Results of latency test, list of computers tested for use with LinuxCNC
01 Dec 2020 16:10 #190777 by seuchato
tommylight
Do you have that ryzen machine a couple of weeks available?
If, I would like to ask you to do some tests for me.
greez
chris
  • tommylight's Avatar Topic Author
  • Moderator
  • Moderator
01 Dec 2020 16:42 #190779 by tommylight
tommylight
Oooops, forgot to say MY new PC ! :)
Yes i will have it and feel free to ask and i will do my best to respond as quickly as i can since i am very busy as usual and i am building a new workshop and some 3 or 4 other machines! ! :)
Hope you can get over whatever the "rough patch" was.
Regards,
Tom.
02 Dec 2020 06:19 - 02 Dec 2020 06:20 #190842 by rootboy
@seuchato
I'm sorry to hear that. :(
As for the PC, after tommylight pointed out the high temp, I set the fans to run continuously. That seems to have fixed it. It's been on non-stop for a week and it is running nice and cool.
Last edit: 02 Dec 2020 06:20 by rootboy. Reason: Make things clearer.
The following user(s) said Thank You: seuchato, tommylight
02 Dec 2020 12:58 #190869 by seuchato
rootboy
thanx, A cpu should only get that hot, if it runs at ultimate power. Heat conduction can do wonders to the lifetime of a cpu.
Greez
chris
02 Dec 2020 13:03 - 02 Dec 2020 13:04 #190871 by seuchato
rootboy
Using the script, it ran but left out a few minor details (the latency results)
Most likely the very directory you started the script in is owned by root. do
cd ..
chown {user} {dirname}
cd {dirname}
sudo ./lcnc-hw
then it should write latency data
greez
chris
Last edit: 02 Dec 2020 13:04 by seuchato. Reason: typo
04 Dec 2020 14:42 - 04 Dec 2020 14:50 #191033 by Clive S
Would this be ok for the p/port
LinuxCNC pc tests, version 20200930, started 04.12.2020 12:25:05
General info:
Dell Inc.,  OptiPlex 780
Bios version A08, dated 01/21/2011
Chipset: Intel Corporation 4 Series
Harddisk is rotational
The amount of swap currently used is 0
CPU related data:
model name	: Intel(R) Core(TM)2 Duo CPU     E8400  @ 3.00GHz
cpu cores	: 1
stepping	: 10
cache size	: 6144 KB
RAM related data:
Maximum Capacity: 8 GB
Size: No Module Installed
GPU related data:
product: 4 Series Chipset Integrated Graphics Controller
configuration: driver=i915 latency=0
configuration: latency=0
Parallel port related data:
number of parallel ports is 1
parport0: PC-style at 0x378 (0x778), irq 7, using FIFO [PCSPP,TRISTATE,COMPAT,EPP,ECP]
Os and desktop related data:
PRETTY_NAME="Linux Mint 19.3"
Should the info below not match with your machine,
kindly post the output of pstree here, including a brief
desciption of your desktop environment, window manager and
display manager. Tia
https://forum.linuxcnc.org/18-computer/39370-script-for-automated-testing-of-computer-latency
Desktop environment : lightdm
Windowmanager       : Xfwm4
Displaymanager      : lightdm
Kernel related data:
Kernel 4.19.106-rt44-lcnc
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash"
Cpu idle driver: none
Kernel modules data:
Check if pcspkr is loaded: No, which is good!
Check if snd modules are loaded: No, which is good!
Keyboard & Mouse related data:
Number of mice: 1
Mouse 0 : SEMICCHIP Usb Mouse
Mice  attached to USB:
Keyboards attached to USB:
LinuxCNC related data:
LinuxCNC version is: 2.8.1.1.g5d082d148
Preparing for latency test:
Started glxgears No. 1, 2, 3, 4, 5
Started firefox with 'https://vimeo.com/150574260', WID
Command for latency test is:
su cnc -c  "latency-histogram --bbinsize 1000 --base 100000 --sbinsize 1000 --nox 2>&1 | tee -a 1607084674.lat &"
Latency testing loop started Fri  4 Dec 12:25:20 GMT 2020,
should end after Fri  4 Dec 14:25:20 GMT 2020
Swap useage: prerun: 0, running: 0
CPU core temperatures:
Core 0: Tmin: 30.0°C, Tmax: 30.0°C, (high = +76.0°C, crit = +100.0°C)
last latency data is as follows:.
 7202 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7202 secs  servo min: -37.800 uS max:  35.500 uS sdev:   1.600 uS
Shall I leave the below in:-
Core 0:       +30.0°C  (high = +76.0°C, crit = +100.0°C)
Note: Using POSIX realtime
    7 secs   base min: -12.700 uS max:  12.900 uS sdev:   4.500 uS
    7 secs  servo min: -19.500 uS max:  18.000 uS sdev:   3.300 uS
    8 secs   base min: -17.000 uS max:  15.900 uS sdev:   4.500 uS
    8 secs  servo min: -19.500 uS max:  18.000 uS sdev:   2.200 uS
   10 secs   base min: -17.500 uS max:  18.400 uS sdev:   4.500 uS
   10 secs  servo min: -20.700 uS max:  19.100 uS sdev:   2.000 uS
   11 secs   base min: -17.500 uS max:  18.400 uS sdev:   4.500 uS
   11 secs  servo min: -21.400 uS max:  21.900 uS sdev:   2.100 uS
   12 secs   base min: -18.700 uS max:  19.400 uS sdev:   4.500 uS
   12 secs  servo min: -21.400 uS max:  21.900 uS sdev:   2.100 uS
   14 secs   base min: -18.700 uS max:  19.700 uS sdev:   4.500 uS
   14 secs  servo min: -21.400 uS max:  21.900 uS sdev:   2.200 uS
   15 secs   base min: -18.700 uS max:  19.700 uS sdev:   4.500 uS
   15 secs  servo min: -21.400 uS max:  21.900 uS sdev:   2.200 uS
   16 secs   base min: -18.700 uS max:  19.700 uS sdev:   4.500 uS
   16 secs  servo min: -21.400 uS max:  21.900 uS sdev:   2.200 uS
   18 secs   base min: -18.700 uS max:  19.700 uS sdev:   4.500 uS
   18 secs  servo min: -21.400 uS max:  21.900 uS sdev:   2.200 uS
   19 secs   base min: -18.700 uS max:  19.700 uS sdev:   4.500 uS
   19 secs  servo min: -21.400 uS max:  21.900 uS sdev:   2.200 uS
   20 secs   base min: -18.700 uS max:  19.700 uS sdev:   4.500 uS
   20 secs  servo min: -21.400 uS max:  21.900 uS sdev:   2.200 uS
   22 secs   base min: -18.700 uS max:  19.700 uS sdev:   4.500 uS
   22 secs  servo min: -21.400 uS max:  21.900 uS sdev:   2.200 uS
   23 secs   base min: -18.700 uS max:  19.700 uS sdev:   4.500 uS
   23 secs  servo min: -21.400 uS max:  21.900 uS sdev:   2.200 uS
   24 secs   base min: -18.700 uS max:  19.700 uS sdev:   4.500 uS
   24 secs  servo min: -21.400 uS max:  21.900 uS sdev:   2.100 uS
   26 secs   base min: -18.700 uS max:  19.700 uS sdev:   4.600 uS
   26 secs  servo min: -21.400 uS max:  21.900 uS sdev:   2.100 uS
   27 secs   base min: -18.700 uS max:  19.700 uS sdev:   4.600 uS
   27 secs  servo min: -22.600 uS max:  22.500 uS sdev:   2.100 uS
   28 secs   base min: -18.700 uS max:  19.700 uS sdev:   4.600 uS
   28 secs  servo min: -22.600 uS max:  22.500 uS sdev:   2.000 uS
   30 secs   base min: -18.700 uS max:  19.700 uS sdev:   4.600 uS
   30 secs  servo min: -22.600 uS max:  22.500 uS sdev:   2.000 uS
   31 secs   base min: -18.700 uS max:  19.700 uS sdev:   4.600 uS
   31 secs  servo min: -22.600 uS max:  22.500 uS sdev:   2.000 uS
   33 secs   base min: -18.700 uS max:  19.700 uS sdev:   4.600 uS
   33 secs  servo min: -22.600 uS max:  22.500 uS sdev:   2.000 uS
   34 secs   base min: -18.700 uS max:  19.700 uS sdev:   4.600 uS
   34 secs  servo min: -22.600 uS max:  22.500 uS sdev:   2.000 uS
   35 secs   base min: -18.700 uS max:  19.700 uS sdev:   4.600 uS
   35 secs  servo min: -22.600 uS max:  22.500 uS sdev:   2.000 uS
   37 secs   base min: -18.700 uS max:  19.700 uS sdev:   4.600 uS
   37 secs  servo min: -22.600 uS max:  22.500 uS sdev:   2.000 uS
   38 secs   base min: -18.700 uS max:  19.700 uS sdev:   4.600 uS
   38 secs  servo min: -22.600 uS max:  22.500 uS sdev:   2.000 uS
   39 secs   base min: -18.700 uS max:  19.700 uS sdev:   4.600 uS
   39 secs  servo min: -22.600 uS max:  22.500 uS sdev:   2.000 uS
   41 secs   base min: -18.700 uS max:  19.700 uS sdev:   4.600 uS
   41 secs  servo min: -22.600 uS max:  22.500 uS sdev:   2.100 uS
   42 secs   base min: -18.700 uS max:  19.700 uS sdev:   4.600 uS
   42 secs  servo min: -22.600 uS max:  22.500 uS sdev:   2.000 uS
   43 secs   base min: -18.700 uS max:  19.700 uS sdev:   4.600 uS
   43 secs  servo min: -22.600 uS max:  22.500 uS sdev:   2.100 uS
   45 secs   base min: -18.700 uS max:  19.700 uS sdev:   4.600 uS
   45 secs  servo min: -22.600 uS max:  22.500 uS sdev:   2.000 uS
   46 secs   base min: -18.700 uS max:  19.700 uS sdev:   4.600 uS
   46 secs  servo min: -22.600 uS max:  22.500 uS sdev:   2.000 uS
   47 secs   base min: -18.700 uS max:  19.700 uS sdev:   4.700 uS
   47 secs  servo min: -22.600 uS max:  22.500 uS sdev:   2.000 uS
   49 secs   base min: -18.700 uS max:  19.700 uS sdev:   4.700 uS
   49 secs  servo min: -22.600 uS max:  22.500 uS sdev:   2.000 uS
   50 secs   base min: -18.700 uS max:  19.700 uS sdev:   4.700 uS
   50 secs  servo min: -22.600 uS max:  22.500 uS sdev:   2.000 uS
   51 secs   base min: -18.700 uS max:  19.700 uS sdev:   4.700 uS
   51 secs  servo min: -22.600 uS max:  22.500 uS sdev:   2.000 uS
   53 secs   base min: -18.700 uS max:  19.700 uS sdev:   4.700 uS
   53 secs  servo min: -22.600 uS max:  22.500 uS sdev:   2.000 uS
   54 secs   base min: -18.700 uS max:  19.700 uS sdev:   4.700 uS
   54 secs  servo min: -22.600 uS max:  22.500 uS sdev:   2.000 uS
   55 secs   base min: -18.700 uS max:  19.700 uS sdev:   4.700 uS
   55 secs  servo min: -22.600 uS max:  22.500 uS sdev:   2.000 uS
   57 secs   base min: -18.700 uS max:  19.700 uS sdev:   4.700 uS
   57 secs  servo min: -22.600 uS max:  22.500 uS sdev:   1.900 uS
   58 secs   base min: -18.700 uS max:  19.700 uS sdev:   4.700 uS
   58 secs  servo min: -22.600 uS max:  22.500 uS sdev:   1.900 uS
   59 secs   base min: -18.700 uS max:  19.700 uS sdev:   4.700 uS
   59 secs  servo min: -22.600 uS max:  22.500 uS sdev:   1.900 uS
   61 secs   base min: -18.700 uS max:  19.700 uS sdev:   4.700 uS
   61 secs  servo min: -22.600 uS max:  22.500 uS sdev:   1.900 uS
   62 secs   base min: -18.700 uS max:  19.700 uS sdev:   4.700 uS
   62 secs  servo min: -22.600 uS max:  22.500 uS sdev:   1.900 uS
   64 secs   base min: -18.700 uS max:  19.700 uS sdev:   4.700 uS
   64 secs  servo min: -22.600 uS max:  22.500 uS sdev:   1.900 uS
   65 secs   base min: -18.700 uS max:  19.700 uS sdev:   4.700 uS
   65 secs  servo min: -22.600 uS max:  22.500 uS sdev:   1.900 uS
   66 secs   base min: -18.700 uS max:  19.700 uS sdev:   4.700 uS
   66 secs  servo min: -22.600 uS max:  22.500 uS sdev:   1.900 uS
   68 secs   base min: -18.700 uS max:  19.700 uS sdev:   4.700 uS
   68 secs  servo min: -22.600 uS max:  22.500 uS sdev:   1.900 uS
   69 secs   base min: -18.700 uS max:  19.700 uS sdev:   4.700 uS
   69 secs  servo min: -22.600 uS max:  22.500 uS sdev:   1.900 uS
   70 secs   base min: -18.700 uS max:  19.700 uS sdev:   4.700 uS
   70 secs  servo min: -22.600 uS max:  22.500 uS sdev:   1.900 uS
   72 secs   base min: -18.700 uS max:  19.700 uS sdev:   4.700 uS
   72 secs  servo min: -22.600 uS max:  22.500 uS sdev:   1.900 uS
   73 secs   base min: -18.700 uS max:  19.700 uS sdev:   4.700 uS
   73 secs  servo min: -22.600 uS max:  22.500 uS sdev:   1.900 uS
   74 secs   base min: -18.700 uS max:  19.700 uS sdev:   4.700 uS
   74 secs  servo min: -22.600 uS max:  22.500 uS sdev:   1.900 uS
   76 secs   base min: -18.700 uS max:  19.700 uS sdev:   4.700 uS
   76 secs  servo min: -22.600 uS max:  22.500 uS sdev:   1.900 uS
   77 secs   base min: -18.700 uS max:  19.700 uS sdev:   4.700 uS
   77 secs  servo min: -22.600 uS max:  22.500 uS sdev:   1.800 uS
   78 secs   base min: -18.700 uS max:  19.700 uS sdev:   4.700 uS
   78 secs  servo min: -22.600 uS max:  22.500 uS sdev:   1.800 uS
   80 secs   base min: -18.700 uS max:  19.700 uS sdev:   4.700 uS
   80 secs  servo min: -22.600 uS max:  22.500 uS sdev:   1.800 uS
   81 secs   base min: -18.700 uS max:  19.700 uS sdev:   4.700 uS
   81 secs  servo min: -22.600 uS max:  22.500 uS sdev:   1.800 uS
   82 secs   base min: -18.700 uS max:  19.700 uS sdev:   4.700 uS
   82 secs  servo min: -22.600 uS max:  22.500 uS sdev:   1.800 uS
   84 secs   base min: -18.700 uS max:  19.700 uS sdev:   4.700 uS
   84 secs  servo min: -22.600 uS max:  22.500 uS sdev:   1.800 uS
   85 secs   base min: -18.700 uS max:  19.700 uS sdev:   4.700 uS
   85 secs  servo min: -22.600 uS max:  22.500 uS sdev:   1.800 uS
   87 secs   base min: -18.700 uS max:  19.700 uS sdev:   4.700 uS
   87 secs  servo min: -22.600 uS max:  22.500 uS sdev:   1.800 uS
   88 secs   base min: -18.700 uS max:  19.700 uS sdev:   4.700 uS
   88 secs  servo min: -22.600 uS max:  22.500 uS sdev:   1.800 uS
   89 secs   base min: -18.700 uS max:  19.700 uS sdev:   4.700 uS
   89 secs  servo min: -22.600 uS max:  22.500 uS sdev:   1.800 uS
   91 secs   base min: -18.700 uS max:  19.700 uS sdev:   4.700 uS
   91 secs  servo min: -22.600 uS max:  22.500 uS sdev:   1.800 uS
   92 secs   base min: -18.700 uS max:  19.700 uS sdev:   4.700 uS
   92 secs  servo min: -22.600 uS max:  22.500 uS sdev:   1.800 uS
   93 secs   base min: -18.700 uS max:  19.700 uS sdev:   4.700 uS
   93 secs  servo min: -22.600 uS max:  22.500 uS sdev:   1.800 uS
   95 secs   base min: -18.700 uS max:  19.700 uS sdev:   4.700 uS
   95 secs  servo min: -22.600 uS max:  22.500 uS sdev:   1.800 uS
   96 secs   base min: -18.700 uS max:  19.700 uS sdev:   4.700 uS
   96 secs  servo min: -22.600 uS max:  22.500 uS sdev:   1.800 uS
   97 secs   base min: -18.700 uS max:  19.700 uS sdev:   4.700 uS
   97 secs  servo min: -22.600 uS max:  22.500 uS sdev:   1.800 uS
   99 secs   base min: -18.700 uS max:  19.700 uS sdev:   4.700 uS
   99 secs  servo min: -22.600 uS max:  22.500 uS sdev:   1.800 uS
  100 secs   base min: -18.700 uS max:  19.700 uS sdev:   4.700 uS
  100 secs  servo min: -22.600 uS max:  22.500 uS sdev:   1.800 uS
  101 secs   base min: -18.700 uS max:  19.700 uS sdev:   4.700 uS
  101 secs  servo min: -22.600 uS max:  22.500 uS sdev:   1.800 uS
  103 secs   base min: -20.000 uS max:  19.700 uS sdev:   4.700 uS
  103 secs  servo min: -22.600 uS max:  22.500 uS sdev:   1.800 uS
  104 secs   base min: -20.000 uS max:  19.700 uS sdev:   4.700 uS
  104 secs  servo min: -22.600 uS max:  22.500 uS sdev:   1.800 uS
  105 secs   base min: -20.000 uS max:  19.700 uS sdev:   4.700 uS
  105 secs  servo min: -22.600 uS max:  22.500 uS sdev:   1.700 uS
  107 secs   base min: -20.000 uS max:  19.700 uS sdev:   4.700 uS
  107 secs  servo min: -22.600 uS max:  22.500 uS sdev:   1.700 uS
  108 secs   base min: -20.000 uS max:  19.700 uS sdev:   4.700 uS
  108 secs  servo min: -22.600 uS max:  22.500 uS sdev:   1.700 uS
  110 secs   base min: -20.000 uS max:  19.700 uS sdev:   4.700 uS
  110 secs  servo min: -22.600 uS max:  22.500 uS sdev:   1.700 uS
  111 secs   base min: -20.000 uS max:  19.700 uS sdev:   4.700 uS
  111 secs  servo min: -22.600 uS max:  22.500 uS sdev:   1.700 uS
  112 secs   base min: -20.000 uS max:  19.700 uS sdev:   4.700 uS
  112 secs  servo min: -22.600 uS max:  22.500 uS sdev:   1.700 uS
  114 secs   base min: -20.000 uS max:  19.700 uS sdev:   4.700 uS
  114 secs  servo min: -22.600 uS max:  22.500 uS sdev:   1.700 uS
  115 secs   base min: -20.000 uS max:  19.700 uS sdev:   4.700 uS
  115 secs  servo min: -22.600 uS max:  22.500 uS sdev:   1.700 uS
  116 secs   base min: -20.000 uS max:  19.700 uS sdev:   4.700 uS
  116 secs  servo min: -22.600 uS max:  22.500 uS sdev:   1.700 uS
  118 secs   base min: -20.000 uS max:  19.700 uS sdev:   4.700 uS
  118 secs  servo min: -22.600 uS max:  22.500 uS sdev:   1.700 uS
  119 secs   base min: -20.000 uS max:  20.500 uS sdev:   4.700 uS
  119 secs  servo min: -22.600 uS max:  22.500 uS sdev:   1.700 uS
  120 secs   base min: -20.000 uS max:  20.500 uS sdev:   4.700 uS
  120 secs  servo min: -22.600 uS max:  22.500 uS sdev:   1.700 uS
  122 secs   base min: -20.000 uS max:  20.500 uS sdev:   4.700 uS
  122 secs  servo min: -22.600 uS max:  22.500 uS sdev:   1.700 uS
  123 secs   base min: -20.000 uS max:  20.500 uS sdev:   4.700 uS
  123 secs  servo min: -22.600 uS max:  22.500 uS sdev:   1.700 uS
  124 secs   base min: -20.000 uS max:  20.500 uS sdev:   4.700 uS
  124 secs  servo min: -22.600 uS max:  22.500 uS sdev:   1.700 uS
  126 secs   base min: -20.000 uS max:  20.500 uS sdev:   4.700 uS
  126 secs  servo min: -22.600 uS max:  22.500 uS sdev:   1.700 uS
  127 secs   base min: -20.000 uS max:  20.500 uS sdev:   4.800 uS
  127 secs  servo min: -22.600 uS max:  22.500 uS sdev:   1.700 uS
  128 secs   base min: -20.000 uS max:  20.500 uS sdev:   4.800 uS
  128 secs  servo min: -22.600 uS max:  22.500 uS sdev:   1.700 uS
  130 secs   base min: -20.000 uS max:  20.500 uS sdev:   4.800 uS
  130 secs  servo min: -22.600 uS max:  22.500 uS sdev:   1.700 uS
  131 secs   base min: -20.000 uS max:  20.500 uS sdev:   4.800 uS
  131 secs  servo min: -22.600 uS max:  22.500 uS sdev:   1.700 uS
  132 secs   base min: -20.000 uS max:  20.500 uS sdev:   4.800 uS
  132 secs  servo min: -22.600 uS max:  22.500 uS sdev:   1.700 uS
  134 secs   base min: -20.000 uS max:  20.500 uS sdev:   4.800 uS
  134 secs  servo min: -22.600 uS max:  22.500 uS sdev:   1.700 uS
  135 secs   base min: -20.000 uS max:  20.500 uS sdev:   4.800 uS
  135 secs  servo min: -22.600 uS max:  22.500 uS sdev:   1.700 uS
  137 secs   base min: -20.000 uS max:  20.500 uS sdev:   4.800 uS
  137 secs  servo min: -22.600 uS max:  22.500 uS sdev:   1.700 uS
  138 secs   base min: -20.000 uS max:  20.500 uS sdev:   4.800 uS
  138 secs  servo min: -22.600 uS max:  22.500 uS sdev:   1.700 uS
  139 secs   base min: -20.000 uS max:  20.500 uS sdev:   4.800 uS
  139 secs  servo min: -22.600 uS max:  22.500 uS sdev:   1.700 uS
  141 secs   base min: -20.000 uS max:  20.500 uS sdev:   4.800 uS
  141 secs  servo min: -22.600 uS max:  22.500 uS sdev:   1.700 uS
  142 secs   base min: -20.000 uS max:  20.500 uS sdev:   4.800 uS
  142 secs  servo min: -22.600 uS max:  22.500 uS sdev:   1.700 uS
  143 secs   base min: -20.000 uS max:  20.500 uS sdev:   4.800 uS
  143 secs  servo min: -22.600 uS max:  22.500 uS sdev:   1.700 uS
  145 secs   base min: -20.000 uS max:  20.500 uS sdev:   4.800 uS
  145 secs  servo min: -22.600 uS max:  22.500 uS sdev:   1.700 uS
  146 secs   base min: -20.000 uS max:  20.500 uS sdev:   4.800 uS
  146 secs  servo min: -22.600 uS max:  22.500 uS sdev:   1.700 uS
  147 secs   base min: -20.000 uS max:  20.500 uS sdev:   4.800 uS
  147 secs  servo min: -22.600 uS max:  22.500 uS sdev:   1.700 uS
  149 secs   base min: -20.000 uS max:  20.500 uS sdev:   4.800 uS
  149 secs  servo min: -22.600 uS max:  22.500 uS sdev:   1.700 uS
  150 secs   base min: -20.000 uS max:  20.500 uS sdev:   4.800 uS
  150 secs  servo min: -22.600 uS max:  22.500 uS sdev:   1.700 uS
  151 secs   base min: -20.000 uS max:  20.500 uS sdev:   4.800 uS
  151 secs  servo min: -22.600 uS max:  22.500 uS sdev:   1.700 uS
  153 secs   base min: -20.000 uS max:  20.500 uS sdev:   4.800 uS
  153 secs  servo min: -22.600 uS max:  22.500 uS sdev:   1.700 uS
  154 secs   base min: -20.000 uS max:  20.500 uS sdev:   4.800 uS
  154 secs  servo min: -22.600 uS max:  22.500 uS sdev:   1.700 uS
  155 secs   base min: -20.000 uS max:  20.500 uS sdev:   4.800 uS
  155 secs  servo min: -22.600 uS max:  22.500 uS sdev:   1.700 uS
  157 secs   base min: -20.000 uS max:  20.500 uS sdev:   4.800 uS
  157 secs  servo min: -22.600 uS max:  22.500 uS sdev:   1.700 uS
  158 secs   base min: -20.000 uS max:  20.500 uS sdev:   4.800 uS
  158 secs  servo min: -22.600 uS max:  22.500 uS sdev:   1.700 uS
  159 secs   base min: -20.000 uS max:  20.500 uS sdev:   4.800 uS
  159 secs  servo min: -22.600 uS max:  22.500 uS sdev:   1.700 uS
  161 secs   base min: -20.000 uS max:  20.500 uS sdev:   4.800 uS
  161 secs  servo min: -22.600 uS max:  22.500 uS sdev:   1.700 uS
  162 secs   base min: -20.000 uS max:  20.500 uS sdev:   4.800 uS
  162 secs  servo min: -22.600 uS max:  22.500 uS sdev:   1.700 uS
  164 secs   base min: -20.000 uS max:  20.500 uS sdev:   4.800 uS
  164 secs  servo min: -22.600 uS max:  22.500 uS sdev:   1.700 uS
  165 secs   base min: -20.000 uS max:  20.500 uS sdev:   4.800 uS
  165 secs  servo min: -22.600 uS max:  22.500 uS sdev:   1.700 uS
  166 secs   base min: -20.000 uS max:  20.500 uS sdev:   4.800 uS
  166 secs  servo min: -22.600 uS max:  22.500 uS sdev:   1.700 uS
  168 secs   base min: -20.000 uS max:  20.500 uS sdev:   4.800 uS
  168 secs  servo min: -22.600 uS max:  22.500 uS sdev:   1.700 uS
  169 secs   base min: -20.000 uS max:  20.500 uS sdev:   4.800 uS
  169 secs  servo min: -22.600 uS max:  22.500 uS sdev:   1.700 uS
  170 secs   base min: -20.000 uS max:  20.500 uS sdev:   4.800 uS
  170 secs  servo min: -22.600 uS max:  22.500 uS sdev:   1.700 uS
  172 secs   base min: -20.000 uS max:  20.500 uS sdev:   4.800 uS
  172 secs  servo min: -23.700 uS max:  24.000 uS sdev:   1.700 uS
  173 secs   base min: -20.000 uS max:  20.500 uS sdev:   4.800 uS
  173 secs  servo min: -23.700 uS max:  24.000 uS sdev:   1.700 uS
  174 secs   base min: -20.000 uS max:  20.500 uS sdev:   4.800 uS
  174 secs  servo min: -23.700 uS max:  24.000 uS sdev:   1.700 uS
  176 secs   base min: -20.000 uS max:  20.500 uS sdev:   4.800 uS
  176 secs  servo min: -23.700 uS max:  24.000 uS sdev:   1.700 uS
  177 secs   base min: -20.000 uS max:  20.500 uS sdev:   4.800 uS
  177 secs  servo min: -23.700 uS max:  24.000 uS sdev:   1.700 uS
  178 secs   base min: -20.000 uS max:  20.500 uS sdev:   4.800 uS
  178 secs  servo min: -23.700 uS max:  24.000 uS sdev:   1.700 uS
  180 secs   base min: -20.000 uS max:  20.500 uS sdev:   4.800 uS
  180 secs  servo min: -23.700 uS max:  24.000 uS sdev:   1.700 uS
  181 secs   base min: -20.000 uS max:  20.500 uS sdev:   4.800 uS
  181 secs  servo min: -23.700 uS max:  24.000 uS sdev:   1.700 uS
  182 secs   base min: -20.000 uS max:  20.500 uS sdev:   4.800 uS
  182 secs  servo min: -23.700 uS max:  24.000 uS sdev:   1.700 uS
  184 secs   base min: -20.000 uS max:  20.500 uS sdev:   4.800 uS
  184 secs  servo min: -23.700 uS max:  24.000 uS sdev:   1.700 uS
  185 secs   base min: -20.000 uS max:  20.500 uS sdev:   4.800 uS
  185 secs  servo min: -23.700 uS max:  24.000 uS sdev:   1.700 uS
  186 secs   base min: -20.000 uS max:  20.500 uS sdev:   4.800 uS
  186 secs  servo min: -23.700 uS max:  24.000 uS sdev:   1.700 uS
  188 secs   base min: -20.000 uS max:  20.500 uS sdev:   4.800 uS
  188 secs  servo min: -23.700 uS max:  24.000 uS sdev:   1.700 uS
  189 secs   base min: -20.000 uS max:  20.500 uS sdev:   4.800 uS
  189 secs  servo min: -23.700 uS max:  24.000 uS sdev:   1.700 uS
  190 secs   base min: -22.700 uS max:  21.900 uS sdev:   4.800 uS
  190 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.700 uS
  192 secs   base min: -22.700 uS max:  21.900 uS sdev:   4.800 uS
  192 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.700 uS
  193 secs   base min: -22.700 uS max:  21.900 uS sdev:   4.800 uS
  193 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.700 uS
  194 secs   base min: -22.700 uS max:  22.900 uS sdev:   4.800 uS
  194 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.700 uS
  196 secs   base min: -22.700 uS max:  22.900 uS sdev:   4.800 uS
  196 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.700 uS
  197 secs   base min: -22.700 uS max:  22.900 uS sdev:   4.800 uS
  197 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.700 uS
  198 secs   base min: -22.700 uS max:  22.900 uS sdev:   4.800 uS
  198 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.700 uS
  200 secs   base min: -22.700 uS max:  22.900 uS sdev:   4.800 uS
  200 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.700 uS
  201 secs   base min: -22.700 uS max:  22.900 uS sdev:   4.700 uS
  201 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.700 uS
  202 secs   base min: -22.700 uS max:  22.900 uS sdev:   4.700 uS
  202 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.700 uS
  204 secs   base min: -22.700 uS max:  22.900 uS sdev:   4.700 uS
  204 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.700 uS
  205 secs   base min: -22.700 uS max:  22.900 uS sdev:   4.700 uS
  205 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.700 uS
  206 secs   base min: -22.700 uS max:  22.900 uS sdev:   4.700 uS
  206 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.700 uS
  208 secs   base min: -22.700 uS max:  22.900 uS sdev:   4.700 uS
  208 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.700 uS
  209 secs   base min: -22.700 uS max:  22.900 uS sdev:   4.700 uS
  209 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.700 uS
  210 secs   base min: -22.700 uS max:  22.900 uS sdev:   4.700 uS
  210 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.700 uS
  212 secs   base min: -22.700 uS max:  22.900 uS sdev:   4.700 uS
  212 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.700 uS
  213 secs   base min: -22.700 uS max:  22.900 uS sdev:   4.700 uS
  213 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.700 uS
  214 secs   base min: -22.700 uS max:  22.900 uS sdev:   4.700 uS
  214 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.700 uS
  216 secs   base min: -22.700 uS max:  22.900 uS sdev:   4.700 uS
  216 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.700 uS
  217 secs   base min: -22.700 uS max:  22.900 uS sdev:   4.700 uS
  217 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.700 uS
  219 secs   base min: -22.700 uS max:  22.900 uS sdev:   4.700 uS
  219 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.700 uS
  220 secs   base min: -22.700 uS max:  22.900 uS sdev:   4.700 uS
  220 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.700 uS
  221 secs   base min: -22.700 uS max:  22.900 uS sdev:   4.700 uS
  221 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.700 uS
  223 secs   base min: -22.700 uS max:  22.900 uS sdev:   4.700 uS
  223 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.700 uS
  224 secs   base min: -22.700 uS max:  22.900 uS sdev:   4.700 uS
  224 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.700 uS
  225 secs   base min: -22.700 uS max:  22.900 uS sdev:   4.700 uS
  225 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.700 uS
  227 secs   base min: -22.700 uS max:  22.900 uS sdev:   4.700 uS
  227 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.700 uS
  228 secs   base min: -22.700 uS max:  22.900 uS sdev:   4.700 uS
  228 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.700 uS
  229 secs   base min: -22.700 uS max:  22.900 uS sdev:   4.700 uS
  229 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.700 uS
  231 secs   base min: -22.700 uS max:  22.900 uS sdev:   4.700 uS
  231 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.700 uS
  232 secs   base min: -22.700 uS max:  22.900 uS sdev:   4.700 uS
  232 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.700 uS
  234 secs   base min: -22.700 uS max:  22.900 uS sdev:   4.700 uS
  234 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.700 uS
  235 secs   base min: -22.700 uS max:  22.900 uS sdev:   4.700 uS
  235 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.700 uS
  236 secs   base min: -22.700 uS max:  22.900 uS sdev:   4.700 uS
  236 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.700 uS
  238 secs   base min: -22.700 uS max:  22.900 uS sdev:   4.700 uS
  238 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.700 uS
  239 secs   base min: -22.700 uS max:  22.900 uS sdev:   4.700 uS
  239 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.700 uS
  240 secs   base min: -22.700 uS max:  22.900 uS sdev:   4.700 uS
  240 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.700 uS
  242 secs   base min: -22.700 uS max:  22.900 uS sdev:   4.700 uS
  242 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.700 uS
  243 secs   base min: -22.700 uS max:  22.900 uS sdev:   4.700 uS
  243 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.700 uS
  244 secs   base min: -22.700 uS max:  22.900 uS sdev:   4.700 uS
  244 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.700 uS
  246 secs   base min: -22.700 uS max:  22.900 uS sdev:   4.700 uS
  246 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.700 uS
  247 secs   base min: -22.700 uS max:  22.900 uS sdev:   4.700 uS
  247 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.700 uS
  248 secs   base min: -22.700 uS max:  22.900 uS sdev:   4.700 uS
  248 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.700 uS
  250 secs   base min: -22.700 uS max:  22.900 uS sdev:   4.800 uS
  250 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.700 uS
  251 secs   base min: -22.700 uS max:  22.900 uS sdev:   4.800 uS
  251 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.700 uS
  252 secs   base min: -22.700 uS max:  22.900 uS sdev:   4.800 uS
  252 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.700 uS
  254 secs   base min: -22.700 uS max:  22.900 uS sdev:   4.800 uS
  254 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.700 uS
  255 secs   base min: -22.700 uS max:  22.900 uS sdev:   4.800 uS
  255 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.700 uS
  257 secs   base min: -22.700 uS max:  22.900 uS sdev:   4.800 uS
  257 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.700 uS
  258 secs   base min: -22.700 uS max:  22.900 uS sdev:   4.800 uS
  258 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.700 uS
  259 secs   base min: -22.700 uS max:  22.900 uS sdev:   4.800 uS
  259 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.700 uS
  261 secs   base min: -22.700 uS max:  22.900 uS sdev:   4.800 uS
  261 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.700 uS
  262 secs   base min: -22.700 uS max:  22.900 uS sdev:   4.800 uS
  262 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.700 uS
  263 secs   base min: -22.700 uS max:  22.900 uS sdev:   4.800 uS
  263 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.700 uS
  265 secs   base min: -22.700 uS max:  22.900 uS sdev:   4.800 uS
  265 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.700 uS
  266 secs   base min: -22.700 uS max:  22.900 uS sdev:   4.800 uS
  266 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.700 uS
  267 secs   base min: -22.700 uS max:  22.900 uS sdev:   4.800 uS
  267 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.700 uS
  269 secs   base min: -22.700 uS max:  22.900 uS sdev:   4.800 uS
  269 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.700 uS
  270 secs   base min: -22.700 uS max:  22.900 uS sdev:   4.800 uS
  270 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.700 uS
  271 secs   base min: -22.700 uS max:  22.900 uS sdev:   4.800 uS
  271 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.700 uS
  273 secs   base min: -22.700 uS max:  22.900 uS sdev:   4.800 uS
  273 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.700 uS
  274 secs   base min: -22.700 uS max:  22.900 uS sdev:   4.800 uS
  274 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.700 uS
  275 secs   base min: -22.700 uS max:  22.900 uS sdev:   4.800 uS
  275 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.700 uS
  277 secs   base min: -22.700 uS max:  22.900 uS sdev:   4.800 uS
  277 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.700 uS
  278 secs   base min: -22.700 uS max:  22.900 uS sdev:   4.800 uS
  278 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.700 uS
  279 secs   base min: -22.700 uS max:  22.900 uS sdev:   4.800 uS
  279 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.700 uS
  281 secs   base min: -22.700 uS max:  22.900 uS sdev:   4.800 uS
  281 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.700 uS
  282 secs   base min: -22.700 uS max:  22.900 uS sdev:   4.800 uS
  282 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.700 uS
  284 secs   base min: -22.700 uS max:  22.900 uS sdev:   4.800 uS
  284 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.700 uS
  285 secs   base min: -22.700 uS max:  22.900 uS sdev:   4.800 uS
  285 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.700 uS
  286 secs   base min: -22.700 uS max:  22.900 uS sdev:   4.800 uS
  286 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.700 uS
  288 secs   base min: -22.700 uS max:  22.900 uS sdev:   4.800 uS
  288 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.700 uS
  289 secs   base min: -22.700 uS max:  22.900 uS sdev:   4.800 uS
  289 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.700 uS
  290 secs   base min: -22.700 uS max:  22.900 uS sdev:   4.800 uS
  290 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.700 uS
  292 secs   base min: -22.700 uS max:  22.900 uS sdev:   4.800 uS
  292 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.700 uS
  293 secs   base min: -22.700 uS max:  22.900 uS sdev:   4.800 uS
  293 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.700 uS
  294 secs   base min: -22.700 uS max:  22.900 uS sdev:   4.800 uS
  294 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.700 uS
  296 secs   base min: -22.700 uS max:  22.900 uS sdev:   4.800 uS
  296 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.700 uS
  297 secs   base min: -22.700 uS max:  22.900 uS sdev:   4.800 uS
  297 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.700 uS
  298 secs   base min: -22.700 uS max:  22.900 uS sdev:   4.800 uS
  298 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.700 uS
  300 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  300 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.700 uS
  301 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  301 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.700 uS
  302 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  302 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.700 uS
  304 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  304 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.700 uS
  305 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  305 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.700 uS
  306 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  306 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.700 uS
  308 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  308 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.600 uS
  309 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  309 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.600 uS
  311 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  311 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.600 uS
  312 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  312 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.600 uS
  313 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  313 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.600 uS
  315 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  315 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.600 uS
  316 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  316 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.600 uS
  317 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  317 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.600 uS
  319 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  319 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.600 uS
  320 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  320 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.600 uS
  321 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  321 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.600 uS
  323 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  323 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.600 uS
  324 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  324 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.600 uS
  325 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  325 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.600 uS
  327 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  327 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.600 uS
  328 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  328 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.600 uS
  329 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  329 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.600 uS
  331 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  331 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.600 uS
  332 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  332 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.600 uS
  333 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  333 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.600 uS
  335 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  335 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.600 uS
  336 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  336 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.600 uS
  337 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  337 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.600 uS
  339 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  339 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.600 uS
  340 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  340 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.600 uS
  342 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  342 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.600 uS
  343 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  343 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.600 uS
  344 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  344 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.600 uS
  346 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  346 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.600 uS
  347 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  347 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.600 uS
  348 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  348 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.600 uS
  350 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  350 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.600 uS
  351 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  351 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.600 uS
  352 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  352 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.600 uS
  354 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  354 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.600 uS
  355 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  355 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.600 uS
  356 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  356 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.600 uS
  358 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  358 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.600 uS
  359 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  359 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.600 uS
  360 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  360 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.600 uS
  362 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  362 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.600 uS
  363 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  363 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.600 uS
  364 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  364 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.600 uS
  366 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  366 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.600 uS
  367 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  367 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.600 uS
  369 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  369 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.600 uS
  370 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  370 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.600 uS
  371 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  371 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.600 uS
  373 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  373 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.600 uS
  374 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  374 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.600 uS
  375 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  375 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.600 uS
  377 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  377 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.600 uS
  378 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  378 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.600 uS
  379 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  379 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.600 uS
  381 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  381 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.600 uS
  382 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  382 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.600 uS
  383 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  383 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.600 uS
  385 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  385 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.600 uS
  386 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  386 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.600 uS
  388 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  388 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.600 uS
  389 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  389 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.600 uS
  390 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  390 secs  servo min: -25.300 uS max:  25.500 uS sdev:   1.600 uS
  392 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  392 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  393 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  393 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  394 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  394 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  396 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  396 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  397 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  397 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  398 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  398 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  400 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  400 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  401 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  401 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  402 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  402 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  404 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  404 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  405 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  405 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  406 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  406 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  408 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  408 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  409 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  409 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  411 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  411 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  412 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  412 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  413 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  413 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  415 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  415 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  416 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  416 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  417 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  417 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  419 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  419 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  420 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  420 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  421 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  421 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  423 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  423 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  424 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  424 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  425 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  425 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  427 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  427 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  428 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  428 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  430 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  430 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  431 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  431 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  432 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  432 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  434 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  434 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  435 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  435 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  436 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  436 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  438 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  438 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  439 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  439 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  440 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  440 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  442 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  442 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  443 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  443 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  444 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  444 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  446 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  446 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  447 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  447 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  448 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  448 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  450 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  450 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  451 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  451 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  452 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  452 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  454 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  454 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  455 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  455 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  457 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  457 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  458 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  458 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  459 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  459 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  461 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  461 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  462 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  462 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  463 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  463 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  465 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  465 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  466 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  466 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  467 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  467 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  469 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  469 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  470 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  470 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  471 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  471 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  473 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  473 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  474 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  474 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  475 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  475 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  477 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  477 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  478 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  478 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  479 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  479 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  481 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  481 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  482 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  482 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  483 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  483 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  485 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  485 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  486 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  486 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  488 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  488 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  489 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  489 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  490 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  490 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  492 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  492 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  493 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  493 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  494 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  494 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  496 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  496 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  497 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  497 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  498 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  498 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  500 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  500 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  501 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  501 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  502 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  502 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  504 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  504 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  505 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  505 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  506 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  506 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  508 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  508 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  509 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  509 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  510 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  510 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  512 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  512 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  513 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  513 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  515 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  515 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  516 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  516 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  517 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  517 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  519 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  519 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  520 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  520 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  521 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  521 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  523 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  523 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  524 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  524 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  525 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  525 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  527 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  527 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  528 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  528 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  529 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  529 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  531 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  531 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  532 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  532 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  533 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  533 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  535 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  535 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  536 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  536 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  538 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  538 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  539 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  539 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  540 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  540 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  542 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  542 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  543 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  543 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  544 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  544 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  546 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  546 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  547 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  547 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  549 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  549 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  550 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  550 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  551 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  551 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  553 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  553 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  554 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  554 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  555 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  555 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  557 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  557 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  558 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  558 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  559 secs   base min: -26.000 uS max:  26.000 uS sdev:   4.800 uS
  559 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  561 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  561 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  562 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  562 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  563 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  563 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  565 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  565 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  566 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  566 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  567 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  567 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  569 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  569 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  570 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  570 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  571 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  571 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  573 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  573 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  574 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  574 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  575 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  575 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  577 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  577 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  578 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  578 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  580 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  580 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  581 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  581 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  582 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  582 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  584 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  584 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  585 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  585 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  586 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  586 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  588 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  588 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  589 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  589 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  590 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  590 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  592 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  592 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  593 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  593 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  594 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  594 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  596 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  596 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  597 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  597 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  598 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  598 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  600 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  600 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  601 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  601 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  603 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  603 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  604 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  604 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  605 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  605 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  607 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  607 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  608 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  608 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  609 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  609 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  611 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  611 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  612 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  612 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  613 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  613 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  615 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  615 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  616 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  616 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  617 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  617 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  619 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  619 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  620 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  620 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  621 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  621 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  623 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  623 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  624 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  624 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  625 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  625 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  627 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  627 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  628 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  628 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  630 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  630 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  631 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  631 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  632 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  632 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  634 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  634 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  635 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  635 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  636 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  636 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  638 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  638 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  639 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  639 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  640 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  640 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  642 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  642 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  643 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  643 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  644 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  644 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  646 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  646 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  647 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  647 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  648 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  648 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  650 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  650 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  651 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  651 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  653 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  653 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  654 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  654 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  655 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  655 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  657 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  657 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  658 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  658 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  659 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  659 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  661 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  661 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  662 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  662 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  663 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  663 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  665 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  665 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  666 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  666 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  667 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  667 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  669 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  669 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  670 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  670 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  671 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  671 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  673 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  673 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  674 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  674 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  675 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  675 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  677 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  677 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  678 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
Core 0:       +30.0°C  (high = +76.0°C, crit = +100.0°C)
  678 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  680 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  680 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  681 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  681 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  682 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  682 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  684 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  684 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  685 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  685 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  686 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  686 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  688 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  688 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  689 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  689 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  690 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  690 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  692 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  692 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  693 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  693 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  694 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  694 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  696 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  696 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  697 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  697 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  698 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  698 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  700 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  700 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  701 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  701 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  702 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  702 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  704 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  704 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  705 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  705 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  707 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  707 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  708 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  708 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  709 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  709 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  711 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  711 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  712 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  712 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  713 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  713 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  715 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  715 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  716 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  716 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  717 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  717 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  719 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  719 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  720 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  720 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  721 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  721 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  723 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  723 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  724 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  724 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  725 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  725 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  727 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  727 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  728 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  728 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  729 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  729 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  731 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  731 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  732 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  732 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  734 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  734 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  735 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  735 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  736 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  736 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  738 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  738 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  739 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  739 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  740 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  740 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  742 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  742 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  743 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  743 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  744 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  744 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  746 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  746 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  747 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  747 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  748 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  748 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  750 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  750 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  751 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  751 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  752 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  752 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  754 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  754 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  755 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  755 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  756 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  756 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  758 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  758 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  759 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  759 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  761 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  761 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  762 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  762 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  763 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  763 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  765 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  765 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  766 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  766 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  767 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  767 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  769 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  769 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  770 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  770 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  771 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  771 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  773 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  773 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  774 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  774 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  775 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  775 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  777 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  777 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  778 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  778 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  779 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  779 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  781 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  781 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  782 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  782 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  783 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  783 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  785 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  785 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  786 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  786 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  787 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  787 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  789 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  789 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  790 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  790 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  792 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  792 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  793 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  793 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  794 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  794 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  796 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  796 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  797 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  797 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  798 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  798 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  800 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  800 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  801 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  801 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  802 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  802 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  804 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  804 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  805 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  805 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  806 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  806 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  808 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  808 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  809 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  809 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  810 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  810 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  812 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  812 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  813 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  813 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  815 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  815 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  816 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  816 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  817 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  817 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  819 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  819 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  820 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  820 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  821 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  821 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  823 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  823 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  824 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  824 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  825 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  825 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  827 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  827 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  828 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  828 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  829 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  829 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  831 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  831 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  832 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  832 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  833 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  833 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  835 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  835 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  836 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  836 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  837 