Results of latency test, list of computers tested for use with LinuxCNC
6 years 19 hours ago - 6 years 19 hours ago #187963 by my1987toyota
seuchato wrote: @my1987toyota
Do you need pcspkr and sound modules? If not, disable them in bios or block the kernel modules to be loaded. Depending on what PC, I usually get much better latency, if these modules are not loaded.
I will try your suggestion in my future tests
for now though I have a test with linux mint19.3 with Preempt on my PnP project computer previously using Debian Wheezy 2.7.14 RTAI
unfortunately it doesn't show core temps ( perhaps too old of a processor )
This is of a Lenovo Think Center 2010 vintage
LinuxCNC pc tests, version 20200930, started 31.10.2020 19:48:39 ******************************************************************************** General info: LENOVO, H215 Bios version D2KT25BUS, dated 08/18/2010 Chipset: Harddisk is non-rotational, ie. SSD The amount of swap currently used is 0 ================================================================================ CPU related data: model name : AMD Athlon(tm) II X2 250 Processor cpu cores : 2 stepping : 3 cache size : 1024 KB ================================================================================ RAM related data: Maximum Capacity: 8 GB Size: 2048 MB Size: No Module Installed ================================================================================ GPU related data: product: RS780L [Radeon 3000] configuration: driver=radeon latency=0 ================================================================================ Parallel port related data: number of parallel ports is 0 ================================================================================ Os and desktop related data: PRETTY_NAME="Linux Mint 19.3" Should the info below not match with your machine, kindly post the output of pstree here, including a brief desciption of your desktop environment, window manager and display manager. Tia https://forum.linuxcnc.org/18-computer/39370-script-for-automated-testing-of-computer-latency Desktop environment : lightdm Windowmanager : Xfwm4 Displaymanager : lightdm ================================================================================ Kernel related data: Kernel 5.0.0-32-generic GRUB_CMDLINE_LINUX_DEFAULT="quiet splash" Cpu idle driver: none ================================================================================ Kernel modules data: Check if pcspkr is loaded: [0;32mNo, which is good![0m Check if snd modules are loaded: [0;31mYes, may cause bigger latency.[0m can probably be disabled in bios, alternatively, you can run "./block-snd-modules" which has just now been created for your convenience. ================================================================================ Keyboard & Mouse related data: Number of mice: 1 Mouse 0 : PixArt USB Optical Mouse Mice attached to USB: Keyboards attached to USB: ================================================================================ LinuxCNC related data: LinuxCNC version is: 2.8.0.96.g589db060d ================================================================================ Preparing for latency test: Started glxgears No. 1, 2, 3, 4, 5 .......... Started firefox with 'https://vimeo.com/150574260', WID 60817513 ================================================================================ Command for latency test is: su cnc001 -c "latency-histogram --nobase --base 25000 --sbinsize 1000 --nox 2>&1 | tee -a 1604188058.lat &" Latency testing loop started Sat Oct 31 19:48:54 EDT 2020, should end after Sat Oct 31 21:48:54 EDT 2020 ================================================================================ Swap useage: prerun: 0, running: 0 ================================================================================ CPU core temperatures:
as you can see without the core temp it won't finish it's report.
Note: Using POSIX non-realtime 0 secs servo min:-996.100 uS max:1250.100 uS sdev: 12.000 uS 1 secs servo min:-997.600 uS max:1462.400 uS sdev: 9.200 uS 2 secs servo min:-997.600 uS max:1462.400 uS sdev: 8.100 uS 3 secs servo min:-998.300 uS max:1462.400 uS sdev: 8.600 uS 3 secs servo min:-998.300 uS max:1462.400 uS sdev: 8.600 uS 4 secs servo min:-999.800 uS max:2151.400 uS sdev: 8.500 uS 5 secs servo min:-999.800 uS max:5366.700 uS sdev: 8.300 uS 6 secs servo min:-999.800 uS max:9617.200 uS sdev: 8.500 uS 8 secs servo min:-999.800 uS max:9617.200 uS sdev: 8.900 uS 9 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.000 uS 10 secs servo min:-999.800 uS max:9617.200 uS sdev: 8.900 uS 11 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.000 uS 11 secs servo min:-999.800 uS max:9617.200 uS sdev: 8.700 uS 13 secs servo min:-999.800 uS max:9617.200 uS sdev: 8.800 uS 14 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 14 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 15 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 16 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS 17 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS 18 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS 18 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS 19 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS 20 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS 21 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS 22 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS 23 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS 24 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS 25 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS 26 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS 26 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS 27 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS 29 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS 30 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS 30 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS 31 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS 32 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS 33 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS 34 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS 34 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS 35 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS 36 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS 37 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS 37 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS 38 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 39 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS 40 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS 41 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 42 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 43 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 44 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 45 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 46 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 46 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.200 uS 47 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 48 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 49 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.200 uS 50 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 50 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 51 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 52 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 53 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 54 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 55 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 56 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 56 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 57 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 58 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 59 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 60 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 61 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 61 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 62 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 63 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 64 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 65 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 66 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 66 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 67 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 68 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 69 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 70 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 71 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 72 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 73 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 74 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 75 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 76 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 77 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 78 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 78 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 79 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 80 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 81 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 82 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 83 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 83 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 84 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 86 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 87 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 88 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 89 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 90 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 91 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 92 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 93 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 94 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 95 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 96 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 97 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 98 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 99 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 99 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 100 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 102 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 103 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 103 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 104 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 105 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 107 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 108 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 109 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 110 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 110 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 111 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 112 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 113 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 114 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 115 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 115 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 117 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 118 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 119 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 120 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 121 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 122 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 123 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 124 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 125 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 126 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 126 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 127 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 129 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 129 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 130 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 131 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 132 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 133 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 134 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 135 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 136 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 137 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 138 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 139 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 139 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 140 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 141 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 142 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 144 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 145 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 145 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 147 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 147 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 148 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 149 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 150 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 151 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 152 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 153 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 155 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 155 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 156 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 157 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 158 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 159 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 160 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 161 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 162 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 164 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 165 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 167 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 167 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 169 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 170 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 171 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 172 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 173 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 174 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 175 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 177 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 177 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 178 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 179 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 180 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 181 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 182 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 183 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 184 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 185 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 186 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 187 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 187 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 188 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 189 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 190 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 191 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 192 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 193 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 194 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 195 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 197 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 198 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 199 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 200 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 201 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 202 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 203 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 204 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 205 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 206 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 207 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 208 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 209 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 210 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 211 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 211 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 212 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 213 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 214 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 215 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 216 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 217 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.200 uS 217 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.200 uS 219 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 220 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.200 uS 221 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 222 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.200 uS 223 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 224 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 224 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 226 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 227 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 228 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 229 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 230 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 231 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 232 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 233 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.200 uS 234 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.200 uS 235 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 236 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 237 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 238 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 239 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 239 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 241 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 242 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 242 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 243 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 245 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 245 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 247 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 248 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 249 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 250 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 251 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 252 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 253 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 254 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 256 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 257 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 258 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 259 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 260 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 261 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 262 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 263 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 264 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 265 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 266 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 267 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 267 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 269 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 270 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 272 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 273 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 274 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 275 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 276 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 277 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 279 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 279 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 281 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 281 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 283 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 283 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 284 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 285 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 286 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 287 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 288 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 289 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 290 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 292 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 292 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 293 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 294 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 295 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 296 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 297 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 297 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 298 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 299 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 300 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 301 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 302 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 303 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 304 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 305 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 306 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 307 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 308 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 309 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 310 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 311 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 312 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 313 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 314 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 314 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 315 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 316 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 317 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 318 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 319 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 320 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 321 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 322 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 323 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 324 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 325 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 326 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 328 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 329 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 330 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 331 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 332 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 332 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 333 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 334 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 335 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 336 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 336 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 337 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 338 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 339 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 340 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 341 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 341 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 342 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 343 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 344 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 345 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 345 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 346 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 347 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 348 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 349 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 350 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 351 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 352 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 353 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 354 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 355 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 356 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 356 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 357 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 358 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 360 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 361 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 362 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 362 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 363 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 364 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 365 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 366 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 367 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 368 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 369 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 370 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 371 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 372 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 372 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 373 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 374 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 375 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 376 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 376 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 377 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 378 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.300 uS 379 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 380 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 381 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 382 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 383 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 384 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 384 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 385 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 386 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 387 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 388 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 389 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 389 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 390 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 391 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 392 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 393 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 393 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 394 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 395 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 396 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 396 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 397 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 398 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 399 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 400 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 401 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 402 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 403 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 404 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 405 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 405 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 407 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 408 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 409 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 410 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 410 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 412 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 413 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 413 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 415 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 415 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 416 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 417 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 418 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 419 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 420 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 420 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 421 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 422 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 423 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 424 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 424 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 425 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 426 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 427 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 428 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 429 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 429 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 430 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 431 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 432 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 433 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 434 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 435 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 436 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 436 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 437 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 438 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 439 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 440 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 441 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 442 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 442 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 443 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 444 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 445 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 446 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 447 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 448 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 448 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 449 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 450 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 451 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 452 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 453 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 454 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.400 uS 455 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS 456 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS 457 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS 458 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS 458 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS 459 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS 460 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS 461 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS 462 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS 463 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS 464 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS 465 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS 465 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS 466 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS 467 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS 468 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS 469 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS 470 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS 471 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS 471 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS 472 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS 473 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS 474 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS 475 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS 477 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS 478 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS 479 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS 479 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS 480 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS 482 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS 482 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS 483 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS 485 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS 486 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS 486 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS 487 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS 489 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS 489 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS 490 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS 491 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS 492 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS 493 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS 494 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS 495 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS 496 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS 497 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS 498 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS 499 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS 499 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS 500 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS 502 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS 503 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS 504 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS 505 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS 506 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS 507 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS 508 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS 509 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS 509 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS 510 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS 511 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS 513 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS 513 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS 514 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS 516 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS 517 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS 517 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS 518 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS 519 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS 520 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS 520 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS 521 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS 522 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS 523 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS 524 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS 524 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS 525 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS 526 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS 527 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS 528 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS 529 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS 530 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS 531 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS 531 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS 532 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS 533 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS 534 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS 535 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS 535 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS 536 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS 537 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.500 uS 538 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS 539 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS 540 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS 541 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS 542 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS 542 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS 544 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS 544 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS 545 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS 546 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS 547 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS 548 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS 549 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS 550 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS 551 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS 552 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS 553 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS 554 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS 555 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS 556 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS 557 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS 558 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS 558 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS 559 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS 560 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS 561 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS 562 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS 562 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS 563 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS 564 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS 565 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS 566 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS 566 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS 567 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS 568 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS 569 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS 571 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS 571 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS 572 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS 573 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS 574 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS 575 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS 576 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS 577 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS 578 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS 579 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS 580 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS 581 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS 582 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS 582 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS 583 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS 584 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS 585 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS 585 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS 586 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS 587 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS 588 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS 589 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS 590 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS 591 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS 593 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS 594 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS 595 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS 595 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS 596 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS 597 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS 598 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS 599 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS 600 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS 602 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS 603 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS 603 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS 604 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS 605 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS 606 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.600 uS 607 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS 607 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS 608 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS 609 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS 610 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS 610 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS 611 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS 612 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS 613 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS 614 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS 615 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS 616 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS 617 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS 618 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS 619 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS 620 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS 620 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS 621 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS 623 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS 624 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS 624 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS 625 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS 626 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS 627 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS 628 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS 629 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS 630 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS 630 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS 631 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS 632 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS 633 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS 634 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS 635 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS 636 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS 637 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS 638 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS 639 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS 640 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS 640 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS 641 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS 642 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS 643 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS 644 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS 645 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS 645 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS 646 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS 647 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS 648 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS 649 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS 650 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS 651 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS 652 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS 652 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS 653 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS 654 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS 655 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS 656 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS 657 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS 658 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS 659 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS 659 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS 660 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS 661 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS 662 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS 663 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS 664 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS 665 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS 666 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS 667 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS 668 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS 668 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS 669 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS 670 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS 671 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS 671 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS 672 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS 673 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS 674 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS 675 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS 676 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS 677 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS 678 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS 679 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS 680 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS 681 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS 682 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS 683 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS 684 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS 685 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS 685 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS 687 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS 687 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS 689 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS 689 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS 690 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS 691 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.700 uS 692 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 693 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 693 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 694 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 695 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 696 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 697 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 698 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 699 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 700 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 701 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 702 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 703 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 704 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 705 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 706 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 706 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 707 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 708 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 709 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 710 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 710 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 711 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 713 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 714 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 715 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 715 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 716 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 717 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 718 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 719 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 720 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 721 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 722 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 723 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 724 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 725 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 726 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 727 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 728 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 728 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 729 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 730 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 731 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 731 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 732 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 733 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 734 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 735 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 735 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 736 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 737 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 738 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 739 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 740 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 741 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 742 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 743 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 744 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 745 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 746 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 747 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 748 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 749 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 750 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 751 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 752 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 753 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 754 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 754 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 755 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 756 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 757 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 758 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 758 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 759 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 760 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 761 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 762 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 762 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 763 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 764 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 765 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 766 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 767 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 768 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 770 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 771 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 771 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 772 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 773 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 774 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 775 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 776 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 776 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 777 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 778 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 779 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 780 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 781 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 782 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 783 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 784 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 784 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 785 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 786 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 787 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 788 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 789 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 789 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 791 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 792 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 793 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 794 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 794 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 795 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 796 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 797 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 798 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 798 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 799 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 800 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 801 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 802 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 803 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 804 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 805 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 806 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 807 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 807 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 808 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 809 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 810 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 812 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 813 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 814 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 815 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 816 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 817 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 818 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 818 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 819 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 820 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 821 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 822 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 823 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 824 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 825 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 825 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 826 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 828 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 829 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 829 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 830 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 831 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 832 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 833 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 834 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 835 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 836 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 837 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 837 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 838 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 839 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 840 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 841 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 841 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 842 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 844 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 844 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 845 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 846 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 847 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 848 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 848 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 849 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 850 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 851 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 852 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 853 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 854 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 855 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 856 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 857 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 858 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 859 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 860 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 861 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 