Results of latency test, list of computers tested for use with LinuxCNC
5 years 10 months ago - 5 years 10 months ago #190871 by seuchato
rootboy
rootboy wrote: ...
Using the script, it ran but left out a few minor details (the latency results)
Most likely the very directory you started the script in is owned by root. do
cd .. chown {user} {dirname} cd {dirname} sudo ./lcnc-hw
then it should write latency data
greez
chris
Last edit: 5 years 10 months ago by seuchato. Reason: typo
5 years 10 months ago - 5 years 10 months ago #191033 by Clive S
Would this be ok for the p/port
LinuxCNC pc tests, version 20200930, started 04.12.2020 12:25:05 ******************************************************************************** General info: Dell Inc., OptiPlex 780 Bios version A08, dated 01/21/2011 Chipset: Intel Corporation 4 Series Harddisk is rotational The amount of swap currently used is 0 ================================================================================ CPU related data: model name : Intel(R) Core(TM)2 Duo CPU E8400 @ 3.00GHz cpu cores : 1 stepping : 10 cache size : 6144 KB ================================================================================ RAM related data: Maximum Capacity: 8 GB Size: No Module Installed Size: 2048 MB Size: No Module Installed Size: No Module Installed ================================================================================ GPU related data: product: 4 Series Chipset Integrated Graphics Controller product: 4 Series Chipset Integrated Graphics Controller configuration: driver=i915 latency=0 configuration: latency=0 ================================================================================ Parallel port related data: number of parallel ports is 1 parport0: PC-style at 0x378 (0x778), irq 7, using FIFO [PCSPP,TRISTATE,COMPAT,EPP,ECP] ================================================================================ Os and desktop related data: PRETTY_NAME="Linux Mint 19.3" Should the info below not match with your machine, kindly post the output of pstree here, including a brief desciption of your desktop environment, window manager and display manager. Tia https://forum.linuxcnc.org/18-computer/39370-script-for-automated-testing-of-computer-latency Desktop environment : lightdm Windowmanager : Xfwm4 Displaymanager : lightdm ================================================================================ Kernel related data: Kernel 4.19.106-rt44-lcnc GRUB_CMDLINE_LINUX_DEFAULT="quiet splash" Cpu idle driver: none ================================================================================ Kernel modules data: Check if pcspkr is loaded: No, which is good! Check if snd modules are loaded: No, which is good! ================================================================================ Keyboard & Mouse related data: Number of mice: 1 Mouse 0 : SEMICCHIP Usb Mouse Mice attached to USB: Keyboards attached to USB: ================================================================================ LinuxCNC related data: LinuxCNC version is: 2.8.1.1.g5d082d148 ================================================================================ Preparing for latency test: Started glxgears No. 1, 2, 3, 4, 5 .......... Started firefox with 'https://vimeo.com/150574260', WID ================================================================================ Command for latency test is: su cnc -c "latency-histogram --bbinsize 1000 --base 100000 --sbinsize 1000 --nox 2>&1 | tee -a 1607084674.lat &" Latency testing loop started Fri 4 Dec 12:25:20 GMT 2020, should end after Fri 4 Dec 14:25:20 GMT 2020 ================================================================================ Swap useage: prerun: 0, running: 0 ================================================================================ CPU core temperatures: Core 0: Tmin: 30.0°C, Tmax: 30.0°C, (high = +76.0°C, crit = +100.0°C) ================================================================================ last latency data is as follows:. 7202 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 7202 secs servo min: -37.800 uS max: 35.500 uS sdev: 1.600 uS
Shall I leave the below in:-
Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) Note: Using POSIX realtime 7 secs base min: -12.700 uS max: 12.900 uS sdev: 4.500 uS 7 secs servo min: -19.500 uS max: 18.000 uS sdev: 3.300 uS 8 secs base min: -17.000 uS max: 15.900 uS sdev: 4.500 uS 8 secs servo min: -19.500 uS max: 18.000 uS sdev: 2.200 uS 10 secs base min: -17.500 uS max: 18.400 uS sdev: 4.500 uS 10 secs servo min: -20.700 uS max: 19.100 uS sdev: 2.000 uS 11 secs base min: -17.500 uS max: 18.400 uS sdev: 4.500 uS 11 secs servo min: -21.400 uS max: 21.900 uS sdev: 2.100 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 12 secs base min: -18.700 uS max: 19.400 uS sdev: 4.500 uS 12 secs servo min: -21.400 uS max: 21.900 uS sdev: 2.100 uS 14 secs base min: -18.700 uS max: 19.700 uS sdev: 4.500 uS 14 secs servo min: -21.400 uS max: 21.900 uS sdev: 2.200 uS 15 secs base min: -18.700 uS max: 19.700 uS sdev: 4.500 uS 15 secs servo min: -21.400 uS max: 21.900 uS sdev: 2.200 uS 16 secs base min: -18.700 uS max: 19.700 uS sdev: 4.500 uS 16 secs servo min: -21.400 uS max: 21.900 uS sdev: 2.200 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 18 secs base min: -18.700 uS max: 19.700 uS sdev: 4.500 uS 18 secs servo min: -21.400 uS max: 21.900 uS sdev: 2.200 uS 19 secs base min: -18.700 uS max: 19.700 uS sdev: 4.500 uS 19 secs servo min: -21.400 uS max: 21.900 uS sdev: 2.200 uS 20 secs base min: -18.700 uS max: 19.700 uS sdev: 4.500 uS 20 secs servo min: -21.400 uS max: 21.900 uS sdev: 2.200 uS 22 secs base min: -18.700 uS max: 19.700 uS sdev: 4.500 uS 22 secs servo min: -21.400 uS max: 21.900 uS sdev: 2.200 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 23 secs base min: -18.700 uS max: 19.700 uS sdev: 4.500 uS 23 secs servo min: -21.400 uS max: 21.900 uS sdev: 2.200 uS 24 secs base min: -18.700 uS max: 19.700 uS sdev: 4.500 uS 24 secs servo min: -21.400 uS max: 21.900 uS sdev: 2.100 uS 26 secs base min: -18.700 uS max: 19.700 uS sdev: 4.600 uS 26 secs servo min: -21.400 uS max: 21.900 uS sdev: 2.100 uS 27 secs base min: -18.700 uS max: 19.700 uS sdev: 4.600 uS 27 secs servo min: -22.600 uS max: 22.500 uS sdev: 2.100 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 28 secs base min: -18.700 uS max: 19.700 uS sdev: 4.600 uS 28 secs servo min: -22.600 uS max: 22.500 uS sdev: 2.000 uS 30 secs base min: -18.700 uS max: 19.700 uS sdev: 4.600 uS 30 secs servo min: -22.600 uS max: 22.500 uS sdev: 2.000 uS 31 secs base min: -18.700 uS max: 19.700 uS sdev: 4.600 uS 31 secs servo min: -22.600 uS max: 22.500 uS sdev: 2.000 uS 33 secs base min: -18.700 uS max: 19.700 uS sdev: 4.600 uS 33 secs servo min: -22.600 uS max: 22.500 uS sdev: 2.000 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 34 secs base min: -18.700 uS max: 19.700 uS sdev: 4.600 uS 34 secs servo min: -22.600 uS max: 22.500 uS sdev: 2.000 uS 35 secs base min: -18.700 uS max: 19.700 uS sdev: 4.600 uS 35 secs servo min: -22.600 uS max: 22.500 uS sdev: 2.000 uS 37 secs base min: -18.700 uS max: 19.700 uS sdev: 4.600 uS 37 secs servo min: -22.600 uS max: 22.500 uS sdev: 2.000 uS 38 secs base min: -18.700 uS max: 19.700 uS sdev: 4.600 uS 38 secs servo min: -22.600 uS max: 22.500 uS sdev: 2.000 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 39 secs base min: -18.700 uS max: 19.700 uS sdev: 4.600 uS 39 secs servo min: -22.600 uS max: 22.500 uS sdev: 2.000 uS 41 secs base min: -18.700 uS max: 19.700 uS sdev: 4.600 uS 41 secs servo min: -22.600 uS max: 22.500 uS sdev: 2.100 uS 42 secs base min: -18.700 uS max: 19.700 uS sdev: 4.600 uS 42 secs servo min: -22.600 uS max: 22.500 uS sdev: 2.000 uS 43 secs base min: -18.700 uS max: 19.700 uS sdev: 4.600 uS 43 secs servo min: -22.600 uS max: 22.500 uS sdev: 2.100 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 45 secs base min: -18.700 uS max: 19.700 uS sdev: 4.600 uS 45 secs servo min: -22.600 uS max: 22.500 uS sdev: 2.000 uS 46 secs base min: -18.700 uS max: 19.700 uS sdev: 4.600 uS 46 secs servo min: -22.600 uS max: 22.500 uS sdev: 2.000 uS 47 secs base min: -18.700 uS max: 19.700 uS sdev: 4.700 uS 47 secs servo min: -22.600 uS max: 22.500 uS sdev: 2.000 uS 49 secs base min: -18.700 uS max: 19.700 uS sdev: 4.700 uS 49 secs servo min: -22.600 uS max: 22.500 uS sdev: 2.000 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 50 secs base min: -18.700 uS max: 19.700 uS sdev: 4.700 uS 50 secs servo min: -22.600 uS max: 22.500 uS sdev: 2.000 uS 51 secs base min: -18.700 uS max: 19.700 uS sdev: 4.700 uS 51 secs servo min: -22.600 uS max: 22.500 uS sdev: 2.000 uS 53 secs base min: -18.700 uS max: 19.700 uS sdev: 4.700 uS 53 secs servo min: -22.600 uS max: 22.500 uS sdev: 2.000 uS 54 secs base min: -18.700 uS max: 19.700 uS sdev: 4.700 uS 54 secs servo min: -22.600 uS max: 22.500 uS sdev: 2.000 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 55 secs base min: -18.700 uS max: 19.700 uS sdev: 4.700 uS 55 secs servo min: -22.600 uS max: 22.500 uS sdev: 2.000 uS 57 secs base min: -18.700 uS max: 19.700 uS sdev: 4.700 uS 57 secs servo min: -22.600 uS max: 22.500 uS sdev: 1.900 uS 58 secs base min: -18.700 uS max: 19.700 uS sdev: 4.700 uS 58 secs servo min: -22.600 uS max: 22.500 uS sdev: 1.900 uS 59 secs base min: -18.700 uS max: 19.700 uS sdev: 4.700 uS 59 secs servo min: -22.600 uS max: 22.500 uS sdev: 1.900 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 61 secs base min: -18.700 uS max: 19.700 uS sdev: 4.700 uS 61 secs servo min: -22.600 uS max: 22.500 uS sdev: 1.900 uS 62 secs base min: -18.700 uS max: 19.700 uS sdev: 4.700 uS 62 secs servo min: -22.600 uS max: 22.500 uS sdev: 1.900 uS 64 secs base min: -18.700 uS max: 19.700 uS sdev: 4.700 uS 64 secs servo min: -22.600 uS max: 22.500 uS sdev: 1.900 uS 65 secs base min: -18.700 uS max: 19.700 uS sdev: 4.700 uS 65 secs servo min: -22.600 uS max: 22.500 uS sdev: 1.900 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 66 secs base min: -18.700 uS max: 19.700 uS sdev: 4.700 uS 66 secs servo min: -22.600 uS max: 22.500 uS sdev: 1.900 uS 68 secs base min: -18.700 uS max: 19.700 uS sdev: 4.700 uS 68 secs servo min: -22.600 uS max: 22.500 uS sdev: 1.900 uS 69 secs base min: -18.700 uS max: 19.700 uS sdev: 4.700 uS 69 secs servo min: -22.600 uS max: 22.500 uS sdev: 1.900 uS 70 secs base min: -18.700 uS max: 19.700 uS sdev: 4.700 uS 70 secs servo min: -22.600 uS max: 22.500 uS sdev: 1.900 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 72 secs base min: -18.700 uS max: 19.700 uS sdev: 4.700 uS 72 secs servo min: -22.600 uS max: 22.500 uS sdev: 1.900 uS 73 secs base min: -18.700 uS max: 19.700 uS sdev: 4.700 uS 73 secs servo min: -22.600 uS max: 22.500 uS sdev: 1.900 uS 74 secs base min: -18.700 uS max: 19.700 uS sdev: 4.700 uS 74 secs servo min: -22.600 uS max: 22.500 uS sdev: 1.900 uS 76 secs base min: -18.700 uS max: 19.700 uS sdev: 4.700 uS 76 secs servo min: -22.600 uS max: 22.500 uS sdev: 1.900 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 77 secs base min: -18.700 uS max: 19.700 uS sdev: 4.700 uS 77 secs servo min: -22.600 uS max: 22.500 uS sdev: 1.800 uS 78 secs base min: -18.700 uS max: 19.700 uS sdev: 4.700 uS 78 secs servo min: -22.600 uS max: 22.500 uS sdev: 1.800 uS 80 secs base min: -18.700 uS max: 19.700 uS sdev: 4.700 uS 80 secs servo min: -22.600 uS max: 22.500 uS sdev: 1.800 uS 81 secs base min: -18.700 uS max: 19.700 uS sdev: 4.700 uS 81 secs servo min: -22.600 uS max: 22.500 uS sdev: 1.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 82 secs base min: -18.700 uS max: 19.700 uS sdev: 4.700 uS 82 secs servo min: -22.600 uS max: 22.500 uS sdev: 1.800 uS 84 secs base min: -18.700 uS max: 19.700 uS sdev: 4.700 uS 84 secs servo min: -22.600 uS max: 22.500 uS sdev: 1.800 uS 85 secs base min: -18.700 uS max: 19.700 uS sdev: 4.700 uS 85 secs servo min: -22.600 uS max: 22.500 uS sdev: 1.800 uS 87 secs base min: -18.700 uS max: 19.700 uS sdev: 4.700 uS 87 secs servo min: -22.600 uS max: 22.500 uS sdev: 1.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 88 secs base min: -18.700 uS max: 19.700 uS sdev: 4.700 uS 88 secs servo min: -22.600 uS max: 22.500 uS sdev: 1.800 uS 89 secs base min: -18.700 uS max: 19.700 uS sdev: 4.700 uS 89 secs servo min: -22.600 uS max: 22.500 uS sdev: 1.800 uS 91 secs base min: -18.700 uS max: 19.700 uS sdev: 4.700 uS 91 secs servo min: -22.600 uS max: 22.500 uS sdev: 1.800 uS 92 secs base min: -18.700 uS max: 19.700 uS sdev: 4.700 uS 92 secs servo min: -22.600 uS max: 22.500 uS sdev: 1.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 93 secs base min: -18.700 uS max: 19.700 uS sdev: 4.700 uS 93 secs servo min: -22.600 uS max: 22.500 uS sdev: 1.800 uS 95 secs base min: -18.700 uS max: 19.700 uS sdev: 4.700 uS 95 secs servo min: -22.600 uS max: 22.500 uS sdev: 1.800 uS 96 secs base min: -18.700 uS max: 19.700 uS sdev: 4.700 uS 96 secs servo min: -22.600 uS max: 22.500 uS sdev: 1.800 uS 97 secs base min: -18.700 uS max: 19.700 uS sdev: 4.700 uS 97 secs servo min: -22.600 uS max: 22.500 uS sdev: 1.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 99 secs base min: -18.700 uS max: 19.700 uS sdev: 4.700 uS 99 secs servo min: -22.600 uS max: 22.500 uS sdev: 1.800 uS 100 secs base min: -18.700 uS max: 19.700 uS sdev: 4.700 uS 100 secs servo min: -22.600 uS max: 22.500 uS sdev: 1.800 uS 101 secs base min: -18.700 uS max: 19.700 uS sdev: 4.700 uS 101 secs servo min: -22.600 uS max: 22.500 uS sdev: 1.800 uS 103 secs base min: -20.000 uS max: 19.700 uS sdev: 4.700 uS 103 secs servo min: -22.600 uS max: 22.500 uS sdev: 1.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 104 secs base min: -20.000 uS max: 19.700 uS sdev: 4.700 uS 104 secs servo min: -22.600 uS max: 22.500 uS sdev: 1.800 uS 105 secs base min: -20.000 uS max: 19.700 uS sdev: 4.700 uS 105 secs servo min: -22.600 uS max: 22.500 uS sdev: 1.700 uS 107 secs base min: -20.000 uS max: 19.700 uS sdev: 4.700 uS 107 secs servo min: -22.600 uS max: 22.500 uS sdev: 1.700 uS 108 secs base min: -20.000 uS max: 19.700 uS sdev: 4.700 uS 108 secs servo min: -22.600 uS max: 22.500 uS sdev: 1.700 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 110 secs base min: -20.000 uS max: 19.700 uS sdev: 4.700 uS 110 secs servo min: -22.600 uS max: 22.500 uS sdev: 1.700 uS 111 secs base min: -20.000 uS max: 19.700 uS sdev: 4.700 uS 111 secs servo min: -22.600 uS max: 22.500 uS sdev: 1.700 uS 112 secs base min: -20.000 uS max: 19.700 uS sdev: 4.700 uS 112 secs servo min: -22.600 uS max: 22.500 uS sdev: 1.700 uS 114 secs base min: -20.000 uS max: 19.700 uS sdev: 4.700 uS 114 secs servo min: -22.600 uS max: 22.500 uS sdev: 1.700 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 115 secs base min: -20.000 uS max: 19.700 uS sdev: 4.700 uS 115 secs servo min: -22.600 uS max: 22.500 uS sdev: 1.700 uS 116 secs base min: -20.000 uS max: 19.700 uS sdev: 4.700 uS 116 secs servo min: -22.600 uS max: 22.500 uS sdev: 1.700 uS 118 secs base min: -20.000 uS max: 19.700 uS sdev: 4.700 uS 118 secs servo min: -22.600 uS max: 22.500 uS sdev: 1.700 uS 119 secs base min: -20.000 uS max: 20.500 uS sdev: 4.700 uS 119 secs servo min: -22.600 uS max: 22.500 uS sdev: 1.700 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 120 secs base min: -20.000 uS max: 20.500 uS sdev: 4.700 uS 120 secs servo min: -22.600 uS max: 22.500 uS sdev: 1.700 uS 122 secs base min: -20.000 uS max: 20.500 uS sdev: 4.700 uS 122 secs servo min: -22.600 uS max: 22.500 uS sdev: 1.700 uS 123 secs base min: -20.000 uS max: 20.500 uS sdev: 4.700 uS 123 secs servo min: -22.600 uS max: 22.500 uS sdev: 1.700 uS 124 secs base min: -20.000 uS max: 20.500 uS sdev: 4.700 uS 124 secs servo min: -22.600 uS max: 22.500 uS sdev: 1.700 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 126 secs base min: -20.000 uS max: 20.500 uS sdev: 4.700 uS 126 secs servo min: -22.600 uS max: 22.500 uS sdev: 1.700 uS 127 secs base min: -20.000 uS max: 20.500 uS sdev: 4.800 uS 127 secs servo min: -22.600 uS max: 22.500 uS sdev: 1.700 uS 128 secs base min: -20.000 uS max: 20.500 uS sdev: 4.800 uS 128 secs servo min: -22.600 uS max: 22.500 uS sdev: 1.700 uS 130 secs base min: -20.000 uS max: 20.500 uS sdev: 4.800 uS 130 secs servo min: -22.600 uS max: 22.500 uS sdev: 1.700 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 131 secs base min: -20.000 uS max: 20.500 uS sdev: 4.800 uS 131 secs servo min: -22.600 uS max: 22.500 uS sdev: 1.700 uS 132 secs base min: -20.000 uS max: 20.500 uS sdev: 4.800 uS 132 secs servo min: -22.600 uS max: 22.500 uS sdev: 1.700 uS 134 secs base min: -20.000 uS max: 20.500 uS sdev: 4.800 uS 134 secs servo min: -22.600 uS max: 22.500 uS sdev: 1.700 uS 135 secs base min: -20.000 uS max: 20.500 uS sdev: 4.800 uS 135 secs servo min: -22.600 uS max: 22.500 uS sdev: 1.700 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 137 secs base min: -20.000 uS max: 20.500 uS sdev: 4.800 uS 137 secs servo min: -22.600 uS max: 22.500 uS sdev: 1.700 uS 138 secs base min: -20.000 uS max: 20.500 uS sdev: 4.800 uS 138 secs servo min: -22.600 uS max: 22.500 uS sdev: 1.700 uS 139 secs base min: -20.000 uS max: 20.500 uS sdev: 4.800 uS 139 secs servo min: -22.600 uS max: 22.500 uS sdev: 1.700 uS 141 secs base min: -20.000 uS max: 20.500 uS sdev: 4.800 uS 141 secs servo min: -22.600 uS max: 22.500 uS sdev: 1.700 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 142 secs base min: -20.000 uS max: 20.500 uS sdev: 4.800 uS 142 secs servo min: -22.600 uS max: 22.500 uS sdev: 1.700 uS 143 secs base min: -20.000 uS max: 20.500 uS sdev: 4.800 uS 143 secs servo min: -22.600 uS max: 22.500 uS sdev: 1.700 uS 145 secs base min: -20.000 uS max: 20.500 uS sdev: 4.800 uS 145 secs servo min: -22.600 uS max: 22.500 uS sdev: 1.700 uS 146 secs base min: -20.000 uS max: 20.500 uS sdev: 4.800 uS 146 secs servo min: -22.600 uS max: 22.500 uS sdev: 1.700 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 147 secs base min: -20.000 uS max: 20.500 uS sdev: 4.800 uS 147 secs servo min: -22.600 uS max: 22.500 uS sdev: 1.700 uS 149 secs base min: -20.000 uS max: 20.500 uS sdev: 4.800 uS 149 secs servo min: -22.600 uS max: 22.500 uS sdev: 1.700 uS 150 secs base min: -20.000 uS max: 20.500 uS sdev: 4.800 uS 150 secs servo min: -22.600 uS max: 22.500 uS sdev: 1.700 uS 151 secs base min: -20.000 uS max: 20.500 uS sdev: 4.800 uS 151 secs servo min: -22.600 uS max: 22.500 uS sdev: 1.700 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 153 secs base min: -20.000 uS max: 20.500 uS sdev: 4.800 uS 153 secs servo min: -22.600 uS max: 22.500 uS sdev: 1.700 uS 154 secs base min: -20.000 uS max: 20.500 uS sdev: 4.800 uS 154 secs servo min: -22.600 uS max: 22.500 uS sdev: 1.700 uS 155 secs base min: -20.000 uS max: 20.500 uS sdev: 4.800 uS 155 secs servo min: -22.600 uS max: 22.500 uS sdev: 1.700 uS 157 secs base min: -20.000 uS max: 20.500 uS sdev: 4.800 uS 157 secs servo min: -22.600 uS max: 22.500 uS sdev: 1.700 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 158 secs base min: -20.000 uS max: 20.500 uS sdev: 4.800 uS 158 secs servo min: -22.600 uS max: 22.500 uS sdev: 1.700 uS 159 secs base min: -20.000 uS max: 20.500 uS sdev: 4.800 uS 159 secs servo min: -22.600 uS max: 22.500 uS sdev: 1.700 uS 161 secs base min: -20.000 uS max: 20.500 uS sdev: 4.800 uS 161 secs servo min: -22.600 uS max: 22.500 uS sdev: 1.700 uS 162 secs base min: -20.000 uS max: 20.500 uS sdev: 4.800 uS 162 secs servo min: -22.600 uS max: 22.500 uS sdev: 1.700 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 164 secs base min: -20.000 uS max: 20.500 uS sdev: 4.800 uS 164 secs servo min: -22.600 uS max: 22.500 uS sdev: 1.700 uS 165 secs base min: -20.000 uS max: 20.500 uS sdev: 4.800 uS 165 secs servo min: -22.600 uS max: 22.500 uS sdev: 1.700 uS 166 secs base min: -20.000 uS max: 20.500 uS sdev: 4.800 uS 166 secs servo min: -22.600 uS max: 22.500 uS sdev: 1.700 uS 168 secs base min: -20.000 uS max: 20.500 uS sdev: 4.800 uS 168 secs servo min: -22.600 uS max: 22.500 uS sdev: 1.700 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 169 secs base min: -20.000 uS max: 20.500 uS sdev: 4.800 uS 169 secs servo min: -22.600 uS max: 22.500 uS sdev: 1.700 uS 170 secs base min: -20.000 uS max: 20.500 uS sdev: 4.800 uS 170 secs servo min: -22.600 uS max: 22.500 uS sdev: 1.700 uS 172 secs base min: -20.000 uS max: 20.500 uS sdev: 4.800 uS 172 secs servo min: -23.700 uS max: 24.000 uS sdev: 1.700 uS 173 secs base min: -20.000 uS max: 20.500 uS sdev: 4.800 uS 173 secs servo min: -23.700 uS max: 24.000 uS sdev: 1.700 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 174 secs base min: -20.000 uS max: 20.500 uS sdev: 4.800 uS 174 secs servo min: -23.700 uS max: 24.000 uS sdev: 1.700 uS 176 secs base min: -20.000 uS max: 20.500 uS sdev: 4.800 uS 176 secs servo min: -23.700 uS max: 24.000 uS sdev: 1.700 uS 177 secs base min: -20.000 uS max: 20.500 uS sdev: 4.800 uS 177 secs servo min: -23.700 uS max: 24.000 uS sdev: 1.700 uS 178 secs base min: -20.000 uS max: 20.500 uS sdev: 4.800 uS 178 secs servo min: -23.700 uS max: 24.000 uS sdev: 1.700 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 180 secs base min: -20.000 uS max: 20.500 uS sdev: 4.800 uS 180 secs servo min: -23.700 uS max: 24.000 uS sdev: 1.700 uS 181 secs base min: -20.000 uS max: 20.500 uS sdev: 4.800 uS 181 secs servo min: -23.700 uS max: 24.000 uS sdev: 1.700 uS 182 secs base min: -20.000 uS max: 20.500 uS sdev: 4.800 uS 182 secs servo min: -23.700 uS max: 24.000 uS sdev: 1.700 uS 184 secs base min: -20.000 uS max: 20.500 uS sdev: 4.800 uS 184 secs servo min: -23.700 uS max: 24.000 uS sdev: 1.700 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 185 secs base min: -20.000 uS max: 20.500 uS sdev: 4.800 uS 185 secs servo min: -23.700 uS max: 24.000 uS sdev: 1.700 uS 186 secs base min: -20.000 uS max: 20.500 uS sdev: 4.800 uS 186 secs servo min: -23.700 uS max: 24.000 uS sdev: 1.700 uS 188 secs base min: -20.000 uS max: 20.500 uS sdev: 4.800 uS 188 secs servo min: -23.700 uS max: 24.000 uS sdev: 1.700 uS 189 secs base min: -20.000 uS max: 20.500 uS sdev: 4.800 uS 189 secs servo min: -23.700 uS max: 24.000 uS sdev: 1.700 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 190 secs base min: -22.700 uS max: 21.900 uS sdev: 4.800 uS 190 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.700 uS 192 secs base min: -22.700 uS max: 21.900 uS sdev: 4.800 uS 192 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.700 uS 193 secs base min: -22.700 uS max: 21.900 uS sdev: 4.800 uS 193 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.700 uS 194 secs base min: -22.700 uS max: 22.900 uS sdev: 4.800 uS 194 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.700 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 196 secs base min: -22.700 uS max: 22.900 uS sdev: 4.800 uS 196 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.700 uS 197 secs base min: -22.700 uS max: 22.900 uS sdev: 4.800 uS 197 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.700 uS 198 secs base min: -22.700 uS max: 22.900 uS sdev: 4.800 uS 198 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.700 uS 200 secs base min: -22.700 uS max: 22.900 uS sdev: 4.800 uS 200 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.700 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 201 secs base min: -22.700 uS max: 22.900 uS sdev: 4.700 uS 201 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.700 uS 202 secs base min: -22.700 uS max: 22.900 uS sdev: 4.700 uS 202 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.700 uS 204 secs base min: -22.700 uS max: 22.900 uS sdev: 4.700 uS 204 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.700 uS 205 secs base min: -22.700 uS max: 22.900 uS sdev: 4.700 uS 205 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.700 uS 206 secs base min: -22.700 uS max: 22.900 uS sdev: 4.700 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 206 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.700 uS 208 secs base min: -22.700 uS max: 22.900 uS sdev: 4.700 uS 208 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.700 uS 209 secs base min: -22.700 uS max: 22.900 uS sdev: 4.700 uS 209 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.700 uS 210 secs base min: -22.700 uS max: 22.900 uS sdev: 4.700 uS 210 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.700 uS 212 secs base min: -22.700 uS max: 22.900 uS sdev: 4.700 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 212 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.700 uS 213 secs base min: -22.700 uS max: 22.900 uS sdev: 4.700 uS 213 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.700 uS 214 secs base min: -22.700 uS max: 22.900 uS sdev: 4.700 uS 214 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.700 uS 216 secs base min: -22.700 uS max: 22.900 uS sdev: 4.700 uS 216 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.700 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 217 secs base min: -22.700 uS max: 22.900 uS sdev: 4.700 uS 217 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.700 uS 219 secs base min: -22.700 uS max: 22.900 uS sdev: 4.700 uS 219 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.700 uS 220 secs base min: -22.700 uS max: 22.900 uS sdev: 4.700 uS 220 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.700 uS 221 secs base min: -22.700 uS max: 22.900 uS sdev: 4.700 uS 221 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.700 uS 223 secs base min: -22.700 uS max: 22.900 uS sdev: 4.700 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 223 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.700 uS 224 secs base min: -22.700 uS max: 22.900 uS sdev: 4.700 uS 224 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.700 uS 225 secs base min: -22.700 uS max: 22.900 uS sdev: 4.700 uS 225 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.700 uS 227 secs base min: -22.700 uS max: 22.900 uS sdev: 4.700 uS 227 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.700 uS 228 secs base min: -22.700 uS max: 22.900 uS sdev: 4.700 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 228 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.700 uS 229 secs base min: -22.700 uS max: 22.900 uS sdev: 4.700 uS 229 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.700 uS 231 secs base min: -22.700 uS max: 22.900 uS sdev: 4.700 uS 231 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.700 uS 232 secs base min: -22.700 uS max: 22.900 uS sdev: 4.700 uS 232 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.700 uS 234 secs base min: -22.700 uS max: 22.900 uS sdev: 4.700 uS 234 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.700 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 235 secs base min: -22.700 uS max: 22.900 uS sdev: 4.700 uS 235 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.700 uS 236 secs base min: -22.700 uS max: 22.900 uS sdev: 4.700 uS 236 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.700 uS 238 secs base min: -22.700 uS max: 22.900 uS sdev: 4.700 uS 238 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.700 uS 239 secs base min: -22.700 uS max: 22.900 uS sdev: 4.700 uS 239 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.700 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 240 secs base min: -22.700 uS max: 22.900 uS sdev: 4.700 uS 240 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.700 uS 242 secs base min: -22.700 uS max: 22.900 uS sdev: 4.700 uS 242 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.700 uS 243 secs base min: -22.700 uS max: 22.900 uS sdev: 4.700 uS 243 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.700 uS 244 secs base min: -22.700 uS max: 22.900 uS sdev: 4.700 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 244 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.700 uS 246 secs base min: -22.700 uS max: 22.900 uS sdev: 4.700 uS 246 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.700 uS 247 secs base min: -22.700 uS max: 22.900 uS sdev: 4.700 uS 247 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.700 uS 248 secs base min: -22.700 uS max: 22.900 uS sdev: 4.700 uS 248 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.700 uS 250 secs base min: -22.700 uS max: 22.900 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 250 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.700 uS 251 secs base min: -22.700 uS max: 22.900 uS sdev: 4.800 uS 251 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.700 uS 252 secs base min: -22.700 uS max: 22.900 uS sdev: 4.800 uS 252 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.700 uS 254 secs base min: -22.700 uS max: 22.900 uS sdev: 4.800 uS 254 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.700 uS 255 secs base min: -22.700 uS max: 22.900 uS sdev: 4.800 uS 255 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.700 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 257 secs base min: -22.700 uS max: 22.900 uS sdev: 4.800 uS 257 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.700 uS 258 secs base min: -22.700 uS max: 22.900 uS sdev: 4.800 uS 258 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.700 uS 259 secs base min: -22.700 uS max: 22.900 uS sdev: 4.800 uS 259 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.700 uS 261 secs base min: -22.700 uS max: 22.900 uS sdev: 4.800 uS 261 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.700 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 262 secs base min: -22.700 uS max: 22.900 uS sdev: 4.800 uS 262 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.700 uS 263 secs base min: -22.700 uS max: 22.900 uS sdev: 4.800 uS 263 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.700 uS 265 secs base min: -22.700 uS max: 22.900 uS sdev: 4.800 uS 265 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.700 uS 266 secs base min: -22.700 uS max: 22.900 uS sdev: 4.800 uS 266 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.700 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 267 secs base min: -22.700 uS max: 22.900 uS sdev: 4.800 uS 267 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.700 uS 269 secs base min: -22.700 uS max: 22.900 uS sdev: 4.800 uS 269 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.700 uS 270 secs base min: -22.700 uS max: 22.900 uS sdev: 4.800 uS 270 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.700 uS 271 secs base min: -22.700 uS max: 22.900 uS sdev: 4.800 uS 271 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.700 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 273 secs base min: -22.700 uS max: 22.900 uS sdev: 4.800 uS 273 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.700 uS 274 secs base min: -22.700 uS max: 22.900 uS sdev: 4.800 uS 274 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.700 uS 275 secs base min: -22.700 uS max: 22.900 uS sdev: 4.800 uS 275 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.700 uS 277 secs base min: -22.700 uS max: 22.900 uS sdev: 4.800 uS 277 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.700 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 278 secs base min: -22.700 uS max: 22.900 uS sdev: 4.800 uS 278 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.700 uS 279 secs base min: -22.700 uS max: 22.900 uS sdev: 4.800 uS 279 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.700 uS 281 secs base min: -22.700 uS max: 22.900 uS sdev: 4.800 uS 281 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.700 uS 282 secs base min: -22.700 uS max: 22.900 uS sdev: 4.800 uS 282 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.700 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 284 secs base min: -22.700 uS max: 22.900 uS sdev: 4.800 uS 284 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.700 uS 285 secs base min: -22.700 uS max: 22.900 uS sdev: 4.800 uS 285 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.700 uS 286 secs base min: -22.700 uS max: 22.900 uS sdev: 4.800 uS 286 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.700 uS 288 secs base min: -22.700 uS max: 22.900 uS sdev: 4.800 uS 288 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.700 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 289 secs base min: -22.700 uS max: 