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  837 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  839 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  839 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  840 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  840 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  842 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  842 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  843 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  843 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  844 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  844 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  846 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  846 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  847 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  847 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  848 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  848 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  850 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  850 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  851 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  851 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  853 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  853 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  854 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  854 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  855 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  855 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  857 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  857 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  858 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  858 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  859 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  859 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  861 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  861 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  862 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  862 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  863 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  863 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  865 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  865 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  866 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  866 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  867 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  867 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  869 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  869 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  870 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  870 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  871 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  871 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  873 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  873 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  874 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  874 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  875 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  875 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  877 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  877 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  878 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  878 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  880 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  880 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  881 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  881 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  882 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  882 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  884 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  884 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  885 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  885 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  886 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  886 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  888 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  888 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  889 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  889 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  890 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  890 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  892 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  892 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  893 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  893 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  894 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  894 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  896 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  896 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  897 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  897 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  898 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  898 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  900 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  900 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  901 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  901 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  903 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  903 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  904 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  904 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  905 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  905 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  907 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  907 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  908 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  908 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  909 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  909 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  911 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  911 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  912 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  912 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  913 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  913 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  915 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  915 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  916 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  916 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  917 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  917 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  919 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  919 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  920 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  920 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  921 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  921 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  923 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  923 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  924 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  924 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  925 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  925 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  927 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  927 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  928 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  928 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  930 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  930 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  931 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  931 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  932 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  932 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  934 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  934 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  935 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  935 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  936 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  936 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  938 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  938 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  939 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  939 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  940 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  940 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  942 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  942 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  943 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  943 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  944 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  944 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  946 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  946 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  947 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  947 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  948 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  948 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  950 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  950 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  951 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  951 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  952 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  952 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  954 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  954 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  955 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  955 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  957 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  957 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  958 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  958 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  959 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  959 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  961 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  961 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  962 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  962 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  963 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  963 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  965 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  965 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  966 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  966 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  967 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  967 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  969 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  969 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  970 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  970 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  971 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  971 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  973 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  973 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  974 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  974 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  975 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  975 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  977 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  977 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  978 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  978 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  979 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  979 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  981 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  981 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  982 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  982 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  984 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  984 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  985 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  985 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  986 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  986 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  988 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  988 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  989 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  989 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  990 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  990 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  992 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  992 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  993 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  993 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  994 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  994 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  996 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  996 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  997 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  997 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
  998 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
  998 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1000 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
 1000 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1001 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
 1001 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1002 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
 1002 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1004 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
 1004 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1005 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
 1005 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1006 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
 1006 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1008 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
 1008 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1009 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
 1009 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1011 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
 1011 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1012 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
 1012 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1013 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
 1013 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1015 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
 1015 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1016 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
 1016 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1017 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
 1017 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1019 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
 1019 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1020 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
 1020 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1021 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
 1021 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1023 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
 1023 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1024 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
 1024 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1025 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
 1025 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1027 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
 1027 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1028 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
 1028 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1029 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
 1029 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1031 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
 1031 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1032 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
 1032 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1034 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
 1034 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1035 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
 1035 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1036 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
 1036 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1038 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
 1038 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1039 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
 1039 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1040 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
 1040 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1042 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
 1042 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1043 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
 1043 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1044 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
 1044 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1046 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
 1046 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1047 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
 1047 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1048 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
 1048 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1050 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
 1050 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1051 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
 1051 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1052 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
 1052 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1054 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
 1054 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1055 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
 1055 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1056 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
 1056 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1058 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
 1058 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1059 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
 1059 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1061 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
 1061 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1062 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
 1062 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1063 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
 1063 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1065 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
 1065 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1066 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
 1066 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1067 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
 1067 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1069 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
 1069 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1070 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
 1070 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1071 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
 1071 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1073 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
 1073 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1074 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
 1074 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1075 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
 1075 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1077 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
 1077 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1078 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
 1078 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1079 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
 1079 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1081 secs   base min: -27.000 uS max:  28.300 uS sdev:   4.800 uS
 1081 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1082 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1082 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1083 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1083 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1085 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1085 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1086 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1086 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1088 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1088 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1089 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1089 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1090 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1090 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1092 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1092 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1093 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1093 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1094 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1094 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1096 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1096 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1097 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1097 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1099 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1099 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1100 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1100 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1101 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1101 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1103 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1103 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1104 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1104 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1105 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1105 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1107 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1107 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1108 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1108 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1109 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1109 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1111 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1111 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1112 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1112 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1113 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1113 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1115 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1115 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1116 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1116 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1117 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1117 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1119 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1119 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1120 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1120 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1122 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1122 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1123 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1123 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1124 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1124 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1126 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1126 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1127 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1127 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1128 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1128 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1130 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1130 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1131 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1131 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1132 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1132 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1134 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1134 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1135 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1135 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1136 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1136 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1138 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1138 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1139 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1139 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1140 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1140 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1142 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1142 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1143 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1143 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1144 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1144 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1146 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1146 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1147 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1147 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1149 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1149 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1150 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1150 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1151 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1151 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1153 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1153 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1154 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1154 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1155 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1155 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1157 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1157 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1158 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1158 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1159 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1159 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1161 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1161 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1162 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1162 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1163 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1163 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1165 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1165 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1166 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1166 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1167 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1167 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1169 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1169 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1170 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1170 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1172 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1172 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1173 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1173 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1174 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1174 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1176 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1176 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1177 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1177 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1178 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1178 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1180 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1180 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1181 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1181 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1183 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1183 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1184 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1184 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1185 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1185 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1187 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1187 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1188 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1188 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1189 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1189 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1191 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1191 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1192 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1192 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1193 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1193 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1195 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1195 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1196 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1196 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1197 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1197 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1199 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1199 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1200 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1200 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1201 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1201 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1203 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1203 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1204 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1204 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1205 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1205 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1207 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1207 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1208 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1208 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1209 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1209 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1211 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1211 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1212 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1212 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1213 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1213 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1215 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1215 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1216 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1216 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1218 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1218 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1219 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1219 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1220 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1220 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1222 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1222 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1223 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1223 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1224 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1224 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1226 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1226 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1227 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1227 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1228 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1228 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1230 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1230 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1231 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1231 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1232 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1232 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1234 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1234 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1235 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1235 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1237 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1237 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1238 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1238 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1239 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1239 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1241 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1241 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1242 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1242 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1243 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1243 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1245 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1245 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1246 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1246 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1247 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1247 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1249 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1249 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1250 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1250 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1251 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1251 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1253 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1253 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1254 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1254 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1255 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1255 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1257 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1257 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1258 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1258 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1259 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1259 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1261 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1261 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1262 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1262 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1264 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1264 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1265 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1265 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1266 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1266 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1268 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1268 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1269 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1269 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1270 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1270 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1272 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1272 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1273 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1273 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1274 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1274 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1276 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1276 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1277 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1277 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1278 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1278 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1280 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1280 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1281 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1281 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1282 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1282 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1284 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1284 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1285 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1285 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1287 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1287 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1288 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1288 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1289 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1289 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1291 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1291 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1292 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1292 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1293 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1293 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1295 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1295 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1296 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1296 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1297 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1297 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1299 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1299 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1300 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1300 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1301 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1301 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1303 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1303 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1304 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1304 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1305 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1305 secs  servo min: -30.300 uS max:  29.600 uS sdev:   1.600 uS
 1307 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1307 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1308 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1308 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1309 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1309 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1311 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1311 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1312 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1312 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1314 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1314 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1315 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1315 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1316 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1316 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1318 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1318 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1319 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1319 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1320 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1320 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1322 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1322 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1323 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1323 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1325 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1325 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1326 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1326 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1327 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1327 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1329 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1329 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1330 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1330 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1331 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1331 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1333 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1333 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1334 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1334 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1335 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1335 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1337 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1337 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1338 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1338 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1339 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1339 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1341 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1341 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1342 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1342 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1343 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1343 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
Core 0:       +30.0°C  (high = +76.0°C, crit = +100.0°C)
 1345 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1345 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1346 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1346 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1348 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1348 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1349 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1349 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1350 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1350 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1352 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1352 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1353 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1353 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1354 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1354 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1356 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1356 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1357 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1357 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1358 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1358 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1360 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1360 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1361 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1361 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1362 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1362 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1364 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1364 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1365 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1365 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1366 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1366 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1368 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1368 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1369 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1369 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1370 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1370 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1372 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1372 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1373 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1373 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1375 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1375 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1376 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1376 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1377 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1377 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1379 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1379 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1380 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1380 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1381 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1381 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1383 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1383 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1384 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1384 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1385 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1385 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1387 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1387 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1388 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1388 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1389 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1389 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1391 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1391 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1392 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1392 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1394 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1394 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1395 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1395 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1396 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1396 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1398 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1398 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1399 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1399 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1400 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1400 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1402 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1402 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1403 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1403 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1404 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1404 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1406 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1406 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1407 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1407 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1408 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1408 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1410 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1410 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1411 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1411 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1413 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1413 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1414 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1414 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1415 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1415 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1417 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1417 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1418 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1418 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1419 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1419 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1421 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1421 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1422 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1422 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1423 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1423 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1425 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1425 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1426 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1426 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1427 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1427 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1429 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1429 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1430 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1430 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1431 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1431 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1433 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1433 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1434 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1434 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1435 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1435 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1437 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1437 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1438 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1438 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1440 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1440 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1441 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1441 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1442 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1442 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1444 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1444 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1445 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1445 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1446 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1446 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1448 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1448 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1449 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1449 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1450 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1450 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1452 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1452 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1453 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1453 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1454 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1454 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1456 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1456 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1457 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1457 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1458 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1458 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1460 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1460 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1461 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1461 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1462 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1462 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1464 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1464 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1465 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1465 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1467 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1467 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1468 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1468 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1469 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1469 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1471 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1471 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1472 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1472 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1473 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1473 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1475 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1475 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1476 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1476 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1477 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1477 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1479 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1479 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1480 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1480 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1481 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1481 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1483 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1483 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1484 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1484 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1485 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1485 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1487 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1487 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1488 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1488 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1489 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1489 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1491 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1491 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1492 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1492 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1494 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1494 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1495 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1495 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1496 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1496 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1498 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1498 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1499 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1499 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1500 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1500 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1502 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1502 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1503 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1503 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1504 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1504 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1506 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1506 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1507 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1507 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1508 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1508 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1510 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1510 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1511 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1511 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1512 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1512 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1514 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1514 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1515 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1515 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1516 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1516 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1518 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1518 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1519 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1519 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1521 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1521 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1522 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1522 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1523 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1523 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1525 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1525 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1526 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1526 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1527 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1527 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1529 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1529 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1530 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1530 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1531 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1531 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1533 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1533 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1534 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1534 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1535 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1535 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1537 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1537 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1538 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1538 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1539 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1539 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1541 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1541 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1542 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1542 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1543 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1543 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1545 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1545 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1546 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1546 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1548 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1548 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1549 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1549 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1550 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1550 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1552 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1552 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1553 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1553 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1554 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1554 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1556 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1556 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1557 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1557 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1558 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1558 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1560 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1560 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1561 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1561 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1562 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1562 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1564 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1564 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1565 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1565 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1566 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1566 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1568 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1568 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1569 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1569 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1570 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1570 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1572 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1572 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1573 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1573 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1575 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1575 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1576 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1576 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1577 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1577 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1579 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1579 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1580 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1580 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1581 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1581 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1583 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1583 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1584 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1584 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1585 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1585 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1587 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1587 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1588 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1588 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1589 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1589 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1591 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1591 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1592 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1592 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1593 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1593 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1595 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1595 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1596 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1596 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1598 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1598 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1599 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1599 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1600 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1600 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1602 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1602 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1603 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1603 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1604 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1604 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1606 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1606 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1607 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1607 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1608 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1608 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1610 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1610 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1611 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1611 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1612 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1612 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1614 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1614 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1615 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1615 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1616 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1616 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1618 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1618 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1619 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1619 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1620 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1620 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1622 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1622 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1623 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1623 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1624 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1624 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1626 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1626 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1627 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1627 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1629 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1629 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1630 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1630 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1631 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1631 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1633 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1633 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1634 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1634 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1635 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1635 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1637 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1637 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1638 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1638 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1639 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1639 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1641 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1641 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1642 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1642 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1643 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1643 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1645 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1645 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1646 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1646 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1647 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1647 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1649 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1649 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1650 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1650 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1652 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1652 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1653 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1653 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1654 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1654 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1656 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1656 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1657 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1657 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1658 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1658 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1660 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1660 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1661 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1661 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1663 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1663 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1664 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1664 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1665 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1665 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1667 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1667 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1668 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1668 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1669 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1669 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1671 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1671 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1672 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1672 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1673 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1673 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1675 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1675 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1676 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1676 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1677 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1677 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1679 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1679 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1680 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1680 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1681 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1681 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1683 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1683 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1684 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1684 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1685 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1685 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1687 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1687 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1688 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1688 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1690 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1690 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1691 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1691 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1692 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1692 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1694 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1694 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1695 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1695 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1696 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1696 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1698 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1698 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1699 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1699 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1700 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1700 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1702 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1702 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1703 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1703 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1704 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1704 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1706 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1706 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1707 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1707 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1708 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1708 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1710 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1710 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1711 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1711 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1712 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1712 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1714 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1714 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1715 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1715 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1717 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1717 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1718 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1718 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1719 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1719 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1721 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1721 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1722 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1722 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1723 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1723 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1725 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1725 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1726 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1726 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1727 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1727 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1729 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1729 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1730 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1730 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1731 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1731 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1733 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1733 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1734 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1734 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1735 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1735 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1737 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1737 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1738 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1738 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1739 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1739 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1741 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1741 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1742 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1742 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1744 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1744 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1745 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1745 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1746 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1746 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1748 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1748 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1749 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1749 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1750 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1750 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1752 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1752 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1753 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1753 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1754 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1754 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1756 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1756 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1757 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1757 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1758 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1758 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1760 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1760 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1761 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1761 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1762 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1762 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1764 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1764 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1765 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1765 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1766 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1766 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1768 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1768 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1769 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1769 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1771 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1771 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1772 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1772 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1773 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1773 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1775 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1775 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1776 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1776 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1777 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1777 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1779 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1779 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1780 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1780 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1782 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1782 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1783 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1783 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1784 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1784 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1786 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1786 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1787 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1787 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1788 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1788 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1790 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1790 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1791 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1791 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1792 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1792 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1794 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1794 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1795 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1795 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1796 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1796 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1798 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1798 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1799 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1799 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1800 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1800 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1802 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1802 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1803 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1803 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1804 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1804 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1806 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1806 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1807 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1807 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1809 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1809 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1810 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1810 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1811 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1811 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1813 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1813 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1814 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1814 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1815 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1815 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1817 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1817 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1818 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1818 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1819 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1819 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1821 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1821 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1822 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1822 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1823 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1823 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1825 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1825 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1826 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1826 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1827 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1827 secs  servo min: -30.400 uS max:  29.600 uS sdev:   1.600 uS