861 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 862 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 863 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 864 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 865 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 866 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 867 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 867 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 868 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 869 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 870 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 871 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 872 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 873 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 873 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 875 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 876 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 877 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 878 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 879 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 880 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 880 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 881 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.800 uS 882 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 883 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 883 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 884 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 886 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 887 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 888 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 889 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 889 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 890 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 891 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 892 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 893 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 894 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 895 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 896 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 897 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 898 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 899 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 900 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 901 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 902 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 903 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 904 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 905 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 905 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 906 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 907 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 908 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 909 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 909 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 910 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 911 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 912 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 913 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 914 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 914 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 915 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 916 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 917 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 918 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 919 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 920 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 922 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 922 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 923 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 924 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 925 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 926 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 926 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 928 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 928 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 929 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 931 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 932 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 932 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 933 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 934 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 935 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 936 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 937 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 938 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 939 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 939 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 940 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 941 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 942 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 944 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 944 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 945 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 946 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 947 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 947 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 948 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 949 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 950 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 951 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 952 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 952 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 953 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 954 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 955 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 957 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 957 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 958 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 960 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 961 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 962 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 963 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 965 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 966 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 966 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 967 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 968 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 969 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 970 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 970 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 971 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 972 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 973 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 973 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 974 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 975 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 976 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 977 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 978 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 979 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 980 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 981 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 982 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 983 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 984 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 985 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 986 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 987 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 987 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 988 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 989 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 990 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 991 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 991 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 992 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 993 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 994 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 994 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 995 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 996 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 997 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 998 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 999 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1000 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1001 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1002 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1003 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1003 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1004 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1005 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1006 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1007 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1007 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1008 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1009 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1010 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1011 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1012 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1013 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1014 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1014 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1015 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1016 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1017 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1018 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1019 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1020 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1021 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1022 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1024 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1025 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1026 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1026 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1028 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1028 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1029 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1030 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1031 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1032 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1033 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1034 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1034 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1035 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1036 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1037 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1038 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1039 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1040 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1041 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1042 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1043 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1044 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1045 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1046 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1047 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1048 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1049 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1050 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1050 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1051 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1052 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1053 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1054 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1055 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1056 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1057 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1058 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1059 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1060 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1060 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1061 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1062 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1063 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1064 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1065 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1066 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1067 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1068 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1069 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1070 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1070 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1071 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1072 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1073 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1074 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1075 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1075 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1076 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1077 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1078 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1079 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1080 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1081 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1082 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1083 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1083 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1085 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1086 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1087 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1088 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1088 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1090 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1091 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1092 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1093 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1094 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1094 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1095 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1096 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1097 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1098 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1099 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1100 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1101 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1101 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1102 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1103 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1104 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1105 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1105 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1106 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1107 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1108 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1109 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1110 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1112 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1113 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1113 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1115 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1116 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1117 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1118 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1119 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1120 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1120 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1121 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1122 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1123 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1124 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1125 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1126 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1127 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1128 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1129 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1130 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1131 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1131 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1132 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1133 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1134 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1135 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1136 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1136 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1137 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1138 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1139 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1139 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1140 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1141 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1142 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1143 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1144 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1145 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1146 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1147 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1148 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1149 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1150 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1151 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1151 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1153 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1153 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1154 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1155 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1156 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1157 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1158 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1159 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1160 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1160 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1161 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1162 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1163 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1164 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1165 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1166 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1166 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1168 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1168 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1170 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1171 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1172 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1172 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1174 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1175 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1176 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1177 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1178 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1179 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1180 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1181 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1181 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1182 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1183 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1184 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1185 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1186 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1187 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1188 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1188 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1189 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1190 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1191 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1193 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1194 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1195 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1196 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1196 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1197 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1198 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1199 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1199 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1200 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1201 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1202 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1203 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1203 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1204 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1206 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1207 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1208 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1208 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1209 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1210 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1211 secs servo min:-999.800 uS max:9617.200 uS sdev: 9.900 uS 1212 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1213 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1213 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1214 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1215 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1216 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1217 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1218 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1218 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1219 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1220 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1221 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1222 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1222 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1223 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1224 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1225 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1225 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1226 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1227 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1228 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1229 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1230 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1231 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1232 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1232 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1234 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1235 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1236 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1238 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1238 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1239 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1240 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1241 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1242 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1243 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1243 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1244 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1245 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1246 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1246 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1247 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1248 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1249 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1250 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1251 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1252 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1253 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1254 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1255 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1256 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1256 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1257 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1258 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1259 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1260 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1260 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1262 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1262 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1263 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1264 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1265 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1266 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1267 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1267 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1268 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1269 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1270 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1271 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1272 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1273 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1274 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1274 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1275 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1276 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1278 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1278 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1280 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1281 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1283 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1283 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1284 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1285 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1286 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1287 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1287 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1288 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1289 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1290 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1291 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1291 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1292 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1293 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1294 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1296 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1297 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1298 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1299 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1300 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1301 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1302 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1302 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1304 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1305 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1305 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1306 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1307 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1308 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1309 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1310 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1311 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1312 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1313 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1314 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1315 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1316 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1316 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1318 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1319 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1320 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1320 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1322 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1323 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1323 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1324 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1325 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1326 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1327 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1328 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1329 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1329 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1330 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1331 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1332 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1333 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1333 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1334 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1335 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1336 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1337 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1338 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1339 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1340 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1341 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1342 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1343 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1343 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1344 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1345 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1346 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1347 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1348 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1349 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1350 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1350 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1351 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1352 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1353 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1354 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1355 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1356 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1356 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1357 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1358 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1359 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1360 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1361 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1362 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1363 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1363 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1364 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1365 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1366 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1367 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1368 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1369 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1370 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1370 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1371 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1372 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1373 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1374 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1374 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1375 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1376 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1377 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1378 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1379 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1380 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1381 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1382 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1383 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1384 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1384 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1385 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1386 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1387 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1388 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1388 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1389 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1390 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1391 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1392 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1392 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1393 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1394 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1395 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1396 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1398 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1398 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1399 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1401 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1402 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1403 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1404 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1405 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1405 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1406 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1407 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1408 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1408 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1409 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1410 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1411 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1412 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1413 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1414 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1415 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1416 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1416 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1418 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1419 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1419 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1420 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1421 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1422 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1423 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1424 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1425 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1426 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1426 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1427 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1428 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1429 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1430 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1430 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1432 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1433 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1433 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1434 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1435 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1436 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1438 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1438 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1440 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1440 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1441 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1442 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1443 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1444 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1445 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1446 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1447 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1448 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1449 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1449 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1450 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1451 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1452 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1453 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1453 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1454 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1455 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1456 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1457 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1458 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1459 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1460 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1461 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1461 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1462 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1463 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1464 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1465 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1466 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1467 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1468 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1469 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1470 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1471 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1472 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1473 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1473 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1474 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1475 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1476 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1477 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1477 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1479 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1479 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1480 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1481 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1482 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1483 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1484 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1485 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1485 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1486 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1488 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1489 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1489 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1490 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1491 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1492 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1492 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1493 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1494 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1495 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1496 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1496 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1497 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1498 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1499 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1500 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1500 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1501 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1502 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1503 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1504 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1505 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1507 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1507 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1509 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1510 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1510 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1511 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1512 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1513 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1513 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1514 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1515 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1516 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1517 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1517 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1519 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1519 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1520 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1521 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1522 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1523 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1523 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1524 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1525 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1526 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1527 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1529 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1529 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1530 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1532 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1532 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1533 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1534 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1535 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1536 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1537 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1538 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1538 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1539 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1540 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1541 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1542 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1543 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1544 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1545 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1546 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1547 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1549 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1550 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1551 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1552 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1552 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1553 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1554 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1555 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1556 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1557 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1557 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1558 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1559 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1560 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1561 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1561 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1563 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1564 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1564 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1566 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1567 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1568 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1569 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1570 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1571 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1572 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1574 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1575 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1575 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1576 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1577 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1578 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1578 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1579 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1580 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1581 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1582 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1582 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1583 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1584 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1585 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1586 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1587 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1588 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1589 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1589 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1591 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1592 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1593 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1594 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1594 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1595 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1596 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1597 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1598 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1599 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1599 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1600 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1601 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1602 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1603 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1603 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1604 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1605 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1606 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1607 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1607 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1608 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1609 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1610 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1611 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1612 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1614 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1615 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1615 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1616 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1617 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1618 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1619 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1619 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1620 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1621 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1622 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1623 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1624 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1625 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1625 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1626 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1627 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1628 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1629 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1630 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1631 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1632 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1633 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1634 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1635 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1636 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1637 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1638 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1639 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1640 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1641 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1642 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1643 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1643 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1644 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1645 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1646 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1647 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1648 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1649 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1650 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1651 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1652 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1653 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1654 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1655 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1655 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1656 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1657 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1658 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1659 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1660 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1661 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1662 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1662 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1663 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1665 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1665 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1666 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1667 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1668 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1669 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1670 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1671 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1672 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1673 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1674 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1675 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1675 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1676 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1677 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1678 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1679 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1679 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1680 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1681 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1682 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1682 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1683 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1684 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1685 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1686 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1686 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1687 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1688 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1689 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1690 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1691 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1692 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1692 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1693 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1694 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1695 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1696 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1697 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1698 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1699 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1699 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1700 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1701 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1702 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1703 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1704 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1705 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1706 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1707 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1707 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1708 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1709 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1710 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1711 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1711 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1713 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1713 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1714 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1715 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1716 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1717 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1718 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1719 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1721 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1722 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1722 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.000 uS 1723 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1725 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1726 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1727 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1728 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1728 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1729 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1730 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1731 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1731 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1732 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1733 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1734 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1735 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1736 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1737 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1738 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1739 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1740 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1741 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1741 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1742 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1743 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1744 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1745 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1745 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1746 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1747 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1748 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1749 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1750 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1751 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1752 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1753 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1753 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1754 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1755 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1756 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1757 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1758 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1760 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1760 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1761 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1762 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1763 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1764 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1765 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1766 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1766 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1768 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1768 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1769 