Results of latency test, list of computers tested for use with LinuxCNC
31 Oct 2020 22:36 - 31 Oct 2020 22:37 #187975 by my1987toyota
Hahahahaha I just suggested that in the original script thread.
If you are using my install ISO and update the kernel the default kernel will be the one that has just been installed.
Thanks BeagleBrainz I am burning the ISO now and getting ready to install . I will probably do a test tomorrow morning ( my time )
Last edit: 31 Oct 2020 22:37 by my1987toyota.
31 Oct 2020 22:41 #187976 by seuchato
my1987toyota:
Could you kindly run
sensors
on the AMD X2 250 based computer and post the result this thread ?
TIA
chris
31 Oct 2020 22:49 #187977 by my1987toyota
um . unfortunately I can't, I am currently loading a different ISO on that computer I will test it when the new ISO finishes loading
  • BeagleBrainz
  • BeagleBrainz's Avatar
  • Visitor
  • Visitor
31 Oct 2020 23:31 #187981 by BeagleBrainz
The thing to do, is when you update via the update manager, is deselect any kernels that show up.
In fact if you right click on the kernel packages in the update manager you can tell the update manager to ignore the updates.
In actual fact there really isn't a need to apply any updates if you are just testing. The system will run just fine.
Unless of course you intend to induce a stack over flow and execute "some arbitrary code" and give your self root permission. Or you're going to visit some dodgy websites.
31 Oct 2020 23:35 #187982 by seuchato
Should get the same results, if you do it after the upload. Important is the same machine. I do not have access to any AMD X2 based machine. This could help determine why there is no temperature data. Be warned: I might ask more :-)
greez
chris
The following user(s) said Thank You: my1987toyota
01 Nov 2020 07:35 #188008 by my1987toyota
linux mint19.3 xfce Lcnc 2.8 rt-preempt
Lenovo Idea Center
LinuxCNC pc tests, version 20200930, started 01.11.2020 08:03:25
General info:
LENOVO,  H215
Bios version D2KT25BUS, dated 08/18/2010
Chipset: Harddisk is non-rotational, ie. SSD
The amount of swap currently used is 2556
CPU related data:
model name	: AMD Athlon(tm) II X2 250 Processor
cpu cores	: 2
stepping	: 3
cache size	: 1024 KB
RAM related data:
Maximum Capacity: 8 GB
Size: No Module Installed
GPU related data:
product: RS780L [Radeon 3000]
configuration: driver=radeon latency=0
Parallel port related data:
number of parallel ports is 0
Os and desktop related data:
PRETTY_NAME="Linux Mint 19.3"
Should the info below not match with your machine,
kindly post the output of pstree here, including a brief
desciption of your desktop environment, window manager and
display manager. Tia
https://forum.linuxcnc.org/18-computer/39370-script-for-automated-testing-of-computer-latency
Desktop environment : lightdm
Windowmanager       : Xfwm4
Displaymanager      : lightdm
Kernel related data:
Kernel 4.19.106-rt46-lcnc
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash"
Cpu idle driver: none
Kernel modules data:
Check if pcspkr is loaded: [0;32mNo, which is good![0m
Check if snd modules are loaded: [0;31mYes, may cause bigger latency.[0m
  can probably be disabled in bios, alternatively, you can run
   "./block-snd-modules"
   which has just now been created for your convenience.
Keyboard & Mouse related data:
Number of mice: 1
Mouse 0 : PixArt USB Optical Mouse
Mice  attached to USB:
Keyboards attached to USB:
LinuxCNC related data:
LinuxCNC version is: 2.8.0.96.g589db060d
Preparing for latency test:
Started glxgears No. 1, 2, 3, 4, 5
Started firefox with 'https://vimeo.com/150574260', WID 60817649
Command for latency test is:
su cnc001 -c  "latency-histogram --nobase --base 25000 --sbinsize 1000 --nox 2>&1 | tee -a 1604235778.lat &"
Latency testing loop started Sun Nov  1 08:03:40 EST 2020,
should end after Sun Nov  1 08:08:40 EST 2020
Swap useage: prerun: 2556, running: 2600
CPU core temperatures:
Note: Using POSIX realtime
    1 secs  servo min: -80.500 uS max:  88.700 uS sdev:   9.900 uS
    1 secs  servo min: -80.500 uS max:  88.700 uS sdev:   8.700 uS
    2 secs  servo min:-105.000 uS max: 101.200 uS sdev:   9.300 uS
    3 secs  servo min:-105.000 uS max: 101.200 uS sdev:   9.300 uS
    3 secs  servo min:-105.000 uS max: 108.300 uS sdev:   9.600 uS
    4 secs  servo min:-105.000 uS max: 108.300 uS sdev:  10.400 uS
    5 secs  servo min:-105.000 uS max: 108.300 uS sdev:   9.900 uS
    6 secs  servo min:-105.000 uS max: 108.300 uS sdev:   9.800 uS
    6 secs  servo min:-109.600 uS max: 108.300 uS sdev:   9.700 uS
    7 secs  servo min:-109.600 uS max: 108.300 uS sdev:   9.800 uS
    8 secs  servo min:-109.600 uS max: 108.300 uS sdev:   9.900 uS
    9 secs  servo min:-109.600 uS max: 108.300 uS sdev:  10.100 uS
    9 secs  servo min:-125.500 uS max: 120.700 uS sdev:  10.100 uS
   10 secs  servo min:-125.500 uS max: 120.700 uS sdev:  10.100 uS
   11 secs  servo min:-125.500 uS max: 120.700 uS sdev:  10.200 uS
   12 secs  servo min:-125.500 uS max: 120.700 uS sdev:  10.300 uS
   12 secs  servo min:-125.500 uS max: 120.700 uS sdev:  10.400 uS
   13 secs  servo min:-125.500 uS max: 120.700 uS sdev:  10.300 uS
   14 secs  servo min:-125.500 uS max: 149.100 uS sdev:  10.400 uS
   15 secs  servo min:-125.500 uS max: 149.100 uS sdev:  10.400 uS
   16 secs  servo min:-135.800 uS max: 149.100 uS sdev:  10.400 uS
   16 secs  servo min:-135.800 uS max: 149.100 uS sdev:  10.500 uS
   17 secs  servo min:-135.800 uS max: 149.100 uS sdev:  10.500 uS
   18 secs  servo min:-135.800 uS max: 149.100 uS sdev:  10.600 uS
   19 secs  servo min:-141.800 uS max: 149.100 uS sdev:  10.600 uS
   20 secs  servo min:-141.800 uS max: 149.100 uS sdev:  10.600 uS
   21 secs  servo min:-141.800 uS max: 149.100 uS sdev:  10.600 uS
   22 secs  servo min:-141.800 uS max: 149.100 uS sdev:  10.600 uS
   23 secs  servo min:-141.800 uS max: 149.100 uS sdev:  10.700 uS
   24 secs  servo min:-141.800 uS max: 149.100 uS sdev:  10.700 uS
   25 secs  servo min:-213.600 uS max: 202.800 uS sdev:  10.700 uS
   26 secs  servo min:-213.600 uS max: 202.800 uS sdev:  10.700 uS
   27 secs  servo min:-213.600 uS max: 202.800 uS sdev:  10.800 uS
   28 secs  servo min:-213.600 uS max: 202.800 uS sdev:  10.700 uS
   29 secs  servo min:-213.600 uS max: 202.800 uS sdev:  10.700 uS
   30 secs  servo min:-213.600 uS max: 202.800 uS sdev:  10.700 uS
   30 secs  servo min:-213.600 uS max: 202.800 uS sdev:  10.600 uS
   31 secs  servo min:-213.600 uS max: 202.800 uS sdev:  10.600 uS
   32 secs  servo min:-213.600 uS max: 202.800 uS sdev:  10.600 uS
   33 secs  servo min:-213.600 uS max: 202.800 uS sdev:  10.600 uS
   34 secs  servo min:-213.600 uS max: 202.800 uS sdev:  10.600 uS
   35 secs  servo min:-213.600 uS max: 202.800 uS sdev:  10.600 uS
   36 secs  servo min:-213.600 uS max: 202.800 uS sdev:  10.500 uS
   37 secs  servo min:-213.600 uS max: 202.800 uS sdev:  10.500 uS
   38 secs  servo min:-213.600 uS max: 202.800 uS sdev:  10.500 uS
   39 secs  servo min:-213.600 uS max: 202.800 uS sdev:  10.500 uS
   40 secs  servo min:-213.600 uS max: 202.800 uS sdev:  10.500 uS
   41 secs  servo min:-213.600 uS max: 202.800 uS sdev:  10.600 uS
   42 secs  servo min:-213.600 uS max: 202.800 uS sdev:  10.600 uS
   43 secs  servo min:-213.600 uS max: 202.800 uS sdev:  10.700 uS
   44 secs  servo min:-213.600 uS max: 202.800 uS sdev:  10.700 uS
   44 secs  servo min:-213.600 uS max: 202.800 uS sdev:  10.800 uS
   45 secs  servo min:-213.600 uS max: 202.800 uS sdev:  10.800 uS
   46 secs  servo min:-250.900 uS max: 202.800 uS sdev:  10.800 uS
   47 secs  servo min:-250.900 uS max: 202.800 uS sdev:  10.800 uS
   48 secs  servo min:-250.900 uS max: 205.100 uS sdev:  10.800 uS
   49 secs  servo min:-250.900 uS max: 205.100 uS sdev:  10.800 uS
   50 secs  servo min:-250.900 uS max: 205.100 uS sdev:  10.800 uS
   51 secs  servo min:-250.900 uS max: 205.100 uS sdev:  10.800 uS
   52 secs  servo min:-250.900 uS max: 205.100 uS sdev:  10.800 uS
   53 secs  servo min:-250.900 uS max: 205.100 uS sdev:  10.700 uS
   54 secs  servo min:-250.900 uS max: 205.100 uS sdev:  10.800 uS