 1829 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1829 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 1830 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1830 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 1831 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1831 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 1833 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1833 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 1834 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1834 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 1835 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1835 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 1837 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1837 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 1838 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1838 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 1840 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1840 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 1841 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1841 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 1842 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1842 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 1844 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1844 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 1845 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1845 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 1846 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1846 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 1848 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1848 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 1849 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1849 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 1850 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1850 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 1852 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1852 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 1853 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1853 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 1854 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1854 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 1856 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1856 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 1857 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1857 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 1858 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1858 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 1860 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1860 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 1861 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1861 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 1863 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1863 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 1864 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1864 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 1865 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1865 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 1867 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1867 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 1868 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1868 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 1869 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1869 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 1871 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1871 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 1872 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1872 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 1873 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1873 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 1875 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1875 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 1876 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1876 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 1877 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1877 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 1879 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1879 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 1880 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1880 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 1881 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1881 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 1883 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1883 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 1884 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1884 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 1885 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1885 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 1887 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1887 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 1888 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1888 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 1890 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1890 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 1891 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1891 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 1892 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1892 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 1894 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1894 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 1895 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1895 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 1896 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1896 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 1898 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1898 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 1899 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1899 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 1900 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1900 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 1902 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1902 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 1903 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1903 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 1904 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1904 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 1906 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1906 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 1907 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1907 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 1908 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1908 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 1910 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1910 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 1911 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1911 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 1913 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1913 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 1914 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1914 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 1915 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1915 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 1917 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1917 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 1918 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1918 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 1919 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1919 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 1921 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1921 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 1922 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1922 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 1924 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1924 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 1925 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1925 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 1926 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1926 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 1928 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1928 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 1929 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1929 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 1930 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1930 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 1932 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1932 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 1933 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1933 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 1934 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1934 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 1936 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1936 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 1937 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1937 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 1938 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1938 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 1940 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1940 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 1941 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1941 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 1942 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1942 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 1944 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1944 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 1945 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1945 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 1946 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1946 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 1948 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1948 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 1949 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1949 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 1951 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1951 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 1952 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1952 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 1953 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1953 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 1955 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1955 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 1956 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1956 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 1957 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1957 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 1959 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1959 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 1960 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1960 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 1961 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1961 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 1963 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1963 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 1964 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1964 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 1965 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1965 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 1967 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1967 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 1968 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1968 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 1969 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1969 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 1971 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1971 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 1972 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1972 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 1973 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1973 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 1975 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1975 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 1976 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1976 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 1978 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1978 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 1979 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1979 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 1980 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1980 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 1982 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1982 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 1983 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1983 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 1984 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1984 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 1986 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1986 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 1987 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1987 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 1989 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1989 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 1990 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1990 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 1991 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1991 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 1993 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1993 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 1994 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1994 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 1995 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1995 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 1997 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1997 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 1998 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1998 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 1999 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 1999 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2001 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2001 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2002 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2002 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2003 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2003 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2005 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2005 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2006 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2006 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2007 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
Core 0:       +30.0°C  (high = +76.0°C, crit = +100.0°C)
 2007 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2009 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2009 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2010 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2010 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2011 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2011 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2013 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2013 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2014 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2014 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2016 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2016 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2017 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2017 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2018 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2018 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2020 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2020 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2021 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2021 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2022 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2022 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2024 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2024 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2025 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2025 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2026 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2026 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2028 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2028 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2029 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2029 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2030 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2030 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2032 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2032 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2033 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2033 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2034 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2034 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2036 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2036 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2037 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2037 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2039 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2039 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2040 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2040 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2041 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2041 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2043 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2043 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2044 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2044 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2045 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2045 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2047 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2047 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2048 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2048 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2049 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2049 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2051 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2051 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2052 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2052 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2053 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2053 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2055 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2055 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2056 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2056 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2057 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2057 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2059 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2059 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2060 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2060 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2061 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2061 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2063 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2063 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2064 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2064 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2066 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2066 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2067 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2067 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2068 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2068 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2070 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2070 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2071 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2071 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2072 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2072 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2074 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2074 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2075 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2075 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2076 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2076 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2078 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2078 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2079 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2079 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2080 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2080 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2082 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2082 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2083 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2083 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2084 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2084 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2086 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2086 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2087 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2087 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2088 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2088 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2090 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2090 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2091 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2091 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2093 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2093 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2094 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2094 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2095 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2095 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2097 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2097 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2098 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2098 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2099 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2099 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2101 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2101 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2102 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2102 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2104 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2104 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2105 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2105 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2106 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2106 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2108 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2108 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2109 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2109 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2110 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2110 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2112 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2112 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2113 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2113 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2114 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2114 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2116 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2116 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2117 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2117 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2118 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2118 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2120 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2120 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2121 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2121 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2122 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2122 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2124 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2124 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2125 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2125 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2127 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2127 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2128 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2128 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2129 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2129 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2131 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2131 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2132 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2132 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2133 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2133 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2135 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2135 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2136 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2136 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2137 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2137 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2139 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2139 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2140 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2140 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2141 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2141 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2143 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2143 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2144 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2144 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2145 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2145 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2147 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2147 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2148 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2148 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2149 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2149 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2151 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2151 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2152 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2152 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2154 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2154 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2155 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2155 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2156 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2156 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2158 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2158 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2159 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2159 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2160 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2160 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2162 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2162 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2163 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2163 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2164 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2164 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2166 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2166 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2167 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2167 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2168 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2168 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2170 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2170 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2171 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2171 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2172 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2172 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2174 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2174 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2175 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2175 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2176 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2176 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2178 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2178 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2179 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2179 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2181 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2181 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2182 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2182 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2183 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2183 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2185 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2185 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2186 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2186 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2187 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2187 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2189 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2189 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2190 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2190 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2191 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2191 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2193 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2193 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2194 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2194 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2195 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2195 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2197 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2197 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2198 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2198 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2199 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2199 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2201 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2201 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2202 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2202 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2203 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2203 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2205 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2205 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2206 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2206 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2208 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2208 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2209 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2209 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2210 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2210 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2212 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2212 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2213 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2213 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2214 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2214 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2216 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2216 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2217 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2217 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2218 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2218 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2220 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2220 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2221 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2221 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2222 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2222 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2224 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2224 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2225 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2225 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2226 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2226 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2228 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2228 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2229 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2229 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2230 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2230 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2232 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2232 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2233 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2233 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2235 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2235 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2236 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2236 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2237 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2237 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2239 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2239 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2240 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2240 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2241 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2241 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2243 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2243 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2244 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2244 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2246 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2246 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2247 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2247 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2248 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2248 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2250 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2250 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2251 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2251 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2252 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2252 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2254 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2254 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2255 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2255 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2256 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2256 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2258 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2258 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2259 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2259 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2260 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2260 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2262 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2262 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2263 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2263 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2264 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2264 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2266 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2266 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2267 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2267 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2269 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2269 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2270 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2270 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2271 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2271 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2273 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2273 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2274 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2274 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2275 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2275 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2277 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2277 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2278 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2278 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2279 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2279 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2281 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2281 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2282 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2282 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2283 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2283 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2285 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2285 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2286 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2286 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2287 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2287 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2289 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2289 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2290 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2290 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2291 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2291 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2293 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2293 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2294 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2294 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2296 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2296 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2297 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2297 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2298 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2298 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2300 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2300 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2301 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2301 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2302 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2302 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2304 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2304 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2305 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2305 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2306 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2306 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2308 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2308 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2309 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2309 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2310 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2310 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2312 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2312 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2313 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2313 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2314 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2314 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2316 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2316 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2317 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2317 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2319 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2319 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2320 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2320 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2321 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2321 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2323 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2323 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2324 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2324 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2325 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2325 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2327 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2327 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2328 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2328 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2329 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2329 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2331 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2331 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2332 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2332 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2333 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2333 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2335 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2335 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2336 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2336 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2337 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2337 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2339 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2339 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2340 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2340 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2341 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2341 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2343 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2343 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2344 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2344 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2346 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2346 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2347 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2347 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2348 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2348 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2350 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2350 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2351 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2351 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2352 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2352 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2354 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2354 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2355 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2355 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2356 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2356 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2358 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2358 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2359 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2359 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2360 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2360 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2362 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2362 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2363 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2363 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2364 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2364 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2366 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2366 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2367 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2367 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2369 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2369 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2370 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2370 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2371 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2371 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2373 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2373 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2374 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2374 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2375 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2375 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2377 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2377 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2378 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2378 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2379 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2379 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2381 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2381 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2382 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2382 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2383 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2383 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2385 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2385 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2386 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2386 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2387 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2387 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2389 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2389 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2390 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2390 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2391 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2391 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2393 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2393 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2394 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2394 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2395 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2395 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2397 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2397 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2398 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2398 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2400 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2400 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2401 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2401 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2402 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2402 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2404 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2404 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2405 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2405 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2406 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2406 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2408 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2408 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2409 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2409 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2411 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2411 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2412 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2412 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2413 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2413 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2415 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2415 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2416 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2416 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2417 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2417 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2419 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2419 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2420 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2420 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2421 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2421 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2423 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2423 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2424 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2424 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2425 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2425 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2427 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2427 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2428 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2428 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2429 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2429 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2431 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2431 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2432 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2432 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2434 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2434 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2435 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2435 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2436 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2436 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2438 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2438 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2439 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2439 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2440 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2440 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2442 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2442 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2443 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2443 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2444 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2444 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2446 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2446 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2447 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2447 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2448 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2448 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2450 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2450 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2451 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2451 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2452 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2452 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2454 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2454 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2455 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2455 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2456 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2456 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2458 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2458 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2459 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2459 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2461 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2461 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2462 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2462 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2463 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2463 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2465 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2465 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2466 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2466 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2467 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2467 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2469 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2469 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2470 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2470 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2471 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2471 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2473 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2473 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2474 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2474 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2475 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2475 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2477 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2477 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2478 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2478 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2479 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2479 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2481 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2481 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2482 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2482 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2484 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2484 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2485 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2485 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2486 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2486 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2488 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2488 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2489 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2489 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2490 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2490 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2492 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2492 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2493 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2493 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2494 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2494 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2496 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2496 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2497 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2497 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2498 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2498 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2500 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2500 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2501 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2501 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2503 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2503 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2504 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2504 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2505 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2505 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2507 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2507 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2508 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2508 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2509 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2509 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2511 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2511 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2512 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2512 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2513 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2513 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2515 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2515 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2516 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2516 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2517 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2517 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2519 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2519 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2520 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2520 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2521 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2521 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2523 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2523 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2524 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2524 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2526 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2526 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2527 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2527 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2528 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2528 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2530 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2530 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2531 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2531 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2532 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2532 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2534 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2534 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2535 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2535 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2536 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2536 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2538 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2538 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2539 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2539 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2540 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2540 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2542 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2542 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2543 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2543 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2544 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2544 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2546 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2546 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2547 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2547 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2548 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2548 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2550 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2550 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2551 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2551 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2553 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2553 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2554 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2554 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2555 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2555 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2557 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2557 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2558 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2558 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2559 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2559 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2561 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2561 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2562 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2562 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2563 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2563 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2565 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2565 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2566 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2566 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2567 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2567 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2569 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2569 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2570 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2570 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2571 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2571 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2573 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2573 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2574 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2574 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2575 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2575 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2577 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2577 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2578 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2578 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2580 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2580 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2581 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2581 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2582 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2582 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2584 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2584 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2585 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2585 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2586 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2586 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2588 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2588 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2589 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2589 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2590 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2590 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2592 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2592 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2593 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2593 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2594 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2594 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2596 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2596 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2597 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2597 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2598 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2598 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2600 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2600 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2601 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2601 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2603 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2603 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2604 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2604 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2605 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2605 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2607 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2607 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2608 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2608 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2609 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2609 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2611 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2611 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2612 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2612 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2613 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2613 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2615 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2615 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2616 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2616 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2617 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2617 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2619 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2619 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2620 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2620 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2621 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2621 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2623 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2623 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2624 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2624 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2625 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2625 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2627 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2627 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2628 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2628 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2629 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2629 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2631 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2631 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2632 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2632 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2634 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2634 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2635 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2635 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2636 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2636 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2638 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2638 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2639 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2639 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2640 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2640 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2642 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2642 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2643 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2643 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2644 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2644 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2646 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2646 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2647 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2647 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2648 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2648 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2650 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2650 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2651 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2651 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2652 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2652 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2654 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2654 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2655 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2655 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2657 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2657 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2658 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2658 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2659 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2659 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2661 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2661 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2662 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2662 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2663 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2663 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2665 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2665 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2666 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2666 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2667 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2667 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2669 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2669 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
Core 0:       +30.0°C  (high = +76.0°C, crit = +100.0°C)
 2670 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2670 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2671 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2671 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2673 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2673 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2674 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2674 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2675 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2675 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2677 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2677 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2678 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2678 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2679 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2679 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2681 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2681 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2682 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2682 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2684 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2684 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2685 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2685 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2686 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2686 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2688 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2688 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2689 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2689 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2690 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2690 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2692 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2692 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2693 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2693 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2694 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2694 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2696 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2696 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2697 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2697 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2698 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2698 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2700 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2700 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2701 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2701 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2702 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2702 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2704 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2704 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2705 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2705 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2706 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2706 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2708 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2708 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2709 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2709 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2711 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2711 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2712 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2712 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2713 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2713 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2715 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2715 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2716 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2716 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2717 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2717 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2719 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2719 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2720 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2720 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2721 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2721 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2723 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2723 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2724 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2724 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2725 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2725 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2727 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2727 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2728 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2728 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2729 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2729 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2731 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2731 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2732 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2732 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2733 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2733 secs  servo min: -30.400 uS max:  30.400 uS sdev:   1.600 uS