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1770 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1771 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1772 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1773 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1774 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1775 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1776 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1776 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1778 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1779 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1780 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1781 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1782 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1783 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1784 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1784 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1785 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1786 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1787 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1787 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1789 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1789 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1790 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1791 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1792 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1793 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1794 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1795 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1795 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1796 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1797 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1798 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1799 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1800 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1801 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1802 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1803 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1804 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1805 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1806 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1807 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1808 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1808 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1809 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1810 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1811 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1812 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1813 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1814 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1815 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1815 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1816 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1817 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1818 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1819 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1820 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1821 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1822 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1823 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1824 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1825 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1826 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1827 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1827 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1828 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1829 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1830 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1831 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1831 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1832 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1833 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1834 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1835 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1835 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1836 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1837 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1839 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1839 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1841 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1841 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1842 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1843 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1844 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1845 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1846 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1847 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1848 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1849 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1849 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1850 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1851 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1852 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1853 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1853 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1854 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1855 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1856 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1857 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1858 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1859 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1860 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1861 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1862 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1863 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1864 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1865 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1866 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1867 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1868 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1869 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1869 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1870 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1871 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1872 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1873 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1873 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1874 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1875 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1876 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1876 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1877 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1878 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1880 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1880 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1881 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1882 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1883 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1885 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1886 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1887 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1887 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1889 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1890 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1891 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1892 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1893 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1893 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1894 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1895 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1896 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1897 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1897 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1898 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1899 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1900 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1901 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1902 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1902 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1903 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1904 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1905 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1906 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1907 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1908 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1909 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1909 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1910 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1911 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1912 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1913 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1913 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1914 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1915 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1916 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1916 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1917 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1918 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1919 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1920 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1921 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1922 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1922 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1923 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1924 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1925 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1926 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1927 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1928 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1929 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1930 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1931 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1932 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1934 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1935 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1935 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1936 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1937 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1938 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1939 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1939 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1940 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1941 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1942 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1943 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1944 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1944 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1945 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1947 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1947 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1949 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1950 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1951 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1952 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1953 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1954 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1954 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1955 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1956 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1957 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1958 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1958 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1959 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1960 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1961 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1962 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1963 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1964 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1965 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1966 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1967 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1967 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1968 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1969 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1970 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1972 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1973 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1973 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1974 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1975 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1976 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1977 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1978 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1979 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1980 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1980 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1981 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1982 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1984 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1985 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1985 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1986 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1987 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1988 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1989 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1991 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1991 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1993 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1994 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1994 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1995 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1996 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1997 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1997 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1998 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 1999 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2000 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2001 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2001 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2002 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2003 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2005 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2005 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2007 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2007 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2008 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2010 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2011 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2012 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2013 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2013 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2015 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2016 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2017 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2017 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2018 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2019 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2020 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2021 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2021 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2022 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2023 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2024 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2026 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2026 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2027 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2028 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2029 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2030 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2031 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2032 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2033 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2034 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2035 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2036 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2037 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2038 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2039 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2039 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2041 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2042 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2042 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2043 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2044 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2045 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2046 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2046 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2047 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2048 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2049 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2050 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2051 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2052 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2053 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2054 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2055 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2056 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2057 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2058 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2059 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2060 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2060 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2061 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2062 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2063 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2064 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2064 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2065 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2066 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2067 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2068 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2068 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2069 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2070 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2071 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2072 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2074 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2075 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2076 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2076 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2077 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2078 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2079 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2080 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2080 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2081 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2082 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2083 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2084 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2085 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2085 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2086 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2087 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2088 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2089 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2090 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2091 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2092 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2094 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2095 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2096 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2097 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2098 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2099 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2100 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2101 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2101 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2102 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2103 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2104 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2105 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2105 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2106 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2107 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2108 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2108 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2109 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2110 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2111 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2112 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2113 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2114 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2115 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2116 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2117 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2118 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2120 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2120 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2121 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2122 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2123 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2124 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2125 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2125 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2126 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2127 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2128 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2129 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2130 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2131 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2132 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2133 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2133 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2134 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2135 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2136 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2137 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2138 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2139 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2140 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2141 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2142 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2142 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2143 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2144 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2145 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2146 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2147 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2148 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2148 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2149 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2150 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2151 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2152 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2153 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2154 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2155 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2155 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2156 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2157 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2158 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2159 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2161 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2162 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2163 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2164 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2165 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2165 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2167 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2168 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2168 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2170 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2170 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2171 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2173 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2173 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2174 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2175 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2176 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2177 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2178 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2178 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2179 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2180 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2181 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2182 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2183 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2183 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2184 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2185 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2186 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2187 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2187 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2188 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2189 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2190 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2191 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2191 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2192 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2193 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2194 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2195 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2196 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2197 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2198 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2199 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2200 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2201 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2202 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2203 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2204 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2205 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2206 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2207 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2208 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2209 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2210 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2210 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2212 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2213 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2214 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2214 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2215 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2216 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2217 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2218 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2218 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2219 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2220 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2221 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2222 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2224 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2224 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2225 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2226 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2227 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2228 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2229 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2230 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2231 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2232 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2232 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2233 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2234 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2236 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2237 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2238 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2238 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2239 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2240 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2241 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2242 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2243 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2244 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2246 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2247 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2247 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2248 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2249 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2250 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2251 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2252 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2252 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2253 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2254 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2255 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2256 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2256 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2257 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2258 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2259 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2261 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2262 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2262 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2263 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2265 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2266 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2267 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2267 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2268 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2269 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2270 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2271 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2272 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2272 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2273 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2274 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2275 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2276 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2277 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2277 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2278 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2279 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2280 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2281 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2282 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2283 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2284 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2285 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2286 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2287 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2288 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2289 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2289 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2290 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2291 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2292 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2293 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2294 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2295 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2296 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2297 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2298 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2299 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2299 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2300 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2301 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2302 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2303 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2304 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2305 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2306 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2307 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2308 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2308 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2309 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2310 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2311 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2311 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2313 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2314 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2314 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2315 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2316 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2317 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2318 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2319 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2320 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2321 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2321 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2322 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2323 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2324 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2326 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2327 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2327 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2329 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2330 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2331 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2332 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2332 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2333 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2334 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2335 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2336 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2337 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2337 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2338 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2339 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2340 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2341 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2342 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2342 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2343 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2344 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2345 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2346 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2347 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2348 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2349 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2350 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2351 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2352 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2353 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2354 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2354 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2355 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2356 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2357 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2358 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2359 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2360 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2361 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2362 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2363 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2364 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2365 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2365 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2367 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2367 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2368 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2369 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2371 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2371 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2372 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2373 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2374 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2375 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2376 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2377 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2378 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2379 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2380 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2381 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2381 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2383 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2384 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2385 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2385 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2386 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2388 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2389 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2390 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2391 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2392 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2393 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2394 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2395 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2396 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2397 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2398 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2398 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2399 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2400 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2401 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2402 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2403 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2404 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2405 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2406 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2407 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2408 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2409 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2409 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2410 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2411 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2412 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2413 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2414 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2415 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2416 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2417 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2418 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2419 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2420 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2420 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2421 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2422 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2423 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2423 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2424 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2425 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2426 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2427 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2428 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2428 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2430 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2430 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2431 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2432 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2433 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2434 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2435 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2436 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2437 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2438 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2439 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2440 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2441 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2442 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2443 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2444 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2444 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2445 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2446 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2447 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2448 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2448 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2449 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2450 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2451 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2452 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2452 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2453 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2454 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2455 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2457 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2458 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2459 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2460 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2460 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2462 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2463 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2463 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2464 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2465 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2466 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2467 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2468 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2469 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2471 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2472 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2473 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2473 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2474 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2475 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2476 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2477 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2478 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2479 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2481 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2482 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2483 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2484 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2485 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2485 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2486 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2487 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2488 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2488 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2489 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2490 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2491 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2492 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2493 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2494 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2495 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2496 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2497 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2498 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2498 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2499 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2501 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2502 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2502 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2504 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2504 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2505 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2506 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2507 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2507 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2509 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2510 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2510 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2511 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2512 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2513 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2514 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2515 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2516 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2517 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2517 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2518 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2519 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2521 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2522 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2522 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2523 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2524 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2525 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2526 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2526 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2527 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2528 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2529 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2530 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2530 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2531 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2532 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2533 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2534 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2534 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2535 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2536 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2537 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2538 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2539 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2540 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2541 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2542 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2543 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2544 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2545 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2546 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2546 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2547 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2548 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2549 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2550 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2551 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2552 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2553 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2553 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2554 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2555 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2556 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2557 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2557 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2558 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2560 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2560 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2562 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2563 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2564 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2565 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2566 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2567 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2568 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2569 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2569 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2570 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2571 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2572 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2572 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2573 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2574 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2575 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2576 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2577 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2578 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2578 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2579 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2580 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2581 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2582 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2583 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2583 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2584 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2585 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2586 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2587 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2588 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2588 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2590 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2590 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2591 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2592 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2593 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2594 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2594 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2595 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2596 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2597 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2598 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2599 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2600 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2601 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2602 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2603 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2605 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2606 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2607 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2608 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2608 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2609 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2610 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2611 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2612 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2613 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2614 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2615 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2616 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2617 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2617 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2618 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2619 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2620 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2621 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2622 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2623 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2623 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2624 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2626 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2627 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2627 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2629 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2630 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2631 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2632 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2632 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2633 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2634 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2635 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2636 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2636 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2637 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2638 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2639 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2640 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2641 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2642 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2643 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2645 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2645 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2646 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2647 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2648 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2649 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2651 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2652 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2653 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2654 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2655 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2656 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2657 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2658 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2659 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2659 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2660 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2661 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2662 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2663 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2664 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2665 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2666 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2667 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2668 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2669 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2670 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2671 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2672 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2673 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2674 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2674 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2675 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2676 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2677 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2678 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2679 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2680 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2681 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2681 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2682 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2683 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2684 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2685 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2686 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2687 