   55 secs  servo min:-250.900 uS max: 205.100 uS sdev:  10.800 uS
   56 secs  servo min:-250.900 uS max: 205.100 uS sdev:  10.800 uS
   57 secs  servo min:-250.900 uS max: 205.100 uS sdev:  10.800 uS
   58 secs  servo min:-250.900 uS max: 205.100 uS sdev:  10.800 uS
   59 secs  servo min:-250.900 uS max: 205.100 uS sdev:  10.800 uS
   60 secs  servo min:-250.900 uS max: 205.100 uS sdev:  10.800 uS
   61 secs  servo min:-250.900 uS max: 205.100 uS sdev:  10.800 uS
   62 secs  servo min:-250.900 uS max: 205.100 uS sdev:  10.800 uS
   63 secs  servo min:-250.900 uS max: 205.100 uS sdev:  10.800 uS
   64 secs  servo min:-250.900 uS max: 205.100 uS sdev:  10.800 uS
   65 secs  servo min:-250.900 uS max: 205.100 uS sdev:  10.900 uS
   66 secs  servo min:-250.900 uS max: 205.100 uS sdev:  10.900 uS
   67 secs  servo min:-250.900 uS max: 205.100 uS sdev:  10.900 uS
   68 secs  servo min:-250.900 uS max: 205.100 uS sdev:  10.900 uS
   68 secs  servo min:-285.700 uS max: 262.000 uS sdev:  10.900 uS
   69 secs  servo min:-285.700 uS max: 262.000 uS sdev:  11.000 uS
   70 secs  servo min:-285.700 uS max: 262.000 uS sdev:  10.900 uS
   71 secs  servo min:-285.700 uS max: 262.000 uS sdev:  10.900 uS
   72 secs  servo min:-285.700 uS max: 262.000 uS sdev:  10.900 uS
   73 secs  servo min:-285.700 uS max: 262.000 uS sdev:  10.900 uS
   74 secs  servo min:-285.700 uS max: 262.000 uS sdev:  10.900 uS
   75 secs  servo min:-285.700 uS max: 262.000 uS sdev:  10.900 uS
   76 secs  servo min:-285.700 uS max: 262.000 uS sdev:  10.900 uS
   77 secs  servo min:-285.700 uS max: 262.000 uS sdev:  10.900 uS
   78 secs  servo min:-285.700 uS max: 262.000 uS sdev:  10.800 uS
   79 secs  servo min:-285.700 uS max: 262.000 uS sdev:  10.900 uS
   80 secs  servo min:-285.700 uS max: 262.000 uS sdev:  10.900 uS
   81 secs  servo min:-285.700 uS max: 262.000 uS sdev:  10.900 uS
   82 secs  servo min:-285.700 uS max: 262.000 uS sdev:  10.900 uS
   83 secs  servo min:-285.700 uS max: 262.000 uS sdev:  10.900 uS
   84 secs  servo min:-285.700 uS max: 262.000 uS sdev:  10.900 uS
   85 secs  servo min:-285.700 uS max: 262.000 uS sdev:  11.000 uS
   86 secs  servo min:-285.700 uS max: 262.000 uS sdev:  11.000 uS
   87 secs  servo min:-285.700 uS max: 262.000 uS sdev:  11.000 uS
   88 secs  servo min:-285.700 uS max: 262.000 uS sdev:  11.000 uS
   89 secs  servo min:-285.700 uS max: 262.000 uS sdev:  11.000 uS
   90 secs  servo min:-285.700 uS max: 262.000 uS sdev:  11.000 uS
   91 secs  servo min:-285.700 uS max: 262.000 uS sdev:  11.000 uS
   92 secs  servo min:-285.700 uS max: 262.000 uS sdev:  11.000 uS
   93 secs  servo min:-285.700 uS max: 262.000 uS sdev:  11.000 uS
   94 secs  servo min:-285.700 uS max: 262.000 uS sdev:  11.000 uS
   95 secs  servo min:-285.700 uS max: 262.000 uS sdev:  11.000 uS
   96 secs  servo min:-285.700 uS max: 262.000 uS sdev:  11.000 uS
   97 secs  servo min:-285.700 uS max: 262.000 uS sdev:  11.000 uS
   98 secs  servo min:-285.700 uS max: 262.000 uS sdev:  11.000 uS
   99 secs  servo min:-285.700 uS max: 262.000 uS sdev:  11.000 uS
  100 secs  servo min:-285.700 uS max: 262.000 uS sdev:  11.000 uS
  101 secs  servo min:-285.700 uS max: 262.000 uS sdev:  11.000 uS
  102 secs  servo min:-285.700 uS max: 262.000 uS sdev:  11.000 uS
  103 secs  servo min:-285.700 uS max: 262.000 uS sdev:  11.000 uS
  104 secs  servo min:-285.700 uS max: 262.000 uS sdev:  11.000 uS
  105 secs  servo min:-285.700 uS max: 262.000 uS sdev:  11.000 uS
  106 secs  servo min:-285.700 uS max: 262.000 uS sdev:  11.100 uS
  107 secs  servo min:-285.700 uS max: 262.000 uS sdev:  11.100 uS
  108 secs  servo min:-285.700 uS max: 262.000 uS sdev:  11.100 uS
  109 secs  servo min:-285.700 uS max: 262.000 uS sdev:  11.100 uS
  110 secs  servo min:-285.700 uS max: 262.000 uS sdev:  11.100 uS
  111 secs  servo min:-285.700 uS max: 262.000 uS sdev:  11.100 uS
  112 secs  servo min:-285.700 uS max: 262.000 uS sdev:  11.100 uS
  113 secs  servo min:-285.700 uS max: 262.000 uS sdev:  11.100 uS
  114 secs  servo min:-285.700 uS max: 262.000 uS sdev:  11.100 uS
  114 secs  servo min:-285.700 uS max: 262.000 uS sdev:  11.000 uS
  115 secs  servo min:-285.700 uS max: 262.000 uS sdev:  11.000 uS
  116 secs  servo min:-285.700 uS max: 262.000 uS sdev:  11.000 uS
  117 secs  servo min:-285.700 uS max: 262.000 uS sdev:  11.000 uS
  118 secs  servo min:-285.700 uS max: 262.000 uS sdev:  11.000 uS
  118 secs  servo min:-285.700 uS max: 262.000 uS sdev:  11.100 uS
  119 secs  servo min:-285.700 uS max: 262.000 uS sdev:  11.000 uS
  120 secs  servo min:-285.700 uS max: 262.000 uS sdev:  11.000 uS
  121 secs  servo min:-285.700 uS max: 262.000 uS sdev:  11.000 uS
  122 secs  servo min:-285.700 uS max: 262.000 uS sdev:  11.000 uS
  123 secs  servo min:-285.700 uS max: 262.000 uS sdev:  11.000 uS
  124 secs  servo min:-285.700 uS max: 262.000 uS sdev:  11.100 uS
  125 secs  servo min:-285.700 uS max: 262.000 uS sdev:  11.100 uS
  126 secs  servo min:-285.700 uS max: 262.000 uS sdev:  11.100 uS
  127 secs  servo min:-285.700 uS max: 262.000 uS sdev:  11.100 uS
  128 secs  servo min:-285.700 uS max: 262.000 uS sdev:  11.100 uS
  129 secs  servo min:-285.700 uS max: 262.000 uS sdev:  11.100 uS
  130 secs  servo min:-285.700 uS max: 262.000 uS sdev:  11.000 uS
  131 secs  servo min:-285.700 uS max: 262.000 uS sdev:  11.000 uS
  132 secs  servo min:-285.700 uS max: 262.000 uS sdev:  11.000 uS
  133 secs  servo min:-285.700 uS max: 262.000 uS sdev:  11.000 uS
  134 secs  servo min:-285.700 uS max: 262.000 uS sdev:  11.000 uS
  135 secs  servo min:-285.700 uS max: 262.000 uS sdev:  11.000 uS
  136 secs  servo min:-285.700 uS max: 262.000 uS sdev:  11.000 uS
  137 secs  servo min:-285.700 uS max: 262.000 uS sdev:  11.000 uS
  138 secs  servo min:-285.700 uS max: 262.000 uS sdev:  11.000 uS
  139 secs  servo min:-285.700 uS max: 262.000 uS sdev:  11.000 uS
  140 secs  servo min:-285.700 uS max: 262.000 uS sdev:  11.000 uS
  141 secs  servo min:-285.700 uS max: 262.000 uS sdev:  11.000 uS
  142 secs  servo min:-285.700 uS max: 262.000 uS sdev:  11.000 uS
  143 secs  servo min:-285.700 uS max: 262.000 uS sdev:  11.000 uS
  144 secs  servo min:-285.700 uS max: 262.000 uS sdev:  11.000 uS
  145 secs  servo min:-285.700 uS max: 262.000 uS sdev:  11.000 uS
  146 secs  servo min:-285.700 uS max: 262.000 uS sdev:  11.000 uS
  147 secs  servo min:-285.700 uS max: 262.000 uS sdev:  11.000 uS
  148 secs  servo min:-285.700 uS max: 262.000 uS sdev:  11.000 uS
  149 secs  servo min:-285.700 uS max: 262.000 uS sdev:  11.000 uS
  150 secs  servo min:-285.700 uS max: 262.000 uS sdev:  11.000 uS
  151 secs  servo min:-285.700 uS max: 262.000 uS sdev:  11.000 uS
  152 secs  servo min:-285.700 uS max: 262.000 uS sdev:  11.000 uS
  153 secs  servo min:-285.700 uS max: 262.000 uS sdev:  11.000 uS
  154 secs  servo min:-285.700 uS max: 262.000 uS sdev:  11.000 uS
  155 secs  servo min:-285.700 uS max: 262.000 uS sdev:  11.000 uS
  156 secs  servo min:-285.700 uS max: 262.000 uS sdev:  11.000 uS
  157 secs  servo min:-285.700 uS max: 262.000 uS sdev:  11.000 uS
  158 secs  servo min:-285.700 uS max: 262.000 uS sdev:  11.000 uS
  159 secs  servo min:-285.700 uS max: 262.000 uS sdev:  11.000 uS
  160 secs  servo min:-285.700 uS max: 262.000 uS sdev:  11.000 uS
  161 secs  servo min:-285.700 uS max: 262.000 uS sdev:  11.000 uS
  162 secs  servo min:-285.700 uS max: 262.000 uS sdev:  11.000 uS
  163 secs  servo min:-285.700 uS max: 262.000 uS sdev:  11.000 uS
  164 secs  servo min:-285.700 uS max: 262.000 uS sdev:  11.000 uS
  165 secs  servo min:-285.700 uS max: 262.000 uS sdev:  11.000 uS
  166 secs  servo min:-285.700 uS max: 262.000 uS sdev:  11.000 uS
  167 secs  servo min:-285.700 uS max: 262.000 uS sdev:  11.000 uS
  168 secs  servo min:-285.700 uS max: 262.000 uS sdev:  11.000 uS
  169 secs  servo min:-285.700 uS max: 262.000 uS sdev:  11.000 uS
  170 secs  servo min:-285.700 uS max: 262.000 uS sdev:  11.000 uS
  171 secs  servo min:-285.700 uS max: 262.000 uS sdev:  11.000 uS
