Script for automated testing of computer latency.
  • Platinum Member
  • Platinum Member
2 years 7 months ago #295863 by Cant do this anymore bye all
Replied by Cant do this anymore bye all on topic Script for automated testing of computer latency.
If you are using a Mesa card, whether the interface is Ethernet, SPI or EPP (Parallel Port) only a servo thread is required. In a basic explanation the Mesa card is getting the info required to move the steppers and generating the timing. Same info just a different physical interface.
When soley using the Parallel Port linuxcnc is generating the step pulses, and this requires a base thread.
I just start with a base thread such as 25us and then adjust it up or down until it’s stable when running a config.
Essentially the Mesa route doesn’t require a lot of tuning, Parallel Port may require some or a lot depending on the machine.
2 years 7 months ago - 2 years 7 months ago #295878 by seuchato
Hey, thanks for the effort to make this whole latency testing more reproducable.
The problem I face is that I can't interpret the results of this script, as I'm not very deep into this topic.
So a few questions:
1) As far as I understand the base thread is mostly used for software step generation. As most setups use mesa cards with their fpga step generation, do I have to worry about base thread latency at all? What about mesa cards connected to the parport?
2) Why is the standard deviation important? If I have a pretty narrow curve with a few large deviations, my standard deviation would be relatively small but because of the few large deviations, my system would still be unusable right?
3) The wiki states that the most important thing is the jitter. If I understand correctly, thats the maximum deviation of the period. So If I get a result of min=-30uS and max=20uS, my jitter would be 30uS. Is that correct?
4) What jitter is considered okay for LinuxCNC when not using software stepping (e.g. using a mesa card)?
Thank you for putting so much work into this community project :)
Last edit: 2 years 7 months ago by seuchato. Reason: Time out
2 years 7 months ago - 2 years 7 months ago #295879 by seuchato
Klopp
Thanks for the flowers :-)
1) correct, and very well answered explained by cornholio, too
2) See this article . Imho it explains jitter and standard deviation well. I'second your conclusion. But that's also depending on use case:
Soft stepping: From my understanding, own experience and reading, I'd conclude, that about 50.000 uS is the community agreed limit. I myself use this PC for my small router on parallel port BOB. It tested around 20.000 uS. In my daily use, I gave it a safety margin, so I actually run it using 50.000 uS for Jitter.
Hard stepping: There are numerous opinions on a reasonable limit. I guess everything under 100.000 can be considered good. tommylight made some statements, that he could see even 200.000 as usable. Kindly note: I lack experience on this, so that's only my finding from reading in LCNC forums.
3) Jitter is the figure to watch. I'd second your conclusion, but be cautious and set some safety margin. Citing tommylight again: "use LinuxCNC for several hours. If no warnings = nice :)"
4) see above: about 100.000 should be fine
greez
chris
Last edit: 2 years 7 months ago by seuchato. Reason: Timeout
2 years 5 months ago #301129 by jg00163206
Replied by jg00163206 on topic Script for automated testing of computer latency.
Using user defined parameters:
Result: running as user: mill,
runtime: 7200 seconds,
parameters: --nobase, --base 100000,
prefix for outfiles 1716355190
nglx: 5,
LinuxCNC pc tests, version 20200930, started 22.05.2024 01:21:08
Hardware info is logged here: 1716355190.hw.
Latency data is logged here: 1716355190.lat.
General info:
Dell Inc., Vostro 270
Bios version A08, dated 11/23/2012
Chipset: Intel Corporation 7 Series/C216
Harddisk is rotational
The amount of swap currently used is 0
CPU related data:
model name : Intel(R) Core(TM) i5-3570 CPU @ 3.40GHz
cpu cores : 4
stepping : 9
cache size : 6144 KB
RAM related data:
Maximum Capacity: 8 GB
GPU related data:
product: Oland GL [FirePro W2100]
product: Xeon E3-1200 v2/3rd Gen Core processor Graphics Controller
configuration: depth=32 driver=radeon latency=0 resolution=1920,1080
configuration: driver=i915 latency=0
Parallel port related data:
number of parallel ports is 0
Os and desktop related data:
PRETTY_NAME="Debian GNU/Linux 12 (bookworm)"
Should the info below not match with your machine,
kindly post the output of pstree here, including a brief
desciption of your desktop environment, window manager and
display manager. Tia
forum.linuxcnc.org/18-computer/39370-scr...-of-computer-latency
Desktop environment : lightdm
Windowmanager : Xfwm4
Displaymanager : lightdm
Kernel related data:
Kernel 6.1.0-18-rt-amd64
GRUB_CMDLINE_LINUX_DEFAULT="quiet"
Cpu idle driver: intel_idle
Kernel modules data:
Check if pcspkr is loaded: ./lcnc-hw: line 576: [: too many arguments
Yes, may cause bigger latency.
can be eliminated using:
sudo echo "install pcspkr /bin/true" >/etc/modprobe.d/pcspkr.conf
Check if snd modules are loaded: Yes, may cause bigger latency.
can probably be disabled in bios, alternatively, you can run
"./block-snd-modules"
which has just now been created for your convenience.
Keyboard & Mouse related data:
Number of mice: 1
Mouse 0 : Telink Wireless Receiver Mouse
Mice attached to USB:
./lcnc-hw: line 631: lsusb: command not found
Keyboards attached to USB:
./lcnc-hw: line 633: lsusb: command not found
LinuxCNC related data:
LinuxCNC version is: 2.9.2
Preparing for latency test:
Started glxgears No. 1, 2, 3, 4, 5
......ATTENTION: default value of option mesa_glthread overridden by environment.