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2688 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2689 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2690 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2691 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2691 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2692 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2693 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2695 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2695 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2696 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2697 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2698 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2699 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2700 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2701 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2701 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2703 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2704 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2704 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2705 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2706 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2707 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2708 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2709 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2710 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2711 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2713 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2713 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2714 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2715 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2716 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2717 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2718 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2719 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2720 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2720 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2721 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2722 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2723 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2724 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2724 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2725 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2726 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2728 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2728 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2729 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2730 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2731 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2732 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2732 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2733 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2734 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2735 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2736 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2736 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2737 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2738 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2739 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2740 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2741 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2742 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2742 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2743 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2744 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2745 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2745 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2746 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2747 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2748 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2749 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2750 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2751 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2752 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2753 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2753 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2754 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2755 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2757 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2758 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2759 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2761 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2761 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2762 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2763 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2764 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2765 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2765 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2766 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2767 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2768 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2769 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2770 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2770 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2771 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2772 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2773 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2774 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2774 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2775 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2776 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2778 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2779 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2780 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2781 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2782 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2783 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2784 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2785 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2786 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2787 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2788 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2788 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2789 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2790 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2791 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2792 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2793 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2794 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2794 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2795 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2796 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2797 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2798 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2799 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2800 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2801 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2802 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2804 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2804 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2805 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2806 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2807 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2807 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2809 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2810 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2811 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2812 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2813 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2814 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2815 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2815 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2816 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2817 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2818 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2819 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2820 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2820 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2822 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2823 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2824 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2825 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2826 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2827 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2828 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2829 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2830 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2831 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2832 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2833 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2834 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2834 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2835 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2836 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2837 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2838 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2839 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2840 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2841 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2841 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2842 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2843 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2844 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2845 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2846 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2847 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2847 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2848 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2849 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2850 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2851 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2851 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2852 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2853 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2854 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2854 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2855 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2856 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2857 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2858 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2859 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2860 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2862 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2862 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2864 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2864 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2865 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2866 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2867 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2868 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2868 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2869 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2870 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2871 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2872 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2872 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2873 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2874 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2875 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2875 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2876 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2877 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2878 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2880 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2881 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2882 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2883 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2884 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2885 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2886 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2887 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2888 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2889 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2889 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2890 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2891 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2892 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2893 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2894 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2895 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2896 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2897 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2898 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2899 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2901 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2901 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2902 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2903 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2904 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2905 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2906 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2907 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2909 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2910 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2911 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2912 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2912 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2913 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2914 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2915 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2916 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2917 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2917 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2919 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2920 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2920 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2921 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2922 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2923 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2924 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2924 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2925 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2926 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2927 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2928 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2929 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2929 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2930 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2931 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2932 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2932 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2933 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2934 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2935 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2936 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2936 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2937 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2939 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2940 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2940 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2941 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2942 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2943 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2944 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2944 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2945 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2946 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2947 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2948 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2949 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2950 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2951 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2951 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2952 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2953 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2954 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2954 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2956 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2956 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2957 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2958 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2959 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2960 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2960 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2961 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2962 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2963 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2964 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2965 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2965 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2966 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2967 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2968 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2969 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2970 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2971 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2972 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2973 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2973 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2974 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2976 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2977 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2978 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2979 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2979 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2980 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2981 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2982 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2983 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2983 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2984 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2985 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2986 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2987 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2988 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2989 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2989 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2990 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2991 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2992 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2993 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2993 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2994 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2995 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2996 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2997 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2997 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2998 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 2999 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3000 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3001 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3002 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3003 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3003 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3004 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3006 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3007 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3007 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3009 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3010 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3010 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3011 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3012 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3013 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3014 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3015 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3015 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3016 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3017 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3018 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3019 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3020 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3021 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3022 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3023 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3024 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3024 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3026 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3027 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3027 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3028 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3030 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3031 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3032 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3033 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3034 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3035 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3036 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3036 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3037 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3038 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3039 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3040 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3040 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3041 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3042 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3043 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3044 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3045 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3046 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3047 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3048 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3049 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3049 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3051 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3051 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3052 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3053 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3054 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3055 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3056 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3056 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3057 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3058 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3059 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3060 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3061 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3061 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3062 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3063 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3064 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3065 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3066 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3067 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3068 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3069 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3070 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3070 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3072 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3072 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3073 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3075 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3076 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3077 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3077 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3078 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3079 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3080 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3081 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3081 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3082 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3083 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3084 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3085 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3085 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3086 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3087 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3088 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3089 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3090 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3090 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3092 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3092 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3094 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3095 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3096 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3096 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3097 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3098 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3099 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3100 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3100 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3101 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3102 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3103 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3104 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3105 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3106 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3106 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3107 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3108 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3109 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3110 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3111 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3111 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3113 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3113 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3114 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3116 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3117 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3117 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3118 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3120 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3120 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3121 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3122 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3123 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3124 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3125 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3126 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3126 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3127 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3128 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3129 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3130 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3131 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3132 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3133 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3134 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3135 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3135 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3137 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3138 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3139 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3139 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3140 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3141 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3142 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3143 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3143 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3144 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3145 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3146 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3147 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3147 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3148 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3149 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3150 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3151 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3152 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3153 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3154 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3155 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3156 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3157 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3159 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3160 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3160 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3162 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3163 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3164 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3164 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3166 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3167 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3167 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3168 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3169 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3170 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3171 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3172 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3173 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3174 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3174 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3175 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3176 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3177 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3179 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3180 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3181 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3181 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3182 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3183 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3184 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3185 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3185 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3186 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3187 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3188 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3189 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3189 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3190 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3191 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3192 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3193 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3194 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3194 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3195 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3196 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3197 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3198 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3199 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3200 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3200 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3201 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3203 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3204 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3205 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3206 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3206 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3207 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3208 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3209 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3210 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3211 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3212 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3213 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3214 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3215 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3215 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3216 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3217 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3219 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3219 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3220 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3222 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3223 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3223 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3224 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3225 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3226 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3227 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3228 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3229 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3229 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3230 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3231 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3232 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3233 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3234 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3235 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3235 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3236 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3237 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3238 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3239 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3240 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3241 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3243 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3244 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3245 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3245 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3247 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3247 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3248 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3249 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3250 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3251 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3252 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3252 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3253 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3254 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3255 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3256 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3257 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3257 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3258 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3259 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3260 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3261 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3262 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3263 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3264 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3265 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3266 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3267 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3268 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3268 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3269 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3271 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3271 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3272 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3273 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3274 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3275 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3275 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3276 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3277 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3278 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3279 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3279 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3280 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3281 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3282 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3283 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3284 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3285 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3286 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3287 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3288 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3289 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3289 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3290 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3291 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3292 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3293 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3293 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3295 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3295 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3296 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3297 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3298 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3299 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3300 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3300 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3301 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3303 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3304 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3305 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3305 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3306 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3308 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3308 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3309 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3310 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3311 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3312 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3313 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3314 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3315 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3315 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3316 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3317 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3318 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3319 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3320 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3321 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3322 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3323 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3324 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3325 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3326 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3327 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3328 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3329 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3330 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3330 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3331 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3332 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3333 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3334 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3334 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3335 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3336 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3337 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3338 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3339 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3339 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3340 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3341 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3342 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3343 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3344 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3345 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3346 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3347 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3349 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3350 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3351 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3351 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3352 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3353 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3354 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3355 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3356 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3357 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3357 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3358 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3359 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3360 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3361 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3362 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3363 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3363 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3365 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3366 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3367 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3368 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3369 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3370 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3371 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3372 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3372 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3373 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3374 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3375 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3376 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3377 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3377 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3378 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3379 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3380 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3381 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3382 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3383 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3384 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3385 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3386 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3387 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3388 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3389 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3390 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3391 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3392 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3393 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3393 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3394 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3395 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3397 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3397 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3398 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3399 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3400 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3400 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3401 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3402 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3403 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3404 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3405 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3406 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3408 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3408 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3410 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3411 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3412 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3413 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3414 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3415 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3415 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3416 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3417 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3418 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3419 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3420 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3421 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3422 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3423 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3424 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3425 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3426 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3427 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3428 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3428 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3429 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3430 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3431 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3432 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3433 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3434 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3435 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3435 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3436 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3437 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3439 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3440 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3441 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3441 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3442 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3443 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3444 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3445 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3445 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3446 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3447 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3448 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3449 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3450 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3451 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3452 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3453 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3454 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3455 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3456 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3457 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3458 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3458 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3460 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3461 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3461 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3462 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3463 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3464 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3465 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3465 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3466 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3467 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3468 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3469 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3470 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3471 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3472 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3472 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3474 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3475 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3476 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3477 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3477 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3478 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3479 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3480 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3481 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3482 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3482 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3484 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3485 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3487 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3488 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3489 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3489 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3490 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3492 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3493 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3494 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3495 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3496 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3497 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3497 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3498 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3499 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3500 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3500 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3501 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3502 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3503 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3504 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3504 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3505 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3506 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3507 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3508 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3509 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3510 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3511 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3512 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3513 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3514 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3516 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3517 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3517 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3518 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3519 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3520 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3521 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3521 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3522 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3523 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3524 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3524 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3525 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3527 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3527 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3528 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3529 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3530 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 3531 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3532 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3533 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3534 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3535 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3536 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3537 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3538 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3539 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3539 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3540 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3541 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3542 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3543 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3544 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3545 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3546 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3546 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3547 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3548 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3549 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3550 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3551 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3552 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3553 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3554 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3554 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3555 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3556 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3557 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3558 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3559 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3560 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3561 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3562 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3563 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3563 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3564 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3565 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3566 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3567 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3567 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3568 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3569 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3570 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3571 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3572 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3572 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3573 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3574 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3576 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3576 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3577 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3578 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3579 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3580 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3581 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3582 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3583 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3584 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3585 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3586 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3587 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3587 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3588 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3589 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3590 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3591 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3592 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3593 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3594 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3595 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3596 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3597 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3598 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3599 