  172 secs  servo min:-285.700 uS max: 262.000 uS sdev:  11.000 uS
  173 secs  servo min:-285.700 uS max: 262.000 uS sdev:  11.000 uS
  174 secs  servo min:-285.700 uS max: 262.000 uS sdev:  11.000 uS
  175 secs  servo min:-285.700 uS max: 262.000 uS sdev:  11.000 uS
  176 secs  servo min:-285.700 uS max: 262.000 uS sdev:  11.000 uS
  177 secs  servo min:-285.700 uS max: 262.000 uS sdev:  11.000 uS
  178 secs  servo min:-285.700 uS max: 262.000 uS sdev:  11.000 uS
  179 secs  servo min:-285.700 uS max: 262.000 uS sdev:  11.000 uS
  180 secs  servo min:-285.700 uS max: 262.000 uS sdev:  11.000 uS
  181 secs  servo min:-285.700 uS max: 262.000 uS sdev:  11.000 uS
  182 secs  servo min:-285.700 uS max: 262.000 uS sdev:  11.000 uS
  183 secs  servo min:-302.200 uS max: 262.000 uS sdev:  11.000 uS
  184 secs  servo min:-302.200 uS max: 262.000 uS sdev:  11.000 uS
  185 secs  servo min:-302.200 uS max: 262.000 uS sdev:  11.100 uS
  186 secs  servo min:-302.200 uS max: 262.000 uS sdev:  11.100 uS
  187 secs  servo min:-302.200 uS max: 262.000 uS sdev:  11.100 uS
  188 secs  servo min:-302.200 uS max: 262.000 uS sdev:  11.100 uS
  189 secs  servo min:-302.200 uS max: 262.000 uS sdev:  11.100 uS
  190 secs  servo min:-302.200 uS max: 262.000 uS sdev:  11.100 uS
  191 secs  servo min:-302.200 uS max: 262.000 uS sdev:  11.100 uS
  191 secs  servo min:-302.200 uS max: 262.000 uS sdev:  11.000 uS
  192 secs  servo min:-302.200 uS max: 262.000 uS sdev:  11.000 uS
  193 secs  servo min:-302.200 uS max: 262.000 uS sdev:  11.000 uS
  194 secs  servo min:-302.200 uS max: 262.000 uS sdev:  11.000 uS
  195 secs  servo min:-302.200 uS max: 262.000 uS sdev:  11.000 uS
  196 secs  servo min:-302.200 uS max: 262.000 uS sdev:  11.000 uS
  197 secs  servo min:-302.200 uS max: 262.000 uS sdev:  11.000 uS
  198 secs  servo min:-302.200 uS max: 262.000 uS sdev:  11.000 uS
  199 secs  servo min:-302.200 uS max: 262.000 uS sdev:  11.000 uS
  199 secs  servo min:-302.200 uS max: 262.000 uS sdev:  11.100 uS
  200 secs  servo min:-302.200 uS max: 262.000 uS sdev:  11.100 uS
  201 secs  servo min:-302.200 uS max: 262.000 uS sdev:  11.100 uS
  202 secs  servo min:-302.200 uS max: 262.000 uS sdev:  11.100 uS
  203 secs  servo min:-302.200 uS max: 262.000 uS sdev:  11.100 uS
  204 secs  servo min:-302.200 uS max: 262.000 uS sdev:  11.100 uS
  205 secs  servo min:-302.200 uS max: 262.000 uS sdev:  11.100 uS
  206 secs  servo min:-302.200 uS max: 262.000 uS sdev:  11.100 uS
  207 secs  servo min:-302.200 uS max: 262.000 uS sdev:  11.100 uS
  208 secs  servo min:-302.200 uS max: 262.000 uS sdev:  11.100 uS
  209 secs  servo min:-302.200 uS max: 262.000 uS sdev:  11.000 uS
  210 secs  servo min:-302.200 uS max: 262.000 uS sdev:  11.000 uS
  211 secs  servo min:-302.200 uS max: 262.000 uS sdev:  11.000 uS
  212 secs  servo min:-302.200 uS max: 262.000 uS sdev:  11.000 uS
  213 secs  servo min:-302.200 uS max: 262.000 uS sdev:  11.000 uS
  214 secs  servo min:-302.200 uS max: 262.000 uS sdev:  11.000 uS
  215 secs  servo min:-302.200 uS max: 262.000 uS sdev:  11.000 uS
  216 secs  servo min:-302.200 uS max: 262.000 uS sdev:  11.000 uS
  217 secs  servo min:-302.200 uS max: 262.000 uS sdev:  11.000 uS
  218 secs  servo min:-302.200 uS max: 262.000 uS sdev:  11.000 uS
  219 secs  servo min:-302.200 uS max: 262.000 uS sdev:  11.000 uS
  220 secs  servo min:-302.200 uS max: 262.000 uS sdev:  11.000 uS
  221 secs  servo min:-302.200 uS max: 262.000 uS sdev:  11.000 uS
  222 secs  servo min:-302.200 uS max: 262.000 uS sdev:  11.000 uS
  222 secs  servo min:-345.700 uS max: 262.000 uS sdev:  11.000 uS
  223 secs  servo min:-345.700 uS max: 262.000 uS sdev:  11.000 uS
  224 secs  servo min:-345.700 uS max: 262.000 uS sdev:  11.000 uS
  225 secs  servo min:-345.700 uS max: 262.000 uS sdev:  11.000 uS
  226 secs  servo min:-345.700 uS max: 262.000 uS sdev:  11.000 uS
  227 secs  servo min:-345.700 uS max: 262.000 uS sdev:  11.000 uS
  228 secs  servo min:-345.700 uS max: 262.000 uS sdev:  11.000 uS
  229 secs  servo min:-345.700 uS max: 262.000 uS sdev:  11.000 uS
  230 secs  servo min:-345.700 uS max: 262.000 uS sdev:  11.000 uS
  231 secs  servo min:-345.700 uS max: 262.000 uS sdev:  11.000 uS
  232 secs  servo min:-345.700 uS max: 262.000 uS sdev:  11.000 uS
  233 secs  servo min:-345.700 uS max: 262.000 uS sdev:  11.000 uS
  234 secs  servo min:-345.700 uS max: 262.000 uS sdev:  11.000 uS
  235 secs  servo min:-345.700 uS max: 262.000 uS sdev:  11.000 uS
  236 secs  servo min:-345.700 uS max: 262.000 uS sdev:  11.000 uS
  237 secs  servo min:-345.700 uS max: 262.000 uS sdev:  11.000 uS
  238 secs  servo min:-345.700 uS max: 262.000 uS sdev:  11.000 uS
  239 secs  servo min:-345.700 uS max: 262.000 uS sdev:  11.000 uS
  240 secs  servo min:-345.700 uS max: 262.000 uS sdev:  11.000 uS
  241 secs  servo min:-345.700 uS max: 262.000 uS sdev:  11.000 uS
  242 secs  servo min:-345.700 uS max: 262.000 uS sdev:  11.000 uS
  243 secs  servo min:-345.700 uS max: 262.000 uS sdev:  11.000 uS
  244 secs  servo min:-345.700 uS max: 262.000 uS sdev:  11.000 uS
  245 secs  servo min:-345.700 uS max: 262.000 uS sdev:  11.000 uS
  246 secs  servo min:-345.700 uS max: 262.000 uS sdev:  11.000 uS
  247 secs  servo min:-345.700 uS max: 262.000 uS sdev:  11.000 uS
  248 secs  servo min:-345.700 uS max: 262.000 uS sdev:  11.000 uS
  249 secs  servo min:-345.700 uS max: 262.000 uS sdev:  11.000 uS
  250 secs  servo min:-345.700 uS max: 262.000 uS sdev:  11.000 uS
  251 secs  servo min:-345.700 uS max: 262.000 uS sdev:  11.000 uS
  252 secs  servo min:-345.700 uS max: 262.000 uS sdev:  11.000 uS
  253 secs  servo min:-345.700 uS max: 262.000 uS sdev:  11.000 uS
  254 secs  servo min:-345.700 uS max: 262.000 uS sdev:  11.000 uS
  255 secs  servo min:-345.700 uS max: 262.000 uS sdev:  11.000 uS
  256 secs  servo min:-345.700 uS max: 262.000 uS sdev:  11.000 uS
  257 secs  servo min:-345.700 uS max: 262.000 uS sdev:  11.000 uS
  258 secs  servo min:-345.700 uS max: 262.000 uS sdev:  11.000 uS
  259 secs  servo min:-345.700 uS max: 262.000 uS sdev:  11.000 uS
  260 secs  servo min:-345.700 uS max: 262.000 uS sdev:  11.000 uS
  261 secs  servo min:-345.700 uS max: 262.000 uS sdev:  11.000 uS
  262 secs  servo min:-345.700 uS max: 262.000 uS sdev:  11.000 uS
  263 secs  servo min:-345.700 uS max: 262.000 uS sdev:  11.000 uS
  264 secs  servo min:-345.700 uS max: 262.000 uS sdev:  11.000 uS
  265 secs  servo min:-345.700 uS max: 262.000 uS sdev:  11.000 uS
  266 secs  servo min:-345.700 uS max: 262.000 uS sdev:  11.000 uS
  267 secs  servo min:-345.700 uS max: 262.000 uS sdev:  11.000 uS
  268 secs  servo min:-345.700 uS max: 262.000 uS sdev:  11.000 uS
  269 secs  servo min:-345.700 uS max: 262.000 uS sdev:  11.000 uS
  270 secs  servo min:-345.700 uS max: 262.000 uS sdev:  11.000 uS
  271 secs  servo min:-345.700 uS max: 262.000 uS sdev:  11.000 uS
  272 secs  servo min:-345.700 uS max: 262.000 uS sdev:  11.000 uS
  273 secs  servo min:-345.700 uS max: 262.000 uS sdev:  11.000 uS
  274 secs  servo min:-345.700 uS max: 262.000 uS sdev:  11.000 uS
  275 secs  servo min:-345.700 uS max: 262.000 uS sdev:  11.000 uS
  276 secs  servo min:-345.700 uS max: 262.000 uS sdev:  11.000 uS
  277 secs  servo min:-345.700 uS max: 262.000 uS sdev:  11.000 uS
  278 secs  servo min:-345.700 uS max: 262.000 uS sdev:  11.000 uS
  279 secs  servo min:-345.700 uS max: 262.000 uS sdev:  11.000 uS
  280 secs  servo min:-345.700 uS max: 262.000 uS sdev:  11.000 uS
  281 secs  servo min:-345.700 uS max: 262.000 uS sdev:  11.000 uS
  282 secs  servo min:-345.700 uS max: 262.000 uS sdev:  11.000 uS
  283 secs  servo min:-345.700 uS max: 262.000 uS sdev:  11.000 uS
  284 secs  servo min:-345.700 uS max: 262.000 uS sdev:  11.000 uS
  285 secs  servo min:-345.700 uS max: 262.000 uS sdev:  11.000 uS
  286 secs  servo min:-345.700 uS max: 262.000 uS sdev:  11.000 uS
  287 secs  servo min:-345.700 uS max: 262.000 uS sdev:  11.000 uS
  288 secs  servo min:-345.700 uS max: 262.000 uS sdev:  11.000 uS
  289 secs  servo min:-345.700 uS max: 262.000 uS sdev:  11.000 uS