 2735 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2735 secs  servo min: -30.800 uS max:  30.400 uS sdev:   1.600 uS
 2736 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2736 secs  servo min: -30.800 uS max:  30.400 uS sdev:   1.600 uS
 2738 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2738 secs  servo min: -30.800 uS max:  30.400 uS sdev:   1.600 uS
 2739 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2739 secs  servo min: -30.800 uS max:  30.400 uS sdev:   1.600 uS
 2740 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2740 secs  servo min: -30.800 uS max:  30.400 uS sdev:   1.600 uS
 2742 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2742 secs  servo min: -30.800 uS max:  30.400 uS sdev:   1.600 uS
 2743 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2743 secs  servo min: -30.800 uS max:  30.400 uS sdev:   1.600 uS
 2744 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2744 secs  servo min: -30.800 uS max:  30.400 uS sdev:   1.600 uS
 2746 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2746 secs  servo min: -30.800 uS max:  30.400 uS sdev:   1.600 uS
 2747 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2747 secs  servo min: -30.800 uS max:  30.400 uS sdev:   1.600 uS
 2748 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2748 secs  servo min: -30.800 uS max:  30.400 uS sdev:   1.600 uS
 2750 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2750 secs  servo min: -30.800 uS max:  30.400 uS sdev:   1.600 uS
 2751 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2751 secs  servo min: -30.800 uS max:  30.400 uS sdev:   1.600 uS
 2752 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2752 secs  servo min: -30.800 uS max:  30.400 uS sdev:   1.600 uS
 2754 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2754 secs  servo min: -30.800 uS max:  30.400 uS sdev:   1.600 uS
 2755 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2755 secs  servo min: -30.800 uS max:  30.400 uS sdev:   1.600 uS
 2756 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2756 secs  servo min: -30.800 uS max:  30.400 uS sdev:   1.600 uS
 2758 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2758 secs  servo min: -30.800 uS max:  30.400 uS sdev:   1.600 uS
 2759 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2759 secs  servo min: -30.800 uS max:  30.400 uS sdev:   1.600 uS
 2761 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2761 secs  servo min: -30.800 uS max:  30.400 uS sdev:   1.600 uS
 2762 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2762 secs  servo min: -30.800 uS max:  30.400 uS sdev:   1.600 uS
 2763 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2763 secs  servo min: -30.800 uS max:  30.400 uS sdev:   1.600 uS
 2765 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2765 secs  servo min: -30.800 uS max:  30.400 uS sdev:   1.600 uS
 2766 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2766 secs  servo min: -30.800 uS max:  30.400 uS sdev:   1.600 uS
 2767 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2767 secs  servo min: -30.800 uS max:  30.400 uS sdev:   1.600 uS
 2769 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2769 secs  servo min: -30.800 uS max:  30.400 uS sdev:   1.600 uS
 2770 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2770 secs  servo min: -30.800 uS max:  30.400 uS sdev:   1.600 uS
 2771 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2771 secs  servo min: -30.800 uS max:  30.400 uS sdev:   1.600 uS
 2773 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2773 secs  servo min: -30.800 uS max:  30.400 uS sdev:   1.600 uS
 2774 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2774 secs  servo min: -30.800 uS max:  30.400 uS sdev:   1.600 uS
 2776 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2776 secs  servo min: -30.800 uS max:  30.400 uS sdev:   1.600 uS
 2777 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2777 secs  servo min: -30.800 uS max:  30.400 uS sdev:   1.600 uS
 2778 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2778 secs  servo min: -30.800 uS max:  30.400 uS sdev:   1.600 uS
 2780 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2780 secs  servo min: -30.800 uS max:  30.400 uS sdev:   1.600 uS
 2781 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2781 secs  servo min: -30.800 uS max:  30.400 uS sdev:   1.600 uS
 2782 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2782 secs  servo min: -30.800 uS max:  30.400 uS sdev:   1.600 uS
 2784 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2784 secs  servo min: -30.800 uS max:  30.400 uS sdev:   1.600 uS
 2785 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2785 secs  servo min: -30.800 uS max:  30.400 uS sdev:   1.600 uS
 2786 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2786 secs  servo min: -30.800 uS max:  30.400 uS sdev:   1.600 uS
 2788 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2788 secs  servo min: -30.800 uS max:  30.400 uS sdev:   1.600 uS
 2789 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2789 secs  servo min: -30.800 uS max:  30.400 uS sdev:   1.600 uS
 2790 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2790 secs  servo min: -30.800 uS max:  30.400 uS sdev:   1.600 uS
 2792 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2792 secs  servo min: -30.800 uS max:  30.400 uS sdev:   1.600 uS
 2793 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2793 secs  servo min: -30.800 uS max:  30.400 uS sdev:   1.600 uS
 2794 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2794 secs  servo min: -30.800 uS max:  30.400 uS sdev:   1.600 uS
 2796 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2796 secs  servo min: -30.800 uS max:  30.400 uS sdev:   1.600 uS
 2797 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2797 secs  servo min: -30.800 uS max:  30.400 uS sdev:   1.600 uS
 2798 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2798 secs  servo min: -30.800 uS max:  30.400 uS sdev:   1.600 uS
 2800 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2800 secs  servo min: -30.800 uS max:  30.400 uS sdev:   1.600 uS
 2801 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2801 secs  servo min: -30.800 uS max:  30.400 uS sdev:   1.600 uS
 2803 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2803 secs  servo min: -30.800 uS max:  30.400 uS sdev:   1.600 uS
 2804 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2804 secs  servo min: -30.800 uS max:  30.400 uS sdev:   1.600 uS
 2805 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2805 secs  servo min: -30.800 uS max:  30.400 uS sdev:   1.600 uS
 2807 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2807 secs  servo min: -30.800 uS max:  30.400 uS sdev:   1.600 uS
 2808 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2808 secs  servo min: -30.800 uS max:  30.400 uS sdev:   1.600 uS
 2809 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2809 secs  servo min: -30.800 uS max:  30.400 uS sdev:   1.600 uS
 2811 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2811 secs  servo min: -30.800 uS max:  30.400 uS sdev:   1.600 uS
 2812 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2812 secs  servo min: -30.800 uS max:  30.400 uS sdev:   1.600 uS
 2813 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2813 secs  servo min: -30.800 uS max:  30.400 uS sdev:   1.600 uS
 2815 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2815 secs  servo min: -30.800 uS max:  30.400 uS sdev:   1.600 uS
 2816 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2816 secs  servo min: -30.800 uS max:  30.400 uS sdev:   1.600 uS
 2817 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2817 secs  servo min: -30.800 uS max:  30.400 uS sdev:   1.600 uS
 2819 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2819 secs  servo min: -30.800 uS max:  30.400 uS sdev:   1.600 uS
 2820 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2820 secs  servo min: -30.800 uS max:  30.400 uS sdev:   1.600 uS
 2821 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2821 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 2823 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2823 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 2824 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2824 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 2826 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2826 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 2827 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2827 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 2828 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2828 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 2830 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2830 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 2831 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2831 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 2832 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2832 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 2834 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2834 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 2835 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2835 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 2837 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2837 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 2838 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2838 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 2839 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2839 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 2841 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2841 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 2842 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2842 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 2843 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2843 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 2845 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2845 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 2846 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2846 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 2847 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2847 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 2849 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2849 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 2850 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2850 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 2851 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2851 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 2853 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2853 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 2854 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2854 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 2855 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2855 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 2857 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2857 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 2858 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2858 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 2859 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2859 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 2861 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2861 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 2862 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2862 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 2864 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2864 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 2865 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2865 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 2866 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2866 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 2868 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2868 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 2869 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2869 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 2870 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2870 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 2872 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2872 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 2873 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2873 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 2874 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2874 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 2876 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2876 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 2877 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2877 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 2878 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2878 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 2880 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2880 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 2881 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2881 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 2882 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2882 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 2884 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2884 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 2885 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2885 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 2887 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2887 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 2888 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2888 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 2889 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2889 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 2891 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2891 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 2892 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2892 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 2893 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2893 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 2895 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2895 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 2896 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2896 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 2897 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2897 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 2899 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2899 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 2900 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2900 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 2901 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2901 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 2903 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2903 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 2904 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2904 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 2905 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2905 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 2907 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2907 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 2908 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2908 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 2909 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2909 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 2911 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2911 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 2912 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2912 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 2913 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2913 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 2915 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2915 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 2916 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2916 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 2918 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2918 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 2919 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2919 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 2920 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2920 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 2922 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2922 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 2923 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2923 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 2924 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2924 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 2926 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2926 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 2927 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2927 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 2928 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2928 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 2930 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2930 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 2931 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2931 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 2932 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2932 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 2934 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2934 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 2935 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2935 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 2936 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2936 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 2938 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2938 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 2939 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2939 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 2941 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2941 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 2942 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2942 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 2943 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2943 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 2945 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2945 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 2946 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2946 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 2947 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2947 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 2949 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2949 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 2950 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2950 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 2951 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2951 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 2953 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2953 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 2954 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2954 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 2955 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2955 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 2957 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2957 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 2958 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2958 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 2960 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2960 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 2961 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2961 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 2962 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2962 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 2964 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2964 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 2965 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2965 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 2966 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2966 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 2968 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2968 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 2969 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2969 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 2970 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2970 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 2972 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2972 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 2973 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2973 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 2974 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2974 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 2976 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2976 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 2977 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2977 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 2978 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2978 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 2980 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2980 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 2981 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2981 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 2983 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2983 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 2984 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2984 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 2985 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2985 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 2987 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2987 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 2988 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2988 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 2989 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2989 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 2991 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2991 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 2992 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2992 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 2993 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2993 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 2995 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2995 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 2996 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2996 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 2997 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2997 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 2999 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 2999 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3000 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3000 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3001 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3001 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3003 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3003 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3004 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3004 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3005 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3005 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3007 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3007 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3008 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3008 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3010 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3010 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3011 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3011 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3012 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3012 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3014 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3014 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3015 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3015 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3016 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3016 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3018 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3018 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3019 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3019 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3020 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3020 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3022 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3022 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3023 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3023 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3024 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3024 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3026 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3026 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3027 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3027 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3028 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3028 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3030 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3030 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3031 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3031 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3033 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3033 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3034 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3034 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3035 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3035 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3037 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3037 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3038 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3038 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3039 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3039 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3041 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3041 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3042 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3042 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3043 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3043 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3045 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3045 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3046 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3046 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3047 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3047 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3049 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3049 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3050 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3050 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3051 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3051 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3053 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3053 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3054 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3054 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3056 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3056 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3057 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3057 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3058 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3058 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3060 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3060 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3061 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3061 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3062 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3062 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3064 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3064 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3065 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3065 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3066 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3066 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3068 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3068 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3069 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3069 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3070 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3070 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3072 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3072 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3073 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3073 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3074 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3074 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3076 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3076 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3077 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3077 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3078 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3078 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3080 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3080 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3081 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3081 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3082 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3082 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3084 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3084 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3085 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3085 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3087 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3087 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3088 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3088 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3089 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3089 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3091 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3091 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3092 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3092 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3093 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3093 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3095 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3095 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3096 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3096 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3097 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3097 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3099 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3099 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3100 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3100 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3102 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3102 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3103 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3103 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3104 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3104 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3106 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3106 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3107 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3107 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3108 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3108 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3110 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3110 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3111 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3111 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3112 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3112 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3114 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3114 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3115 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3115 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3116 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3116 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3118 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3118 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3119 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3119 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3121 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3121 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3122 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3122 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3123 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3123 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3125 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3125 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3126 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3126 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3127 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3127 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3129 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3129 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3130 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3130 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3131 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3131 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3133 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3133 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3134 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3134 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3135 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3135 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3137 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3137 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3138 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3138 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3139 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3139 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3141 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3141 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3142 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3142 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3144 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3144 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3145 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3145 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3146 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3146 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3148 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3148 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3149 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3149 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3150 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3150 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3152 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3152 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3153 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3153 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3155 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3155 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3156 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3156 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3157 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3157 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3159 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3159 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3160 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3160 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3161 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3161 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3163 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3163 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3164 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3164 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3165 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3165 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3167 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3167 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3168 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3168 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3169 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3169 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3171 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3171 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3172 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3172 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3173 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3173 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3175 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3175 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3176 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3176 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3178 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3178 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3179 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3179 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3180 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3180 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3182 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3182 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3183 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3183 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3184 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3184 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3186 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3186 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3187 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3187 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3188 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3188 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3190 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3190 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3191 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3191 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3192 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3192 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3194 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3194 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3195 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3195 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3196 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3196 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3198 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3198 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3199 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3199 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3200 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3200 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3202 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3202 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3203 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3203 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3205 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3205 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3206 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3206 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3207 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3207 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3209 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3209 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3210 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3210 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3211 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3211 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3213 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3213 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3214 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3214 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3215 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3215 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3217 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3217 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3218 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3218 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3219 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3219 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3221 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3221 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3222 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3222 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3223 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3223 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3225 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3225 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3226 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3226 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3227 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3227 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3229 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3229 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3230 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3230 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3232 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3232 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3233 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3233 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3234 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3234 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3236 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3236 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3237 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3237 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3238 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3238 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3240 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3240 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3241 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3241 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3243 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3243 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3244 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3244 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3245 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3245 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3247 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3247 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3248 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3248 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3249 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3249 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3251 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3251 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3252 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3252 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3253 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3253 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3255 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3255 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3256 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3256 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3257 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3257 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3259 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3259 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3260 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3260 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3261 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3261 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3263 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3263 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3264 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3264 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3265 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3265 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3267 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3267 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3268 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3268 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3270 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3270 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3271 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3271 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3272 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3272 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3274 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3274 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3275 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3275 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3276 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3276 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3278 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3278 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3279 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3279 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3280 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3280 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3282 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3282 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3283 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3283 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3284 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3284 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3286 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3286 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3287 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3287 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3288 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3288 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3290 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3290 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3291 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3291 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3293 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3293 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3294 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3294 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3295 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3295 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3297 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3297 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3298 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3298 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3299 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3299 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3301 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3301 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3302 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3302 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3303 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3303 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3305 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3305 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3306 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3306 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3307 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3307 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3309 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3309 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3310 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3310 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3311 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3311 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3313 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3313 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3314 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3314 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3315 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3315 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3317 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3317 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3318 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3318 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3320 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3320 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3321 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3321 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3322 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3322 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3324 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3324 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3325 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3325 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3326 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3326 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3328 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3328 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3329 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3329 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3330 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3330 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3332 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3332 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
Core 0:       +30.0°C  (high = +76.0°C, crit = +100.0°C)
 3333 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3333 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3334 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3334 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3336 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3336 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3337 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3337 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3338 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3338 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3340 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3340 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3341 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3341 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3342 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3342 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3344 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3344 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3345 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3345 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3347 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3347 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3348 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3348 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3349 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3349 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3351 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3351 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3352 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3352 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3353 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3353 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3355 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3355 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3356 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3356 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3357 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3357 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3359 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3359 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3360 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3360 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3361 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3361 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3363 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3363 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3364 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3364 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3365 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3365 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3367 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3367 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3368 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3368 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3369 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3369 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3371 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3371 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3372 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3372 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3373 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3373 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3375 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3375 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3376 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3376 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3378 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3378 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3379 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3379 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3380 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3380 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3382 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3382 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3383 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3383 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3384 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3384 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3386 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3386 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3387 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3387 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3388 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3388 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3390 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3390 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3391 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3391 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3392 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3392 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3394 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3394 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3395 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3395 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3396 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3396 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3398 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3398 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3399 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3399 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3400 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3400 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3402 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3402 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3403 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3403 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3405 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3405 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3406 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3406 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3407 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3407 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3409 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3409 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3410 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3410 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3411 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3411 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3413 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3413 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3414 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3414 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3415 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3415 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3417 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3417 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3418 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3418 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3419 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3419 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3421 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3421 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3422 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3422 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3423 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3423 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3425 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3425 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3426 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3426 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3428 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3428 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3429 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3429 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3430 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3430 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3432 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3432 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3433 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3433 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3434 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3434 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3436 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3436 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3437 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3437 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3438 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3438 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3440 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3440 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3441 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3441 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3442 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3442 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3444 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3444 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3445 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3445 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3446 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3446 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3448 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3448 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3449 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3449 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3450 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3450 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3452 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3452 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3453 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3453 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3455 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3455 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3456 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3456 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3457 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3457 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3459 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3459 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3460 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3460 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3461 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3461 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3463 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3463 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3464 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3464 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3465 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3465 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3467 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3467 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3468 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3468 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3469 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3469 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3471 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3471 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3472 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3472 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3473 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3473 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3475 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3475 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3476 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3476 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3478 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3478 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3479 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3479 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3480 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3480 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3482 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3482 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3483 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3483 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3484 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3484 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3486 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3486 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3487 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3487 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3489 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3489 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3490 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3490 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3491 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3491 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3493 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3493 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3494 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3494 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3495 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3495 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3497 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3497 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3498 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3498 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3499 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3499 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3501 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3501 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3502 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3502 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3503 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3503 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3505 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3505 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3506 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3506 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3507 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3507 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3509 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3509 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3510 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3510 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3511 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3511 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3513 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3513 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3514 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3514 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3516 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3516 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3517 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3517 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3518 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3518 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3520 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3520 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3521 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3521 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3522 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3522 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3524 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3524 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3525 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3525 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3526 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3526 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3528 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3528 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3529 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3529 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3530 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3530 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3532 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3532 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3533 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3533 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3534 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3534 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3536 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3536 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3537 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3537 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3538 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3538 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3540 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3540 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3541 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3541 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3543 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3543 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3544 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3544 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3545 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3545 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3547 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3547 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3548 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3548 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3549 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3549 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3551 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3551 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3552 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3552 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3553 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3553 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3555 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3555 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3556 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3556 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3557 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3557 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3559 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3559 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3560 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3560 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3561 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3561 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3563 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3563 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3564 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3564 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3565 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3565 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3567 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3567 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3568 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3568 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3570 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3570 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3571 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3571 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3572 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3572 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3574 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3574 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3575 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3575 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3576 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3576 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3578 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3578 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3579 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3579 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3580 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3580 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3582 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3582 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3583 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3583 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3584 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3584 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3586 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3586 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3587 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3587 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3588 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3588 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3590 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3590 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3591 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3591 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3592 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3592 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3594 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3594 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3595 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3595 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3597 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3597 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3598 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3598 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3599 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3599 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3601 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3601 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3602 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3602 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3603 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3603 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3605 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3605 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3606 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3606 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3607 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3607 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3609 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3609 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3610 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3610 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3611 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3611 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3613 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3613 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3614 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3614 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3615 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3615 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3617 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3617 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3618 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3618 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3619 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3619 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3621 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3621 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3622 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3622 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3624 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3624 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3625 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3625 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3626 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3626 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3628 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3628 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3629 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3629 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3630 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3630 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3632 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3632 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3633 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3633 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3634 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3634 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3636 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3636 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3637 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3637 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3638 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3638 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3640 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3640 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3641 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3641 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3642 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3642 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3644 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3644 