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3600 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3601 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3601 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3602 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3603 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3604 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3605 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3606 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3607 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3607 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3608 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3609 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3610 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3610 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3611 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3612 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3613 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3615 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3616 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3616 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3617 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3618 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3619 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3620 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3621 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3621 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3623 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3624 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3624 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3625 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3626 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3627 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3628 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3628 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3629 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3630 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3631 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3632 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3633 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3634 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3634 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3635 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3636 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3637 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3638 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3639 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3640 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3641 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3642 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3643 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3643 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3644 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3645 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3646 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3647 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3648 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3649 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3649 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3650 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3651 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3652 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3653 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3654 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3655 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3655 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3656 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3657 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3658 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3659 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3659 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3660 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3661 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3663 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3664 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3664 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3665 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3666 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3667 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3668 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3669 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3669 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3670 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3671 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3672 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3673 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3673 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3675 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3676 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3677 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3678 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3679 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3681 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3682 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3684 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3685 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3686 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3687 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3687 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3688 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3689 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3690 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3691 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3691 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3692 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3693 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3694 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3695 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3696 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3696 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3697 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3698 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3700 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3701 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3702 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3703 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3703 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3705 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3706 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3706 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3707 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3708 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3709 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3710 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3710 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3711 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3712 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3713 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3714 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3715 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3715 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3716 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3717 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3718 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3719 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3720 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3721 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3722 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3722 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3723 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3724 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3725 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3726 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3727 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3728 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3728 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3729 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3730 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3731 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3731 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3732 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3733 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3734 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3735 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3736 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3737 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3738 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3740 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3740 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3741 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3743 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3743 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3745 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3746 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3747 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3748 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3749 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3749 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3750 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3751 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3752 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3753 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3754 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3755 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3756 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3756 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3757 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3758 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3759 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3760 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3761 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3762 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3763 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3765 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3765 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3766 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3767 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3769 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3770 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3771 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3771 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3772 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3773 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3774 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3775 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3775 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3776 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3777 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3778 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3779 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3779 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3780 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3782 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3782 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3783 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3784 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3785 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3786 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3787 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3788 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3789 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3790 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3791 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3792 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3793 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3793 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3794 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3795 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3796 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3797 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3797 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3798 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3799 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3800 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3802 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3803 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3803 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3804 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3805 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3806 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3807 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3808 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3809 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3810 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3812 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3812 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3813 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3814 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3815 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3816 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3817 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3818 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3818 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3819 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3820 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3821 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3822 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3822 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3824 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3824 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3826 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3826 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3828 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3829 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3830 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3831 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3832 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3832 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3833 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3834 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3835 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3836 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3836 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3837 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3838 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3839 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3840 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3840 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3841 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3842 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3843 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3844 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3844 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3845 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3846 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3847 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3848 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3849 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3849 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3850 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3851 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3852 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3853 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3854 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3854 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3856 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3856 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3857 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3858 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3859 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3860 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3860 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3861 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3862 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3863 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3864 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3864 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3865 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3866 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3867 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3868 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3869 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3870 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3871 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3872 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3873 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3874 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3875 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3875 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3876 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3877 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3878 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3879 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3880 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3881 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3882 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3883 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3884 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3884 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3886 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3887 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3887 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3888 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3889 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3890 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3891 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3892 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3892 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3893 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3894 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3896 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3896 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3897 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3898 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3899 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3900 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3901 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3901 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3902 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3903 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3904 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3905 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3906 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3907 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3908 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3909 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3910 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3911 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3911 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3912 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3914 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3915 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3916 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3917 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3918 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3918 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3919 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3920 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3921 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3922 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3922 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3923 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3924 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3925 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3926 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3926 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3927 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3928 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3929 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3930 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3931 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3931 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3932 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3933 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3934 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3935 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3936 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3938 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3938 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3939 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3940 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3941 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3942 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3943 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3943 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3945 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3946 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3947 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3948 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3949 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3949 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3950 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3952 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3953 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3953 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3955 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3955 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3956 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3958 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3958 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3959 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3960 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3961 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3962 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3963 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3964 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3965 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3966 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3967 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3968 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3969 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3970 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3971 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3971 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3972 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3973 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3975 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3976 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3977 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3978 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3979 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3979 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3980 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3981 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3982 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3983 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3983 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3985 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3985 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3986 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3987 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3988 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3989 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3990 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3991 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3992 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3993 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3994 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3994 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3995 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3996 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3997 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3998 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 3999 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4000 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4001 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4001 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4002 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4003 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4005 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4005 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4006 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4007 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4008 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4009 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4009 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4010 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4011 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4012 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4013 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4014 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4014 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4016 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4016 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4018 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4018 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4019 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4020 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4021 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4022 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4023 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4024 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4024 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4025 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4026 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4027 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4028 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4028 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4029 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4030 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4031 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4032 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4033 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4034 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4035 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4036 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4038 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4039 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4040 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4041 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4042 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4043 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4044 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4044 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4046 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4046 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4048 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4048 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4049 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4050 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4051 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4052 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4053 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4053 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4054 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4055 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4056 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4057 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4058 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4058 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4059 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4060 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4061 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4062 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4064 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4064 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4065 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4066 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4067 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4068 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4069 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4070 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4071 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4072 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4073 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4074 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4075 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4076 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4077 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4078 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4079 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4081 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4082 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4083 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4084 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4085 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4085 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4086 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4087 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4088 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4089 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4090 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4091 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4092 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4093 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4094 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4094 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4095 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4096 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4097 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4098 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4099 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4099 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4100 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4101 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4102 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4103 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4104 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4104 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4105 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4106 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4107 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4108 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4109 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4110 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4111 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4112 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4113 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4114 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4114 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4115 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4116 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4117 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4118 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4119 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4120 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4121 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4122 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4123 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4124 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4125 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4125 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4127 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4127 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4128 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4129 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4130 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4131 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4132 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4133 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4133 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4134 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4135 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4136 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4137 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4138 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4139 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4140 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4140 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4141 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4143 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4143 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4145 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4146 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4147 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4148 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4149 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4149 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4150 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4151 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4152 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4153 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4153 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4155 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4155 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4156 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4158 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4158 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4159 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4160 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4161 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4163 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4163 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4165 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4166 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4166 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4167 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4168 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4169 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4170 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4171 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4171 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4172 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4173 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4174 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4174 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4175 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4176 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4177 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4178 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4178 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4179 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4180 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4181 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4182 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4182 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4183 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4185 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4186 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4188 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4189 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4190 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4190 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4191 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4192 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4193 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4193 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4194 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4195 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4196 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4197 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4197 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4198 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4199 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4200 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4201 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4202 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4202 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4203 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4205 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4206 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4207 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4208 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4209 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4210 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4211 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4211 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4212 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4213 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4214 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4215 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4216 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4217 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4217 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4218 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4219 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4220 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4221 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4221 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4223 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4223 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4224 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4225 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4227 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4227 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4228 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4229 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4230 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4231 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4232 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4232 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4233 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4234 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4235 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4236 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4236 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4237 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4238 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4239 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4240 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4241 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4241 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4242 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4243 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4244 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4245 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4246 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4248 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4248 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4250 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4250 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4252 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4253 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4255 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4256 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4257 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4258 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4259 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4260 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4262 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4262 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4263 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4264 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4265 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4266 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4266 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4267 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4269 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4270 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4270 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4272 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4272 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4274 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4275 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4276 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4277 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4278 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4279 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4279 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4280 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4281 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4282 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4283 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4284 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4285 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4285 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4286 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4287 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4288 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4289 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4290 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4290 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4291 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4292 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4294 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4295 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4296 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4297 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4298 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4299 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4300 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4301 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4302 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4303 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4304 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4305 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4306 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4306 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4307 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4308 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4309 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4310 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4312 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4312 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4313 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4314 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4315 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4316 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4317 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4318 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4319 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4320 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4321 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4322 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4322 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4323 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4324 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4325 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4325 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4326 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4327 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4328 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4329 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4330 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4331 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4332 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4334 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4334 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4335 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4336 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4337 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4338 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4339 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4339 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4340 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4341 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4342 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4343 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4343 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4344 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4345 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4346 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4347 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4347 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4348 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4349 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4350 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4351 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4352 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4353 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4353 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4354 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4355 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4356 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4357 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4358 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4359 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4359 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4360 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4361 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4362 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4363 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4364 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4365 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4366 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4367 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4368 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4368 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4369 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4370 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4371 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4372 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4373 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4374 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4375 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4376 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4377 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4378 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4380 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4380 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4382 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4382 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4383 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4384 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4385 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4386 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4386 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4387 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4388 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4389 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4390 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4391 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4392 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4392 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4394 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4395 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4396 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4397 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4397 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4398 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4399 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4401 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4401 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4403 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4404 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4405 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4406 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4406 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4407 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4408 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4409 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4410 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4411 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4412 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4413 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4413 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4414 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4415 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4416 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4417 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4418 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4419 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4420 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4420 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4421 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4422 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4423 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4424 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4425 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4427 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4428 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4429 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4429 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4430 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4431 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4432 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4433 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4434 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4435 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4436 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4437 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4438 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4439 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4440 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4441 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4443 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4443 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4444 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4445 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4446 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4447 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4448 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4448 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4449 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4450 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4451 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4451 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4453 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4453 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4454 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4455 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4456 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4456 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4457 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4458 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4460 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4461 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4462 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4463 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4464 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4465 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4465 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4466 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4467 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4468 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4469 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4469 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4470 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4471 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4472 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4473 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4473 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4474 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4475 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4476 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4477 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4478 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4479 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4480 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4481 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4482 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4483 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4485 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4486 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4487 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4488 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4489 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4490 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4490 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4492 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4492 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4493 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4494 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4495 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4496 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4497 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4498 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4499 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4500 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4500 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4501 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4502 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4503 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4504 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4505 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4505 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4506 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4507 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4508 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4509 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4510 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4510 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4512 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4513 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4514 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4515 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4516 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4517 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4518 