LinuxCNC pc tests, version 20200930, started 29.11.2020 00:04:11
General info:
Gigabyte Technology Co., Ltd., X570 AORUS ELITE
Bios version F11, dated 12/06/2019
Chipset: Harddisk is non-rotational, ie. SSD
The amount of swap currently used is 0
CPU related data:
model name : AMD Ryzen 5 3500X 6-Core Processor
cpu cores : 6
stepping : 0
cache size : 512 KB
RAM related data:
Maximum Capacity: 128 GB
Maximum Voltage: 1.2 V
Non-Volatile Size: None
Volatile Size: 4 GB
Cache Size: None
Logical Size: None
Volatile Size: 4 GB
Cache Size: None
Logical Size: None
Volatile Size: 4 GB
Cache Size: None
Logical Size: None
Volatile Size: 4 GB
Cache Size: None
Logical Size: None
GPU related data:
product: Ellesmere [Radeon RX 470/480/570/570X/580/580X/590]
configuration: driver=amdgpu latency=0
Parallel port related data:
number of parallel ports is 0
Os and desktop related data:
PRETTY_NAME="Linux Mint 20"
Should the info below not match with your machine,
kindly post the output of pstree here, including a brief
desciption of your desktop environment, window manager and
display manager. Tia
https://forum.linuxcnc.org/18-computer/39370-script-for-automated-testing-of-computer-latency
Desktop environment : gnome
Windowmanager : Metacity (Marco)
Displaymanager : lightdm
Kernel related data:
Kernel 4.9.0-13-rt-amd64
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash"
Cpu idle driver: acpi_idle
Kernel modules data:
Check if pcspkr is loaded: [0;32mNo, which is good![0m
Check if snd modules are loaded: [0;31mYes, may cause bigger latency.[0m
can probably be disabled in bios, alternatively, you can run
"./block-snd-modules"
which has just now been created for your convenience.
Keyboard & Mouse related data:
Number of mice: 1
Mouse 0 : Razer Razer DeathAdder
Mice attached to USB:
Razer USA, Ltd DeathAdder Mouse
Keyboards attached to USB:
Dell Computer Corp. Multimedia Pro Keyboard
Dell Computer Corp. Multimedia Pro Keyboard Hub
LinuxCNC related data:
LinuxCNC version is: 2.9.0~pre0.3030.g742c3e294
Preparing for latency test:
Started glxgears No. 1, 2, 3, 4, 5
Started firefox with 'https://vimeo.com/150574260', WID 60819820
Command for latency test is:
su cnc -c "latency-histogram --nobase --sbinsize 1000 --nox 2>&1 | tee -a 1606604595.lat &"
Latency testing loop started Sun 29 Nov 2020 12:04:24 AM CET,
should end after Sun 29 Nov 2020 12:06:24 AM CET
Swap useage: prerun: 0, running: 0
CPU core temperatures:
124 secs servo min: -17.600 uS max: 15.900 uS sdev: 1.600 uS
125 secs servo min: -17.600 uS max: 15.900 uS sdev: 1.600 uS