22.900 uS sdev: 4.800 uS 289 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.700 uS 290 secs base min: -22.700 uS max: 22.900 uS sdev: 4.800 uS 290 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.700 uS 292 secs base min: -22.700 uS max: 22.900 uS sdev: 4.800 uS 292 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.700 uS 293 secs base min: -22.700 uS max: 22.900 uS sdev: 4.800 uS 293 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.700 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 294 secs base min: -22.700 uS max: 22.900 uS sdev: 4.800 uS 294 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.700 uS 296 secs base min: -22.700 uS max: 22.900 uS sdev: 4.800 uS 296 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.700 uS 297 secs base min: -22.700 uS max: 22.900 uS sdev: 4.800 uS 297 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.700 uS 298 secs base min: -22.700 uS max: 22.900 uS sdev: 4.800 uS 298 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.700 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 300 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 300 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.700 uS 301 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 301 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.700 uS 302 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 302 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.700 uS 304 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 304 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.700 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 305 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 305 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.700 uS 306 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 306 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.700 uS 308 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 308 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.600 uS 309 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 309 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 311 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 311 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.600 uS 312 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 312 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.600 uS 313 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 313 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.600 uS 315 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 315 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 316 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 316 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.600 uS 317 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 317 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.600 uS 319 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 319 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.600 uS 320 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 320 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 321 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 321 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.600 uS 323 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 323 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.600 uS 324 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 324 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.600 uS 325 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 325 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 327 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 327 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.600 uS 328 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 328 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.600 uS 329 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 329 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.600 uS 331 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 331 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 332 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 332 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.600 uS 333 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 333 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.600 uS 335 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 335 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.600 uS 336 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 336 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 337 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 337 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.600 uS 339 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 339 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.600 uS 340 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 340 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.600 uS 342 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 342 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 343 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 343 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.600 uS 344 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 344 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.600 uS 346 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 346 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.600 uS 347 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 347 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 348 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 348 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.600 uS 350 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 350 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.600 uS 351 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 351 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.600 uS 352 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 352 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 354 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 354 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.600 uS 355 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 355 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.600 uS 356 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 356 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.600 uS 358 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 358 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 359 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 359 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.600 uS 360 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 360 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.600 uS 362 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 362 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.600 uS 363 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 363 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 364 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 364 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.600 uS 366 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 366 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.600 uS 367 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 367 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.600 uS 369 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 369 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 370 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 370 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.600 uS 371 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 371 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.600 uS 373 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 373 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.600 uS 374 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 374 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 375 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 375 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.600 uS 377 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 377 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.600 uS 378 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 378 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.600 uS 379 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 379 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 381 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 381 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.600 uS 382 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 382 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.600 uS 383 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 383 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.600 uS 385 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 385 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 386 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 386 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.600 uS 388 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 388 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.600 uS 389 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 389 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.600 uS 390 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 390 secs servo min: -25.300 uS max: 25.500 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 392 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 392 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 393 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 393 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 394 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 394 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 396 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 396 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 397 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 397 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 398 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 398 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 400 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 400 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 401 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 401 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 402 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 402 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 404 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 404 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 405 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 405 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 406 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 406 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 408 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 408 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 409 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 409 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 411 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 411 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 412 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 412 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 413 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 413 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 415 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 415 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 416 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 416 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 417 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 417 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 419 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 419 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 420 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 420 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 421 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 421 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 423 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 423 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 424 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 424 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 425 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 425 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 427 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 427 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 428 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 428 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 430 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 430 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 431 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 431 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 432 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 432 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 434 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 434 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 435 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 435 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 436 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 436 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 438 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 438 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 439 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 439 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 440 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 440 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 442 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 442 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 443 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 443 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 444 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 444 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 446 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 446 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 447 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 447 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 448 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 448 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 450 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 450 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 451 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 451 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 452 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 452 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 454 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 454 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 455 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 455 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 457 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 457 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 458 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 458 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 459 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 459 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 461 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 461 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 462 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 462 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 463 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 463 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 465 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 465 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 466 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 466 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 467 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 467 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 469 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 469 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 470 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 470 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 471 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 471 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 473 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 473 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 474 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 474 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 475 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 475 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 477 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 477 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 478 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 478 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 479 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 479 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 481 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 481 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 482 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 482 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 483 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 483 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 485 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 485 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 486 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 486 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 488 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 488 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 489 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 489 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 490 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 490 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 492 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 492 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 493 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 493 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 494 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 494 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 496 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 496 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 497 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 497 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 498 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 498 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 500 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 500 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 501 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 501 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 502 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 502 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 504 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 504 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 505 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 505 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 506 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 506 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 508 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 508 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 509 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 509 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 510 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 510 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 512 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 512 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 513 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 513 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 515 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 515 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 516 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 516 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 517 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 517 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 519 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 519 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 520 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 520 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 521 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 521 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 523 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 523 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 524 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 524 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 525 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 525 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 527 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 527 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 528 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 528 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 529 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 529 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 531 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 531 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 532 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 532 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 533 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 533 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 535 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 535 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 536 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 536 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 538 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 538 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 539 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 539 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 540 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 540 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 542 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 542 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 543 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 543 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 544 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 544 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 546 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 546 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 547 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 547 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 549 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 549 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 550 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 550 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 551 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 551 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 553 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 553 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 554 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 554 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 555 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 555 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 557 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 557 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 558 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 558 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 559 secs base min: -26.000 uS max: 26.000 uS sdev: 4.800 uS 559 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 561 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 561 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 562 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 562 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 563 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 563 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 565 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 565 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 566 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 566 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 567 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 567 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 569 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 569 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 570 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 570 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 571 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 571 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 573 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 573 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 574 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 574 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 575 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 575 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 577 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 577 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 578 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 578 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 580 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 580 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 581 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 581 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 582 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 582 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 584 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 584 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 585 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 585 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 586 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 586 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 588 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 588 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 589 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 589 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 590 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 590 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 592 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 592 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 593 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 593 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 594 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 594 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 596 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 596 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 597 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 597 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 598 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 598 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 600 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 600 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 601 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 601 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 603 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 603 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 604 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 604 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 605 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 605 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 607 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 607 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 608 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 608 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 609 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 609 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 611 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 611 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 612 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 612 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 613 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 613 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 615 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 615 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 616 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 616 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 617 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 617 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 619 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 619 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 620 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 620 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 621 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 621 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 623 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 623 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 624 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 624 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 625 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 625 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 627 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 627 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 628 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 628 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 630 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 630 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 631 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 631 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 632 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 632 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 634 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 634 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 635 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 635 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 636 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 636 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 638 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 638 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 639 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 639 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 640 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 640 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 642 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 642 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 643 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 643 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 644 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 644 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 646 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 646 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 647 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 647 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 648 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 648 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 650 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 650 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 651 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 651 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 653 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 653 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 654 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 654 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 655 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 655 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 657 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 657 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 658 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 658 