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3645 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3645 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3647 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3647 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3648 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3648 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3649 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3649 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3651 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3651 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3652 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3652 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3653 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3653 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3655 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3655 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3656 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3656 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3657 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3657 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3659 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3659 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3660 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3660 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3661 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3661 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3663 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3663 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3664 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3664 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3665 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3665 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3667 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3667 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3668 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3668 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3669 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3669 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3671 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3671 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3672 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3672 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3673 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3673 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3675 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3675 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3676 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3676 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3678 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3678 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3679 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3679 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3680 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3680 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3682 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3682 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3683 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3683 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3684 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3684 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3686 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3686 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3687 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3687 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3688 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3688 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3690 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3690 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3691 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3691 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3692 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3692 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3694 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3694 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3695 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3695 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3696 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3696 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3698 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3698 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3699 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3699 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3701 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3701 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3702 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3702 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3703 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3703 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3705 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3705 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3706 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3706 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3707 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3707 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3709 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3709 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3710 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3710 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3711 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3711 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3713 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3713 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3714 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3714 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3716 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3716 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3717 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3717 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3718 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3718 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3720 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3720 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3721 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3721 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3722 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3722 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3724 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3724 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3725 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3725 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3726 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3726 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3728 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3728 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3729 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3729 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3730 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3730 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3732 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3732 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3733 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3733 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3735 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3735 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3736 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3736 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3737 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3737 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3739 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3739 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3740 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3740 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3741 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3741 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3743 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3743 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3744 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3744 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3746 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3746 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3747 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3747 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3748 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3748 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3750 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3750 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3751 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3751 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3752 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3752 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3754 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3754 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3755 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3755 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3756 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3756 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3758 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3758 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3759 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3759 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3760 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3760 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3762 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3762 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3763 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3763 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3764 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3764 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3766 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3766 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3767 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3767 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3768 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3768 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3770 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3770 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3771 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3771 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3773 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3773 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3774 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3774 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3775 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3775 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3777 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3777 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3778 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3778 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3779 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3779 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3781 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3781 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3782 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3782 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3783 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3783 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3785 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3785 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3786 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3786 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3787 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3787 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3789 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3789 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3790 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3790 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3791 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3791 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3793 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3793 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3794 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3794 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3796 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3796 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3797 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3797 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3798 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3798 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3800 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3800 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3801 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3801 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3802 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3802 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3804 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3804 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3805 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3805 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3806 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3806 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3808 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3808 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3809 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3809 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3810 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3810 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3812 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3812 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3813 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3813 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3814 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3814 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3816 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3816 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3817 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3817 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3819 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3819 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3820 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3820 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3821 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3821 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3823 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3823 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3824 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3824 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3825 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3825 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3827 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3827 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3828 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3828 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3829 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3829 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3831 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3831 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3832 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3832 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3834 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3834 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3835 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3835 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3836 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3836 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3838 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3838 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3839 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3839 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3840 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3840 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3842 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3842 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3843 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3843 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3844 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3844 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3846 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3846 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3847 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3847 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3848 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3848 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3850 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3850 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3851 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3851 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3852 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3852 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3854 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3854 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3855 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3855 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3856 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3856 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3858 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3858 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3859 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3859 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3861 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3861 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3862 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3862 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3863 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3863 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3865 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3865 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3866 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3866 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3867 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3867 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3869 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3869 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3870 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3870 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3871 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3871 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3873 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3873 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3874 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3874 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3875 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3875 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3877 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3877 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3878 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3878 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3879 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3879 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3881 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3881 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3882 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3882 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3883 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3883 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3885 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3885 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3886 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3886 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3888 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3888 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3889 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3889 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3890 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3890 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3892 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3892 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3893 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3893 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3894 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3894 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3896 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3896 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3897 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3897 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3898 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3898 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3900 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3900 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3901 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3901 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3902 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3902 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3904 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3904 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3905 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3905 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3906 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3906 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3908 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3908 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3909 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3909 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3910 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3910 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3912 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3912 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3913 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3913 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3915 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3915 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3916 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3916 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3917 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3917 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3919 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3919 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3920 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3920 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3921 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3921 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3923 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3923 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3924 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3924 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3925 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3925 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3927 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3927 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3928 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3928 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3929 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3929 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3931 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3931 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3932 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3932 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3933 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3933 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3935 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3935 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3936 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3936 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3938 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3938 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3939 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3939 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3940 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3940 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3942 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3942 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3943 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3943 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3944 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3944 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3946 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3946 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3947 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3947 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3948 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3948 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3950 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3950 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3951 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3951 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3952 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3952 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3954 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3954 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3955 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3955 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3956 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3956 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3958 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3958 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3959 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3959 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3960 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3960 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3962 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3962 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3963 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3963 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3965 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3965 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3966 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3966 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3967 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3967 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3969 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3969 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3970 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3970 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3971 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3971 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3973 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3973 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3974 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3974 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3975 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3975 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3977 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3977 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3978 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3978 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3979 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3979 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3981 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3981 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3982 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3982 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3983 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3983 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3985 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3985 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3986 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3986 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3988 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3988 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3989 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3989 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3990 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3990 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3992 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3992 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3993 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3993 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
Core 0:       +30.0°C  (high = +76.0°C, crit = +100.0°C)
 3994 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3994 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3996 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3996 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3997 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3997 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 3998 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 3998 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4000 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4000 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4001 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4001 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4003 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4003 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4004 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4004 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4005 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4005 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4007 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4007 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4008 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4008 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4009 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4009 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4011 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4011 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4012 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4012 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4013 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4013 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4015 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4015 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4016 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4016 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4017 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4017 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4019 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4019 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4020 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4020 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4021 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4021 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4023 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4023 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4024 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4024 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4026 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4026 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4027 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4027 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4028 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4028 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4030 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4030 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4031 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4031 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4032 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4032 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4034 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4034 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4035 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4035 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4036 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4036 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4038 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4038 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4039 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4039 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4040 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4040 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4042 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4042 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4043 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4043 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4044 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4044 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4046 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4046 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4047 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4047 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4048 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4048 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4050 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4050 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4051 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4051 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4053 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4053 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4054 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4054 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4055 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4055 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4057 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4057 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4058 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4058 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4059 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4059 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4061 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4061 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4062 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4062 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4063 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4063 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4065 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4065 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4066 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4066 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4067 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4067 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4069 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4069 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4070 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4070 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4071 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4071 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4073 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4073 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4074 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4074 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4075 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4075 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4077 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4077 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4078 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4078 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4080 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4080 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4081 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4081 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4082 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4082 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4084 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4084 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4085 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4085 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4087 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4087 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4088 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4088 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4089 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4089 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4091 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4091 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4092 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4092 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4093 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4093 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4095 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4095 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4096 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4096 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4097 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4097 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4099 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4099 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4100 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4100 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4101 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4101 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4103 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4103 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4104 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4104 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4105 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4105 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4107 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4107 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4108 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4108 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4109 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4109 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4111 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4111 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4112 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4112 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4114 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4114 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4115 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4115 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4116 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4116 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4118 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4118 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4119 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4119 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4120 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4120 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4122 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4122 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4123 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4123 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4124 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4124 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4126 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4126 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4127 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4127 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4128 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4128 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4130 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4130 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4131 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4131 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4132 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4132 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4134 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4134 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4135 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4135 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4137 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4137 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4138 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4138 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4139 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4139 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4141 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4141 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4142 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4142 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4143 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4143 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4145 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4145 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4146 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4146 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4147 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4147 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4149 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4149 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4150 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4150 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4151 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4151 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4153 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4153 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4154 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4154 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4155 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4155 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4157 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4157 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4158 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4158 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4159 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4159 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4161 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4161 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4162 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4162 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4164 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4164 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4165 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4165 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4166 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4166 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4168 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4168 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4169 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4169 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4170 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4170 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4172 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4172 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4173 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4173 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4174 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4174 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4176 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4176 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4177 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4177 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4178 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4178 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4180 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4180 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4181 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4181 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4182 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4182 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4184 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4184 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4185 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4185 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4186 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4186 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4188 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4188 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4189 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4189 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4191 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4191 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4192 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4192 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4193 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4193 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4195 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4195 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4196 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4196 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4197 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4197 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4199 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4199 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4200 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4200 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4202 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4202 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4203 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4203 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4204 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4204 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4206 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4206 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4207 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4207 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4208 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4208 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4210 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4210 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4211 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4211 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4212 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4212 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4214 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4214 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4215 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4215 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4216 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4216 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4218 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4218 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4219 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4219 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4220 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4220 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4222 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4222 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4223 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4223 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4225 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4225 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4226 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4226 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4227 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4227 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4229 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4229 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4230 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4230 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4231 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4231 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4233 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4233 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4234 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4234 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4235 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4235 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4237 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4237 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4238 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4238 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4239 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4239 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4241 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4241 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4242 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4242 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4243 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4243 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4245 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4245 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4246 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4246 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4247 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4247 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4249 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4249 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4250 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4250 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4252 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4252 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4253 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4253 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4254 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4254 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4256 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4256 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4257 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4257 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4258 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4258 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4260 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4260 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4261 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4261 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4263 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4263 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4264 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4264 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4265 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4265 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4267 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4267 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4268 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4268 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4269 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4269 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4271 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4271 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4272 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4272 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4273 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4273 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4275 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4275 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4276 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4276 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4277 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4277 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4279 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4279 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4280 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4280 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4281 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4281 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4283 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4283 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4284 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4284 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4285 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4285 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4287 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4287 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4288 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4288 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4289 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4289 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4291 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4291 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4292 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4292 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4293 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4293 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4295 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4295 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4296 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4296 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4298 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4298 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4299 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4299 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4300 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4300 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4302 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4302 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4303 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4303 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4304 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4304 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4306 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4306 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4307 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4307 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4308 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4308 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4310 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4310 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4311 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4311 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4312 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4312 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4314 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4314 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4315 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4315 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4317 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4317 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4318 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4318 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4319 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4319 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4321 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4321 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4322 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4322 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4323 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4323 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4325 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4325 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4326 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4326 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4327 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4327 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4329 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4329 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4330 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4330 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4331 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4331 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4333 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4333 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4334 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4334 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4335 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4335 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4337 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4337 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4338 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4338 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4339 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4339 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4341 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4341 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4342 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4342 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4344 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4344 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4345 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4345 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4346 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4346 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4348 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4348 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4349 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4349 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4350 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4350 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4352 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4352 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4353 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4353 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4354 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4354 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4356 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4356 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4357 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4357 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4358 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4358 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4360 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4360 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4361 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4361 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4362 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4362 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4364 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4364 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4365 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4365 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4366 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4366 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4368 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4368 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4369 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4369 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4371 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4371 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4372 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4372 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4373 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4373 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4375 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4375 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4376 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4376 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4377 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4377 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4379 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4379 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4380 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4380 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4381 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4381 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4383 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4383 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4384 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4384 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4385 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4385 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4387 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4387 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4388 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4388 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4389 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4389 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4391 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4391 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4392 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4392 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4394 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4394 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4395 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4395 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4396 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4396 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4398 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4398 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4399 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4399 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4400 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4400 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4402 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4402 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4403 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4403 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4404 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4404 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4406 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4406 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4407 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4407 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4408 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4408 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4410 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4410 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4411 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4411 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4412 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4412 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4414 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4414 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4415 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4415 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4416 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4416 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4418 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4418 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4419 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4419 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4421 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4421 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4422 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4422 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4423 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4423 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4425 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4425 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4426 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4426 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4427 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4427 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4429 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4429 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4430 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4430 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4431 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4431 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4433 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4433 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4434 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4434 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4436 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4436 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4437 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4437 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4438 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4438 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4440 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4440 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4441 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4441 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4442 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4442 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4444 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4444 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4445 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4445 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4446 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4446 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4448 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4448 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4449 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4449 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4450 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4450 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4452 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4452 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4453 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4453 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4455 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4455 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4456 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4456 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4457 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4457 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4459 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4459 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4460 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4460 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4461 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4461 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4463 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4463 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4464 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4464 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4465 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4465 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4467 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4467 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4468 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4468 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4469 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4469 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4471 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4471 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4472 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4472 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4473 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4473 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4475 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4475 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4476 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4476 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4477 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4477 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4479 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4479 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4480 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4480 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4482 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4482 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4483 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4483 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4484 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4484 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4486 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4486 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4487 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4487 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4488 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4488 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4490 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4490 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4491 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4491 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4492 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4492 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4494 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4494 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4495 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4495 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4496 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4496 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4498 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4498 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4499 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4499 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4500 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4500 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4502 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4502 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4503 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4503 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4504 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4504 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4506 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4506 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4507 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4507 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4509 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4509 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4510 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4510 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4511 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4511 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4513 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4513 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4514 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4514 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4515 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4515 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4517 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4517 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4518 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4518 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4519 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4519 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4521 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4521 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4522 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4522 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4523 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4523 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4525 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4525 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4526 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4526 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4527 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4527 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4529 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4529 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4530 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4530 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4531 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4531 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4533 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4533 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4534 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4534 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4536 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4536 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4537 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4537 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4538 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4538 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4540 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4540 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4541 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4541 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4542 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4542 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4544 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4544 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4545 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4545 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4546 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4546 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4548 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4548 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4549 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4549 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4550 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4550 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4552 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4552 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4553 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4553 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4554 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4554 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4556 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4556 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4557 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4557 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4558 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4558 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4560 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4560 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4561 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4561 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4563 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4563 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4564 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4564 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4565 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4565 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4567 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4567 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4568 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4568 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4569 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4569 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4571 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4571 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4572 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4572 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4573 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4573 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4575 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4575 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4576 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4576 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4577 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4577 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4579 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4579 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4580 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4580 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4581 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4581 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4583 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4583 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4584 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4584 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4585 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4585 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4587 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4587 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4588 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4588 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4590 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4590 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4591 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4591 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4592 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4592 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4594 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4594 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4595 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4595 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4596 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4596 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4598 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4598 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4599 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4599 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4600 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4600 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4602 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4602 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4603 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4603 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4604 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4604 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4606 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4606 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4607 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4607 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4608 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4608 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4610 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4610 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4611 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4611 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4612 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4612 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4614 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4614 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4615 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4615 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4617 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4617 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4618 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4618 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4619 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4619 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4621 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4621 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4622 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4622 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4623 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4623 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4625 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4625 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4626 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4626 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4627 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4627 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4629 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4629 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4630 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4630 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4631 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4631 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4633 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4633 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4634 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4634 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4635 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4635 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4637 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4637 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4638 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4638 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4640 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4640 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4641 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4641 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4642 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4642 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4644 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4644 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4645 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4645 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4646 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4646 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4648 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4648 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4649 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4649 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4650 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4650 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4652 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4652 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4653 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4653 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4655 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4655 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