  290 secs  servo min:-345.700 uS max: 262.000 uS sdev:  11.000 uS
  291 secs  servo min:-345.700 uS max: 262.000 uS sdev:  11.000 uS
  292 secs  servo min:-345.700 uS max: 262.000 uS sdev:  11.000 uS
  293 secs  servo min:-345.700 uS max: 262.000 uS sdev:  11.000 uS
  294 secs  servo min:-345.700 uS max: 262.000 uS sdev:  11.000 uS
  295 secs  servo min:-345.700 uS max: 262.000 uS sdev:  11.000 uS
  296 secs  servo min:-345.700 uS max: 262.000 uS sdev:  11.000 uS
  297 secs  servo min:-345.700 uS max: 262.000 uS sdev:  11.000 uS
  298 secs  servo min:-345.700 uS max: 262.000 uS sdev:  11.000 uS
  299 secs  servo min:-345.700 uS max: 262.000 uS sdev:  11.000 uS
  300 secs  servo min:-345.700 uS max: 262.000 uS sdev:  11.000 uS
  301 secs  servo min:-345.700 uS max: 262.000 uS sdev:  11.000 uS
  302 secs  servo min:-345.700 uS max: 262.000 uS sdev:  11.000 uS
  303 secs  servo min:-345.700 uS max: 262.000 uS sdev:  11.000 uS
cnc001@cnc001:~$ sensors
k10temp-pci-00c3
Adapter: PCI adapter
temp1:        +32.0°C  (high = +70.0°C)
k10temp-pci-00c3
k10temp-pci-00c3
temp1:        +31.6°C  (high = +70.0°C)
k10temp-pci-00c3
k10temp-pci-00c3
temp1:        +31.9°C  (high = +70.0°C)
k10temp-pci-00c3
temp1:        +31.8°C  (high = +70.0°C)
hopefully what you were looking for seuchato
01 Nov 2020 10:04 - 01 Nov 2020 10:07 #188016 by my1987toyota
Same Lenovo think center with Debian Buster and Lcnc 2.8 rt-preempt
LinuxCNC pc tests, version 20200930, started 01.11.2020 10:31:47
General info:
LENOVO,  H215
The amount of swap currently used is 0
CPU related data:
cpu cores	: 2
stepping	: 3
RAM related data:
GPU related data:
PRETTY_NAME="Debian GNU/Linux 10 (buster)"
Desktop environment : xfce4
Kernel 4.19.0-11-rt-amd64
GRUB_CMDLINE_LINUX_DEFAULT="quiet"
Check if pcspkr is loaded: [0;31mYes, may cause bigger latency.[0m
  can be eliminated using:
  sudo echo "install pcspkr /bin/true" >/etc/modprobe.d/pcspkr.conf
Number of mice: 1
Started firefox with 'https://vimeo.com/150574260', WID 35651731
su cnc001 -c  "latency-histogram --nobase --base 100000 --sbinsize 1000 --nox 2>&1 | tee -a 1604244661.lat &"
Latency testing loop started Sun 01 Nov 2020 10:32:02 AM EST,
should end after Sun 01 Nov 2020 10:37:02 AM EST
Swap useage: prerun: 0, running: 0
AMD Athlon currently doesn't like displaying it's core temp. That said here are the sensors reading's during the
5 minute test
cnc001@debian:~$ sensors
k10temp-pci-00c3
temp1:        +33.0°C  (high = +70.0°C)
k10temp-pci-00c3
temp1:        +33.2°C  (high = +70.0°C)
bash: sensor: command not found
k10temp-pci-00c3
temp1:        +33.5°C  (high = +70.0°C)
k10temp-pci-00c3
temp1:        +33.8°C  (high = +70.0°C)
k10temp-pci-00c3
temp1:        +33.4°C  (high = +70.0°C)
k10temp-pci-00c3
k10temp-pci-00c3
k10temp-pci-00c3
cnc001@debian:~$
And beacuse the script won't complete it's task without a temp reading
    0 secs  servo min: -73.500 uS max:  72.300 uS sdev:  10.300 uS
    1 secs  servo min: -82.500 uS max:  80.200 uS sdev:  10.800 uS
    2 secs  servo min: -82.500 uS max:  80.200 uS sdev:  10.800 uS
    3 secs  servo min: -85.600 uS max:  81.400 uS sdev:  10.700 uS
    3 secs  servo min: -85.600 uS max:  84.800 uS sdev:  10.900 uS
    4 secs  servo min: -85.600 uS max:  84.800 uS sdev:  10.800 uS
    5 secs  servo min: -86.900 uS max:  84.800 uS sdev:  10.700 uS
    6 secs  servo min: -86.900 uS max:  84.800 uS sdev:  10.600 uS
    7 secs  servo min:-107.800 uS max: 101.700 uS sdev:  10.700 uS
    8 secs  servo min:-107.800 uS max: 101.700 uS sdev:  10.700 uS
    9 secs  servo min:-107.800 uS max: 101.700 uS sdev:  10.700 uS
   10 secs  servo min:-107.800 uS max: 101.700 uS sdev:  10.800 uS
   11 secs  servo min:-107.800 uS max: 101.700 uS sdev:  10.700 uS
   12 secs  servo min:-107.800 uS max: 101.700 uS sdev:  10.800 uS
   13 secs  servo min:-107.800 uS max: 101.700 uS sdev:  11.000 uS
   14 secs  servo min:-107.800 uS max: 101.700 uS sdev:  11.000 uS
   15 secs  servo min:-107.800 uS max: 101.700 uS sdev:  11.100 uS
   16 secs  servo min:-107.800 uS max: 101.700 uS sdev:  11.100 uS
   17 secs  servo min:-107.800 uS max: 101.700 uS sdev:  11.100 uS
   18 secs  servo min:-116.600 uS max: 116.200 uS sdev:  11.300 uS
   18 secs  servo min:-116.600 uS max: 140.400 uS sdev:  11.600 uS
   19 secs  servo min:-116.600 uS max: 140.400 uS sdev:  11.800 uS
   20 secs  servo min:-118.000 uS max: 140.400 uS sdev:  12.000 uS
   21 secs  servo min:-118.000 uS max: 140.400 uS sdev:  12.100 uS
   22 secs  servo min:-118.000 uS max: 140.400 uS sdev:  12.300 uS
   23 secs  servo min:-118.400 uS max: 140.400 uS sdev:  12.500 uS
   24 secs  servo min:-118.400 uS max: 140.400 uS sdev:  12.400 uS
   25 secs  servo min:-118.400 uS max: 140.400 uS sdev:  12.600 uS
   26 secs  servo min:-121.400 uS max: 140.400 uS sdev:  12.700 uS
   27 secs  servo min:-121.400 uS max: 140.400 uS sdev:  12.800 uS
   28 secs  servo min:-121.400 uS max: 140.400 uS sdev:  12.800 uS
   29 secs  servo min:-121.400 uS max: 140.400 uS sdev:  12.800 uS
   30 secs  servo min:-121.400 uS max: 140.400 uS sdev:  12.800 uS
   31 secs  servo min:-121.400 uS max: 140.400 uS sdev:  12.800 uS
   31 secs  servo min:-121.400 uS max: 140.400 uS sdev:  12.700 uS
   32 secs  servo min:-121.400 uS max: 140.400 uS sdev:  12.700 uS
   33 secs  servo min:-121.400 uS max: 140.400 uS sdev:  12.600 uS
   34 secs  servo min:-121.400 uS max: 140.400 uS sdev:  12.600 uS
   35 secs  servo min:-121.400 uS max: 140.400 uS sdev:  12.700 uS
   36 secs  servo min:-121.400 uS max: 140.400 uS sdev:  12.600 uS
   37 secs  servo min:-121.400 uS max: 140.400 uS sdev:  12.600 uS
   38 secs  servo min:-121.400 uS max: 140.400 uS sdev:  12.700 uS
   39 secs  servo min:-121.400 uS max: 140.400 uS sdev:  12.700 uS
   40 secs  servo min:-125.400 uS max: 140.400 uS sdev:  12.700 uS
   41 secs  servo min:-125.400 uS max: 140.400 uS sdev:  12.800 uS
   41 secs  servo min:-132.800 uS max: 140.400 uS sdev:  12.900 uS
   42 secs  servo min:-132.800 uS max: 140.400 uS sdev:  12.900 uS
   43 secs  servo min:-132.800 uS max: 140.400 uS sdev:  12.900 uS
   44 secs  servo min:-132.800 uS max: 140.400 uS sdev:  13.000 uS
   45 secs  servo min:-132.800 uS max: 140.400 uS sdev:  13.000 uS
   46 secs  servo min:-132.800 uS max: 140.400 uS sdev:  13.100 uS
   47 secs  servo min:-132.800 uS max: 140.400 uS sdev:  13.200 uS
   48 secs  servo min:-132.800 uS max: 140.400 uS sdev:  13.200 uS
   49 secs  servo min:-132.800 uS max: 140.400 uS sdev:  13.200 uS
   50 secs  servo min:-132.800 uS max: 140.400 uS sdev:  13.200 uS
   51 secs  servo min:-132.800 uS max: 140.400 uS sdev:  13.200 uS
   52 secs  servo min:-132.800 uS max: 140.400 uS sdev:  13.100 uS
   53 secs  servo min:-132.800 uS max: 140.400 uS sdev:  13.100 uS
   54 secs  servo min:-132.800 uS max: 140.400 uS sdev:  13.100 uS
   55 secs  servo min:-132.800 uS max: 140.400 uS sdev:  13.100 uS
   56 secs  servo min:-132.800 uS max: 140.400 uS sdev:  13.100 uS
   57 secs  servo min:-132.800 uS max: 140.400 uS sdev:  13.100 uS
   58 secs  servo min:-132.800 uS max: 140.400 uS sdev:  13.100 uS
   58 secs  servo min:-132.800 uS max: 140.400 uS sdev:  13.000 uS
   59 secs  servo min:-132.800 uS max: 140.400 uS sdev:  13.000 uS
   60 secs  servo min:-132.800 uS max: 140.400 uS sdev:  13.100 uS
   61 secs  servo min:-132.800 uS max: 140.400 uS sdev:  13.100 uS
   62 secs  servo min:-132.800 uS max: 140.400 uS sdev:  13.100 uS
   63 secs  servo min:-132.800 uS max: 140.400 uS sdev:  13.200 uS
   64 secs  servo min:-132.800 uS max: 140.400 uS sdev:  13.200 uS
   65 secs  servo min:-132.800 uS max: 140.400 uS sdev:  13.300 uS
   66 secs  servo min:-132.800 uS max: 140.400 uS sdev:  13.300 uS
   67 secs  servo min:-132.800 uS max: 140.400 uS sdev:  13.300 uS
   68 secs  servo min:-132.800 uS max: 140.400 uS sdev:  13.300 uS
   68 secs  servo min:-132.800 uS max: 140.400 uS sdev:  13.400 uS
   69 secs  servo min:-132.800 uS max: 140.400 uS sdev:  13.400 uS
   70 secs  servo min:-132.800 uS max: 140.400 uS sdev:  13.300 uS
   71 secs  servo min:-132.800 uS max: 140.400 uS sdev:  13.300 uS
