This is an early test of my Dell OptiPlex 7010 core i5 , 8gigs ram , 250gig SSD
and a whole lot of frustration.
In short Linux Mint 19.3 XFCE and Lcnc 2.8 Preempt don't go
well together for this machine .
A 300 second test was more then long enough to test this out
No mater what Bios settings I tried it didn't improve much.
sorry for the long post I don't currently know how to do the post within a post
LinuxCNC pc tests, version 20200930, started 29.10.2020 23:34:41
General info:
Dell Inc., OptiPlex 7010
Bios version A29, dated 06/28/2018
Chipset: Intel Corporation 7 Series/C216
Harddisk is non-rotational, ie. SSD
The amount of swap currently used is 0
CPU related data:
model name : Intel(R) Core(TM) i5-3570 CPU @ 3.40GHz
cpu cores : 4
stepping : 9
cache size : 6144 KB
RAM related data:
Maximum Capacity: 32 GB
Size: No Module Installed
GPU related data:
product: Xeon E3-1200 v2/3rd Gen Core processor Graphics Controller
configuration: driver=i915 latency=0
Parallel port related data:
number of parallel ports is 0
Os and desktop related data:
PRETTY_NAME="Linux Mint 19.3"
Should the info below not match with your machine,
kindly post the output of pstree here, including a brief
desciption of your desktop environment, window manager and
display manager. Tia
forum.linuxcnc.org/18-computer/39370-scr...-of-computer-latency
Desktop environment : lightdm
Windowmanager : Xfwm4
Displaymanager : lightdm
Kernel related data:
Kernel 5.0.0-32-generic
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash"
Cpu idle driver: intel_idle
Kernel modules data:
Check if pcspkr is loaded: No, which is good!
Check if snd modules are loaded: Yes, may cause bigger latency.
can probably be disabled in bios, alternatively, you can run
"./block-snd-modules"
which has just now been created for your convenience.
Keyboard & Mouse related data:
Number of mice: 1
Mouse 0 :
Mice attached to USB:
Keyboards attached to USB:
Dell Computer Corp. Keyboard
LinuxCNC related data:
LinuxCNC version is: 2.8.0.96.g589db060d
Preparing for latency test:
Started glxgears No. 1, 2, 3, 4, 5
Started firefox with ' vimeo.com/150574260 ', WID
Command for latency test is:
su cnc -c "latency-histogram --nobase --base 25000 --sbinsize 1000 --nox 2>&1 | tee -a 1604028827.lat &"
Latency testing loop started Thu Oct 29 23:34:55 EDT 2020,
should end after Thu Oct 29 23:39:55 EDT 2020
Swap useage: prerun: 0, running: 0
CPU core temperatures:
Core 0: Tmin: 36.0°C, Tmax: 41.0°C, (high = +85.0°C, crit = +105.0°C)
Core 1: Tmin: 40.0°C, Tmax: 45.0°C, (high = +85.0°C, crit = +105.0°C)
Core 2: Tmin: 37.0°C, Tmax: 43.0°C, (high = +85.0°C, crit = +105.0°C)
Core 3: Tmin: 37.0°C, Tmax: 44.0°C, (high = +85.0°C, crit = +105.0°C)
last latency data is as follows:.
299 secs servo min:-999.900 uS max:8653.700 uS sdev: 7.400 uS
300 secs servo min:-999.900 uS max:8653.700 uS sdev: 7.400 uS