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4519 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4520 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4522 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4522 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4523 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4524 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4525 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4526 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4527 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4528 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4529 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4529 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4530 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4531 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4532 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4533 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4534 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4534 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4535 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4536 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4537 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4538 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4539 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4539 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4540 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4541 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4542 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4543 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4544 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4545 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4546 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4547 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4548 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4549 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4550 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4551 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4552 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4553 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4554 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4555 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4556 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4556 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4557 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4558 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4559 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4560 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4561 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4561 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4562 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4563 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4564 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4565 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4565 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4566 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4567 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4569 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4570 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4571 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4572 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4573 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4574 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4575 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4576 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4577 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4578 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4579 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4579 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4580 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4582 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4582 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4583 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4584 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4585 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4586 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4587 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4588 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4589 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4590 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4591 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4591 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4592 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4593 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4595 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4596 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4596 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4597 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4598 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4599 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4600 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4601 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4601 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4602 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4603 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4604 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4605 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4605 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4606 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4607 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4608 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4609 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4611 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4611 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4612 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4613 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4615 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4616 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4616 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4618 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4618 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4619 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4620 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4621 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4621 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4622 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4623 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4624 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4625 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4626 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4627 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4628 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4629 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4629 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4630 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4632 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4632 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4634 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4634 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4635 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4637 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4638 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4638 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4639 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4640 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4641 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4642 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4642 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4643 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4644 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4645 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4645 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4646 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4648 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4648 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4649 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4650 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4651 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4653 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4654 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4655 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4656 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4657 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4657 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4658 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4659 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4660 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4661 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4661 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4662 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4663 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4664 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4665 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4666 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4667 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4669 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4669 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4671 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4672 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4672 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4673 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4674 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4675 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4676 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4677 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4678 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4679 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4680 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4680 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4681 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4682 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4683 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4684 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4685 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4686 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4686 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4687 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4688 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4689 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4690 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4690 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4691 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4692 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4693 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4694 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4696 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4696 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4697 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4698 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4700 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4700 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4701 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4702 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4703 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4703 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4704 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4705 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4706 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4707 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4708 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4709 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4710 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4711 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4712 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4713 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4713 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4714 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4716 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4717 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4718 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4719 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4719 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4720 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4721 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4722 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4723 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4724 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4725 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4726 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4727 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4728 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4728 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4729 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4730 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4731 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4732 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4732 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4733 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4734 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4735 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4736 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4737 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4737 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4738 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4739 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4741 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4742 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4743 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4744 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4745 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4746 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4747 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4748 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4749 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4750 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4751 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4752 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4753 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4754 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4755 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4756 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4757 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4758 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4759 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4760 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4761 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4762 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4764 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4765 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4765 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4767 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4768 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4768 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4769 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4770 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4771 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4772 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4773 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4773 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4774 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4775 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4776 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4777 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4778 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4780 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4781 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4781 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4782 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4783 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4785 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4786 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4787 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4787 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4788 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4790 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4790 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4791 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4793 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4793 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4794 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4795 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4796 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4797 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4798 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4799 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4800 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4801 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4802 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4803 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4804 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4805 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4806 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4807 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4809 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4810 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4811 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4811 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4812 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4813 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4814 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4815 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4816 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4817 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4818 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4819 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4820 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4821 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4822 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4822 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4823 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4824 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4825 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4827 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4828 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4829 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4830 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4830 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4832 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4833 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4833 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4834 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4835 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4836 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4837 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4837 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4838 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4839 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4840 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4841 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4842 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4843 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4844 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4844 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4845 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4846 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4847 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4848 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4849 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4849 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4850 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4851 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4852 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4853 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4854 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4855 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4856 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4857 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4858 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4859 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4860 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4861 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4862 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4863 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4864 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4865 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4866 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4866 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4867 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4869 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4869 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4870 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4872 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4872 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4873 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4874 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4875 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4876 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4877 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4877 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4878 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4879 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4880 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4881 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4882 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4883 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4884 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4886 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4886 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4888 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4889 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4890 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4891 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4892 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4893 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4894 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4895 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4896 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4897 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4898 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4899 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4901 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4901 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4902 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4903 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4904 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4905 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4906 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4907 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4908 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4908 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4909 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4910 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4911 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4912 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4913 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4914 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4915 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4916 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4917 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4918 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4918 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4919 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4920 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4921 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4922 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4922 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4923 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4924 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4925 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4926 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4927 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4928 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4929 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4930 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4931 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4932 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4933 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4934 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4935 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4936 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4937 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4938 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4939 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4939 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4940 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4941 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4942 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4942 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4943 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4944 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4945 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4946 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4947 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4948 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4948 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4949 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4950 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4951 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4952 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4954 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4954 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4955 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4956 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4957 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4958 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4959 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4960 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4961 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4961 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4962 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4963 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4964 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4965 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4965 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4966 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4967 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4968 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4969 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4970 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4971 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4971 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4972 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4973 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4974 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4975 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4976 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4977 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4979 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4979 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4980 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4981 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4982 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4982 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4983 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4984 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4985 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4986 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4986 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4987 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4988 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4989 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4990 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4990 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4991 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4992 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4993 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4994 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4995 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4997 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4998 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 4998 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5000 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5001 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5002 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5002 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5003 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5004 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5005 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5005 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5006 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5007 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5008 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5009 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5009 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5010 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5011 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5012 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5013 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5013 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5014 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5016 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5017 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5017 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5018 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5019 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5020 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5021 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5021 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5022 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5023 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5024 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5025 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5026 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5027 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5027 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5028 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5029 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5030 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5031 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5031 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5032 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5033 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5034 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5035 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5035 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5036 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5038 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5038 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5040 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5041 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5042 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5042 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5043 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5044 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5045 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5045 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5047 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5047 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5048 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5049 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5050 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5051 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5052 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5053 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5054 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5055 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5056 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5056 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5057 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5058 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5059 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5060 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5061 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5062 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5062 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5063 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5065 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5065 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5066 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5067 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5068 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5069 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5070 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5070 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5071 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5072 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5073 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5074 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5075 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5077 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5077 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5078 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5080 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5080 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5081 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5082 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5083 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5084 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5085 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5086 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5086 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5087 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5088 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5089 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5090 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5090 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5091 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5092 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5093 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5094 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5094 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5095 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5096 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5097 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5098 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5099 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5099 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5100 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5101 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5102 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5103 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5104 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5105 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5106 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5107 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5108 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5108 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5110 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5110 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5111 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5112 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5113 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5113 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5114 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5115 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5116 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5117 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5117 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5118 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5119 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5120 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5121 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5122 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5122 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5123 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5124 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5125 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5126 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5127 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5127 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5128 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5129 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5130 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5131 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5131 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5132 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5133 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5134 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5134 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5135 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5136 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5137 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5138 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5139 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5140 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5141 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5141 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5142 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5144 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5144 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5146 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5147 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5148 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5149 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5149 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5150 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5151 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5152 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5153 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5154 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5155 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5155 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5156 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5157 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5158 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5159 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5159 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5161 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5162 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5163 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5164 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5164 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5165 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5166 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5167 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5168 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5169 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5170 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5170 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5171 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5172 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5173 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5174 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5174 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5175 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5176 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5177 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5178 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5179 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5179 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5180 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5181 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5182 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5183 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5184 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5185 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5186 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5187 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5188 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5189 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5189 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5190 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5191 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5192 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5193 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5195 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5195 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5196 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5197 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5198 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5199 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5200 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5201 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5202 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5203 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5203 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5204 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5206 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5206 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5207 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5208 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5210 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5210 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5211 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5212 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5213 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5214 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5214 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5215 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5216 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5217 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5218 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5218 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5219 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5220 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5221 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5222 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5222 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5223 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5224 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5226 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5227 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5228 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5229 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5230 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5231 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5232 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5233 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5233 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5234 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5235 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5236 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5237 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5238 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5239 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5240 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5240 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5241 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5242 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5243 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5244 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5245 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5245 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5246 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5247 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5248 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5249 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5250 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5251 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5252 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5253 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5254 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5254 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5256 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5256 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5257 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5258 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5259 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5260 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5261 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5262 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5263 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5264 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5265 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5266 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5267 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5268 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5269 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5269 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5270 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5272 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5272 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5273 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5274 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5275 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5276 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5277 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5278 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5279 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5279 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5280 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5281 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5282 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5284 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5285 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5286 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5287 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5287 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5288 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5290 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5290 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5291 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5293 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5293 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5294 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5295 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5296 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5297 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5297 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5298 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5299 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5300 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5301 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5302 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5302 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5303 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5304 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5305 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5306 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5306 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5307 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5308 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5310 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5310 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5311 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5312 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5313 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5314 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5315 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5316 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5318 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5319 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5319 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5320 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5321 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5322 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5323 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5323 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5324 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5325 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5326 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5328 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5329 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5329 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5331 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5332 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5333 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5333 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5334 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5336 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5336 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5337 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5338 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5339 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5340 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5341 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5342 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5343 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5344 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5345 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5346 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5346 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5347 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5348 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5349 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5350 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5351 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5352 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5353 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5354 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5355 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5356 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5357 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5358 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5359 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5360 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5361 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5362 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5363 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5364 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5364 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5365 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5366 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5367 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5367 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5369 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5369 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5370 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5371 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5372 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5374 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5374 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5375 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5376 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5377 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5378 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5379 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5379 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5380 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5381 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5382 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5383 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5384 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5384 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5385 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5386 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5387 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5388 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5389 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5389 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5390 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5391 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5392 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5393 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5394 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5395 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5396 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5397 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5397 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5398 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5399 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5400 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5401 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5402 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5403 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5404 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5405 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5406 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5407 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5407 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5408 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5409 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5410 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5411 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5412 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5412 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5413 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5415 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5415 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5416 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5417 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5418 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5419 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5419 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5420 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5421 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5423 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5423 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5424 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5425 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5426 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5426 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5427 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5428 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5429 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5430 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5431 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5432 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5433 