   72 secs  servo min:-132.800 uS max: 140.400 uS sdev:  13.300 uS
   73 secs  servo min:-132.800 uS max: 140.400 uS sdev:  13.200 uS
   74 secs  servo min:-132.800 uS max: 140.400 uS sdev:  13.200 uS
   75 secs  servo min:-132.800 uS max: 140.400 uS sdev:  13.200 uS
   76 secs  servo min:-132.800 uS max: 140.400 uS sdev:  13.200 uS
   77 secs  servo min:-132.800 uS max: 140.400 uS sdev:  13.200 uS
   78 secs  servo min:-132.800 uS max: 140.400 uS sdev:  13.100 uS
   79 secs  servo min:-132.800 uS max: 140.400 uS sdev:  13.100 uS
   80 secs  servo min:-132.800 uS max: 140.400 uS sdev:  13.100 uS
   81 secs  servo min:-132.800 uS max: 140.400 uS sdev:  13.100 uS
   82 secs  servo min:-132.800 uS max: 140.400 uS sdev:  13.100 uS
   83 secs  servo min:-132.800 uS max: 140.400 uS sdev:  13.200 uS
   84 secs  servo min:-132.800 uS max: 140.400 uS sdev:  13.200 uS
   85 secs  servo min:-132.800 uS max: 140.400 uS sdev:  13.200 uS
   86 secs  servo min:-132.800 uS max: 140.400 uS sdev:  13.300 uS
   87 secs  servo min:-132.800 uS max: 140.400 uS sdev:  13.300 uS
   88 secs  servo min:-132.800 uS max: 140.400 uS sdev:  13.300 uS
   89 secs  servo min:-132.800 uS max: 140.400 uS sdev:  13.300 uS
   90 secs  servo min:-132.800 uS max: 140.400 uS sdev:  13.400 uS
   91 secs  servo min:-132.800 uS max: 140.400 uS sdev:  13.400 uS
   92 secs  servo min:-132.800 uS max: 140.400 uS sdev:  13.400 uS
   93 secs  servo min:-132.800 uS max: 140.400 uS sdev:  13.400 uS
   93 secs  servo min:-132.800 uS max: 140.400 uS sdev:  13.300 uS
   94 secs  servo min:-132.800 uS max: 140.400 uS sdev:  13.300 uS
   95 secs  servo min:-132.800 uS max: 140.400 uS sdev:  13.300 uS
   96 secs  servo min:-132.800 uS max: 140.400 uS sdev:  13.300 uS
   97 secs  servo min:-132.800 uS max: 140.400 uS sdev:  13.300 uS
   98 secs  servo min:-132.800 uS max: 140.400 uS sdev:  13.300 uS
   99 secs  servo min:-132.800 uS max: 140.400 uS sdev:  13.300 uS
  100 secs  servo min:-132.800 uS max: 140.400 uS sdev:  13.300 uS
  101 secs  servo min:-132.800 uS max: 140.400 uS sdev:  13.200 uS
  102 secs  servo min:-132.800 uS max: 140.400 uS sdev:  13.300 uS
  103 secs  servo min:-132.800 uS max: 140.400 uS sdev:  13.300 uS
  104 secs  servo min:-132.800 uS max: 140.400 uS sdev:  13.300 uS
  105 secs  servo min:-132.800 uS max: 140.400 uS sdev:  13.300 uS
  106 secs  servo min:-132.800 uS max: 140.400 uS sdev:  13.300 uS
  107 secs  servo min:-132.800 uS max: 140.400 uS sdev:  13.400 uS
  108 secs  servo min:-132.800 uS max: 140.400 uS sdev:  13.400 uS
  109 secs  servo min:-132.800 uS max: 140.400 uS sdev:  13.400 uS
  110 secs  servo min:-132.800 uS max: 141.300 uS sdev:  13.400 uS
  111 secs  servo min:-132.800 uS max: 141.300 uS sdev:  13.400 uS
  112 secs  servo min:-132.800 uS max: 141.300 uS sdev:  13.400 uS
  113 secs  servo min:-132.800 uS max: 141.300 uS sdev:  13.400 uS
  114 secs  servo min:-132.800 uS max: 141.300 uS sdev:  13.400 uS
  115 secs  servo min:-132.800 uS max: 141.300 uS sdev:  13.400 uS
  116 secs  servo min:-132.800 uS max: 141.300 uS sdev:  13.400 uS
  117 secs  servo min:-132.800 uS max: 141.300 uS sdev:  13.400 uS
  118 secs  servo min:-132.800 uS max: 141.300 uS sdev:  13.400 uS
  119 secs  servo min:-132.800 uS max: 141.300 uS sdev:  13.400 uS
  120 secs  servo min:-132.800 uS max: 141.300 uS sdev:  13.400 uS
  121 secs  servo min:-132.800 uS max: 141.300 uS sdev:  13.500 uS
  122 secs  servo min:-132.800 uS max: 141.300 uS sdev:  13.500 uS
  123 secs  servo min:-132.800 uS max: 141.300 uS sdev:  13.500 uS
  124 secs  servo min:-132.800 uS max: 141.300 uS sdev:  13.500 uS
  125 secs  servo min:-132.800 uS max: 141.300 uS sdev:  13.500 uS
  126 secs  servo min:-132.800 uS max: 141.300 uS sdev:  13.500 uS
  126 secs  servo min:-132.800 uS max: 141.300 uS sdev:  13.600 uS
  127 secs  servo min:-132.800 uS max: 141.300 uS sdev:  13.600 uS
  128 secs  servo min:-132.800 uS max: 141.300 uS sdev:  13.600 uS
  129 secs  servo min:-132.800 uS max: 141.300 uS sdev:  13.600 uS
  130 secs  servo min:-132.800 uS max: 141.300 uS sdev:  13.600 uS
  131 secs  servo min:-132.800 uS max: 141.300 uS sdev:  13.600 uS
  132 secs  servo min:-132.800 uS max: 141.300 uS sdev:  13.600 uS
  133 secs  servo min:-132.800 uS max: 141.300 uS sdev:  13.600 uS
  134 secs  servo min:-132.800 uS max: 141.300 uS sdev:  13.600 uS
  135 secs  servo min:-132.800 uS max: 141.300 uS sdev:  13.600 uS
  136 secs  servo min:-132.800 uS max: 141.300 uS sdev:  13.600 uS
  137 secs  servo min:-132.800 uS max: 141.300 uS sdev:  13.600 uS
  138 secs  servo min:-132.800 uS max: 141.300 uS sdev:  13.600 uS
  139 secs  servo min:-132.800 uS max: 141.300 uS sdev:  13.600 uS
  140 secs  servo min:-132.800 uS max: 141.300 uS sdev:  13.600 uS
  141 secs  servo min:-132.800 uS max: 141.300 uS sdev:  13.600 uS
  142 secs  servo min:-132.800 uS max: 141.300 uS sdev:  13.700 uS
  143 secs  servo min:-132.800 uS max: 141.300 uS sdev:  13.700 uS
  144 secs  servo min:-132.800 uS max: 141.300 uS sdev:  13.700 uS
  145 secs  servo min:-132.800 uS max: 141.300 uS sdev:  13.700 uS
  146 secs  servo min:-132.800 uS max: 141.300 uS sdev:  13.700 uS
  147 secs  servo min:-132.800 uS max: 141.300 uS sdev:  13.700 uS
  148 secs  servo min:-132.800 uS max: 141.300 uS sdev:  13.700 uS
  149 secs  servo min:-132.800 uS max: 141.300 uS sdev:  13.700 uS
  150 secs  servo min:-132.800 uS max: 141.300 uS sdev:  13.700 uS
  151 secs  servo min:-132.800 uS max: 141.300 uS sdev:  13.700 uS
  152 secs  servo min:-132.800 uS max: 141.300 uS sdev:  13.700 uS
  153 secs  servo min:-132.800 uS max: 141.300 uS sdev:  13.800 uS
  154 secs  servo min:-132.800 uS max: 141.300 uS sdev:  13.700 uS
  155 secs  servo min:-132.800 uS max: 141.300 uS sdev:  13.700 uS
  156 secs  servo min:-132.800 uS max: 141.300 uS sdev:  13.700 uS
  157 secs  servo min:-132.800 uS max: 141.300 uS sdev:  13.700 uS
  158 secs  servo min:-132.800 uS max: 141.300 uS sdev:  13.700 uS
  159 secs  servo min:-132.800 uS max: 141.300 uS sdev:  13.700 uS
  160 secs  servo min:-132.800 uS max: 141.300 uS sdev:  13.700 uS
  161 secs  servo min:-132.800 uS max: 141.300 uS sdev:  13.700 uS
  162 secs  servo min:-132.800 uS max: 141.300 uS sdev:  13.800 uS
  163 secs  servo min:-132.800 uS max: 141.300 uS sdev:  13.800 uS
  164 secs  servo min:-132.800 uS max: 141.300 uS sdev:  13.800 uS
  165 secs  servo min:-132.800 uS max: 141.300 uS sdev:  13.800 uS
  166 secs  servo min:-132.800 uS max: 141.300 uS sdev:  13.800 uS
  167 secs  servo min:-132.800 uS max: 141.300 uS sdev:  13.800 uS
  168 secs  servo min:-132.800 uS max: 141.300 uS sdev:  13.800 uS
  169 secs  servo min:-132.800 uS max: 141.300 uS sdev:  13.800 uS
  170 secs  servo min:-132.800 uS max: 141.300 uS sdev:  13.800 uS
  171 secs  servo min:-132.800 uS max: 141.300 uS sdev:  13.900 uS
  172 secs  servo min:-132.800 uS max: 141.300 uS sdev:  13.900 uS
  173 secs  servo min:-132.800 uS max: 141.300 uS sdev:  13.900 uS
  174 secs  servo min:-132.800 uS max: 141.300 uS sdev:  13.900 uS
  175 secs  servo min:-132.800 uS max: 141.300 uS sdev:  13.900 uS
  175 secs  servo min:-133.700 uS max: 154.100 uS sdev:  13.900 uS
  176 secs  servo min:-133.700 uS max: 154.100 uS sdev:  13.900 uS
  177 secs  servo min:-133.700 uS max: 154.100 uS sdev:  13.800 uS
  178 secs  servo min:-133.700 uS max: 154.100 uS sdev:  13.800 uS
  179 secs  servo min:-133.700 uS max: 154.100 uS sdev:  13.800 uS
  180 secs  servo min:-133.700 uS max: 154.100 uS sdev:  13.800 uS
  181 secs  servo min:-133.700 uS max: 154.100 uS sdev:  13.800 uS
  182 secs  servo min:-133.700 uS max: 154.100 uS sdev:  13.800 uS
  183 secs  servo min:-133.700 uS max: 154.100 uS sdev:  13.800 uS
  184 secs  servo min:-133.700 uS max: 154.100 uS sdev:  13.800 uS
  185 secs  servo min:-133.700 uS max: 154.100 uS sdev:  13.800 uS
  186 secs  servo min:-133.700 uS max: 154.100 uS sdev:  13.900 uS
  187 secs  servo min:-133.700 uS max: 154.100 uS sdev:  13.900 uS
  188 secs  servo min:-133.700 uS max: 154.100 uS sdev:  13.900 uS