Core 0:       +30.0°C  (high = +76.0°C, crit = +100.0°C)
 4656 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4656 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4657 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4657 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4659 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4659 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4660 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4660 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4661 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4661 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4663 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4663 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4664 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4664 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4665 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4665 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4667 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4667 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4668 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4668 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4669 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4669 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4671 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4671 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4672 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4672 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4673 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4673 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4675 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4675 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4676 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4676 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4677 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4677 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4679 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4679 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4680 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4680 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4681 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4681 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4683 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4683 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4684 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4684 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4686 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4686 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4687 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4687 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4688 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4688 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4690 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4690 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4691 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4691 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4692 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4692 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4694 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4694 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4695 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4695 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4696 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4696 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4698 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4698 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4699 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4699 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4700 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4700 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4702 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4702 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4703 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4703 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4704 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4704 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4706 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4706 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4707 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4707 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4708 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4708 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4710 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4710 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4711 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4711 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4712 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4712 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4714 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4714 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4715 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4715 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4716 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4716 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4718 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4718 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4719 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4719 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4721 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4721 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4722 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4722 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4723 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4723 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4725 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4725 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4726 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4726 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4727 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4727 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4729 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4729 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4730 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4730 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4731 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4731 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4733 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4733 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4734 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4734 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4735 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4735 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4737 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4737 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4738 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4738 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4740 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4740 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4741 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4741 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4742 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4742 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4744 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4744 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4745 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4745 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4746 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4746 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4748 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4748 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4749 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4749 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4750 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4750 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4752 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4752 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4753 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4753 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4754 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4754 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4756 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4756 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4757 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4757 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4758 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4758 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4760 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4760 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4761 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4761 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4762 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4762 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4764 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4764 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4765 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4765 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4767 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4767 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4768 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4768 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4769 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4769 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4771 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4771 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4772 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4772 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4773 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4773 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4775 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4775 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4776 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4776 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4777 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4777 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4779 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4779 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4780 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4780 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4781 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4781 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4783 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4783 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4784 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4784 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4785 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4785 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4787 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4787 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4788 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4788 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4790 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4790 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4791 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4791 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4792 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4792 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4794 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4794 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4795 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4795 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4796 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4796 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4798 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4798 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4799 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4799 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4800 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4800 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4802 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4802 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4803 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4803 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4804 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4804 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4806 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4806 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4807 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4807 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4808 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4808 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4810 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4810 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4811 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4811 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4812 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4812 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4814 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4814 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4815 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4815 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4817 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4817 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4818 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4818 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4819 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4819 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4821 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4821 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4822 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4822 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4823 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4823 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4825 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4825 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4826 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4826 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4827 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4827 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4829 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4829 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4830 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4830 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4831 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4831 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4833 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4833 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4834 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4834 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4835 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4835 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4837 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4837 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4838 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4838 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4839 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4839 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4841 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4841 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4842 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4842 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4844 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4844 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4845 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4845 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4846 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4846 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4848 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4848 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4849 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4849 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4850 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4850 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4852 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4852 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4853 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4853 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4854 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4854 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4856 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4856 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4857 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4857 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4858 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4858 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4860 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4860 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4861 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4861 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4862 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4862 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4864 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4864 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4865 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4865 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4866 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4866 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4868 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4868 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4869 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4869 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4871 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4871 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4872 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4872 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4873 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4873 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4875 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4875 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4876 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4876 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4877 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4877 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4879 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4879 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4880 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4880 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4881 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4881 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4883 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4883 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4884 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4884 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4885 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4885 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4887 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4887 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4888 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4888 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4889 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4889 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4891 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4891 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4892 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4892 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4893 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4893 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4895 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4895 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4896 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4896 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4898 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4898 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4899 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4899 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4900 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4900 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4902 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4902 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4903 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4903 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4904 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4904 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4906 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4906 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4907 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4907 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4908 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4908 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4910 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4910 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4911 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4911 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4912 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4912 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4914 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4914 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4915 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4915 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4916 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4916 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4918 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4918 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4919 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4919 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4920 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4920 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4922 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4922 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4923 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4923 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4925 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4925 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4926 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4926 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4927 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4927 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4929 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4929 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4930 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4930 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4931 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4931 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4933 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4933 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4934 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4934 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4935 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4935 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4937 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4937 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4938 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4938 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4939 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4939 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4941 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4941 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4942 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4942 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4944 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4944 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4945 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4945 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4946 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4946 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4948 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4948 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4949 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4949 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4950 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4950 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4952 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4952 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4953 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4953 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4954 secs   base min: -27.000 uS max:  29.900 uS sdev:   4.800 uS
 4954 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4956 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 4956 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4957 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 4957 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4958 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 4958 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4960 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 4960 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4961 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 4961 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4963 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 4963 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4964 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 4964 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4965 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 4965 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4967 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 4967 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4968 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 4968 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4969 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 4969 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4971 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 4971 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4972 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 4972 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4973 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 4973 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4975 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 4975 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4976 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 4976 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4977 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 4977 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4979 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 4979 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4980 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 4980 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4981 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 4981 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4983 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 4983 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4984 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 4984 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4986 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 4986 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4987 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 4987 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4988 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 4988 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4990 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 4990 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4991 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 4991 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4992 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 4992 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4994 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 4994 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4995 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 4995 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4996 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 4996 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4998 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 4998 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 4999 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 4999 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5000 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5000 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5002 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5002 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5003 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5003 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5004 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5004 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5006 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5006 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5007 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5007 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5008 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5008 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5010 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5010 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5011 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5011 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5013 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5013 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5014 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5014 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5015 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5015 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5017 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5017 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5018 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5018 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5019 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5019 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5021 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5021 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5022 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5022 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5023 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5023 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5025 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5025 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5026 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5026 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5027 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5027 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5029 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5029 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5030 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5030 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5031 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5031 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5033 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5033 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5034 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5034 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5036 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5036 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5037 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5037 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5038 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5038 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5040 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5040 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5041 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5041 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5042 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5042 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5044 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5044 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5045 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5045 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5046 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5046 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5048 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5048 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5049 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5049 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5050 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5050 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5052 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5052 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5053 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5053 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5054 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5054 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5056 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5056 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5057 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5057 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5058 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5058 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5060 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5060 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5061 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5061 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5063 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5063 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5064 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5064 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5065 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5065 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5067 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5067 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5068 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5068 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5069 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5069 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5071 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5071 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5072 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5072 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5074 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5074 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5075 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5075 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5076 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5076 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5078 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5078 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5079 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5079 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5080 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5080 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5082 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5082 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5083 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5083 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5084 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5084 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5086 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5086 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5087 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5087 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5088 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5088 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5090 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5090 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5091 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5091 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5092 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5092 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5094 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5094 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5095 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5095 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5097 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5097 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5098 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5098 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5099 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5099 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5101 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5101 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5102 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5102 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5103 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5103 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5105 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5105 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5106 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5106 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5107 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5107 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5109 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5109 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5110 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5110 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5111 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5111 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5113 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5113 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5114 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5114 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5115 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5115 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5117 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5117 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5118 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5118 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5119 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5119 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5121 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5121 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5122 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5122 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5124 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5124 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5125 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5125 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5126 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5126 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5128 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5128 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5129 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5129 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5130 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5130 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5132 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5132 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5133 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5133 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5134 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5134 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5136 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5136 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5137 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5137 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5138 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5138 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5140 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5140 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5141 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5141 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5142 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5142 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5144 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5144 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5145 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5145 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5147 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5147 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5148 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5148 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5149 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5149 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5151 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5151 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5152 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5152 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5153 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5153 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5155 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5155 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5156 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5156 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5157 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5157 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5159 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5159 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5160 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5160 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5162 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5162 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5163 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5163 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5164 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5164 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5166 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5166 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5167 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5167 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5168 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5168 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5170 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5170 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5171 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5171 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5172 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5172 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5174 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5174 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5175 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5175 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5176 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5176 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5178 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5178 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5179 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5179 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5180 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5180 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5182 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5182 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5183 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5183 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5185 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5185 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5186 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5186 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5187 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5187 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5189 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5189 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5190 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5190 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5191 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5191 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5193 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5193 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5194 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5194 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5195 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5195 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5197 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5197 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5198 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5198 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5199 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5199 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5201 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5201 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5202 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5202 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5203 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5203 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5205 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5205 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5206 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5206 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5208 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5208 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5209 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5209 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5210 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5210 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5212 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5212 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5213 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5213 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5214 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5214 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5216 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5216 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5217 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5217 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5218 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5218 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5220 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5220 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5221 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5221 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5223 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5223 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5224 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5224 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5225 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5225 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5227 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5227 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5228 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5228 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5229 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5229 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5231 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5231 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5232 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5232 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5233 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5233 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5235 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5235 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5236 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5236 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5237 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5237 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5239 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5239 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5240 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5240 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5241 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5241 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5243 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5243 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5244 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5244 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5245 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5245 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5247 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5247 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5248 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5248 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5250 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5250 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5251 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5251 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5252 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5252 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5254 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5254 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5255 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5255 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5256 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5256 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5258 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5258 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5259 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5259 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5260 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5260 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5262 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5262 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5263 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5263 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5264 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5264 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5266 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5266 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5267 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5267 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5268 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5268 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5270 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5270 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5271 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5271 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5272 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5272 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5274 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5274 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5275 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5275 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5277 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5277 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5278 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5278 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5279 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5279 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5281 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5281 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5282 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5282 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5283 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5283 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5285 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5285 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5286 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5286 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5287 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5287 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5289 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5289 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5290 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5290 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5291 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5291 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5293 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5293 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5294 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5294 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5295 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5295 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5297 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5297 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5298 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5298 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5299 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5299 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5301 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5301 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5302 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5302 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5304 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5304 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5305 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5305 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5306 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5306 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5308 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5308 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5309 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5309 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5310 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5310 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5312 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5312 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5313 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5313 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5315 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5315 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5316 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5316 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5317 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5317 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
Core 0:       +30.0°C  (high = +76.0°C, crit = +100.0°C)
 5319 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5319 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5320 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5320 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5321 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5321 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5323 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5323 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5324 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5324 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5325 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5325 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5327 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5327 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5328 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5328 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5329 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5329 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5331 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5331 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5332 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5332 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5333 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5333 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5335 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5335 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5336 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5336 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5338 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5338 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5339 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5339 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5340 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5340 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5342 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5342 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5343 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5343 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5344 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5344 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5346 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5346 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5347 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5347 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5348 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5348 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5350 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5350 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5351 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5351 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5352 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5352 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5354 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5354 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5355 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5355 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5356 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5356 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5358 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5358 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5359 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5359 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5360 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5360 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5362 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5362 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5363 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5363 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5365 secs   base min: -27.900 uS max:  30.300 uS sdev:   4.800 uS
 5365 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5366 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5366 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5367 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5367 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5369 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5369 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5370 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5370 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5371 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5371 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5373 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5373 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5374 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5374 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5375 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5375 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5377 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5377 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5378 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5378 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5379 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5379 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5381 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5381 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5382 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5382 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5383 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5383 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5385 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5385 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5386 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5386 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5388 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5388 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5389 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5389 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5390 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5390 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5392 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5392 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5393 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5393 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5394 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5394 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5396 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5396 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5397 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5397 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5398 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5398 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5400 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5400 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5401 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5401 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5402 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5402 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5404 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5404 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5405 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5405 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5406 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5406 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5408 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5408 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5409 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5409 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5411 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5411 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5412 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5412 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5413 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5413 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5415 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5415 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5416 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5416 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5417 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5417 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5419 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5419 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5420 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5420 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5421 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5421 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5423 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5423 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5424 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5424 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5426 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5426 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5427 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5427 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5428 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5428 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5430 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5430 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5431 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5431 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5432 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5432 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5434 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5434 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5435 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5435 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5436 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5436 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5438 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5438 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5439 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5439 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5440 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5440 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5442 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5442 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5443 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5443 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5444 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5444 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5446 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5446 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5447 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5447 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5449 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5449 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5450 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5450 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5451 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5451 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5453 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5453 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5454 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5454 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5455 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5455 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5457 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5457 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5458 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5458 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5459 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5459 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5461 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5461 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5462 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5462 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5463 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5463 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5465 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5465 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5466 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5466 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5467 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5467 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5469 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5469 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5470 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5470 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5471 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5471 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5473 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5473 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5474 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5474 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5475 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5475 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5477 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5477 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5478 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5478 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5480 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5480 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5481 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5481 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5482 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5482 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5484 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5484 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5485 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5485 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5486 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5486 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5488 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5488 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5489 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5489 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5490 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5490 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5492 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5492 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5493 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5493 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5494 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5494 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5496 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5496 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5497 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5497 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5498 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5498 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5500 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5500 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5501 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5501 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5502 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5502 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5504 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5504 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5505 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5505 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5507 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5507 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5508 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5508 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5509 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5509 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5511 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5511 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5512 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5512 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5513 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5513 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5515 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5515 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5516 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5516 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5517 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5517 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5519 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5519 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5520 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5520 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5521 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5521 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5523 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5523 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5524 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5524 