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5434 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5435 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5436 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5437 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5437 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5438 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5439 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5440 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5441 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5442 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5442 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5443 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5444 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5445 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5446 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5447 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5447 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5448 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5449 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5450 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5451 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5451 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5452 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5453 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5454 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5455 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5455 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5456 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5457 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5458 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5459 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5459 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5460 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5461 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5462 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5463 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5464 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5465 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5466 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5466 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5467 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5468 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5469 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5470 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5470 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5471 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5472 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5473 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5474 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5475 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5475 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5476 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5478 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5478 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5479 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5480 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5481 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5482 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5483 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5484 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5484 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5485 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5486 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5487 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5488 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5489 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5490 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5491 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5491 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5492 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5493 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5494 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5495 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5496 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5497 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5498 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5499 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5500 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5500 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5501 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5502 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5503 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5504 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5504 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5505 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5506 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5507 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5508 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5508 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5509 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5510 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5511 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5512 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5513 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5514 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5515 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5516 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5517 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5518 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5519 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5520 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5521 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5522 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5522 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5523 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5524 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5526 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5526 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5527 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5528 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5529 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5530 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5531 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5532 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5532 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5533 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5534 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5535 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5536 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5537 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5538 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5538 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5539 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5540 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5541 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5542 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5542 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5543 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5544 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5545 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5546 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5546 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5548 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5549 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5550 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5551 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5552 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5553 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5554 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5554 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5555 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5556 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5557 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5557 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5558 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5559 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5560 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5561 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5563 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5564 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5564 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5565 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5566 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5568 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5569 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5570 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5571 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5572 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5573 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5574 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5574 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5575 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5576 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5577 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5578 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5578 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5579 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5580 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5581 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5582 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5583 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5584 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5585 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5585 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5586 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5587 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5589 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5590 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5591 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5592 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5593 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5593 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5594 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5595 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5596 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5597 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5597 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5598 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5599 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5600 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5601 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5602 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5602 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5603 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5604 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5605 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5606 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5607 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5608 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5609 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5610 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5611 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5612 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5613 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5614 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5615 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5615 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5616 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5617 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5618 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5618 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5620 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5621 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5622 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5623 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5623 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5625 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5626 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5627 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5628 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5629 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5630 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5630 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5631 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5632 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5633 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5634 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5635 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5635 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5636 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5638 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5638 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5639 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5640 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5641 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5641 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5642 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5643 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5644 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5645 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5646 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5647 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5648 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5649 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5650 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5651 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5652 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5653 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5654 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5655 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5656 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5656 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5657 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5658 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5659 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5659 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5660 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5661 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5662 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5663 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5664 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5665 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5666 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5667 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5667 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5668 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5669 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5670 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5671 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5671 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5672 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5674 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5675 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5675 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5677 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5678 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5678 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5679 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5680 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5681 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5682 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5683 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5684 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5685 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5685 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5686 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5687 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5688 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5689 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5690 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5691 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5692 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5693 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5695 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5696 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5696 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5698 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5699 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5699 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5700 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5701 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5702 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5703 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5704 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5705 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5705 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5706 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5707 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5708 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5709 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5710 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5711 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5712 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5712 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5714 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5715 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5715 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5717 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5718 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5720 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5720 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5721 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5722 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5723 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5723 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5725 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5726 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5726 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5727 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5728 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5729 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5730 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5730 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5731 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5732 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5733 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5734 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5734 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5735 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5736 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5737 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5738 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5739 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5740 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5741 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5742 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5743 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5743 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5744 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5745 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5746 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5747 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5747 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5748 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5749 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5750 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5751 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5751 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5752 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5753 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5754 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5755 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5756 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5757 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5758 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5759 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5760 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5761 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5761 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5762 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5763 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5764 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5765 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5765 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5766 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5767 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5768 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5769 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5769 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5770 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5771 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5773 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5774 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5775 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5775 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5776 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5778 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5778 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5780 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5781 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5782 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5783 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5784 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5784 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5785 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5786 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5787 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5788 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5788 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5789 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5790 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5791 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5791 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5792 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5793 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5794 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5795 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5796 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5796 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5797 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5798 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5799 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5800 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5801 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5802 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5803 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5804 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5805 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5806 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5807 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5808 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5809 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5810 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5810 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5811 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5812 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5813 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5814 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5815 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5816 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5817 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5818 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5819 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5820 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5821 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5822 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5823 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5823 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5825 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5825 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5826 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5827 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5828 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5829 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5830 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5830 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5831 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5832 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5833 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5834 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5835 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5836 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5837 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5838 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5839 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5840 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5840 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5841 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5842 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5843 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5844 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5845 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5846 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5846 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5847 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5848 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5849 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5850 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5852 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5853 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5853 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5854 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5855 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5856 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5857 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5858 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5858 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5859 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5860 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5861 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5862 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5862 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5863 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5864 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5865 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5867 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5868 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5869 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5870 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5871 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5871 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5872 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5873 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5874 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5874 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5875 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5876 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5877 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5878 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5879 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5879 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5880 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5881 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5882 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5883 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5884 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5885 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5886 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5887 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5888 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5888 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5889 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5890 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5891 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5892 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5893 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5894 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5895 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5895 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5896 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5897 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5898 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5898 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5899 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5900 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5901 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5902 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5902 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5904 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5905 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5906 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5906 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5907 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5908 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5909 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5910 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5911 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5912 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5913 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5914 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5915 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5916 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5917 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5918 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5918 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5920 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5921 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5921 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5922 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5923 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5924 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5925 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5925 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5926 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5927 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5928 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5929 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5930 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5931 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5932 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5933 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5934 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5934 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5936 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5937 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5937 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5938 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5940 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5940 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5942 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5942 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5943 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5944 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5945 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5946 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5947 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5947 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5948 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5949 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5950 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5951 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5952 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5953 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5954 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5954 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5956 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5956 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5957 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5958 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5959 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5960 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5961 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5962 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5963 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5963 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5964 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5965 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5966 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5967 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5968 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5969 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5970 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5971 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5972 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5973 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5974 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5975 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5976 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5976 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5978 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5979 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5980 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5980 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5981 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5982 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5983 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5984 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5985 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5986 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5986 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5987 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5988 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5989 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5990 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5991 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5991 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5992 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5994 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5994 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5995 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5996 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5997 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5998 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 5999 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6000 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6000 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6001 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6002 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6003 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6004 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6005 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6006 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6006 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6007 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6008 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6009 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6010 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6011 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6012 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6013 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6014 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6015 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6016 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6017 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6018 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6018 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6020 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6020 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6021 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6022 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6023 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6023 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6024 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6025 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6026 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6027 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6028 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6028 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6029 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6030 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6031 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6032 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6032 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6033 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6034 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6036 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6037 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6038 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6039 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6040 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6041 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6041 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6042 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6043 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6044 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6045 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6045 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6046 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6047 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6048 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6049 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6050 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6051 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6052 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6052 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6053 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6054 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6055 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6056 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6057 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6058 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6059 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6059 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6060 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6061 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6062 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6063 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6064 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6065 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6066 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6067 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6067 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6068 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6069 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6070 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6071 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6071 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6073 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6074 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6074 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6075 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6076 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6077 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6078 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6079 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6080 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6081 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6082 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6083 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6083 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6084 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6085 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6086 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6087 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6088 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6089 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6089 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6090 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6091 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6092 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6092 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6093 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6094 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6095 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6096 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6096 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6097 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6098 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6099 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6100 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6101 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6102 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6102 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6103 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6105 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6105 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6106 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6107 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6108 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6109 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6109 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6110 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6111 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6112 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6113 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6113 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6114 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6115 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6116 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6117 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6118 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6119 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6120 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6121 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6122 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6123 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6124 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6125 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6125 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6126 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6127 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6128 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6128 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6130 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6131 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.200 uS 6131 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6132 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6133 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6134 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6134 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6135 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6136 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6137 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6138 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6138 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6139 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6141 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6142 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6143 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6144 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6145 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6146 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6147 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6148 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6148 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6149 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6150 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6151 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6152 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6153 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6153 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6154 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6155 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6156 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6157 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6158 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6158 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6159 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6160 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6161 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6162 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6163 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6163 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6164 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6165 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6166 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6167 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6168 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6170 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6170 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6172 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6172 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6173 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6174 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6175 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6176 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6176 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6177 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6178 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6179 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6180 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6180 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6181 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6182 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6183 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6184 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6185 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6186 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6187 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6189 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6189 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6190 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6192 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6192 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6193 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6194 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6195 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6196 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6197 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6197 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6198 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6199 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6200 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6201 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6201 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6202 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6204 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6205 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6206 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6207 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6208 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6209 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6211 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6212 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6213 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6214 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6215 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6215 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6216 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6217 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6218 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6219 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6219 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6220 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6221 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6222 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6223 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6224 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6225 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6226 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6227 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6228 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6228 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6229 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6230 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6231 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6232 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6233 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6234 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6235 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6236 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6237 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6238 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6239 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6239 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6241 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6242 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6243 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6244 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6245 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6246 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6247 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6248 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6249 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6249 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6250 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6252 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6252 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6253 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6254 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6255 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6256 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6256 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6257 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6258 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6259 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6259 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6261 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6261 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6262 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6263 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6264 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6265 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6265 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6266 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6267 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6268 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6269 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6269 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6270 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6271 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6272 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6273 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6274 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6275 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6275 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6276 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6277 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6279 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6280 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6280 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6281 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6282 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6283 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6283 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6284 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6285 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6286 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6287 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6287 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6289 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6289 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6290 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6291 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6292 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6292 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6294 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6295 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6296 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6297 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6298 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6299 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6300 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6301 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6301 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6302 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6303 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6304 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6305 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6306 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6307 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6307 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6308 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6309 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6310 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6311 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6311 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6312 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6313 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6314 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6315 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6316 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6317 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6318 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6319 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6320 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6321 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6322 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6323 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6324 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6325 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6326 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6327 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6327 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6328 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6329 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6330 