  189 secs  servo min:-133.700 uS max: 154.100 uS sdev:  13.900 uS
  190 secs  servo min:-133.700 uS max: 154.100 uS sdev:  13.900 uS
  191 secs  servo min:-133.700 uS max: 154.100 uS sdev:  13.900 uS
  192 secs  servo min:-133.700 uS max: 154.100 uS sdev:  13.900 uS
  193 secs  servo min:-133.700 uS max: 154.100 uS sdev:  13.900 uS
  194 secs  servo min:-133.700 uS max: 154.100 uS sdev:  13.900 uS
  195 secs  servo min:-133.700 uS max: 154.100 uS sdev:  13.900 uS
  196 secs  servo min:-133.700 uS max: 154.100 uS sdev:  13.900 uS
  197 secs  servo min:-133.700 uS max: 154.100 uS sdev:  13.900 uS
  198 secs  servo min:-133.700 uS max: 154.100 uS sdev:  13.900 uS
  199 secs  servo min:-133.700 uS max: 154.100 uS sdev:  13.900 uS
  200 secs  servo min:-133.700 uS max: 154.100 uS sdev:  13.900 uS
  201 secs  servo min:-133.700 uS max: 154.100 uS sdev:  13.900 uS
  202 secs  servo min:-133.700 uS max: 154.100 uS sdev:  13.900 uS
  203 secs  servo min:-133.700 uS max: 154.100 uS sdev:  13.900 uS
  204 secs  servo min:-133.700 uS max: 154.100 uS sdev:  13.900 uS
  205 secs  servo min:-133.700 uS max: 154.100 uS sdev:  13.900 uS
  206 secs  servo min:-133.700 uS max: 154.100 uS sdev:  13.900 uS
  207 secs  servo min:-133.700 uS max: 154.100 uS sdev:  13.900 uS
  208 secs  servo min:-133.700 uS max: 154.100 uS sdev:  13.900 uS
  209 secs  servo min:-133.700 uS max: 154.100 uS sdev:  14.000 uS
  210 secs  servo min:-133.700 uS max: 154.100 uS sdev:  14.000 uS
  211 secs  servo min:-133.700 uS max: 154.100 uS sdev:  14.000 uS
  212 secs  servo min:-133.700 uS max: 154.100 uS sdev:  14.000 uS
  213 secs  servo min:-133.700 uS max: 154.100 uS sdev:  14.000 uS
  214 secs  servo min:-133.700 uS max: 154.100 uS sdev:  14.000 uS
  215 secs  servo min:-133.700 uS max: 154.100 uS sdev:  14.000 uS
  216 secs  servo min:-133.700 uS max: 154.100 uS sdev:  14.000 uS
  217 secs  servo min:-133.700 uS max: 154.100 uS sdev:  14.000 uS
  218 secs  servo min:-133.700 uS max: 154.100 uS sdev:  14.000 uS
  219 secs  servo min:-133.700 uS max: 154.100 uS sdev:  14.000 uS
  220 secs  servo min:-133.700 uS max: 154.100 uS sdev:  14.000 uS
  221 secs  servo min:-133.700 uS max: 154.100 uS sdev:  14.000 uS
  222 secs  servo min:-133.700 uS max: 154.100 uS sdev:  14.000 uS
  223 secs  servo min:-133.700 uS max: 154.100 uS sdev:  14.000 uS
  224 secs  servo min:-133.700 uS max: 154.100 uS sdev:  14.000 uS
  225 secs  servo min:-133.700 uS max: 154.100 uS sdev:  14.000 uS
  226 secs  servo min:-133.700 uS max: 154.100 uS sdev:  14.000 uS
  227 secs  servo min:-133.700 uS max: 154.100 uS sdev:  14.000 uS
  228 secs  servo min:-133.700 uS max: 154.100 uS sdev:  14.000 uS
  229 secs  servo min:-133.700 uS max: 154.100 uS sdev:  14.000 uS
  230 secs  servo min:-133.700 uS max: 154.100 uS sdev:  14.000 uS
  231 secs  servo min:-133.700 uS max: 154.100 uS sdev:  14.000 uS
  232 secs  servo min:-133.700 uS max: 154.100 uS sdev:  14.000 uS
  233 secs  servo min:-133.700 uS max: 154.100 uS sdev:  14.000 uS
  234 secs  servo min:-133.700 uS max: 154.100 uS sdev:  14.000 uS
  235 secs  servo min:-133.700 uS max: 154.100 uS sdev:  14.100 uS
  236 secs  servo min:-133.700 uS max: 154.100 uS sdev:  14.100 uS
  237 secs  servo min:-133.700 uS max: 154.100 uS sdev:  14.100 uS
  238 secs  servo min:-133.700 uS max: 154.100 uS sdev:  14.100 uS
  239 secs  servo min:-133.700 uS max: 154.100 uS sdev:  14.100 uS
  240 secs  servo min:-133.700 uS max: 154.100 uS sdev:  14.100 uS
  241 secs  servo min:-133.700 uS max: 154.100 uS sdev:  14.000 uS
  242 secs  servo min:-133.700 uS max: 154.100 uS sdev:  14.000 uS
  243 secs  servo min:-133.700 uS max: 154.100 uS sdev:  14.000 uS
  244 secs  servo min:-133.700 uS max: 154.100 uS sdev:  14.000 uS
  245 secs  servo min:-133.700 uS max: 154.100 uS sdev:  14.100 uS
  246 secs  servo min:-133.700 uS max: 154.100 uS sdev:  14.100 uS
  247 secs  servo min:-133.700 uS max: 154.100 uS sdev:  14.100 uS
  248 secs  servo min:-133.700 uS max: 154.100 uS sdev:  14.100 uS
  249 secs  servo min:-133.700 uS max: 154.100 uS sdev:  14.100 uS
  250 secs  servo min:-133.700 uS max: 154.100 uS sdev:  14.100 uS
  251 secs  servo min:-133.700 uS max: 154.100 uS sdev:  14.100 uS
  252 secs  servo min:-133.700 uS max: 154.100 uS sdev:  14.100 uS
  253 secs  servo min:-133.700 uS max: 154.100 uS sdev:  14.100 uS
  254 secs  servo min:-133.700 uS max: 154.100 uS sdev:  14.100 uS
  255 secs  servo min:-133.700 uS max: 154.100 uS sdev:  14.100 uS
  256 secs  servo min:-133.700 uS max: 154.100 uS sdev:  14.100 uS
  257 secs  servo min:-133.700 uS max: 154.100 uS sdev:  14.100 uS
  258 secs  servo min:-133.700 uS max: 154.100 uS sdev:  14.100 uS
  259 secs  servo min:-133.700 uS max: 154.100 uS sdev:  14.100 uS
  260 secs  servo min:-133.700 uS max: 154.100 uS sdev:  14.100 uS
  261 secs  servo min:-133.700 uS max: 154.100 uS sdev:  14.100 uS
  262 secs  servo min:-133.700 uS max: 154.100 uS sdev:  14.100 uS
  263 secs  servo min:-133.700 uS max: 154.100 uS sdev:  14.100 uS
  264 secs  servo min:-133.700 uS max: 154.100 uS sdev:  14.100 uS
  265 secs  servo min:-133.700 uS max: 154.100 uS sdev:  14.100 uS
  266 secs  servo min:-133.700 uS max: 154.100 uS sdev:  14.100 uS
  267 secs  servo min:-133.700 uS max: 154.100 uS sdev:  14.100 uS
  268 secs  servo min:-133.700 uS max: 154.100 uS sdev:  14.100 uS
  269 secs  servo min:-133.700 uS max: 154.100 uS sdev:  14.100 uS
  270 secs  servo min:-133.700 uS max: 154.100 uS sdev:  14.100 uS
  271 secs  servo min:-133.700 uS max: 154.100 uS sdev:  14.100 uS
  272 secs  servo min:-133.700 uS max: 154.100 uS sdev:  14.100 uS
  273 secs  servo min:-133.700 uS max: 154.100 uS sdev:  14.100 uS
  274 secs  servo min:-133.700 uS max: 154.100 uS sdev:  14.100 uS
  275 secs  servo min:-133.700 uS max: 154.100 uS sdev:  14.100 uS
  276 secs  servo min:-133.700 uS max: 154.100 uS sdev:  14.100 uS
  277 secs  servo min:-133.700 uS max: 154.100 uS sdev:  14.100 uS
  277 secs  servo min:-133.700 uS max: 154.100 uS sdev:  14.200 uS
  278 secs  servo min:-133.700 uS max: 154.100 uS sdev:  14.200 uS
  279 secs  servo min:-133.700 uS max: 154.100 uS sdev:  14.200 uS
  280 secs  servo min:-133.700 uS max: 154.100 uS sdev:  14.200 uS
  281 secs  servo min:-133.700 uS max: 154.100 uS sdev:  14.200 uS
  281 secs  servo min:-133.700 uS max: 154.100 uS sdev:  14.100 uS
  282 secs  servo min:-133.700 uS max: 154.100 uS sdev:  14.100 uS
  283 secs  servo min:-133.700 uS max: 154.100 uS sdev:  14.100 uS
  284 secs  servo min:-133.700 uS max: 154.100 uS sdev:  14.100 uS
  285 secs  servo min:-133.700 uS max: 154.100 uS sdev:  14.100 uS
  286 secs  servo min:-133.700 uS max: 154.100 uS sdev:  14.100 uS
  287 secs  servo min:-133.700 uS max: 154.100 uS sdev:  14.100 uS
  288 secs  servo min:-133.700 uS max: 154.100 uS sdev:  14.100 uS
  289 secs  servo min:-133.700 uS max: 154.100 uS sdev:  14.100 uS
  289 secs  servo min:-133.700 uS max: 154.100 uS sdev:  14.200 uS
  290 secs  servo min:-133.700 uS max: 154.100 uS sdev:  14.100 uS
  291 secs  servo min:-133.700 uS max: 154.100 uS sdev:  14.200 uS
  292 secs  servo min:-133.700 uS max: 154.100 uS sdev:  14.200 uS
  293 secs  servo min:-133.700 uS max: 154.100 uS sdev:  14.200 uS
  294 secs  servo min:-133.700 uS max: 154.100 uS sdev:  14.200 uS
  295 secs  servo min:-133.700 uS max: 154.100 uS sdev:  14.200 uS
  296 secs  servo min:-133.700 uS max: 154.100 uS sdev:  14.200 uS
  297 secs  servo min:-133.700 uS max: 154.100 uS sdev:  14.200 uS
  298 secs  servo min:-133.700 uS max: 154.100 uS sdev:  14.200 uS
  299 secs  servo min:-133.700 uS max: 154.100 uS sdev:  14.200 uS
  300 secs  servo min:-133.700 uS max: 154.100 uS sdev:  14.200 uS
  301 secs  servo min:-133.700 uS max: 154.100 uS sdev:  14.200 uS
  302 secs  servo min:-133.700 uS max: 154.100 uS sdev:  14.200 uS
  303 secs  servo min:-133.700 uS max: 154.100 uS sdev:  14.200 uS
  304 secs  servo min:-133.700 uS max: 154.100 uS sdev:  14.200 uS
I am pretty sure another couple of Gigs of Ram would greatly benefit this machine
Last edit: 01 Nov 2020 10:07 by my1987toyota.
