am not sure if make install-menus is still valid, I will have a look tomorrow.
I only did a run in place LinuxCNC for the RTAI kernels because there are no upgradeable Buster packages for RTAI.There are some rough edges for beginners - but I'm sure they will be ired out: No CNC menu, so latency-histogram needs to be started from commandline "~/linuxcnc-dev/scripts/rip-environment latency-histogram". Same for stepconfwizard etc.
- twoflowers
- Visitor
18 Feb 2020 09:45 #157693
by twoflowers
As I played around a bit more, another question rises: How did you get the python qt stuff of linuxcnc working on beowulf? Is this already fixed in 2.9 and it would be good idea to build 2.9 on RPi, too, as I did not get theses things working on 2.8?
- phillc54
18 Feb 2020 11:03 - 18 Feb 2020 11:08 #157699
by phillc54
Oops, double post...
I shouldn't do this on my phone.
Last edit: 18 Feb 2020 11:08 by phillc54.
- phillc54
18 Feb 2020 11:04 #157700
by phillc54
As an experiment I did the same today from Stretch to Buster and it worked as well.
I do intend to get RPi4 to have a bit of a play.
Beowulf was made as a distribution upgrade from ASCII. It worked flawlessly.As I played around a bit more, another question rises: How did you get the python qt stuff of linuxcnc working on beowulf? Is this already fixed in 2.9 and it would be good idea to build 2.9 on RPi, too, as I did not get theses things working on 2.8?
- Thank you received: 7488
18 Feb 2020 11:07 #157702
Replied by tommylight on topic ISO for a sysvinit distribution
Redundancy ?
Time to create page: 0.150 seconds