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 659 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 659 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 661 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 661 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 662 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 662 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 663 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 663 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 665 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 665 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 666 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 666 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 667 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 667 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 669 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 669 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 670 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 670 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 671 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 671 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 673 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 673 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 674 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 674 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 675 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 675 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 677 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 677 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 678 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 678 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 680 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 680 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 681 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 681 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 682 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 682 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 684 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 684 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 685 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 685 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 686 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 686 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 688 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 688 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 689 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 689 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 690 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 690 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 692 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 692 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 693 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 693 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 694 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 694 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 696 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 696 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 697 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 697 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 698 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 698 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 700 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 700 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 701 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 701 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 702 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 702 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 704 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 704 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 705 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 705 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 707 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 707 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 708 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 708 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 709 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 709 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 711 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 711 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 712 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 712 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 713 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 713 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 715 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 715 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 716 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 716 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 717 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 717 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 719 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 719 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 720 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 720 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 721 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 721 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 723 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 723 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 724 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 724 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 725 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 725 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 727 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 727 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 728 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 728 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 729 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 729 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 731 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 731 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 732 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 732 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 734 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 734 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 735 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 735 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 736 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 736 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 738 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 738 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 739 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 739 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 740 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 740 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 742 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 742 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 743 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 743 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 744 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 744 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 746 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 746 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 747 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 747 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 748 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 748 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 750 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 750 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 751 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 751 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 752 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 752 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 754 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 754 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 755 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 755 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 756 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 756 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 758 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 758 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 759 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 759 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 761 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 761 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 762 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 762 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 763 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 763 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 765 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 765 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 766 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 766 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 767 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 767 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 769 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 769 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 770 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 770 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 771 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 771 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 773 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 773 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 774 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 774 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 775 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 775 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 777 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 777 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 778 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 778 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 779 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 779 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 781 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 781 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 782 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 782 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 783 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 783 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 785 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 785 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 786 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 786 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 787 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 787 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 789 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 789 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 790 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 790 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 792 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 792 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 793 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 793 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 794 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 794 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 796 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 796 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 797 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 797 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 798 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 798 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 800 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 800 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 801 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 801 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 802 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 802 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 804 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 804 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 805 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 805 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 806 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 806 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 808 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 808 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 809 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 809 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 810 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 810 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 812 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 812 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 813 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 813 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 815 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 815 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 816 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 816 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 817 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 817 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 819 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 819 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 820 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 820 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 821 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 821 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 823 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 823 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 824 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 824 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 825 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 825 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 827 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 827 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 828 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 828 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 829 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 829 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 831 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 831 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 832 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 832 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 833 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 833 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 835 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 835 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 836 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 836 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 837 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 837 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 839 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 839 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 840 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 840 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 842 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 842 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 843 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 843 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 844 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 844 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 846 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 846 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 847 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 847 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 848 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 848 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 850 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 850 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 851 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 851 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 853 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 853 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 854 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 854 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 855 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 855 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 857 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 857 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 858 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 858 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 859 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 859 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 861 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 861 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 862 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 862 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 863 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 863 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 865 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 865 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 866 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 866 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 867 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 867 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 869 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 869 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 870 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 870 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 871 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 871 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 873 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 873 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 874 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 874 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 875 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 875 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 877 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 877 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 878 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 878 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 880 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 880 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 881 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 881 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 882 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 882 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 884 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 884 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 885 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 885 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 886 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 886 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 888 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 888 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 889 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 889 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 890 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 890 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 892 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 892 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 893 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 893 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 894 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 894 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 896 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 896 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 897 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 897 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 898 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 898 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 900 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 900 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 901 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 901 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 903 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 903 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 904 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 904 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 905 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 905 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 907 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 907 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 908 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 908 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 909 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 909 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 911 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 911 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 912 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 912 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 913 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 913 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 915 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 915 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 916 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 916 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 917 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 917 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 919 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 919 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 920 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 920 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 921 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 921 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 923 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 923 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 924 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 924 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 925 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 925 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 927 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 927 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 928 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 928 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 930 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 930 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 931 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 931 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 932 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 932 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 934 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 934 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 935 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 935 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 936 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 936 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 938 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 938 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 939 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 939 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 940 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 940 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 942 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 942 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 943 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 943 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 944 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 944 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 946 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 946 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 947 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 947 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 948 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 948 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 950 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 950 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 951 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 951 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 952 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 952 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 954 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 954 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 955 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 955 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 957 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 957 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 958 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 958 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 959 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 959 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 961 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 961 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 962 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 962 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 963 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 963 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 965 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 965 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 966 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 966 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 967 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 967 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 969 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 969 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 970 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 970 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 971 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 971 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 973 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 973 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 974 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 974 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 975 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 975 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 977 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 977 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 978 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 978 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 979 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 979 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 981 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 981 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 982 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 982 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 984 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 984 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 985 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 985 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 986 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 986 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 988 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 988 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 989 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 989 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 990 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 990 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 992 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 992 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 993 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 993 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 994 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 994 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 996 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 996 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 997 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 997 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 998 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 998 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1000 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 1000 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1001 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 1001 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1002 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 1002 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1004 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 1004 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1005 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 1005 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1006 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 1006 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1008 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 1008 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1009 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 1009 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1011 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 1011 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1012 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 1012 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1013 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 1013 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1015 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 1015 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1016 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 1016 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1017 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 1017 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1019 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 1019 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1020 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 1020 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1021 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 1021 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1023 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 1023 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1024 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 1024 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1025 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 1025 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1027 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 1027 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1028 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 1028 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1029 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 1029 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1031 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 1031 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1032 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 1032 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1034 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 1034 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1035 