01 Nov 2020 12:26 #188026 by seuchato
my1987toyota: my quick finds:
Mint:
Not much, bur still something. Conclusion: Add RAM.
Buster:
Looks like it is a "IdeaCentre H215". Nice, small thingy, I guess.
Looks smallish.
I had a raden 3450. Gave really bad results. Changed it for 45xx and/or 6xxx series: whole different world in latency, going from barely useable to good for soft stepping. Such GPU's can be obtained at around 20$.
k10temp-pci-00c3
That helps a lot. Thanks! I have to modify the script accordingly (lookup has to be for "core|temp", not only core). Maybe even add a check, whether there is any temp data at all would probably be nice. Better than to have to post the whole *.lat file. You could use:
tail -n2 <yourlatfile>.lat
and add this instead of the whole file.
greez chris
01 Nov 2020 16:02 #188053 by my1987toyota
seuchato I am glad it proved useful to you .
I had a feeling it needed more ram and I now have another 2 gigs on the way.
The H215 Idea center I am using has the graphics card portion integrated into the mother board
I will look into an add on card to see if it will help .
fortunately I wont be working on the PnP project for awhile so I have time to mess with the computer configuration
at least now when I plug in a usb camera I get video, I couldn't do that with Debian Wheezy for some reason.
16 Nov 2020 19:15 #189570 by my1987toyota
a short test with a total of 4Gb ram on the Lenovo H215 Idea Center. Debian Buster and RT-Preempt
LinuxCNC pc tests, version 20200930, started 06.11.2020 20:19:25
General info:
LENOVO,  H215
CPU related data:
cpu cores	: 2
stepping	: 3
RAM related data:
GPU related data:
Number of mice: 1
Dell Computer Corp. Keyboard
Started firefox with 'https://vimeo.com/150574260', WID 48234499
su cnc001 -c  "latency-histogram --nobase --base 100000 --sbinsize 1000 --nox 2>&1 | tee -a 1604711937.lat &"
Latency testing loop started Fri 06 Nov 2020 08:19:39 PM EST,
should end after Fri 06 Nov 2020 08:24:39 PM EST
k10temp-pci-00c3
temp1:        +41.0°C  (high = +70.0°C)
    0 secs  servo min: -41.300 uS max:  45.900 uS sdev:  10.400 uS
    1 secs  servo min: -43.600 uS max:  49.400 uS sdev:  10.300 uS
    2 secs  servo min: -49.800 uS max:  49.400 uS sdev:  10.000 uS
    3 secs  servo min: -49.800 uS max:  51.300 uS sdev:  10.600 uS
    3 secs  servo min: -49.800 uS max:  51.300 uS sdev:  10.100 uS
    4 secs  servo min: -49.800 uS max:  51.300 uS sdev:   9.900 uS
    5 secs  servo min: -49.800 uS max:  51.300 uS sdev:   9.800 uS
    5 secs  servo min: -49.800 uS max:  51.300 uS sdev:   9.500 uS
    6 secs  servo min: -49.800 uS max:  51.300 uS sdev:   9.600 uS
    7 secs  servo min: -50.500 uS max:  51.300 uS sdev:   9.500 uS
    8 secs  servo min: -50.500 uS max:  53.300 uS sdev:   9.500 uS
    8 secs  servo min: -51.200 uS max:  53.300 uS sdev:   9.500 uS
    9 secs  servo min: -64.000 uS max:  57.500 uS sdev:   9.500 uS
   10 secs  servo min: -64.000 uS max:  57.500 uS sdev:   9.500 uS
   11 secs  servo min: -64.000 uS max:  58.900 uS sdev:   9.600 uS
   12 secs  servo min: -64.000 uS max:  58.900 uS sdev:   9.700 uS
   13 secs  servo min: -64.000 uS max:  58.900 uS sdev:   9.900 uS
   14 secs  servo min: -64.000 uS max:  58.900 uS sdev:  10.100 uS
   14 secs  servo min: -64.000 uS max:  58.900 uS sdev:  10.300 uS
   15 secs  servo min: -64.000 uS max:  58.900 uS sdev:  10.500 uS
   16 secs  servo min: -64.000 uS max:  58.900 uS sdev:  10.700 uS
   17 secs  servo min: -64.000 uS max:  58.900 uS sdev:  10.800 uS
   17 secs  servo min: -64.000 uS max:  58.900 uS sdev:  11.000 uS
   18 secs  servo min: -64.000 uS max:  58.900 uS sdev:  11.100 uS
   19 secs  servo min: -64.000 uS max:  58.900 uS sdev:  11.200 uS
   20 secs  servo min: -64.000 uS max:  58.900 uS sdev:  11.200 uS
   20 secs  servo min: -64.000 uS max:  58.900 uS sdev:  11.300 uS
   21 secs  servo min: -64.000 uS max:  58.900 uS sdev:  11.300 uS
   22 secs  servo min: -64.000 uS max:  58.900 uS sdev:  11.500 uS
   23 secs  servo min: -64.000 uS max:  58.900 uS sdev:  11.700 uS
   24 secs  servo min: -64.000 uS max:  58.900 uS sdev:  12.000 uS
   24 secs  servo min: -64.000 uS max:  58.900 uS sdev:  12.200 uS
   25 secs  servo min: -64.000 uS max:  58.900 uS sdev:  12.400 uS
   26 secs  servo min: -64.000 uS max:  58.900 uS sdev:  12.600 uS
   27 secs  servo min: -64.000 uS max:  58.900 uS sdev:  12.700 uS
   28 secs  servo min: -64.000 uS max:  58.900 uS sdev:  12.600 uS
   28 secs  servo min: -64.000 uS max:  58.900 uS sdev:  12.500 uS
   29 secs  servo min: -64.000 uS max:  58.900 uS sdev:  12.500 uS
   30 secs  servo min: -64.000 uS max:  58.900 uS sdev:  12.400 uS
   31 secs  servo min: -64.000 uS max:  58.900 uS sdev:  12.300 uS
   32 secs  servo min: -64.000 uS max:  58.900 uS sdev:  12.200 uS
   33 secs  servo min: -64.000 uS max:  58.900 uS sdev:  12.300 uS
   34 secs  servo min: -64.000 uS max:  58.900 uS sdev:  12.300 uS
   35 secs  servo min: -64.000 uS max:  58.900 uS sdev:  12.300 uS
   36 secs  servo min: -64.000 uS max:  58.900 uS sdev:  12.400 uS
   37 secs  servo min: -64.000 uS max:  58.900 uS sdev:  12.400 uS
   38 secs  servo min: -64.000 uS max:  58.900 uS sdev:  12.500 uS
   39 secs  servo min: -64.000 uS max:  58.900 uS sdev:  12.600 uS
   40 secs  servo min: -64.000 uS max:  58.900 uS sdev:  12.800 uS
   41 secs  servo min: -64.000 uS max:  58.900 uS sdev:  12.900 uS
   41 secs  servo min: -64.000 uS max:  58.900 uS sdev:  13.000 uS
   42 secs  servo min: -64.000 uS max:  58.900 uS sdev:  13.100 uS
   43 secs  servo min: -64.000 uS max:  58.900 uS sdev:  13.200 uS
   44 secs  servo min: -64.000 uS max:  65.100 uS sdev:  13.200 uS
   45 secs  servo min: -64.000 uS max:  65.100 uS sdev:  13.300 uS
   45 secs  servo min: -64.000 uS max:  65.100 uS sdev:  13.400 uS
   46 secs  servo min: -64.000 uS max:  65.100 uS sdev:  13.500 uS
   47 secs  servo min: -64.000 uS max:  65.100 uS sdev:  13.500 uS
   48 secs  servo min: -64.000 uS max:  65.100 uS sdev:  13.600 uS
   49 secs  servo min: -64.000 uS max:  65.100 uS sdev:  13.500 uS
   49 secs  servo min: -64.000 uS max:  65.700 uS sdev:  13.500 uS
   50 secs  servo min: -64.000 uS max:  65.700 uS sdev:  13.400 uS
   51 secs  servo min: -64.000 uS max:  65.700 uS sdev:  13.400 uS
   51 secs  servo min: -64.000 uS max:  65.700 uS sdev:  13.300 uS
   52 secs  servo min: -64.000 uS max:  65.700 uS sdev:  13.300 uS
   53 secs  servo min: -64.000 uS max:  65.700 uS sdev:  13.200 uS
   54 secs  servo min: -64.000 uS max:  65.700 uS sdev:  13.200 uS
   55 secs  servo min: -64.000 uS max:  65.700 uS sdev:  13.200 uS
   56 secs  servo min: -64.000 uS max:  65.700 uS sdev:  13.200 uS
   57 secs  servo min: -64.000 uS max:  65.700 uS sdev:  13.200 uS
   58 secs  servo min: -64.000 uS max:  65.700 uS sdev:  13.200 uS
   59 secs  servo min: -64.000 uS max:  65.700 uS sdev:  13.300 uS
   60 secs  servo min: -64.000 uS max:  65.700 uS sdev:  13.300 uS
   61 secs  servo min: -64.000 uS max:  65.700 uS sdev:  13.400 uS
   62 secs  servo min: -64.000 uS max:  65.700 uS sdev:  13.500 uS
   63 secs  servo min: -64.000 uS max:  65.700 uS sdev:  13.500 uS
   64 secs  servo min: -64.000 uS max:  65.700 uS sdev:  13.500 uS
   65 secs  servo min: -64.000 uS max:  65.700 uS sdev:  13.400 uS
   66 secs  servo min: -64.000 uS max:  65.700 uS sdev:  13.400 uS
   67 secs  servo min: -64.000 uS max:  65.700 uS sdev:  13.300 uS
   68 secs  servo min: -64.000 uS max:  65.700 uS sdev:  13.300 uS
   69 secs  servo min: -64.000 uS max:  65.700 uS sdev:  13.300 uS
   70 secs  servo min: -64.000 uS max:  65.700 uS sdev:  13.200 uS
   71 secs  servo min: -64.000 uS max:  65.700 uS sdev:  13.200 uS
   72 secs  servo min: -64.000 uS max:  65.700 uS sdev:  13.200 uS
   73 secs  servo min: -64.000 uS max:  65.700 uS sdev:  13.200 uS
   74 secs  servo min: -64.000 uS max:  65.700 uS sdev:  13.200 uS
   75 secs  servo min: -64.000 uS max:  65.700 uS sdev:  13.200 uS
   76 secs  servo min: -64.000 uS max:  65.700 uS sdev:  13.200 uS
   77 secs  servo min: -64.000 uS max:  65.700 uS sdev:  13.200 uS
   78 secs  servo min: -64.000 uS max:  65.700 uS sdev:  13.200 uS
   79 secs  servo min: -64.000 uS max:  65.700 uS sdev:  13.200 uS
   80 secs  servo min: -64.000 uS max:  65.700 uS sdev:  13.300 uS
   81 secs  servo min: -64.000 uS max:  65.700 uS sdev:  13.300 uS
   82 secs  servo min: -64.000 uS max:  65.700 uS sdev:  13.400 uS
   83 secs  servo min: -64.000 uS max:  65.700 uS sdev:  13.400 uS
   83 secs  servo min: -64.000 uS max:  65.700 uS sdev:  13.500 uS
   84 secs  servo min: -64.000 uS max:  65.700 uS sdev:  13.500 uS
   85 secs  servo min: -64.000 uS max:  65.700 uS sdev:  13.400 uS
   86 secs  servo min: -64.000 uS max:  65.700 uS sdev:  13.400 uS
   87 secs  servo min: -64.000 uS max:  65.700 uS sdev:  13.300 uS
   88 secs  servo min: -64.000 uS max:  65.700 uS sdev:  13.300 uS
   89 secs  servo min: -64.000 uS max:  65.700 uS sdev:  13.300 uS
   90 secs  servo min: -64.000 uS max:  65.700 uS sdev:  13.300 uS
   91 secs  servo min: -64.000 uS max:  65.700 uS sdev:  13.300 uS
   91 secs  servo min: -64.000 uS max:  65.700 uS sdev:  13.200 uS
   92 secs  servo min: -64.000 uS max:  65.700 uS sdev:  13.200 uS
   93 secs  servo min: -64.000 uS max:  65.700 uS sdev:  13.200 uS
   94 secs  servo min: -64.000 uS max:  65.700 uS sdev:  13.200 uS
   95 secs  servo min: -64.000 uS max:  65.700 uS sdev:  13.300 uS
   96 secs  servo min: -64.000 uS max:  65.700 uS sdev:  13.300 uS
   97 secs  servo min: -64.000 uS max:  65.700 uS sdev:  13.300 uS
   98 secs  servo min: -64.000 uS max:  65.700 uS sdev:  13.400 uS
   99 secs  servo min: -64.000 uS max:  65.700 uS sdev:  13.400 uS
  100 secs  servo min: -64.000 uS max:  65.700 uS sdev:  13.400 uS
  101 secs  servo min: -64.000 uS max:  65.700 uS sdev:  13.400 uS
  102 secs  servo min: -64.000 uS max:  65.700 uS sdev:  13.300 uS
  103 secs  servo min: -64.000 uS max:  65.700 uS sdev:  13.300 uS
  104 secs  servo min: -64.000 uS max:  65.700 uS sdev:  13.300 uS
  105 secs  servo min: -64.000 uS max:  65.700 uS sdev:  13.300 uS
  106 secs  servo min: -64.000 uS max:  65.700 uS sdev:  13.300 uS
  107 secs  servo min: -64.000 uS max:  65.700 uS sdev:  13.300 uS
  108 secs  servo min: -64.000 uS max:  65.700 uS sdev:  13.200 uS
  109 secs  servo min: -64.000 uS max:  65.700 uS sdev:  13.200 uS
  110 secs  servo min: -64.000 uS max:  65.700 uS sdev:  13.200 uS
  111 secs  servo min: -64.000 uS max:  65.700 uS sdev:  13.200 uS
  112 secs  servo min: -64.000 uS max:  65.700 uS sdev:  13.200 uS
  113 secs  servo min: -64.000 uS max:  65.700 uS sdev:  13.200 uS
  114 secs  servo min: -64.000 uS max:  67.000 uS sdev:  13.200 uS
  115 secs  servo min: -64.000 uS max:  67.000 uS sdev:  13.200 uS
  116 secs  servo min: -64.000 uS max:  67.000 uS sdev:  13.300 uS
  117 secs  servo min: -64.000 uS max:  67.000 uS sdev:  13.300 uS
  118 secs  servo min: -64.000 uS max:  67.000 uS sdev:  13.300 uS
  119 secs  servo min: -64.000 uS max:  67.000 uS sdev:  13.400 uS
  120 secs  servo min: -64.000 uS max:  67.000 uS sdev:  13.400 uS
  121 secs  servo min: -64.000 uS max:  67.000 uS sdev:  13.400 uS
  122 secs  servo min: -64.000 uS max:  67.000 uS sdev:  13.400 uS
  122 secs  servo min: -64.000 uS max:  67.000 uS sdev:  13.300 uS
  123 secs  servo min: -64.000 uS max:  67.000 uS sdev:  13.300 uS
  124 secs  servo min: -64.000 uS max:  67.000 uS sdev:  13.300 uS
  125 secs  servo min: -64.000 uS max:  67.000 uS sdev:  13.300 uS
  126 secs  servo min: -64.000 uS max:  67.000 uS sdev:  13.300 uS
  127 secs  servo min: -64.000 uS max:  67.000 uS sdev:  13.300 uS
  128 secs  servo min: -64.000 uS max:  67.000 uS sdev:  13.300 uS
  128 secs  servo min: -64.000 uS max:  67.000 uS sdev:  13.200 uS
  129 secs  servo min: -64.000 uS max:  67.000 uS sdev:  13.200 uS
  130 secs  servo min: -64.000 uS max:  67.000 uS sdev:  13.200 uS
  131 secs  servo min: -64.000 uS max:  67.000 uS sdev:  13.200 uS
  131 secs  servo min: -64.000 uS max:  67.000 uS sdev:  13.300 uS
  132 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.300 uS