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6331 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6332 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6333 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6333 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6334 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6335 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6336 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6337 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6338 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6338 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6339 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6340 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6341 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6342 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6343 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6344 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6345 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6345 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6346 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6347 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6348 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6349 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6350 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6351 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6352 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6353 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6354 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6355 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6355 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6357 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6358 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6359 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6360 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6361 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6361 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6362 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6363 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6364 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6365 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6366 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6367 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6368 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6369 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6370 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6370 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6371 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6373 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6373 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6374 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6375 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6376 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6377 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6378 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6378 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6379 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6380 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6381 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6382 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6383 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6384 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6384 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6385 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6386 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6387 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6388 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6389 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6390 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6390 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6391 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6392 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6393 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6394 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6394 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6395 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6396 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6397 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6398 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6399 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6400 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6401 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6402 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6403 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6404 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6406 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6406 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6408 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6408 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6410 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6410 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6411 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6412 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6413 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6414 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6414 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6415 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6416 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6417 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6418 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6418 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6419 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6420 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6421 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6422 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6422 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6423 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6424 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6426 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6427 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6428 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6429 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6429 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6431 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6432 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6432 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6433 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6434 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6436 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6436 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6438 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6439 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6439 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6440 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6441 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6442 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6442 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6443 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6444 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6445 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6447 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6447 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6448 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6449 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6450 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6452 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6453 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6453 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6454 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6455 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6456 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6456 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6457 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6458 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6459 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6460 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6461 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6462 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6463 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6464 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6464 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6465 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6466 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6467 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6468 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6469 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6470 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6471 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6472 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6473 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6473 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6475 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6475 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6476 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6477 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6478 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6479 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6480 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6481 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6481 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6482 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6483 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6484 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6485 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6485 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6486 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6488 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6489 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6490 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6490 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6491 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6492 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6493 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6494 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6494 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6495 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6496 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6497 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6497 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6498 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6500 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6500 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6501 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6502 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6503 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6504 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6504 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6505 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6506 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6507 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6509 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6510 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6510 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6511 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6512 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6513 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6514 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6515 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6515 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6516 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6517 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6518 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6518 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6519 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6520 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6521 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6522 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6523 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6523 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6524 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6525 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6526 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6527 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6527 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6528 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6529 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6530 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6531 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6532 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6533 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6534 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6535 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6536 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6536 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6537 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6538 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6539 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6540 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6541 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6542 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6543 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6544 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6545 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6546 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6547 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6548 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6549 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6550 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6551 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6551 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6552 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6553 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6555 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6555 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6556 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6557 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6558 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6559 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6559 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6560 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6561 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6562 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6563 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6563 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6564 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6565 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6566 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6567 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6567 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6568 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6569 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6570 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6571 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6571 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6572 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6573 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6574 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6575 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6576 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6576 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6578 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6579 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6580 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6581 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6582 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6583 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6584 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6584 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6585 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6586 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6587 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6587 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6588 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6589 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6590 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6591 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6592 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6594 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6595 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6596 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6597 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6598 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6599 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6600 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6601 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6601 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6602 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6603 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6604 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6605 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6605 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6606 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6607 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6608 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6608 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6609 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6610 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6611 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6612 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6613 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6614 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6615 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6616 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6617 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6618 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6619 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6620 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6621 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6622 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6623 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6623 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6624 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6625 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6626 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6627 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6627 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6628 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6629 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6630 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6631 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6632 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6633 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6633 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6634 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6635 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6636 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6637 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6638 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6638 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6639 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6640 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6641 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6642 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6643 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6644 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6645 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6646 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6647 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6647 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6648 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6649 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6650 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6651 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6651 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6652 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6653 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6654 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6655 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6656 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6657 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6657 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6659 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6660 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6661 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6663 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6664 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6665 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6665 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6666 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6667 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6668 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6669 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6670 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6671 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6672 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6673 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6674 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6675 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6675 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6676 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6677 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6678 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6678 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6679 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6680 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6681 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6682 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6683 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6683 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6684 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6685 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6686 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6687 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6688 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6689 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6690 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6691 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6691 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6692 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6694 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6694 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6695 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6696 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6697 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6698 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6699 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6700 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6700 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6701 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6702 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6703 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6704 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6706 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6707 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6708 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6709 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6710 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6711 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6712 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6712 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6713 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6714 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6715 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6716 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6717 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6717 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6718 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6719 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6720 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6721 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6722 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6722 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6723 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6724 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6725 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6726 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6727 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6728 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6729 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6730 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6731 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6731 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6732 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6733 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6734 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6734 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6736 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6736 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6737 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6738 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6739 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6740 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6740 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6741 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6742 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6743 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6744 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6744 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6745 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6746 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6747 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6748 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6748 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6749 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6750 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6751 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6752 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6753 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6754 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6754 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6755 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6756 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6757 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6758 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6758 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6759 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6760 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6761 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6762 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6763 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6764 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6764 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6765 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6766 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6767 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6768 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6769 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6770 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6771 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6772 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6773 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6774 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6775 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6775 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6777 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6777 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6778 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6779 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6780 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6781 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6782 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6783 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6784 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6785 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6786 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6786 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6787 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6789 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6790 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6790 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6792 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6792 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6793 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6794 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6795 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6796 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6796 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6797 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6798 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6799 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6799 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6800 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6801 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6802 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6803 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6804 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6805 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6806 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6806 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6807 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6808 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6809 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6810 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6811 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6812 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6813 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6814 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6815 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6815 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6816 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6817 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6818 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6819 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6820 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6821 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6821 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6822 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6823 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6824 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6826 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6826 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6827 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6828 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6829 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6830 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6831 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6831 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6832 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6833 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6834 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6835 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6836 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6837 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6838 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6838 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6839 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6840 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6841 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6841 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6842 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6843 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6844 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6845 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6846 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6847 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6847 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6848 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6849 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6850 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6851 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6852 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6853 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6854 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6855 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6855 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6857 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6858 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6858 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6859 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6860 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6861 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6862 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6863 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6864 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6864 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6865 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6866 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6867 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6868 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6869 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6870 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6871 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6872 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6873 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6874 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6875 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6876 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6877 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6877 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6878 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6879 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6880 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6881 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6881 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6882 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6883 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6884 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6885 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6886 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6887 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6888 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6889 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6890 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6891 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6891 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6892 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6894 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6894 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6895 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6896 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6897 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6898 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6899 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6900 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6901 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6901 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6902 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6903 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6904 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6905 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6905 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6906 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6907 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6908 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6909 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6910 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6911 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6912 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6912 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6913 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6914 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6915 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6916 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6917 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6918 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6920 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6921 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6922 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6923 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6923 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6924 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6925 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6926 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6927 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6927 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6928 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6929 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6930 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6930 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6932 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6933 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6933 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6934 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6936 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6936 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6937 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6938 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6939 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6940 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6941 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6942 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6943 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6943 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6944 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6945 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6946 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6947 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6947 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6948 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6949 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6950 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6951 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6951 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6952 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6953 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6954 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6955 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6956 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6957 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6958 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6958 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6959 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6960 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6961 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6962 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6962 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6963 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6964 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6965 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6966 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6967 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6967 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6968 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6969 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6970 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6971 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6972 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6973 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6973 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6975 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6975 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6977 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6978 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6979 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6980 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6980 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6981 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6983 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6984 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6984 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6985 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6986 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6987 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6988 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6988 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6989 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6990 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6991 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6991 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6992 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6993 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6994 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6995 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6996 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6996 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6997 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6999 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 6999 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7001 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7001 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7002 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7004 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7005 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7005 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7006 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7007 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7008 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7009 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7010 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7011 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7012 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7012 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7013 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7014 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7015 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7016 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7016 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7017 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7018 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7019 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7020 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7021 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7022 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7023 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7024 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7025 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7026 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7027 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7028 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7029 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7029 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7030 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7031 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7032 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7033 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7033 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7034 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7035 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7036 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7037 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7038 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7038 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7039 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7040 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7041 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7042 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7043 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7043 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7044 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7045 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7046 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7047 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7047 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7048 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7049 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7050 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7051 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7051 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7052 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7053 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7054 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7055 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7056 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7056 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7057 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7058 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7059 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7060 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7061 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7062 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7063 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7064 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7065 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7066 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7067 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7068 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7068 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7069 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7070 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7071 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7071 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7072 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7073 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7074 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7075 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7075 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7077 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7078 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7078 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7079 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7080 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7081 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7082 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7083 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7083 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7085 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7085 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7086 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7088 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7089 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7089 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7090 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7091 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7092 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7093 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7093 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7094 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7095 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7096 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7097 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7098 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7098 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7100 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7100 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7101 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7103 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7104 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7104 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7105 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7106 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7107 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7108 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7108 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7109 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7110 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7111 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7112 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7112 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7114 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7114 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7115 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7116 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7117 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7118 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7119 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7119 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7120 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7121 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7122 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7123 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7124 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7124 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7125 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7126 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7127 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7128 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7129 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7130 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7131 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7131 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7132 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7133 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7134 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7135 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7135 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7136 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7138 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7139 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7140 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7141 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7142 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7143 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7143 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7144 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7145 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7146 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7147 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7148 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7149 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7151 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7151 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7152 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7153 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7154 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7154 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7155 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7156 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7157 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7158 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7158 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7159 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7160 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7161 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7162 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7163 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7164 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7165 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7166 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7166 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7167 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7168 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7169 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7170 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7171 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7172 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7172 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7173 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7174 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7175 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7176 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7176 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7177 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7178 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7179 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7180 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7181 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7182 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7183 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7183 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7184 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7185 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7186 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7187 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7188 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7189 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7189 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7190 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7192 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7192 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7193 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7194 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7195 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7196 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7197 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7198 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7198 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7199 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7200 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7201 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS 7202 secs servo min:-999.800 uS max:9617.200 uS sdev: 10.100 uS
with Linux Mint 19.3 XFCE it's not suitable for Linuxcnc ( huge understatment )
Next- Debian Buster and see how it does with that.
Last edit: 6 years 19 hours ago by my1987toyota.
  • BeagleBrainz
  • New Member
  • New Member
6 years 19 hours ago #187965 by BeagleBrainz
Did you notice you aren't running a RT kernel ?
You just booted into a "generic" kernel ?
Hence the reason the latency is unusable.
6 years 19 hours ago #187966 by my1987toyota
BeagleBrainz wrote: Did you notice you aren't running a RT kernel ?
interesting I must have missed something.
I thought you either had RTAI or Preempt-RT
6 years 19 hours ago #187968 by seuchato
I'll add a check on RT or RTAI kernels to prevent this.
The following user(s) said Thank You: my1987toyota
  • BeagleBrainz
  • New Member
  • New Member
6 years 19 hours ago #187969 by BeagleBrainz
Hahahahaha I just suggested that in the original script thread.
If you are using my install ISO and update the kernel the default kernel will be the one that has just been installed.
6 years 18 hours ago #187971 by seuchato
Time to create page: 0.204 seconds