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 1035 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1036 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 1036 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1038 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 1038 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1039 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 1039 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1040 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 1040 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1042 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 1042 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1043 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 1043 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1044 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 1044 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1046 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 1046 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1047 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 1047 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1048 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 1048 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1050 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 1050 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1051 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 1051 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1052 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 1052 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1054 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 1054 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1055 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 1055 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1056 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 1056 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1058 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 1058 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1059 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 1059 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1061 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 1061 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1062 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 1062 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1063 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 1063 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1065 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 1065 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1066 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 1066 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1067 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 1067 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1069 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 1069 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1070 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 1070 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1071 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 1071 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1073 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 1073 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1074 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 1074 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1075 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 1075 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1077 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 1077 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1078 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 1078 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1079 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 1079 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1081 secs base min: -27.000 uS max: 28.300 uS sdev: 4.800 uS 1081 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1082 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1082 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1083 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1083 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1085 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1085 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1086 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1086 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1088 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1088 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1089 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1089 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1090 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1090 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1092 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1092 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1093 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1093 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1094 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1094 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1096 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1096 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1097 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1097 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1099 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1099 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1100 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1100 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1101 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1101 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1103 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1103 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1104 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1104 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1105 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1105 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1107 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1107 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1108 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1108 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1109 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1109 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1111 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1111 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1112 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1112 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1113 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1113 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1115 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1115 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1116 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1116 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1117 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1117 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1119 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1119 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1120 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1120 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1122 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1122 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1123 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1123 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1124 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1124 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1126 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1126 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1127 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1127 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1128 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1128 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1130 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1130 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1131 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1131 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1132 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1132 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1134 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1134 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1135 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1135 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1136 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1136 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1138 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1138 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1139 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1139 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1140 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1140 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1142 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1142 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1143 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1143 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1144 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1144 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1146 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1146 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1147 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1147 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1149 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1149 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1150 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1150 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1151 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1151 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1153 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1153 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1154 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1154 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1155 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1155 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1157 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1157 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1158 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1158 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1159 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1159 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1161 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1161 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1162 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1162 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1163 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1163 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1165 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1165 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1166 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1166 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1167 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1167 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1169 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1169 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1170 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1170 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1172 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1172 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1173 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1173 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1174 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1174 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1176 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1176 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1177 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1177 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1178 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1178 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1180 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1180 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1181 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1181 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1183 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1183 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1184 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1184 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1185 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1185 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1187 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1187 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1188 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1188 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1189 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1189 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1191 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1191 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1192 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1192 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1193 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1193 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1195 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1195 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1196 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1196 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1197 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1197 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1199 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1199 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1200 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1200 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1201 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1201 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1203 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1203 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1204 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1204 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1205 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1205 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1207 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1207 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1208 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1208 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1209 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1209 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1211 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1211 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1212 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1212 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1213 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1213 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1215 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1215 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1216 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1216 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1218 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1218 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1219 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1219 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1220 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1220 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1222 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1222 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1223 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1223 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1224 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1224 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1226 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1226 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1227 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1227 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1228 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1228 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1230 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1230 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1231 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1231 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1232 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1232 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1234 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1234 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1235 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1235 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1237 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1237 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1238 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1238 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1239 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1239 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1241 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1241 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1242 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1242 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1243 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1243 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1245 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1245 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1246 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1246 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1247 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1247 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1249 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1249 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1250 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1250 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1251 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1251 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1253 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1253 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1254 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1254 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1255 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1255 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1257 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1257 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1258 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1258 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1259 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1259 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1261 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1261 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1262 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1262 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1264 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1264 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1265 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1265 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1266 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1266 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1268 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1268 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1269 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1269 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1270 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1270 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1272 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1272 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1273 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1273 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1274 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1274 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1276 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1276 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1277 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1277 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1278 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1278 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1280 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1280 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1281 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1281 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1282 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1282 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1284 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1284 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1285 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1285 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1287 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1287 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1288 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1288 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1289 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1289 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1291 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1291 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1292 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1292 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1293 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1293 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1295 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1295 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1296 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1296 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1297 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1297 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1299 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1299 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1300 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1300 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1301 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1301 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1303 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1303 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1304 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1304 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS 1305 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1305 secs servo min: -30.300 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1307 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1307 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1308 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1308 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1309 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1309 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1311 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1311 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1312 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1312 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1314 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1314 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1315 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1315 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1316 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1316 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1318 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1318 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1319 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1319 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1320 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1320 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1322 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1322 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1323 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1323 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1325 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1325 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1326 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1326 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1327 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1327 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1329 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1329 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1330 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1330 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1331 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1331 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1333 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1333 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1334 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1334 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1335 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1335 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1337 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1337 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1338 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1338 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1339 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1339 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1341 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1341 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1342 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1342 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1343 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1343 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1345 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1345 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1346 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1346 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1348 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1348 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1349 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1349 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1350 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1350 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1352 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1352 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1353 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1353 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1354 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1354 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1356 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1356 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1357 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1357 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1358 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1358 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1360 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1360 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1361 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1361 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1362 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1362 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1364 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1364 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1365 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1365 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1366 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1366 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1368 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1368 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1369 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1369 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1370 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1370 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1372 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1372 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1373 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1373 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1375 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1375 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1376 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1376 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1377 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1377 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1379 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1379 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1380 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1380 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1381 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1381 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1383 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1383 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1384 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1384 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1385 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1385 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1387 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1387 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1388 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1388 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1389 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1389 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1391 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1391 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1392 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1392 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1394 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1394 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1395 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1395 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1396 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1396 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1398 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1398 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1399 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1399 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1400 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1400 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1402 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1402 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1403 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1403 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1404 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1404 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1406 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1406 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1407 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1407 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1408 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1408 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1410 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1410 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1411 