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5525 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5525 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5527 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5527 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5528 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5528 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5529 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5529 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5531 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5531 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5532 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5532 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5534 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5534 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5535 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5535 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5536 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5536 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5538 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5538 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5539 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5539 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5540 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5540 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5542 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5542 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5543 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5543 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5544 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5544 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5546 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5546 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5547 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5547 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5548 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5548 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5550 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5550 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5551 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5551 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5553 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5553 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5554 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5554 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5555 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5555 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5557 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5557 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5558 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5558 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5559 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5559 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5561 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5561 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5562 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5562 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5563 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5563 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5565 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5565 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5566 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5566 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5567 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5567 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5569 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5569 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5570 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5570 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5572 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5572 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5573 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5573 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5574 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5574 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5576 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5576 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5577 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5577 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5578 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5578 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5580 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5580 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5581 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5581 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5582 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5582 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5584 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5584 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5585 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5585 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5586 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5586 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5588 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5588 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5589 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5589 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5590 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5590 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5592 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5592 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5593 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5593 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5595 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5595 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5596 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5596 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5597 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5597 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5599 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5599 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5600 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5600 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5601 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5601 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5603 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5603 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5604 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5604 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5605 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5605 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5607 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5607 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5608 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5608 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5610 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5610 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5611 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5611 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5612 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5612 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5614 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5614 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5615 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5615 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5616 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5616 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5618 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5618 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5619 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5619 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5620 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5620 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5622 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5622 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5623 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5623 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5624 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5624 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5626 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5626 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5627 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5627 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5628 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5628 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5630 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5630 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5631 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5631 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5633 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5633 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5634 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5634 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5635 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5635 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5637 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5637 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5638 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5638 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5639 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5639 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5641 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5641 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5642 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5642 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5643 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5643 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5645 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5645 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5646 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5646 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5647 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5647 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5649 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5649 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5650 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5650 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5651 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5651 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5653 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5653 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5654 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5654 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5656 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5656 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5657 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5657 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5658 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5658 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5660 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5660 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5661 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5661 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5662 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5662 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5664 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5664 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5665 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5665 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5666 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5666 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5668 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5668 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5669 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5669 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5670 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5670 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5672 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5672 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5673 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5673 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5674 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5674 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5676 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5676 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5677 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5677 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5678 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5678 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5680 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5680 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5681 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5681 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5683 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5683 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5684 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5684 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5685 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5685 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5687 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5687 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5688 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5688 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5689 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5689 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5691 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5691 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5692 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5692 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5693 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5693 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5695 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5695 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5696 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5696 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5697 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5697 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5699 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5699 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5700 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5700 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5701 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5701 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5703 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5703 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5704 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5704 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5705 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5705 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5707 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5707 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5708 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5708 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5709 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5709 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5711 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5711 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5712 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5712 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5714 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5714 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5715 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5715 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5716 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5716 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5718 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5718 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5719 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5719 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5720 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5720 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5722 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5722 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5723 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5723 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5724 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5724 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5726 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5726 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5727 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5727 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5728 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5728 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5730 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5730 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5731 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5731 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5733 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5733 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5734 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5734 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5735 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5735 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5737 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5737 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5738 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5738 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5739 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5739 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5741 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5741 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5742 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5742 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5743 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5743 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5745 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5745 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5746 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5746 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5747 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5747 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5749 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5749 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5750 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5750 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5751 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5751 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5753 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5753 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5754 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5754 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5755 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5755 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5757 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5757 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5758 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5758 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5760 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5760 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5761 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5761 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5762 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5762 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5764 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5764 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5765 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5765 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5766 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5766 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5768 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5768 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5769 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5769 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5770 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5770 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5772 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5772 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5773 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5773 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5774 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5774 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5776 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5776 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5777 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5777 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5778 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5778 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5780 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5780 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5781 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5781 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5783 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5783 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5784 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5784 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5785 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5785 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5787 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5787 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5788 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5788 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5789 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5789 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5791 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5791 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5792 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5792 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5793 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5793 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5795 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5795 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5796 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5796 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5797 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5797 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5799 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5799 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5800 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5800 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5801 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5801 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5803 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5803 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5804 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5804 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5805 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5805 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5807 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5807 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5808 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5808 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5810 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5810 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5811 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5811 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5812 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5812 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5814 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5814 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5815 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5815 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5816 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5816 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5818 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5818 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5819 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5819 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5820 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5820 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5822 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5822 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5823 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5823 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5824 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5824 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5826 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5826 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5827 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5827 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5828 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5828 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5830 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5830 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5831 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5831 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5833 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5833 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5834 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5834 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5835 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5835 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5837 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5837 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5838 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5838 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5839 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5839 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5841 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5841 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5842 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5842 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5844 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5844 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5845 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5845 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5846 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5846 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5848 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5848 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5849 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5849 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5850 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5850 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5852 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5852 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5853 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5853 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5854 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5854 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5856 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5856 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5857 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5857 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5858 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5858 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5860 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5860 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5861 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5861 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5862 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5862 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5864 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5864 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5865 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5865 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5866 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5866 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5868 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5868 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5869 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5869 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5871 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5871 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5872 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5872 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5873 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5873 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5875 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5875 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5876 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5876 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5878 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5878 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5879 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5879 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5880 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5880 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5882 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5882 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5883 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5883 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5884 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5884 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5886 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5886 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5887 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5887 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5888 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5888 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5890 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5890 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5891 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5891 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5892 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5892 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5894 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5894 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5895 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5895 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5896 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5896 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5898 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5898 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5899 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5899 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5900 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5900 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5902 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5902 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5903 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5903 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5905 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5905 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5906 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5906 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5907 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5907 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5909 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5909 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5910 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5910 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5911 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5911 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5913 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5913 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5914 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5914 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5915 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5915 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5917 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5917 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5918 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5918 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5919 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5919 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5921 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5921 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5922 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5922 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5923 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5923 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5925 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5925 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5926 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5926 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5928 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5928 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5929 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5929 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5930 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5930 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5932 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5932 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5933 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5933 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5934 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5934 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5936 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5936 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5937 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5937 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5938 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5938 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5940 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5940 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5941 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5941 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5942 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5942 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5944 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5944 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5945 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5945 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5946 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5946 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5948 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5948 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5949 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5949 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5950 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5950 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5952 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5952 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5953 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5953 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5955 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5955 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5956 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5956 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5957 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5957 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5959 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5959 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5960 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5960 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5961 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5961 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5963 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5963 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5964 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5964 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5965 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5965 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5967 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5967 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5968 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5968 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5969 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5969 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5971 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5971 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5972 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5972 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5973 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5973 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5975 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5975 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5976 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5976 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5978 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5978 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5979 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5979 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
Core 0:       +30.0°C  (high = +76.0°C, crit = +100.0°C)
 5980 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5980 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5982 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5982 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5983 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5983 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5984 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5984 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5986 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5986 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5987 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5987 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5988 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5988 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5990 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5990 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5991 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5991 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5992 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5992 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5994 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5994 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5995 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5995 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5996 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5996 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5998 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5998 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 5999 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 5999 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6000 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6000 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6002 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6002 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6003 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6003 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6005 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6005 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6006 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6006 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6007 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6007 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6009 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6009 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6010 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6010 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6011 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6011 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6013 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6013 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6014 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6014 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6015 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6015 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6017 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6017 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6018 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6018 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6019 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6019 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6021 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6021 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6022 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6022 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6023 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6023 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6025 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6025 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6026 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6026 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6027 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6027 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6029 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6029 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6030 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6030 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6031 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6031 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6033 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6033 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6034 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6034 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6036 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6036 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6037 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6037 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6038 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6038 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6040 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6040 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6041 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6041 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6043 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6043 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6044 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6044 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6045 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6045 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6047 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6047 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6048 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6048 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6049 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6049 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6051 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6051 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6052 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6052 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6053 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6053 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6055 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6055 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6056 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6056 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6057 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6057 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6059 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6059 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6060 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6060 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6061 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6061 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6063 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6063 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6064 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6064 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6065 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6065 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6067 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6067 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6068 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6068 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6070 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6070 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6071 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6071 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6072 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6072 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6074 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6074 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6075 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6075 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6076 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6076 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6078 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6078 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6079 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6079 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6080 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6080 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6082 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6082 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6083 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6083 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6084 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6084 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6086 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6086 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6087 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6087 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6088 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6088 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6090 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6090 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6091 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6091 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6092 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6092 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6094 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6094 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6095 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6095 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6097 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6097 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6098 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6098 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6099 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6099 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6101 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6101 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6102 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6102 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6103 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6103 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6105 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6105 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6106 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6106 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6108 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6108 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6109 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6109 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6110 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6110 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6112 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6112 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6113 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6113 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6114 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6114 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6116 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6116 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6117 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6117 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6118 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6118 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6120 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6120 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6121 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6121 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6122 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6122 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6124 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6124 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6125 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6125 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6126 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6126 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6128 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6128 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6129 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6129 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6130 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6130 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6132 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6132 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6133 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6133 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6135 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6135 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6136 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6136 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6137 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6137 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6139 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6139 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6140 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6140 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6141 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6141 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6143 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6143 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6144 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6144 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6145 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6145 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6147 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6147 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6148 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6148 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6149 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6149 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6151 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6151 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6152 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6152 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6153 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6153 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6155 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6155 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6156 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6156 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6157 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6157 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6159 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6159 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6160 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6160 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6162 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6162 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6163 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6163 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6164 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6164 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6166 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6166 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6167 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6167 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6168 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6168 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6170 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6170 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6171 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6171 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6172 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6172 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6174 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6174 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6175 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6175 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6176 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6176 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6178 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6178 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6179 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6179 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6180 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6180 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6182 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6182 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6183 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6183 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6185 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6185 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6186 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6186 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6187 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6187 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6189 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6189 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6190 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6190 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6191 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6191 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6193 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6193 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6194 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6194 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6195 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6195 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6197 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6197 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6198 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6198 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6199 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6199 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6201 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6201 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6202 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6202 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6203 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6203 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6205 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6205 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6206 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6206 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6207 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6207 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6209 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6209 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6210 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6210 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6212 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6212 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6213 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6213 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6214 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6214 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6216 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6216 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6217 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6217 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6218 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6218 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6220 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6220 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6221 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6221 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6222 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6222 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6224 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6224 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6225 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6225 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6226 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6226 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6228 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6228 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6229 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6229 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6230 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6230 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6232 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6232 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6233 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6233 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6234 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6234 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6236 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6236 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6237 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6237 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6239 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6239 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6240 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6240 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6241 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6241 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6243 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6243 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6244 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6244 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6245 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6245 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6247 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6247 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6248 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6248 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6249 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6249 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6251 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6251 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6252 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6252 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6254 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6254 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6255 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6255 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6256 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6256 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6258 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6258 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6259 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6259 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6260 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6260 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6262 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6262 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6263 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6263 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6264 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6264 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6266 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6266 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6267 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6267 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6268 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6268 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6270 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6270 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6271 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6271 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6273 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6273 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6274 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6274 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6275 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6275 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6277 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6277 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6278 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6278 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6279 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6279 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6281 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6281 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6282 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6282 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6283 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6283 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6285 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6285 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6286 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6286 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6287 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6287 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6289 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6289 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6290 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6290 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6291 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6291 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6293 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6293 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6294 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6294 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6295 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6295 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6297 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6297 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6298 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6298 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6300 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6300 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6301 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6301 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6302 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6302 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6304 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6304 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6305 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6305 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6306 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6306 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6308 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6308 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6309 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6309 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6310 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6310 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6312 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6312 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6313 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6313 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6314 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6314 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6316 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6316 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6317 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6317 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6318 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6318 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6320 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6320 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6321 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6321 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6323 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6323 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6324 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6324 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6325 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6325 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6327 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6327 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6328 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6328 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6329 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6329 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6331 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6331 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6332 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6332 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6334 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6334 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6335 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6335 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6336 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6336 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6338 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6338 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6339 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6339 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6340 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6340 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6342 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6342 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6343 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6343 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6344 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6344 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6346 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6346 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6347 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6347 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6348 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6348 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6350 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6350 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6351 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6351 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6352 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6352 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6354 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6354 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6355 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6355 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6356 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6356 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6358 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6358 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6359 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6359 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6361 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6361 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6362 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6362 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6363 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6363 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6365 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6365 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6366 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6366 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6367 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6367 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6369 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6369 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6370 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6370 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6371 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6371 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6373 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6373 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6374 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6374 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6375 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6375 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6377 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6377 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6378 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6378 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6379 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6379 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6381 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6381 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6382 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6382 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6383 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6383 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6385 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6385 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6386 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6386 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6388 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6388 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6389 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6389 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6390 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6390 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6392 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6392 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6393 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6393 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6394 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6394 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6396 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6396 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6397 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6397 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6398 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6398 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6400 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6400 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6401 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6401 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6402 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6402 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6404 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6404 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6405 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6405 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6406 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6406 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6408 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6408 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6409 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6409 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6411 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6411 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6412 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6412 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6413 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6413 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6415 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6415 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6416 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6416 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6417 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6417 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6419 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6419 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6420 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6420 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6421 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6421 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6423 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6423 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6424 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6424 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6425 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6425 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6427 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6427 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6428 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6428 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6429 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6429 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6431 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6431 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6432 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6432 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6434 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6434 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6435 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6435 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6436 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6436 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6438 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6438 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6439 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6439 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6440 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6440 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6442 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6442 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6443 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6443 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6445 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6445 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6446 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6446 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6447 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6447 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6449 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6449 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6450 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6450 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6451 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6451 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6453 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6453 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6454 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6454 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6455 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6455 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6457 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6457 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6458 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6458 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6459 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6459 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6461 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6461 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6462 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6462 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6463 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6463 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6465 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6465 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6466 