  133 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.300 uS
  134 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.300 uS
  134 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.400 uS
  135 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.400 uS
  136 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.400 uS
  137 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.300 uS
  138 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.300 uS
  139 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.300 uS
  140 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.300 uS
  141 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.200 uS
  142 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.200 uS
  143 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.200 uS
  144 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.200 uS
  145 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.100 uS
  146 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.100 uS
  147 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.100 uS
  148 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.100 uS
  149 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.100 uS
  150 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.100 uS
  151 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.100 uS
  152 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.100 uS
  152 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.200 uS
  153 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.200 uS
  154 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.200 uS
  155 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.200 uS
  156 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.300 uS
  157 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.200 uS
  158 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.200 uS
  159 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.200 uS
  160 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.200 uS
  161 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.200 uS
  162 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.200 uS
  163 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.200 uS
  164 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.200 uS
  165 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.200 uS
  166 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.100 uS
  167 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.200 uS
  168 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.200 uS
  169 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.200 uS
  170 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.200 uS
  171 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.300 uS
  172 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.300 uS
  173 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.300 uS
  174 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.200 uS
  175 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.200 uS
  176 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.200 uS
  177 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.200 uS
  178 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.100 uS
  179 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.100 uS
  180 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.100 uS
  181 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.100 uS
  182 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.100 uS
  183 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.100 uS
  184 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.100 uS
  185 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.100 uS
  186 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.100 uS
  187 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.100 uS
  188 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.100 uS
  189 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.100 uS
  190 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.100 uS
  191 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.100 uS
  191 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.200 uS
  192 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.200 uS
  193 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.200 uS
  194 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.100 uS
  195 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.100 uS
  196 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.100 uS
  197 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.100 uS
  198 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.100 uS
  199 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.100 uS
  200 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.100 uS
  201 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.100 uS
  202 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.100 uS
  203 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.100 uS
  204 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.100 uS
  205 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.100 uS
  206 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.200 uS
  207 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.200 uS
  208 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.200 uS
  209 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.200 uS
  210 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.100 uS
  211 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.100 uS
  212 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.100 uS
  213 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.100 uS
  214 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.100 uS
  215 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.100 uS
  216 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.000 uS
  217 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.000 uS
  218 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.000 uS
  219 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.000 uS
  220 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.000 uS
  221 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.000 uS
  222 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.000 uS
  223 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.000 uS
  224 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.000 uS
  225 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.100 uS
  226 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.100 uS
  227 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.100 uS
  228 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.100 uS
  229 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.100 uS
  230 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.100 uS
  231 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.100 uS
  232 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.100 uS
  233 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.000 uS
  234 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.000 uS
  235 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.000 uS
  236 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.000 uS
  237 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.000 uS
  238 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.000 uS
  239 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.000 uS
  239 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.100 uS
  240 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.100 uS
  241 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.100 uS
  242 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.100 uS
  243 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.100 uS
  244 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.100 uS
  245 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.200 uS
  246 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.200 uS
  247 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.200 uS
  248 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.200 uS
  249 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.200 uS
  250 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.200 uS
  251 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.200 uS
  252 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.200 uS
  253 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.200 uS
  254 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.200 uS
  255 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.200 uS
  256 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.200 uS
  257 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.200 uS
  258 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.200 uS
  258 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.100 uS
  259 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.100 uS
  260 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.200 uS
  261 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.200 uS
  262 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.200 uS
  263 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.200 uS
  264 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.200 uS
  265 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.200 uS
  266 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.200 uS
  267 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.200 uS
  268 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.200 uS
  269 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.200 uS
  270 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.200 uS
  271 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.200 uS
  272 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.200 uS
  273 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.200 uS
  274 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.200 uS
  275 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.200 uS
  276 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.200 uS
  277 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.200 uS
  278 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.200 uS
  279 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.100 uS
  280 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.100 uS
  280 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.200 uS
  281 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.200 uS
  282 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.200 uS
  283 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.200 uS
  284 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.200 uS
  285 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.200 uS
  286 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.200 uS
  287 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.200 uS
  288 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.200 uS
  289 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.200 uS
  290 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.200 uS
  291 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.200 uS
  292 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.200 uS
  293 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.200 uS
  294 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.200 uS
  295 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.200 uS
  296 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.200 uS
  297 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.200 uS
  298 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.200 uS
  299 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.200 uS
  300 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.200 uS
  301 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.200 uS
  302 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.200 uS
  303 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.200 uS
  304 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.200 uS
  305 secs  servo min: -66.100 uS max:  67.000 uS sdev:  13.200 uS
Now that looks usable.:)
Time to create page: 0.483 seconds