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1411 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1413 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1413 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1414 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1414 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1415 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1415 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1417 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1417 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1418 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1418 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1419 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1419 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1421 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1421 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1422 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1422 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1423 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1423 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1425 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1425 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1426 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1426 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1427 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1427 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1429 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1429 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1430 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1430 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1431 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1431 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1433 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1433 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1434 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1434 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1435 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1435 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1437 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1437 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1438 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1438 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1440 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1440 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1441 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1441 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1442 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1442 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1444 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1444 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1445 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1445 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1446 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1446 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1448 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1448 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1449 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1449 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1450 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1450 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1452 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1452 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1453 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1453 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1454 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1454 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1456 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1456 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1457 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1457 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1458 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1458 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1460 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1460 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1461 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1461 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1462 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1462 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1464 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1464 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1465 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1465 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1467 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1467 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1468 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1468 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1469 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1469 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1471 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1471 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1472 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1472 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1473 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1473 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1475 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1475 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1476 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1476 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1477 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1477 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1479 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1479 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1480 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1480 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1481 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1481 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1483 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1483 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1484 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1484 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1485 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1485 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1487 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1487 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1488 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1488 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1489 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1489 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1491 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1491 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1492 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1492 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1494 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1494 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1495 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1495 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1496 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1496 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1498 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1498 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1499 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1499 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1500 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1500 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1502 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1502 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1503 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1503 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1504 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1504 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1506 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1506 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1507 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1507 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1508 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1508 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1510 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1510 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1511 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1511 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1512 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1512 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1514 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1514 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1515 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1515 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1516 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1516 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1518 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1518 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1519 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1519 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1521 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1521 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1522 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1522 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1523 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1523 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1525 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1525 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1526 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1526 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1527 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1527 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1529 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1529 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1530 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1530 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1531 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1531 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1533 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1533 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1534 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1534 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1535 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1535 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1537 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1537 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1538 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1538 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1539 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1539 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1541 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1541 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1542 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1542 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1543 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1543 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1545 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1545 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1546 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1546 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1548 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1548 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1549 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1549 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1550 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1550 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1552 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1552 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1553 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1553 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1554 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1554 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1556 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1556 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1557 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1557 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1558 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1558 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1560 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1560 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1561 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1561 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1562 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1562 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1564 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1564 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1565 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1565 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1566 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1566 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1568 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1568 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1569 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1569 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1570 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1570 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1572 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1572 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1573 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1573 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1575 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1575 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1576 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1576 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1577 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1577 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1579 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1579 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1580 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1580 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1581 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1581 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1583 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1583 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1584 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1584 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1585 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1585 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1587 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1587 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1588 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1588 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1589 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1589 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1591 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1591 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1592 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1592 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1593 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1593 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1595 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1595 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1596 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1596 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1598 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1598 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1599 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1599 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1600 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1600 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1602 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1602 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1603 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1603 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1604 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1604 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1606 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1606 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1607 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1607 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1608 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1608 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1610 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1610 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1611 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1611 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1612 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1612 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1614 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1614 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1615 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1615 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1616 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1616 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1618 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1618 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1619 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1619 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1620 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1620 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1622 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1622 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1623 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1623 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1624 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1624 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1626 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1626 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1627 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1627 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1629 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1629 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1630 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1630 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1631 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1631 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1633 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1633 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1634 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1634 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1635 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1635 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1637 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1637 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1638 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1638 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1639 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1639 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1641 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1641 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1642 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1642 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1643 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1643 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1645 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1645 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1646 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1646 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1647 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1647 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1649 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1649 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1650 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1650 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1652 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1652 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1653 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1653 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1654 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1654 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1656 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1656 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1657 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1657 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1658 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1658 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1660 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1660 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1661 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1661 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1663 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1663 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1664 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1664 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1665 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1665 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1667 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1667 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1668 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1668 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1669 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1669 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1671 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1671 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1672 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1672 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1673 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1673 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1675 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1675 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1676 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1676 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1677 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1677 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1679 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1679 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1680 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1680 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1681 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1681 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1683 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1683 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1684 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1684 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1685 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1685 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1687 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1687 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1688 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1688 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1690 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1690 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1691 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1691 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1692 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1692 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1694 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1694 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1695 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1695 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1696 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1696 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1698 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1698 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1699 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1699 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1700 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1700 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1702 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1702 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1703 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1703 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1704 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1704 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1706 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1706 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1707 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1707 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1708 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1708 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1710 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1710 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1711 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1711 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1712 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1712 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1714 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1714 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1715 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1715 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1717 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1717 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1718 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1718 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1719 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1719 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1721 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1721 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1722 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1722 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1723 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1723 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1725 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1725 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1726 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1726 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1727 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1727 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1729 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1729 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1730 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1730 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1731 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1731 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1733 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1733 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1734 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1734 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1735 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1735 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1737 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1737 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1738 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1738 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1739 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1739 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1741 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1741 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1742 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1742 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1744 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1744 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1745 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1745 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1746 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1746 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1748 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1748 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1749 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1749 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1750 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1750 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1752 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1752 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1753 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1753 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1754 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1754 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1756 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1756 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1757 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1757 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1758 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1758 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1760 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1760 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1761 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1761 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1762 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1762 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1764 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1764 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1765 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1765 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1766 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1766 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1768 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1768 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1769 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1769 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1771 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1771 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1772 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1772 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1773 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1773 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1775 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1775 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1776 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1776 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1777 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1777 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1779 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1779 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1780 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1780 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1782 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1782 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1783 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1783 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1784 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1784 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1786 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1786 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1787 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1787 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1788 