- Hardware & Machines
- Computers and Hardware
- Results of latency test, list of computers tested for use with LinuxCNC
- Thank you received: 7472
17 Nov 2020 07:12 #189577
Replied by tommylight on topic Results of latency test, list of computers tested for use with LinuxCNC
- seuchato
- Thank you received: 126
17 Nov 2020 20:58 #189623
by seuchato
Replied by seuchato on topic Results of latency test, list of computers tested for use with LinuxCNC
my1987toyota
Yep, sure for servo and even for parallel stuff. I suggest, you run a full test, once the new script with Load and AMD Temp is finished. If, kindly add it to the very same post to keep related stuff together.
greez chris
greez chris
- rootboy
- Thank you received: 25
26 Nov 2020 19:27 - 26 Nov 2020 19:29 #190354
by rootboy
Replied by rootboy on topic Results of latency test, list of computers tested for use with LinuxCNC
I just set up a Dell Optiplex 7010 USFF Intel i5-3470S 2.90GHz 8GB DDR3 from eBay. Setup with Mint 20 using tommylight's instructions. The Mint/LinuxCNC install went flawlessly.
Doing a manual latency test I got:
Servo thread 8501 ns
Base thread ~11K ns
With plenty of abuse (Gimp, Blender, Firefox, glxgears x 5, package manager, LibreOffice Writer, LibreOffice Math, etc)
Currently it's 7630 and 12405. I think that I'm good.
Using the script, it ran but left out a few minor details (the latency results)
And then it finished without divulging the results...
In my .lat file I got mostly just temperatures, but also what looks to be a load failure:
(I trimmed down to just a snippet)
Base thread ~11K ns
LinuxCNC pc tests, version 20200930, started 26.11.2020 10:29:59
General info:
Dell Inc., OptiPlex 7010
Bios version A23, dated 08/09/2016
Chipset: Intel Corporation 7 Series/C216
Harddisk is rotational
The amount of swap currently used is 648
CPU related data:
model name : Intel(R) Core(TM) i5-3470S CPU @ 2.90GHz
cpu cores : 4
stepping : 9
cache size : 6144 KB
RAM related data:
Maximum Capacity: 16 GB
GPU related data:
product: Xeon E3-1200 v2/3rd Gen Core processor Graphics Controller
configuration: driver=i915 latency=0
Parallel port related data:
number of parallel ports is 0
Os and desktop related data:
PRETTY_NAME="Linux Mint 20"
Should the info below not match with your machine,
kindly post the output of pstree here, including a brief
desciption of your desktop environment, window manager and
display manager. Tia
https://forum.linuxcnc.org/18-computer/39370-script-for-automated-testing-of-computer-latency
Desktop environment : gnome
Windowmanager : Metacity (Marco)
Displaymanager : lightdm
Kernel related data:
Kernel 4.9.0-13-rt-amd64
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash"
Cpu idle driver: intel_idle
Kernel modules data:
Check if pcspkr is loaded: No, which is good!
Check if snd modules are loaded: Yes, may cause bigger latency.
can probably be disabled in bios, alternatively, you can run
"./block-snd-modules"
which has just now been created for your convenience.
Keyboard & Mouse related data:
Number of mice: 1
Mouse 0 : Logitech Wireless Mouse
Mice attached to USB:
Keyboards attached to USB:
Logitech, Inc. Keyboard K120
LinuxCNC related data:
LinuxCNC version is: 2.8.0.124.g4501e6d67
Preparing for latency test:
Started glxgears No. 1, 2, 3, 4, 5
Started firefox with 'https://vimeo.com/150574260', WID 69206211
Command for latency test is:
su johwaa -c "latency-histogram --nobase --sbinsize 1000 --nox 2>&1 | tee -a 1606408155.lat &"
Latency testing loop started Thu 26 Nov 2020 10:30:14 AM CST,
should end after Thu 26 Nov 2020 12:30:14 PM CST
Swap useage: prerun: 648, running: 772
CPU core temperatures:
Core 0: Tmin: 71.0°C, Tmax: 76.0°C, (high = +93.0°C, crit = +103.0°C)
Core 1: Tmin: 70.0°C, Tmax: 74.0°C, (high = +93.0°C, crit = +103.0°C)
Core 2: Tmin: 70.0°C, Tmax: 75.0°C, (high = +93.0°C, crit = +103.0°C)
Core 3: Tmin: 69.0°C, Tmax: 73.0°C, (high = +93.0°C, crit = +103.0°C)
last latency data is as follows:.And then it finished without divulging the results...
Core 0: +73.0°C (high = +93.0°C, crit = +103.0°C)
Core 1: +73.0°C (high = +93.0°C, crit = +103.0°C)
Core 2: +73.0°C (high = +93.0°C, crit = +103.0°C)
Core 3: +70.0°C (high = +93.0°C, crit = +103.0°C)
invalid command name "wm"
while executing
"wm withdraw ."
(procedure "load_packages" line 4)
invoked from within
"load_packages"
invoked from within
"if ![info exists ::LH(start)] {
set_defaults
config
progress "Loading packages"
load_packages
signal trap SIGINT finish
progress "Making g..."