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6466 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6467 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6467 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6469 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6469 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6470 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6470 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6472 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6472 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6473 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6473 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6474 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6474 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6476 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6476 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6477 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6477 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6478 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6478 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6480 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6480 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6481 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6481 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6482 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6482 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6484 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6484 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6485 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6485 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6486 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6486 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6488 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6488 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6489 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6489 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6490 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6490 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6492 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6492 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6493 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6493 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6495 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6495 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6496 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6496 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6497 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6497 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6499 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6499 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6500 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6500 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6501 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6501 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6503 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6503 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6504 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6504 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6505 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6505 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6507 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6507 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6508 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6508 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6509 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6509 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6511 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6511 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6512 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6512 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6513 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6513 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6515 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6515 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6516 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6516 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6517 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6517 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6519 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6519 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6520 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6520 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6522 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6522 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6523 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6523 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6524 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6524 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6526 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6526 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6527 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6527 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6528 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6528 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6530 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6530 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6531 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6531 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6532 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6532 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6534 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6534 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6535 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6535 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6537 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6537 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6538 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6538 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6539 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6539 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6541 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6541 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6542 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6542 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6543 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6543 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6545 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6545 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6546 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6546 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6547 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6547 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6549 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6549 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6550 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6550 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6551 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6551 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6553 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6553 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6554 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6554 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6556 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6556 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6557 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6557 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6558 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6558 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6560 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6560 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6561 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6561 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6562 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6562 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6564 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6564 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6565 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6565 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6566 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6566 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6568 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6568 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6569 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6569 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6570 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6570 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6572 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6572 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6573 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6573 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6574 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6574 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6576 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6576 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6577 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6577 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6578 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6578 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6580 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6580 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6581 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6581 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6583 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6583 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6584 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6584 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6585 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6585 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6587 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6587 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6588 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6588 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6589 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6589 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6591 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6591 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6592 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6592 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6593 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6593 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6595 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6595 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6596 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6596 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6597 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6597 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6599 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6599 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6600 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6600 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6601 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6601 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6603 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6603 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6604 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6604 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6605 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6605 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6607 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6607 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6608 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6608 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6610 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6610 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6611 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6611 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6612 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6612 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6614 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6614 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6615 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6615 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6616 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6616 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6618 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6618 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6619 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6619 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6621 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6621 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6622 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6622 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6623 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6623 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6625 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6625 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6626 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6626 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6627 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6627 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6629 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6629 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6630 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6630 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6631 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6631 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6633 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6633 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6634 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6634 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6635 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6635 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6637 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6637 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6638 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6638 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6639 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6639 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6641 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6641 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6642 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6642 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
Core 0:       +30.0°C  (high = +76.0°C, crit = +100.0°C)
 6643 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6643 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6645 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6645 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6646 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6646 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6648 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6648 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6649 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6649 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6650 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6650 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6652 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6652 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6653 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6653 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6654 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6654 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6656 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6656 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6657 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6657 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6658 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6658 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6660 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6660 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6661 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6661 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6662 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6662 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6664 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6664 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6665 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6665 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6666 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6666 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6668 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6668 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6669 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6669 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6670 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6670 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6672 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6672 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6673 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6673 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6675 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6675 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6676 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6676 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6677 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6677 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6679 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6679 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6680 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6680 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6681 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6681 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6683 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6683 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6684 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6684 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6685 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6685 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6687 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6687 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6688 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6688 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6689 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6689 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6691 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6691 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6692 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6692 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6693 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6693 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6695 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6695 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6696 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6696 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6697 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6697 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6699 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6699 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6700 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6700 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6702 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6702 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6703 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6703 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6704 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6704 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6706 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6706 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6707 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6707 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6708 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6708 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6710 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6710 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6711 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6711 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6712 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6712 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6714 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6714 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6715 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6715 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6717 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6717 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6718 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6718 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6719 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6719 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6721 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6721 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6722 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6722 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6723 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6723 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6725 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6725 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6726 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6726 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6727 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6727 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6729 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6729 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6730 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6730 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6731 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6731 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6733 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6733 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6734 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6734 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6736 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6736 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6737 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6737 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6738 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6738 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6740 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6740 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6741 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6741 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6742 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6742 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6744 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6744 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6745 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6745 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6746 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6746 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6748 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6748 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6749 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6749 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6750 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6750 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6752 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6752 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6753 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6753 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6754 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6754 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6756 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6756 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6757 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6757 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6758 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6758 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6760 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6760 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6761 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6761 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6763 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6763 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6764 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6764 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6765 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6765 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6767 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6767 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6768 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6768 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6769 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6769 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6771 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6771 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6772 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6772 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6773 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6773 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6775 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6775 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6776 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6776 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6777 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6777 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6779 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6779 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6780 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6780 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6781 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6781 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6783 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6783 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6784 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6784 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6785 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6785 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6787 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6787 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6788 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6788 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6790 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6790 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6791 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6791 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6792 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6792 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6794 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6794 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6795 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6795 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6796 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6796 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6798 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6798 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6799 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6799 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6800 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6800 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6802 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6802 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6803 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6803 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6804 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6804 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6806 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6806 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6807 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6807 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6808 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6808 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6810 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6810 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6811 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6811 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6812 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6812 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6814 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6814 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6815 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6815 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6817 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6817 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6818 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6818 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6819 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6819 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6821 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6821 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6822 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6822 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6823 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6823 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6825 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6825 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6826 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6826 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6827 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6827 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6829 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6829 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6830 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6830 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6832 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6832 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6833 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6833 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6834 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6834 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6836 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6836 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6837 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6837 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6838 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6838 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6840 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6840 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6841 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6841 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6842 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6842 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6844 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6844 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6845 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6845 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6846 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6846 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6848 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6848 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6849 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6849 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6851 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6851 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6852 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6852 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6853 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6853 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6855 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6855 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6856 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6856 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6857 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6857 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6859 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6859 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6860 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6860 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6861 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6861 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6863 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6863 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6864 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6864 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6865 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6865 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6867 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6867 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6868 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6868 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6869 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6869 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6871 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6871 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6872 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6872 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6873 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6873 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6875 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6875 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6876 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6876 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6878 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6878 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6879 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6879 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6880 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6880 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6882 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6882 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6883 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6883 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6884 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6884 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6886 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6886 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6887 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6887 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6888 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6888 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6890 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6890 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6891 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6891 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6892 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6892 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6894 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6894 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6895 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6895 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6896 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6896 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6898 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6898 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6899 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6899 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6900 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6900 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6902 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6902 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6903 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6903 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6905 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6905 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6906 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6906 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6907 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6907 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6909 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6909 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6910 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6910 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6911 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6911 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6913 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6913 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6914 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6914 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6915 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6915 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6917 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6917 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6918 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6918 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6919 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6919 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6921 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6921 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6922 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6922 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6923 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6923 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6925 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6925 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6926 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6926 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6927 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6927 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6929 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6929 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6930 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6930 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6932 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6932 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6933 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6933 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6934 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6934 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6936 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6936 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6937 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6937 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6938 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6938 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6940 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6940 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6941 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6941 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6942 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6942 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6944 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6944 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6945 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6945 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6946 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6946 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6948 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6948 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6949 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6949 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6950 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6950 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6952 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6952 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6953 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6953 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6954 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6954 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6956 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6956 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6957 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6957 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6959 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6959 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6960 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6960 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6961 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6961 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6963 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6963 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6964 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6964 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6965 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6965 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6967 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6967 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6968 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6968 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6969 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6969 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6971 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6971 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6972 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6972 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6973 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6973 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6975 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6975 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6976 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6976 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6977 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6977 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6979 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6979 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6980 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6980 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6981 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6981 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6983 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6983 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6984 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6984 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6986 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6986 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6987 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6987 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6988 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6988 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6990 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6990 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6991 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6991 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6992 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6992 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6994 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6994 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6995 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6995 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6997 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6997 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6998 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6998 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 6999 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 6999 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 7001 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7001 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 7002 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7002 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 7003 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7003 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 7005 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7005 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 7006 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7006 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 7007 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7007 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 7009 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7009 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 7010 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7010 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 7011 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7011 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 7013 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7013 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 7014 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7014 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 7015 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7015 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 7017 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7017 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 7018 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7018 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 7019 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7019 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 7021 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7021 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 7022 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7022 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 7024 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7024 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 7025 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7025 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 7026 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7026 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 7028 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7028 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 7029 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7029 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 7030 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7030 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 7032 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7032 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 7033 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7033 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 7034 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7034 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 7036 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7036 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 7037 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7037 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 7038 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7038 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 7040 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7040 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 7041 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7041 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 7042 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7042 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 7044 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7044 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 7045 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7045 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 7046 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7046 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 7048 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7048 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 7049 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7049 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 7051 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7051 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 7052 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7052 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 7053 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7053 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 7055 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7055 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 7056 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7056 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 7057 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7057 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 7059 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7059 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 7060 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7060 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 7061 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7061 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 7063 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7063 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 7064 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7064 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 7066 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7066 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 7067 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7067 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 7068 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7068 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 7070 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7070 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 7071 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7071 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 7072 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7072 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 7074 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7074 secs  servo min: -31.600 uS max:  30.900 uS sdev:   1.600 uS
 7075 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7075 secs  servo min: -37.800 uS max:  35.500 uS sdev:   1.600 uS
 7076 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7076 secs  servo min: -37.800 uS max:  35.500 uS sdev:   1.600 uS
 7078 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7078 secs  servo min: -37.800 uS max:  35.500 uS sdev:   1.600 uS
 7079 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7079 secs  servo min: -37.800 uS max:  35.500 uS sdev:   1.600 uS
 7080 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7080 secs  servo min: -37.800 uS max:  35.500 uS sdev:   1.600 uS
 7082 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7082 secs  servo min: -37.800 uS max:  35.500 uS sdev:   1.600 uS
 7083 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7083 secs  servo min: -37.800 uS max:  35.500 uS sdev:   1.600 uS
 7085 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7085 secs  servo min: -37.800 uS max:  35.500 uS sdev:   1.600 uS
 7086 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7086 secs  servo min: -37.800 uS max:  35.500 uS sdev:   1.600 uS
 7087 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7087 secs  servo min: -37.800 uS max:  35.500 uS sdev:   1.600 uS
 7089 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7089 secs  servo min: -37.800 uS max:  35.500 uS sdev:   1.600 uS
 7090 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7090 secs  servo min: -37.800 uS max:  35.500 uS sdev:   1.600 uS
 7091 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7091 secs  servo min: -37.800 uS max:  35.500 uS sdev:   1.600 uS
 7093 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7093 secs  servo min: -37.800 uS max:  35.500 uS sdev:   1.600 uS
 7094 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7094 secs  servo min: -37.800 uS max:  35.500 uS sdev:   1.600 uS
 7095 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7095 secs  servo min: -37.800 uS max:  35.500 uS sdev:   1.600 uS
 7097 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7097 secs  servo min: -37.800 uS max:  35.500 uS sdev:   1.600 uS
 7098 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7098 secs  servo min: -37.800 uS max:  35.500 uS sdev:   1.600 uS
 7099 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7099 secs  servo min: -37.800 uS max:  35.500 uS sdev:   1.600 uS
 7101 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7101 secs  servo min: -37.800 uS max:  35.500 uS sdev:   1.600 uS
 7102 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7102 secs  servo min: -37.800 uS max:  35.500 uS sdev:   1.600 uS
 7103 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7103 secs  servo min: -37.800 uS max:  35.500 uS sdev:   1.600 uS
 7105 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7105 secs  servo min: -37.800 uS max:  35.500 uS sdev:   1.600 uS
 7106 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7106 secs  servo min: -37.800 uS max:  35.500 uS sdev:   1.600 uS
 7107 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7107 secs  servo min: -37.800 uS max:  35.500 uS sdev:   1.600 uS
 7109 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7109 secs  servo min: -37.800 uS max:  35.500 uS sdev:   1.600 uS
 7110 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7110 secs  servo min: -37.800 uS max:  35.500 uS sdev:   1.600 uS
 7112 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7112 secs  servo min: -37.800 uS max:  35.500 uS sdev:   1.600 uS
 7113 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7113 secs  servo min: -37.800 uS max:  35.500 uS sdev:   1.600 uS
 7114 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7114 secs  servo min: -37.800 uS max:  35.500 uS sdev:   1.600 uS
 7116 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7116 secs  servo min: -37.800 uS max:  35.500 uS sdev:   1.600 uS
 7117 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7117 secs  servo min: -37.800 uS max:  35.500 uS sdev:   1.600 uS
 7118 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7118 secs  servo min: -37.800 uS max:  35.500 uS sdev:   1.600 uS
 7120 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7120 secs  servo min: -37.800 uS max:  35.500 uS sdev:   1.600 uS
 7121 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7121 secs  servo min: -37.800 uS max:  35.500 uS sdev:   1.600 uS
 7122 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7122 secs  servo min: -37.800 uS max:  35.500 uS sdev:   1.600 uS
 7124 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7124 secs  servo min: -37.800 uS max:  35.500 uS sdev:   1.600 uS
 7125 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7125 secs  servo min: -37.800 uS max:  35.500 uS sdev:   1.600 uS
 7126 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7126 secs  servo min: -37.800 uS max:  35.500 uS sdev:   1.600 uS
 7128 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7128 secs  servo min: -37.800 uS max:  35.500 uS sdev:   1.600 uS
 7129 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7129 secs  servo min: -37.800 uS max:  35.500 uS sdev:   1.600 uS
 7130 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7130 secs  servo min: -37.800 uS max:  35.500 uS sdev:   1.600 uS
 7132 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7132 secs  servo min: -37.800 uS max:  35.500 uS sdev:   1.600 uS
 7133 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7133 secs  servo min: -37.800 uS max:  35.500 uS sdev:   1.600 uS
 7134 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7134 secs  servo min: -37.800 uS max:  35.500 uS sdev:   1.600 uS
 7136 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7136 secs  servo min: -37.800 uS max:  35.500 uS sdev:   1.600 uS
 7137 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7137 secs  servo min: -37.800 uS max:  35.500 uS sdev:   1.600 uS
 7139 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7139 secs  servo min: -37.800 uS max:  35.500 uS sdev:   1.600 uS
 7140 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7140 secs  servo min: -37.800 uS max:  35.500 uS sdev:   1.600 uS
 7141 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7141 secs  servo min: -37.800 uS max:  35.500 uS sdev:   1.600 uS
 7143 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7143 secs  servo min: -37.800 uS max:  35.500 uS sdev:   1.600 uS
 7144 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7144 secs  servo min: -37.800 uS max:  35.500 uS sdev:   1.600 uS
 7145 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7145 secs  servo min: -37.800 uS max:  35.500 uS sdev:   1.600 uS
 7147 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7147 secs  servo min: -37.800 uS max:  35.500 uS sdev:   1.600 uS
 7148 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7148 secs  servo min: -37.800 uS max:  35.500 uS sdev:   1.600 uS
 7149 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7149 secs  servo min: -37.800 uS max:  35.500 uS sdev:   1.600 uS
 7151 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7151 secs  servo min: -37.800 uS max:  35.500 uS sdev:   1.600 uS
 7152 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7152 secs  servo min: -37.800 uS max:  35.500 uS sdev:   1.600 uS
 7153 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7153 secs  servo min: -37.800 uS max:  35.500 uS sdev:   1.600 uS
 7155 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7155 secs  servo min: -37.800 uS max:  35.500 uS sdev:   1.600 uS
 7156 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7156 secs  servo min: -37.800 uS max:  35.500 uS sdev:   1.600 uS
 7157 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7157 secs  servo min: -37.800 uS max:  35.500 uS sdev:   1.600 uS
 7159 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7159 secs  servo min: -37.800 uS max:  35.500 uS sdev:   1.600 uS
 7160 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7160 secs  servo min: -37.800 uS max:  35.500 uS sdev:   1.600 uS
 7161 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7161 secs  servo min: -37.800 uS max:  35.500 uS sdev:   1.600 uS
 7163 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7163 secs  servo min: -37.800 uS max:  35.500 uS sdev:   1.600 uS
 7164 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7164 secs  servo min: -37.800 uS max:  35.500 uS sdev:   1.600 uS
 7166 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7166 secs  servo min: -37.800 uS max:  35.500 uS sdev:   1.600 uS
 7167 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7167 secs  servo min: -37.800 uS max:  35.500 uS sdev:   1.600 uS
 7168 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7168 secs  servo min: -37.800 uS max:  35.500 uS sdev:   1.600 uS
 7170 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7170 secs  servo min: -37.800 uS max:  35.500 uS sdev:   1.600 uS
 7171 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7171 secs  servo min: -37.800 uS max:  35.500 uS sdev:   1.600 uS
 7172 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7172 secs  servo min: -37.800 uS max:  35.500 uS sdev:   1.600 uS
 7174 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7174 secs  servo min: -37.800 uS max:  35.500 uS sdev:   1.600 uS
 7175 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7175 secs  servo min: -37.800 uS max:  35.500 uS sdev:   1.600 uS
 7176 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7176 secs  servo min: -37.800 uS max:  35.500 uS sdev:   1.600 uS
 7178 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7178 secs  servo min: -37.800 uS max:  35.500 uS sdev:   1.600 uS
 7179 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7179 secs  servo min: -37.800 uS max:  35.500 uS sdev:   1.600 uS
 7180 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7180 secs  servo min: -37.800 uS max:  35.500 uS sdev:   1.600 uS
 7182 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7182 secs  servo min: -37.800 uS max:  35.500 uS sdev:   1.600 uS
 7183 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7183 secs  servo min: -37.800 uS max:  35.500 uS sdev:   1.600 uS
 7184 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7184 secs  servo min: -37.800 uS max:  35.500 uS sdev:   1.600 uS
 7186 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7186 secs  servo min: -37.800 uS max:  35.500 uS sdev:   1.600 uS
 7187 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7187 secs  servo min: -37.800 uS max:  35.500 uS sdev:   1.600 uS
 7189 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7189 secs  servo min: -37.800 uS max:  35.500 uS sdev:   1.600 uS
 7190 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7190 secs  servo min: -37.800 uS max:  35.500 uS sdev:   1.600 uS
 7191 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7191 secs  servo min: -37.800 uS max:  35.500 uS sdev:   1.600 uS
 7193 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7193 secs  servo min: -37.800 uS max:  35.500 uS sdev:   1.600 uS
 7194 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7194 secs  servo min: -37.800 uS max:  35.500 uS sdev:   1.600 uS
 7195 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7195 secs  servo min: -37.800 uS max:  35.500 uS sdev:   1.600 uS
 7197 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7197 secs  servo min: -37.800 uS max:  35.500 uS sdev:   1.600 uS
 7198 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7198 secs  servo min: -37.800 uS max:  35.500 uS sdev:   1.600 uS
 7199 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7199 secs  servo min: -37.800 uS max:  35.500 uS sdev:   1.600 uS
 7201 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7201 secs  servo min: -37.800 uS max:  35.500 uS sdev:   1.600 uS
 7202 secs   base min: -31.800 uS max:  32.800 uS sdev:   4.800 uS
 7202 secs  servo min: -37.800 uS max:  35.500 uS sdev:   1.600 uS
Note: Using POSIX realtime
    0 secs   base min:  -8.100 uS max:   9.900 uS sdev:   0.900 uS
    0 secs  servo min:  -3.300 uS max:   3.600 uS sdev:   1.000 uS
    2 secs   base min: -13.000 uS max:  13.200 uS sdev:   0.900 uS
    2 secs  servo min: -13.600 uS max:   9.900 uS sdev:   1.000 uS
    3 secs   base min: -13.000 uS max:  14.500 uS sdev:   1.000 uS
    3 secs  servo min: -13.600 uS max:  12.200 uS sdev:   1.000 uS
    4 secs   base min: -13.600 uS max:  15.600 uS sdev:   1.000 uS
    4 secs  servo min: -13.600 uS max:  13.200 uS sdev:   1.100 uS
    6 secs   base min: -13.600 uS max:  15.600 uS sdev:   1.100 uS
    6 secs  servo min: -13.600 uS max:  13.200 uS sdev:   1.100 uS
    7 secs   base min: -14.700 uS max:  16.500 uS sdev:   1.100 uS
    7 secs  servo min: -13.600 uS max:  13.200 uS sdev:   1.100 uS
    9 secs   base min: -17.700 uS max:  16.500 uS sdev:   1.100 uS
    9 secs  servo min: -13.600 uS max:  13.200 uS sdev:   1.100 uS
   10 secs   base min: -17.700 uS max:  16.500 uS sdev:   1.100 uS
   10 secs  servo min: -13.800 uS max:  13.200 uS sdev:   1.200 uS
   11 secs   base min: -17.700 uS max:  16.500 uS sdev:   1.100 uS
   11 secs  servo min: -13.800 uS max:  13.200 uS sdev:   1.100 uS
   13 secs   base min: -17.700 uS max:  17.900 uS sdev:   1.100 uS
   13 secs  servo min: -13.800 uS max:  13.200 uS sdev:   1.100 uS
   14 secs   base min: -17.700 uS max:  17.900 uS sdev:   1.100 uS
   14 secs  servo min: -13.800 uS max:  13.200 uS sdev:   1.100 uS
   15 secs   base min: -17.700 uS max:  17.900 uS sdev:   1.100 uS
   15 secs  servo min: -13.800 uS max:  13.200 uS sdev:   1.100 uS
   17 secs   base min: -17.700 uS max:  17.900 uS sdev:   1.100 uS
   17 secs  servo min: -15.000 uS max:  13.200 uS sdev:   1.100 uS
   18 secs   base min: -17.700 uS max:  17.900 uS sdev:   1.100 uS
   18 secs  servo min: -15.000 uS max:  13.200 uS sdev:   1.100 uS
   19 secs   base min: -17.700 uS max:  17.900 uS sdev:   1.100 uS
   19 secs  servo min: -15.000 uS max:  13.200 uS sdev:   1.100 uS
   21 secs   base min: -17.700 uS max:  17.900 uS sdev:   1.100 uS
   21 secs  servo min: -15.000 uS max:  13.200 uS sdev:   1.100 uS
   22 secs   base min: -17.700 uS max:  17.900 uS sdev:   1.100 uS
   22 secs  servo min: -15.000 uS max:  13.200 uS sdev:   1.100 uS
   23 secs   base min: -17.700 uS max:  17.900 uS sdev:   1.100 uS
   23 secs  servo min: -15.000 uS max:  13.200 uS sdev:   1.100 uS
   25 secs   base min: -18.000 uS max:  18.600 uS sdev:   1.100 uS
   25 secs  servo min: -15.000 uS max:  13.200 uS sdev:   1.100 uS
   26 secs   base min: -18.000 uS max:  18.600 uS sdev:   1.200 uS
   26 secs  servo min: -15.000 uS max:  13.200 uS sdev:   1.100 uS
   27 secs   base min: -18.000 uS max:  18.900 uS sdev:   1.200 uS
   27 secs  servo min: -15.000 uS max:  13.200 uS sdev:   1.100 uS
   29 secs   base min: -18.000 uS max:  19.300 uS sdev:   1.200 uS
   29 secs  servo min: -15.000 uS max:  13.800 uS sdev:   1.200 uS
   30 secs   base min: -18.000 uS max:  19.300 uS sdev:   1.200 uS
   30 secs  servo min: -15.000 uS max:  13.800 uS sdev:   1.100 uS
   31 secs   base min: -18.000 uS max:  19.300 uS sdev:   1.200 uS
   31 secs  servo min: -15.000 uS max:  13.800 uS sdev:   1.200 uS
   33 secs   base min: -18.000 uS max:  19.300 uS sdev:   1.200 uS
   33 secs  servo min: -15.000 uS max:  14.000 uS sdev:   1.200 uS
   34 secs   base min: -18.000 uS max:  19.300 uS sdev:   1.200 uS
   34 secs  servo min: -15.000 uS max:  14.000 uS sdev:   1.200 uS
   35 secs   base min: -18.000 uS max:  19.300 uS sdev:   1.200 uS
   35 secs  servo min: -15.000 uS max:  14.100 uS sdev:   1.200 uS
   37 secs   base min: -18.000 uS max:  19.300 uS sdev:   1.200 uS
   37 secs  servo min: -15.000 uS max:  14.100 uS sdev:   1.100 uS
   38 secs   base min: -18.000 uS max:  19.300 uS sdev:   1.200 uS
   38 secs  servo min: -15.000 uS max:  14.100 uS sdev:   1.100 uS
   39 secs   base min: -18.000 uS max:  19.300 uS sdev:   1.200 uS
   39 secs  servo min: -15.000 uS max:  14.100 uS sdev:   1.100 uS
   41 secs   base min: -18.000 uS max:  19.300 uS sdev:   1.200 uS
   41 secs  servo min: -15.000 uS max:  14.100 uS sdev:   1.100 uS
   42 secs   base min: -18.000 uS max:  19.300 uS sdev:   1.200 uS
   42 secs  servo min: -15.000 uS max:  14.100 uS sdev:   1.100 uS
   43 secs   base min: -18.000 uS max:  19.300 uS sdev:   1.200 uS
   43 secs  servo min: -15.000 uS max:  14.100 uS sdev:   1.100 uS
   45 secs   base min: -18.000 uS max:  19.300 uS sdev:   1.200 uS
   45 secs  servo min: -15.000 uS max:  14.100 uS sdev:   1.100 uS
   46 secs   base min: -18.000 uS max:  19.300 uS sdev:   1.200 uS
   46 secs  servo min: -15.000 uS max:  14.100 uS sdev:   1.100 uS
   47 secs   base min: -18.000 uS max:  19.300 uS sdev:   1.200 uS
   47 secs  servo min: -15.000 uS max:  14.100 uS sdev:   1.100 uS
   49 secs   base min: -18.000 uS max:  19.300 uS sdev:   1.200 uS
   49 secs  servo min: -15.000 uS max:  14.100 uS sdev:   1.100 uS
   50 secs   base min: -18.000 uS max:  19.300 uS sdev:   1.200 uS
   50 secs  servo min: -15.000 uS max:  14.100 uS sdev:   1.100 uS
   51 secs   base min: -18.000 uS max:  19.300 uS sdev:   1.200 uS
   51 secs  servo min: -15.000 uS max:  14.100 uS sdev:   1.100 uS
   53 secs   base min: -18.000 uS max:  19.300 uS sdev:   1.200 uS
   53 secs  servo min: -15.000 uS max:  14.100 uS sdev:   1.100 uS
   54 secs   base min: -18.000 uS max:  19.300 uS sdev:   1.200 uS
   54 secs  servo min: -15.000 uS max:  14.100 uS sdev:   1.100 uS
   55 secs   base min: -18.000 uS max:  19.300 uS sdev:   1.200 uS
   55 secs  servo min: -15.000 uS max:  14.100 uS sdev:   1.100 uS
   57 secs   base min: -18.000 uS max:  19.300 uS sdev:   1.200 uS
   57 secs  servo min: -15.000 uS max:  14.100 uS sdev:   1.100 uS
   58 secs   base min: -18.000 uS max:  19.300 uS sdev:   1.200 uS
   58 secs  servo min: -15.000 uS max:  14.100 uS sdev:   1.100 uS
   59 secs   base min: -18.000 uS max:  19.300 uS sdev:   1.200 uS
   59 secs  servo min: -15.000 uS max:  14.100 uS sdev:   1.100 uS
   61 secs   base min: -18.000 uS max:  19.300 uS sdev:   1.200 uS
   61 secs  servo min: -15.000 uS max:  14.100 uS sdev:   1.100 uS
   62 secs   base min: -18.000 uS max:  19.300 uS sdev:   1.200 uS
   62 secs  servo min: -15.000 uS max:  14.100 uS sdev:   1.100 uS
   63 secs   base min: -18.000 uS max:  19.300 uS sdev:   1.100 uS
   63 secs  servo min: -15.000 uS max:  14.100 uS sdev:   1.100 uS
   65 secs   base min: -18.000 uS max:  19.300 uS sdev:   1.100 uS
   65 secs  servo min: -15.000 uS max:  14.100 uS sdev:   1.100 uS
   66 secs   base min: -18.000 uS max:  19.300 uS sdev:   1.100 uS
   66 secs  servo min: -15.000 uS max:  14.100 uS sdev:   1.100 uS
   67 secs   base min: -18.000 uS max:  19.300 uS sdev:   1.100 uS
   67 secs  servo min: -15.000 uS max:  14.100 uS sdev:   1.100 uS
   69 secs   base min: -18.000 uS max:  19.300 uS sdev:   1.100 uS
   69 secs  servo min: -15.000 uS max:  14.100 uS sdev:   1.100 uS
   70 secs   base min: -18.000 uS max:  19.300 uS sdev:   1.100 uS
   70 secs  servo min: -15.000 uS max:  14.100 uS sdev:   1.100 uS
   71 secs   base min: -18.000 uS max:  19.300 uS sdev:   1.100 uS
   71 secs  servo min: -15.000 uS max:  14.100 uS sdev:   1.100 uS
   73 secs   base min: -18.000 uS max:  19.300 uS sdev:   1.100 uS
   73 secs  servo min: -15.000 uS max:  14.100 uS sdev:   1.100 uS
   74 secs   base min: -18.000 uS max:  19.300 uS sdev:   1.100 uS
   74 secs  servo min: -15.000 uS max:  14.100 uS sdev:   1.100 uS
   75 secs   base min: -18.000 uS max:  19.300 uS sdev:   1.100 uS
   75 secs  servo min: -15.000 uS max:  14.100 uS sdev:   1.100 uS
   77 secs   base min: -18.000 uS max:  19.300 uS sdev:   1.100 uS
   77 secs  servo min: -15.000 uS max:  14.100 uS sdev:   1.100 uS
   78 secs   base min: -18.000 uS max:  19.300 uS sdev:   1.100 uS
   78 secs  servo min: -15.000 uS max:  14.100 uS sdev:   1.100 uS
   79 secs   base min: -18.000 uS max:  19.300 uS sdev:   1.100 uS
   79 secs  servo min: -15.000 uS max:  14.100 uS sdev:   1.100 uS
   81 secs   base min: -18.000 uS max:  19.300 uS sdev:   1.100 uS
   81 secs  servo min: -15.000 uS max:  14.100 uS sdev:   1.100 uS
   82 secs   base min: -18.000 uS max:  19.300 uS sdev:   1.100 uS
   82 secs  servo min: -15.000 uS max:  14.100 uS sdev:   1.100 uS
   83 secs   base min: -18.000 uS max:  19.300 uS sdev:   1.100 uS
   83 secs  servo min: -15.000 uS max:  14.100 uS sdev:   1.100 uS
   85 secs   base min: -18.000 uS max:  19.300 uS sdev:   1.100 uS
   85 secs  servo min: -15.000 uS max:  14.100 uS sdev:   1.100 uS
   86 secs   base min: -18.000 uS max:  19.300 uS sdev:   1.100 uS
   86 secs  servo min: -15.000 uS max:  14.100 uS sdev:   1.100 uS
   87 secs   base min: -18.000 uS max:  19.300 uS sdev:   1.100 uS
   87 secs  servo min: -15.000 uS max:  14.100 uS sdev:   1.100 uS
   89 secs   base min: -18.000 uS max:  19.300 uS sdev:   1.100 uS
   89 secs  servo min: -15.000 uS max:  14.100 uS sdev:   1.100 uS
   90 secs   base min: -18.000 uS max:  19.300 uS sdev:   1.100 uS
   90 secs  servo min: -15.000 uS max:  14.100 uS sdev:   1.100 uS
   91 secs   base min: -18.000 uS max:  19.300 uS sdev:   1.100 uS
   91 secs  servo min: -15.000 uS max:  14.100 uS sdev:   1.100 uS
   93 secs   base min: -18.000 uS max:  19.300 uS sdev:   1.100 uS
   93 secs  servo min: -15.000 uS max:  14.100 uS sdev:   1.100 uS
   94 secs   base min: -18.000 uS max:  19.300 uS sdev:   1.100 uS
   94 secs  servo min: -15.000 uS max:  14.100 uS sdev:   1.100 uS
   95 secs   base min: -18.000 uS max:  19.300 uS sdev:   1.100 uS
   95 secs  servo min: -15.000 uS max:  14.100 uS sdev:   1.100 uS
   97 secs   base min: -18.000 uS max:  19.300 uS sdev:   1.100 uS
   97 secs  servo min: -15.000 uS max:  14.100 uS sdev:   1.100 uS
   98 secs   base min: -18.000 uS max:  19.300 uS sdev:   1.100 uS
   98 secs  servo min: -15.000 uS max:  14.100 uS sdev:   1.100 uS
   99 secs   base min: -18.000 uS max:  19.300 uS sdev:   1.100 uS
   99 secs  servo min: -15.000 uS max:  14.100 uS sdev:   1.100 uS
  101 secs   base min: -18.000 uS max:  19.300 uS sdev:   1.100 uS
  101 secs  servo min: -15.000 uS max:  14.100 uS sdev:   1.100 uS
  102 secs   base min: -18.000 uS max:  19.300 uS sdev:   1.100 uS
  102 secs  servo min: -15.000 uS max:  15.100 uS sdev:   1.100 uS
  103 secs   base min: -18.000 uS max:  19.300 uS sdev:   1.100 uS
  103 secs  servo min: -15.000 uS max:  15.100 uS sdev:   1.100 uS
  105 secs   base min: -18.000 uS max:  19.300 uS sdev:   1.100 uS
  105 secs  servo min: -15.000 uS max:  15.100 uS sdev:   1.100 uS
  106 secs   base min: -18.000 uS max:  19.300 uS sdev:   1.100 uS
  106 secs  servo min: -15.000 uS max:  15.100 uS sdev:   1.100 uS
  107 secs   base min: -18.000 uS max:  19.300 uS sdev:   1.100 uS
  107 secs  servo min: -15.000 uS max:  15.100 uS sdev:   1.100 uS
  109 secs   base min: -18.000 uS max:  19.300 uS sdev:   1.100 uS
  109 secs  servo min: -15.000 uS max:  15.100 uS sdev:   1.100 uS
  110 secs   base min: -18.000 uS max:  19.300 uS sdev:   1.100 uS
  110 secs  servo min: -15.000 uS max:  15.100 uS sdev:   1.100 uS
  111 secs   base min: -18.000 uS max:  19.300 uS sdev:   1.100 uS
  111 secs  servo min: -15.000 uS max:  15.100 uS sdev:   1.100 uS
  113 secs   base min: -18.000 uS max:  19.300 uS sdev:   1.100 uS
  113 secs  servo min: -15.000 uS max:  15.100 uS sdev:   1.100 uS
  114 secs   base min: -18.000 uS max:  19.300 uS sdev:   1.100 uS
  114 secs  servo min: -15.000 uS max:  15.100 uS sdev:   1.100 uS
  115 secs   base min: -18.000 uS max:  19.300 uS sdev:   1.100 uS
  115 secs  servo min: -15.000 uS max:  15.100 uS sdev:   1.100 uS
  117 secs   base min: -18.000 uS max:  19.300 uS sdev:   1.100 uS
  117 secs  servo min: -15.000 uS max:  15.100 uS sdev:   1.100 uS
  118 secs   base min: -18.000 uS max:  19.300 uS sdev:   1.100 uS
  118 secs  servo min: -15.000 uS max:  15.100 uS sdev:   1.100 uS
  119 secs   base min: -18.000 uS max:  19.300 uS sdev:   1.100 uS
  119 secs  servo min: -15.000 uS max:  15.100 uS sdev:   1.100 uS
  121 secs   base min: -18.000 uS max:  19.300 uS sdev:   1.100 uS
  121 secs  servo min: -15.000 uS max:  15.100 uS sdev:   1.100 uS
  122 secs   base min: -18.000 uS max:  19.300 uS sdev:   1.100 uS
  122 secs  servo min: -15.900 uS max:  17.000 uS sdev:   1.100 uS
  123 secs   base min: -18.000 uS max:  19.300 uS sdev:   1.100 uS
  123 secs  servo min: -15.900 uS max:  17.000 uS sdev:   1.100 uS
  125 secs   base min: -18.000 uS max:  19.300 uS sdev:   1.100 uS
  125 secs  servo min: -15.900 uS max:  17.000 uS sdev:   1.100 uS
  126 secs   base min: -18.000 uS max:  19.300 uS sdev:   1.100 uS
  126 secs  servo min: -15.900 uS max:  17.000 uS sdev:   1.100 uS
  128 secs   base min: -18.000 uS max:  19.300 uS sdev:   1.100 uS
  128 secs  servo min: -15.900 uS max:  17.000 uS sdev:   1.100 uS
  129 secs   base min: -18.000 uS max:  19.300 uS sdev:   1.100 uS
  129 secs  servo min: -15.900 uS max:  17.000 uS sdev:   1.100 uS
Last edit: 04 Dec 2020 14:50 by Clive S.
  • tommylight's Avatar Topic Author
  • Moderator
  • Moderator
04 Dec 2020 15:40 #191037 by tommylight
That should do nicely for parallel port, if there are no excursions during longer periods of use.
The following user(s) said Thank You: seuchato, Clive S
04 Dec 2020 16:04 #191039 by Clive S
That ran for 2 hours
  • Moderator
  • Moderator
04 Dec 2020 16:50 #191043 by tommylight
Nice, but still there are PC's that will under certain circumstances have excursions, so set the base period to 40000 and use LinuxCNC for several hours. If no warnings = nice :)
If warnings, try 50000.
  • macsddau@linuxcnc
  • macsddau@linuxcnc's Avatar
  • Premium Member
  • Premium Member
05 Dec 2020 23:46 #191184 by macsddau@linuxcnc
my contrib to hardware testing.
LinuxCNC pc tests, version 20200930, started 06.12.2020 00:27:37
General info:
ASRock,  To Be Filled By O.E.M.
Bios version P1.90, dated 05/21/2018
Chipset: Harddisk is non-rotational, ie. SSD
The amount of swap currently used is 0
CPU related data:
model name	: Intel(R) Celeron(R) CPU J3355 @ 2.00GHz
cpu cores	: 2
stepping	: 9
cache size	: 1024 KB
RAM related data:
Maximum Capacity: 16 GB
Maximum Voltage: 1.5 V
Maximum Voltage: Unknown
Size: No Module Installed
GPU related data:
configuration: driver=i915 latency=0
Parallel port related data:
number of parallel ports is 1
parport0: PC-style at 0x378, irq 5 [PCSPP]
Os and desktop related data:
PRETTY_NAME="Debian GNU/Linux 10 (buster)"
Should the info below not match with your machine,
kindly post the output of pstree here, including a brief
desciption of your desktop environment, window manager and
display manager. Tia
https://forum.linuxcnc.org/18-computer/39370-script-for-automated-testing-of-computer-latency
Desktop environment : xfce4
Windowmanager       : Xfwm4
Displaymanager      : lightdm
Kernel related data:
Kernel 4.19.0-13-rt-amd64
GRUB_CMDLINE_LINUX_DEFAULT="quiet isolcpus=1"
Cpu idle driver: intel_idle
Kernel modules data:
Check if pcspkr is loaded: Yes, may cause bigger latency.
  can be eliminated using:
  sudo echo "install pcspkr /bin/true" >/etc/modprobe.d/pcspkr.conf
Check if snd modules are loaded: No, which is good!
Keyboard & Mouse related data:
Number of mice: 1
Mouse 0 : Genius       NetScroll+Mini Traveler
Mice  attached to USB:
KYE Systems Corp. (Mouse Systems) Pocket Mouse LE
Keyboards attached to USB:
Logitech, Inc. Keyboard K120
LinuxCNC related data:
LinuxCNC version is: 2.8.1.1.g5d082d148
Preparing for latency test:
Started glxgears No. 1, 2, 3, 4, 5
Started firefox with 'https://vimeo.com/150574260', WID 33554718
Command for latency test is:
su cnc -c  "latency-histogram --bbinsize 1000 --base 25000 --sbinsize 1000 --nox 2>&1 | tee -a 1607210855.lat &"
Latency testing loop started dimanche 6 décembre 2020, 00:27:53 (UTC+0100),
should end after dimanche 6 décembre 2020, 02:27:53 (UTC+0100)
Useless to proceed, read the relevant part in 1607210855.lat
>>>Unexpected realtime delay on task 0 with period 25000<<<
Swap useage: prerun: 0, running: 0
CPU core temperatures:
Core 0: Tmin: 35.0°C, Tmax: 45.0°C, (high = +105.0°C, crit = +105.0°C)
Core 2: Tmin: 32.0°C, Tmax: 43.0°C, (high = +105.0°C, crit = +105.0°C)
last latency data is as follows:.
  532 secs   base min: -19.500 uS max:  21.400 uS sdev:   0.200 uS
  532 secs  servo min: -16.900 uS max:  17.000 uS sdev:   0.200 uS
Try to use as describe :
Result :
bash: /etc/modprobe.d/pcspkr.conf: Permission non accordée
(sorry in French)
Time to create page: 0.464 seconds