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1788 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1790 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1790 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1791 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1791 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1792 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1792 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1794 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1794 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1795 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1795 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1796 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1796 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1798 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1798 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1799 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1799 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1800 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1800 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1802 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1802 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1803 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1803 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1804 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1804 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1806 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1806 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1807 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1807 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1809 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1809 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1810 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1810 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1811 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1811 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1813 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1813 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1814 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1814 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1815 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1815 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1817 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1817 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1818 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1818 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1819 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1819 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1821 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1821 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1822 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1822 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1823 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1823 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1825 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1825 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1826 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1826 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS 1827 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1827 secs servo min: -30.400 uS max: 29.600 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1829 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1829 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 1830 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1830 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 1831 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1831 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 1833 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1833 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1834 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1834 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 1835 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1835 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 1837 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1837 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 1838 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1838 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1840 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1840 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 1841 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1841 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 1842 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1842 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 1844 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1844 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1845 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1845 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 1846 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1846 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 1848 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1848 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 1849 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1849 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1850 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1850 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 1852 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1852 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 1853 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1853 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 1854 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1854 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1856 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1856 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 1857 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1857 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 1858 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1858 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 1860 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1860 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1861 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1861 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 1863 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1863 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 1864 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1864 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 1865 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1865 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1867 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1867 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 1868 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1868 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 1869 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1869 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 1871 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1871 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1872 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1872 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 1873 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1873 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 1875 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1875 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 1876 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1876 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1877 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1877 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 1879 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1879 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 1880 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1880 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 1881 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1881 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1883 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1883 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 1884 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1884 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 1885 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1885 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 1887 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1887 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1888 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1888 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 1890 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1890 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 1891 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1891 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 1892 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1892 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1894 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1894 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 1895 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1895 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 1896 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1896 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 1898 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1898 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1899 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1899 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 1900 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1900 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 1902 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1902 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 1903 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1903 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1904 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1904 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 1906 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1906 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 1907 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1907 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 1908 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1908 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1910 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1910 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 1911 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1911 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 1913 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1913 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 1914 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1914 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1915 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1915 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 1917 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1917 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 1918 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1918 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 1919 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1919 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1921 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1921 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 1922 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1922 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 1924 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1924 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 1925 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1925 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1926 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1926 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 1928 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1928 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 1929 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1929 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 1930 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1930 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1932 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1932 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 1933 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1933 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 1934 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1934 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 1936 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1936 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1937 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1937 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 1938 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1938 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 1940 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1940 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 1941 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1941 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1942 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1942 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 1944 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1944 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 1945 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1945 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 1946 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1946 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1948 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1948 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 1949 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1949 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 1951 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1951 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 1952 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1952 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1953 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1953 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 1955 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1955 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 1956 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1956 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 1957 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1957 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1959 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1959 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 1960 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1960 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 1961 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1961 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 1963 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1963 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1964 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1964 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 1965 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1965 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 1967 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1967 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 1968 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1968 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1969 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1969 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 1971 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1971 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 1972 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1972 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 1973 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1973 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1975 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1975 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 1976 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1976 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 1978 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1978 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 1979 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1979 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1980 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1980 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 1982 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1982 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 1983 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1983 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 1984 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1984 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 1986 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1986 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 1987 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1987 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 1989 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1989 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 1990 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1990 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 1991 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1991 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1993 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1993 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 1994 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1994 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 1995 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1995 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 1997 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 1997 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 1998 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1998 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 1999 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 1999 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2001 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2001 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2002 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2002 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2003 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2003 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2005 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2005 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2006 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2006 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2007 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2007 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2009 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2009 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2010 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2010 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2011 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2011 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2013 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2013 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2014 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2014 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2016 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2016 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2017 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2017 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2018 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2018 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2020 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2020 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2021 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2021 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2022 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2022 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2024 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2024 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2025 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2025 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2026 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2026 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2028 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2028 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2029 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2029 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2030 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2030 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2032 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2032 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2033 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2033 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2034 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2034 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2036 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2036 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2037 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2037 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2039 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2039 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2040 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2040 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2041 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2041 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2043 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2043 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2044 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2044 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2045 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2045 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2047 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2047 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2048 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2048 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2049 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2049 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2051 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2051 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2052 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2052 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2053 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2053 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2055 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2055 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2056 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2056 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2057 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2057 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2059 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2059 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2060 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2060 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2061 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2061 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2063 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2063 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2064 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2064 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2066 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2066 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2067 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2067 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2068 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2068 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2070 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2070 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2071 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2071 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2072 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2072 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2074 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2074 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2075 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2075 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2076 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2076 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2078 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2078 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2079 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2079 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2080 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2080 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2082 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2082 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2083 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2083 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2084 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2084 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2086 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2086 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2087 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2087 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2088 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2088 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2090 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2090 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2091 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2091 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2093 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2093 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2094 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2094 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2095 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2095 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2097 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2097 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2098 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2098 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2099 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2099 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2101 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2101 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2102 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2102 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2104 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2104 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2105 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2105 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2106 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2106 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2108 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2108 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2109 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2109 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2110 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2110 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2112 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2112 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2113 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2113 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2114 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2114 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2116 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2116 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2117 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2117 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2118 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2118 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2120 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2120 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2121 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2121 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2122 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2122 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2124 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2124 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2125 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2125 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2127 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2127 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2128 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2128 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2129 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2129 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2131 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2131 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2132 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2132 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2133 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2133 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2135 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2135 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2136 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2136 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2137 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2137 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2139 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2139 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2140 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2140 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2141 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2141 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2143 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2143 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2144 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2144 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2145 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2145 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2147 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2147 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2148 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2148 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2149 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2149 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2151 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2151 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2152 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2152 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2154 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2154 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2155 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2155 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2156 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2156 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2158 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2158 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2159 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2159 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2160 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2160 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2162 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2162 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2163 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2163 