(file "/usr/bin/latency-histogram" line 840)(I trimmed down to just a snippet)
Last edit: 26 Nov 2020 19:29 by rootboy.
26 Nov 2020 19:34 #190357
Looking good on the latency, but i am baffled by the processor temperature, is the PC located in an oven? 73 degrees C seems to much for a PC that is doing light work.
- Bari
- Thank you received: 234
26 Nov 2020 20:36 #190366
by Bari
Replied by Bari on topic Results of latency test, list of computers tested for use with LinuxCNC
New fixed RTAI is available, thread is here: forum.linuxcnc.org/18-computer/40728-rta...fixed-testers-needed
- rootboy
27 Nov 2020 02:04 #190390
by rootboy
It's a USFF box, and yeah, it's pretty toasty. It's pretty clean on the inside, no appreciable gunk on the fans.
I initially put it down as small box = big heat, but I took a look in the BIOS to see what I could do with the fans on this thing (I just got it yesterday). It turns out that I could run them flat out if I wanted to. Works for me.
Now the idle temps are:
26C, 20C, 24C, and 29C with the PC as cool as a cucumber. Thanks for pointing it out!
Just for grins I'll run the script again and see how hot it gets.
- rootboy
27 Nov 2020 05:04 #190397
by rootboy
Here's the second run with the fan blasting away.
Cutting to the chase, this appears to be the important parts:
Core 0: Tmin: 34.0°C, Tmax: 53.0°C, (high = +93.0°C, crit = +103.0°C)
Core 1: Tmin: 27.0°C, Tmax: 50.0°C, (high = +93.0°C, crit = +103.0°C)
Core 2: Tmin: 31.0°C, Tmax: 51.0°C, (high = +93.0°C, crit = +103.0°C)
Core 3: Tmin: 31.0°C, Tmax: 52.0°C, (high = +93.0°C, crit = +103.0°C)
7202 secs servo min: -41.300 uS max: 41.500 uS sdev: 3.000 uS
7203 secs servo min: -41.300 uS max: 41.500 uS sdev: 3.000 uS
The following user(s) said Thank You: seuchato, tommylight
27 Nov 2020 09:49 #190417
Much better.
28 Nov 2020 23:17 #190567
New PC:
-MB Gigabyte Aorus Elite X570
-AMD Ryzen 5 3500X
-16GB (4X4GB)
-256GB NVME
-AMD RX480
-Noctua NH-D15
-Mesa 6i25
-Mint 20
-4.9.0-13-rt
-AMD Ryzen 5 3500X
-16GB (4X4GB)
-256GB NVME
-AMD RX480
-Noctua NH-D15
-Mesa 6i25
-Mint 20
-4.9.0-13-rt
LinuxCNC pc tests, version 20200930, started 29.11.2020 00:04:11
General info:
Gigabyte Technology Co., Ltd., X570 AORUS ELITE
Bios version F11, dated 12/06/2019
Chipset: Harddisk is non-rotational, ie. SSD
The amount of swap currently used is 0
CPU related data:
model name : AMD Ryzen 5 3500X 6-Core Processor
cpu cores : 6
stepping : 0
cache size : 512 KB
RAM related data:
Maximum Capacity: 128 GB
Maximum Voltage: 1.2 V
Non-Volatile Size: None
Volatile Size: 4 GB
Cache Size: None
Logical Size: None
Volatile Size: 4 GB
Cache Size: None
Logical Size: None
Volatile Size: 4 GB
Cache Size: None
Logical Size: None
Volatile Size: 4 GB
Cache Size: None
Logical Size: None
GPU related data:
product: Ellesmere [Radeon RX 470/480/570/570X/580/580X/590]
configuration: driver=amdgpu latency=0
Cpu idle driver: acpi_idle
Check if pcspkr is loaded: [0;32mNo, which is good![0m
Check if snd modules are loaded: [0;31mYes, may cause bigger latency.[0m
Number of mice: 1
Mouse 0 : Razer Razer DeathAdder
Razer USA, Ltd DeathAdder Mouse
Dell Computer Corp. Multimedia Pro Keyboard
Dell Computer Corp. Multimedia Pro Keyboard Hub
LinuxCNC version is: 2.9.0~pre0.3030.g742c3e294
Started firefox with 'https://vimeo.com/150574260', WID 60819820
su cnc -c "latency-histogram --nobase --sbinsize 1000 --nox 2>&1 | tee -a 1606604595.lat &"
Latency testing loop started Sun 29 Nov 2020 12:04:24 AM CET,
should end after Sun 29 Nov 2020 12:06:24 AM CET
Swap useage: prerun: 0, running: 0
124 secs servo min: -17.600 uS max: 15.900 uS sdev: 1.600 uS
125 secs servo min: -17.600 uS max: 15.900 uS sdev: 1.600 uSPlease Log in or Create an account to join the conversation.
- seuchato
01 Dec 2020 16:08 #190776
by seuchato
rootboy
I just went through a rough patch in my life. I will look into the troubles with the you report . Regarding temperatures: I'd renew the cooling paste in between CPU and cooler.
Greez
chris
Greez
chris
Time to create page: 0.168 seconds