Started firefox with ' vimeo.com/150574260 ', WID
STartime = Wed May 22 01:21:22 AM EDT 2024
Command for latency test is:
su mill -c "latency-histogram --nobase --base 100000 --sbinsize 1000 --nox 2>&1 | tee -a 1716355190.lat &"
Latency testing loop started Wed May 22 01:21:22 AM EDT 2024,
should end after Wed May 22 03:21:22 AM EDT 2024
Core 0: +49.0°C (high = +85.0°C, crit = +105.0°C)
Core 1: +48.0°C (high = +85.0°C, crit = +105.0°C)
Core 2: +46.0°C (high = +85.0°C, crit = +105.0°C)
Core 3: +46.0°C (high = +85.0°C, crit = +105.0°C)
done command, retval = 0
.Note: Using POSIX realtime
0 s servo min: -4.400 us max: 5.400 us sdev: 1.600 us
. 1 s servo min: -4.400 us max: 7.100 us sdev: 1.600 us
2 s servo min: -5.500 us max: 7.600 us sdev: 1.600 us
. 2 s servo min: -7.700 us max: 10.100 us sdev: 1.700 us
. 3 s servo min: -7.700 us max: 10.100 us sdev: 1.700 us
4 s servo min: -7.700 us max: 10.100 us sdev: 1.600 us
. 4 s servo min: -7.700 us max: 10.100 us sdev: 1.600 us
5 s servo min: -7.700 us max: 10.100 us sdev: 1.700 us
There are no windows in the stack
Invalid window '%1'
Usage: windowactivate [options] [window=%1]
--sync - only exit once the window is active (is visible + active)
If no window is given, %1 is used. See WINDOW STACK in xdotool(1)
Remaining 0d 1h:59m:55s, press ^C to abort...
6 s servo min: -15.200 us max: 13.200 us sdev: 1.700 us
7 s servo min: -15.200 us max: 13.200 us sdev: 1.700 us
8 s servo min: -15.200 us max: 13.200 us sdev: 1.700 us
9 s servo min: -23.900 us max: 24.300 us sdev: 1.800 us
Core 0: +57.0°C (high = +85.0°C, crit = +105.0°C)
Core 1: +57.0°C (high = +85.0°C, crit = +105.0°C)
Core 2: +54.0°C (high = +85.0°C, crit = +105.0°C)
Core 3: +53.0°C (high = +85.0°C, crit = +105.0°C)
Remaining 0d 1h:59m:50s, press ^C to abort...
10 s servo min: -23.900 us max: 24.300 us sdev: 1.800 us
11 s servo min: -23.900 us max: 24.300 us sdev: 1.800 us
12 s servo min: -23.900 us max: 24.300 us sdev: 1.800 us
13 s servo min: -23.900 us max: 24.300 us sdev: 1.700 us
14 s servo min: -23.900 us max: 24.300 us sdev: 1.700 us
15 s servo min: -23.900 us max: 24.300 us sdev: 1.700 us
Core 0: +59.0°C (high = +85.0°C, crit = +105.0°C)
Core 1: +58.0°C (high = +85.0°C, crit = +105.0°C)
Core 2: +56.0°C (high = +85.0°C, crit = +105.0°C)
Core 3: +54.0°C (high = +85.0°C, crit = +105.0°C)
Remaining 0d 1h:59m:45s, press ^C to abort...
15 s servo min: -49.500 us max: 35.900 us sdev: 1.700 us
16 s servo min: -49.500 us max: 35.900 us sdev: 1.700 us
17 s servo min: -49.500 us max: 35.900 us sdev: 1.700 us
18 s servo min: -49.500 us max: 35.900 us sdev: 1.700 us
19 s servo min: -49.500 us max: 35.900 us sdev: 1.700 us
20 s servo min: -49.500 us max: 35.900 us sdev: 1.700 us
Core 0: +61.0°C (high = +85.0°C, crit = +105.0°C)
Core 1: +59.0°C (high = +85.0°C, crit = +105.0°C)
Core 2: +55.0°C (high = +85.0°C, crit = +105.0°C)
Core 3: +56.0°C (high = +85.0°C, crit = +105.0°C)
Remaining 0d 1h:59m:40s, press ^C to abort...
2 years 5 months ago #301159 by seuchato
jg00163206
Did you press ^C to abort?
If, a bit a pitty, as it does not look off too far, given you have still screws to turn to optimise.
Greez
chris
11 months 2 days ago #339488 by Futterama
Hello there, I'm new here and have been looking into a reliable way to test my PC latency using different BIOS settings and found this script.
I like it a lot but I have only found the initial version of the script, the one attached to the very first post. I'm only running it from a live image, currently version 2.9.4. Apart from replacing the Vimeo link with a working one, I also found a minor spacing error on line 576:
if [ $(lsmod | grep spkr) =="" ]; then
should be:
if [ $(lsmod | grep spkr) == "" ]; then
I also experienced the missing latency output after the script finished so I replaced "secs" on line 936 with "us sdev" as mentioned  here by arvidb:
grep "us sdev" $latoutf \
At line 631, lsusb is called and it was not installed so I ran the following and that fixed it:
sudo apt-get update sudo apt-get install usbutils
I will look for other things to fix and post it here. I hope this thread is not completely dead even though it seems like it, but I feel it would be a shame to let all this good work "go to waste" and not keep the script updated, because during my testing and while running the script, I encountered a larger latency spike than what I could produce manually.
The following user(s) said Thank You: seuchato, onceloved
Time to create page: 0.387 seconds