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2164 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2164 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2166 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2166 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2167 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2167 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2168 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2168 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2170 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2170 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2171 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2171 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2172 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2172 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2174 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2174 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2175 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2175 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2176 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2176 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2178 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2178 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2179 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2179 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2181 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2181 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2182 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2182 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2183 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2183 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2185 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2185 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2186 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2186 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2187 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2187 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2189 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2189 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2190 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2190 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2191 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2191 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2193 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2193 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2194 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2194 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2195 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2195 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2197 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2197 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2198 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2198 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2199 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2199 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2201 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2201 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2202 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2202 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2203 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2203 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2205 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2205 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2206 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2206 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2208 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2208 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2209 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2209 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2210 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2210 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2212 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2212 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2213 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2213 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2214 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2214 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2216 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2216 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2217 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2217 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2218 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2218 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2220 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2220 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2221 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2221 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2222 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2222 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2224 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2224 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2225 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2225 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2226 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2226 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2228 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2228 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2229 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2229 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2230 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2230 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2232 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2232 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2233 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2233 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2235 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2235 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2236 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2236 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2237 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2237 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2239 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2239 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2240 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2240 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2241 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2241 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2243 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2243 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2244 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2244 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2246 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2246 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2247 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2247 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2248 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2248 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2250 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2250 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2251 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2251 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2252 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2252 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2254 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2254 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2255 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2255 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2256 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2256 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2258 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2258 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2259 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2259 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2260 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2260 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2262 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2262 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2263 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2263 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2264 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2264 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2266 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2266 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2267 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2267 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2269 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2269 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2270 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2270 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2271 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2271 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2273 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2273 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2274 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2274 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2275 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2275 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2277 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2277 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2278 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2278 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2279 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2279 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2281 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2281 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2282 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2282 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2283 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2283 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2285 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2285 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2286 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2286 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2287 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2287 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2289 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2289 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2290 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2290 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2291 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2291 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2293 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2293 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2294 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2294 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2296 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2296 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2297 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2297 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2298 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2298 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2300 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2300 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2301 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2301 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2302 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2302 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2304 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2304 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2305 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2305 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2306 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2306 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2308 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2308 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2309 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2309 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2310 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2310 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2312 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2312 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2313 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2313 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2314 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2314 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2316 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2316 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2317 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2317 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2319 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2319 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2320 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2320 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2321 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2321 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2323 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2323 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2324 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2324 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2325 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2325 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2327 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2327 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2328 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2328 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2329 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2329 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2331 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2331 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2332 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2332 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2333 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2333 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2335 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2335 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2336 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2336 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2337 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2337 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2339 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2339 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2340 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2340 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2341 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2341 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2343 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2343 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2344 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2344 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2346 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2346 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2347 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2347 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2348 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2348 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2350 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2350 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2351 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2351 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2352 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2352 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2354 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2354 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2355 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2355 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2356 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2356 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2358 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2358 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2359 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2359 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2360 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2360 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2362 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2362 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2363 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2363 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2364 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2364 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2366 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2366 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2367 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2367 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2369 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2369 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2370 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2370 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2371 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2371 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2373 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2373 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2374 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2374 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2375 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2375 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2377 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2377 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2378 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2378 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2379 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2379 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2381 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2381 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2382 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2382 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2383 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2383 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2385 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2385 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2386 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2386 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2387 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2387 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2389 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2389 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2390 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2390 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2391 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2391 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2393 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2393 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2394 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2394 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2395 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2395 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2397 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2397 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2398 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2398 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2400 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2400 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2401 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2401 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2402 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2402 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2404 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2404 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2405 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2405 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2406 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2406 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2408 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2408 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2409 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2409 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2411 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2411 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2412 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2412 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2413 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2413 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2415 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2415 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2416 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2416 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2417 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2417 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2419 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2419 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2420 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2420 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2421 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2421 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2423 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2423 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2424 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2424 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2425 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2425 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2427 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2427 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2428 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2428 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2429 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2429 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2431 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2431 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2432 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2432 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2434 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2434 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2435 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2435 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2436 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2436 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2438 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2438 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2439 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2439 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2440 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2440 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2442 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2442 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2443 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2443 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2444 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2444 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2446 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2446 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2447 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2447 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2448 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2448 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2450 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2450 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2451 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2451 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2452 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2452 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2454 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2454 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2455 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2455 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2456 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2456 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2458 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2458 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2459 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2459 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2461 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2461 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2462 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2462 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2463 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2463 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2465 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2465 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2466 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2466 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2467 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2467 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2469 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2469 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2470 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2470 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2471 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2471 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2473 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2473 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2474 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2474 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2475 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2475 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2477 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2477 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2478 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2478 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2479 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2479 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2481 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2481 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2482 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2482 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2484 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2484 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2485 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2485 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2486 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2486 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2488 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2488 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2489 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2489 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2490 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2490 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2492 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2492 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2493 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2493 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2494 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2494 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2496 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2496 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2497 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2497 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2498 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2498 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2500 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2500 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2501 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2501 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2503 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2503 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2504 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2504 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2505 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2505 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2507 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2507 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2508 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2508 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2509 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2509 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2511 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2511 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2512 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2512 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2513 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2513 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2515 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2515 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2516 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2516 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2517 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2517 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2519 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2519 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2520 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2520 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2521 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2521 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2523 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2523 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2524 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2524 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2526 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2526 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2527 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2527 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2528 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2528 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2530 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2530 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2531 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2531 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2532 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2532 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2534 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2534 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2535 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2535 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2536 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2536 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2538 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2538 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2539 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2539 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2540 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2540 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2542 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2542 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2543 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2543 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2544 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2544 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2546 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2546 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2547 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2547 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2548 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2548 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2550 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2550 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2551 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2551 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2553 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2553 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2554 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2554 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2555 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2555 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2557 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2557 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2558 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2558 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2559 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2559 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2561 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2561 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2562 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2562 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2563 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2563 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2565 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2565 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2566 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2566 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2567 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2567 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2569 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2569 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2570 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2570 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2571 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2571 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2573 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2573 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2574 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2574 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2575 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2575 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2577 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2577 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2578 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2578 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2580 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2580 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2581 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2581 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2582 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2582 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2584 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2584 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2585 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2585 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2586 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2586 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2588 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2588 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2589 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2589 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2590 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2590 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2592 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2592 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2593 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2593 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2594 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2594 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2596 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2596 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2597 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2597 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2598 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2598 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2600 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2600 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2601 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2601 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2603 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2603 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2604 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2604 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2605 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2605 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2607 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2607 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2608 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2608 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2609 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2609 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2611 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2611 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2612 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2612 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2613 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2613 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2615 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2615 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2616 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2616 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2617 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2617 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2619 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2619 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2620 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2620 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2621 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2621 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2623 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2623 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2624 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2624 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2625 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2625 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2627 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2627 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2628 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2628 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2629 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2629 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2631 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2631 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2632 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2632 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2634 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2634 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2635 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2635 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2636 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2636 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2638 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2638 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2639 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2639 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2640 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2640 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2642 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2642 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2643 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2643 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2644 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2644 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2646 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2646 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2647 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2647 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2648 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2648 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2650 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2650 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2651 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2651 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2652 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2652 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2654 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2654 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2655 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2655 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2657 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2657 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2658 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2658 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2659 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2659 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2661 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2661 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2662 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2662 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2663 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2663 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2665 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2665 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2666 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2666 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2667 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2667 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2669 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2669 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2670 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2670 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2671 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2671 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2673 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2673 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2674 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2674 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2675 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2675 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2677 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2677 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2678 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2678 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2679 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2679 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2681 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2681 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2682 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2682 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2684 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2684 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2685 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2685 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2686 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2686 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2688 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2688 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2689 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2689 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2690 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2690 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2692 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2692 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2693 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2693 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2694 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2694 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2696 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2696 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2697 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2697 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2698 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2698 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2700 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2700 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2701 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2701 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2702 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2702 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2704 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2704 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2705 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2705 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2706 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2706 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2708 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2708 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2709 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2709 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2711 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2711 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2712 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2712 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2713 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2713 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2715 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2715 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2716 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2716 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2717 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2717 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2719 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2719 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2720 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2720 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2721 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2721 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2723 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2723 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2724 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2724 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2725 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2725 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2727 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2727 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2728 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2728 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2729 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2729 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2731 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2731 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2732 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2732 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS 2733 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2733 secs servo min: -30.400 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2735 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2735 secs servo min: -30.800 uS max: 30.400 uS sdev: 1.600 uS 2736 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2736 secs servo min: -30.800 uS max: 30.400 uS sdev: 1.600 uS 2738 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2738 secs servo min: -30.800 uS max: 30.400 uS sdev: 1.600 uS 2739 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2739 secs servo min: -30.800 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2740 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2740 secs servo min: -30.800 uS max: 30.400 uS sdev: 1.600 uS 2742 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2742 secs servo min: -30.800 uS max: 30.400 uS sdev: 1.600 uS 2743 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2743 secs servo min: -30.800 uS max: 30.400 uS sdev: 1.600 uS 2744 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2744 secs servo min: -30.800 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2746 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2746 secs servo min: -30.800 uS max: 30.400 uS sdev: 1.600 uS 2747 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2747 secs servo min: -30.800 uS max: 30.400 uS sdev: 1.600 uS 2748 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2748 secs servo min: -30.800 uS max: 30.400 uS sdev: 1.600 uS 2750 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2750 secs servo min: -30.800 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2751 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2751 secs servo min: -30.800 uS max: 30.400 uS sdev: 1.600 uS 2752 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2752 secs servo min: -30.800 uS max: 30.400 uS sdev: 1.600 uS 2754 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2754 secs servo min: -30.800 uS max: 30.400 uS sdev: 1.600 uS 2755 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2755 secs servo min: -30.800 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2756 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2756 secs servo min: -30.800 uS max: 30.400 uS sdev: 1.600 uS 2758 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2758 secs servo min: -30.800 uS max: 30.400 uS sdev: 1.600 uS 2759 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2759 secs servo min: -30.800 uS max: 30.400 uS sdev: 1.600 uS 2761 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2761 secs servo min: -30.800 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2762 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2762 secs servo min: -30.800 uS max: 30.400 uS sdev: 1.600 uS 2763 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2763 secs servo min: -30.800 uS max: 30.400 uS sdev: 1.600 uS 2765 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2765 secs servo min: -30.800 uS max: 30.400 uS sdev: 1.600 uS 2766 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2766 secs servo min: -30.800 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2767 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2767 secs servo min: -30.800 uS max: 30.400 uS sdev: 1.600 uS 2769 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2769 secs servo min: -30.800 uS max: 30.400 uS sdev: 1.600 uS 2770 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2770 secs servo min: -30.800 uS max: 30.400 uS sdev: 1.600 uS 2771 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2771 secs servo min: -30.800 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2773 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2773 secs servo min: -30.800 uS max: 30.400 uS sdev: 1.600 uS 2774 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2774 secs servo min: -30.800 uS max: 30.400 uS sdev: 1.600 uS 2776 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2776 secs servo min: -30.800 uS max: 30.400 uS sdev: 1.600 uS 2777 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2777 secs servo min: -30.800 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2778 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2778 secs servo min: -30.800 uS max: 30.400 uS sdev: 1.600 uS 2780 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2780 secs servo min: -30.800 uS max: 30.400 uS sdev: 1.600 uS 2781 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2781 secs servo min: -30.800 uS max: 30.400 uS sdev: 1.600 uS 2782 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2782 secs servo min: -30.800 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2784 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2784 secs servo min: -30.800 uS max: 30.400 uS sdev: 1.600 uS 2785 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2785 secs servo min: -30.800 uS max: 30.400 uS sdev: 1.600 uS 2786 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2786 secs servo min: -30.800 uS max: 30.400 uS sdev: 1.600 uS 2788 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2788 secs servo min: -30.800 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2789 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2789 secs servo min: -30.800 uS max: 30.400 uS sdev: 1.600 uS 2790 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2790 secs servo min: -30.800 uS max: 30.400 uS sdev: 1.600 uS 2792 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2792 secs servo min: -30.800 uS max: 30.400 uS sdev: 1.600 uS 2793 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2793 secs servo min: -30.800 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2794 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2794 secs servo min: -30.800 uS max: 30.400 uS sdev: 1.600 uS 2796 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2796 secs servo min: -30.800 uS max: 30.400 uS sdev: 1.600 uS 2797 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2797 secs servo min: -30.800 uS max: 30.400 uS sdev: 1.600 uS 2798 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2798 secs servo min: -30.800 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2800 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2800 secs servo min: -30.800 uS max: 30.400 uS sdev: 1.600 uS 2801 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2801 secs servo min: -30.800 uS max: 30.400 uS sdev: 1.600 uS 2803 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2803 secs servo min: -30.800 uS max: 30.400 uS sdev: 1.600 uS 2804 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2804 secs servo min: -30.800 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2805 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2805 secs servo min: -30.800 uS max: 30.400 uS sdev: 1.600 uS 2807 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2807 secs servo min: -30.800 uS max: 30.400 uS sdev: 1.600 uS 2808 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2808 secs servo min: -30.800 uS max: 30.400 uS sdev: 1.600 uS 2809 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2809 secs servo min: -30.800 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2811 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2811 secs servo min: -30.800 uS max: 30.400 uS sdev: 1.600 uS 2812 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2812 secs servo min: -30.800 uS max: 30.400 uS sdev: 1.600 uS 2813 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2813 secs servo min: -30.800 uS max: 30.400 uS sdev: 1.600 uS 2815 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2815 secs servo min: -30.800 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2816 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2816 secs servo min: -30.800 uS max: 30.400 uS sdev: 1.600 uS 2817 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2817 secs servo min: -30.800 uS max: 30.400 uS sdev: 1.600 uS 2819 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2819 secs servo min: -30.800 uS max: 30.400 uS sdev: 1.600 uS 2820 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2820 secs servo min: -30.800 uS max: 30.400 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2821 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2821 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 2823 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2823 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 2824 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2824 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 2826 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2826 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2827 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2827 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 2828 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2828 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 2830 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2830 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 2831 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2831 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2832 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2832 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 2834 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2834 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 2835 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2835 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 2837 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2837 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 2838 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2838 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 2839 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2839 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 2841 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2841 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 2842 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2842 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 2843 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2843 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 2845 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2845 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 2846 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2846 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 2847 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2847 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2849 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2849 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 2850 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2850 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 2851 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2851 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 2853 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2853 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2854 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2854 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 2855 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2855 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 2857 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2857 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 2858 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2858 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 2859 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2859 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 2861 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2861 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 2862 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2862 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 2864 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2864 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 2865 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2865 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 2866 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2866 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 2868 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2868 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 2869 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2869 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 2870 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2870 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2872 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2872 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 2873 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2873 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 2874 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2874 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 2876 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2876 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 2877 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2877 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 2878 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2878 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 2880 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2880 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 2881 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2881 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 2882 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2882 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 2884 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2884 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 2885 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2885 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 2887 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2887 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 2888 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2888 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 2889 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2889 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 2891 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2891 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 2892 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2892 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 2893 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2893 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 2895 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2895 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 2896 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2896 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 2897 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2897 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2899 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2899 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 2900 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2900 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 2901 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2901 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 2903 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2903 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 2904 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2904 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 2905 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2905 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 2907 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2907 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 2908 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2908 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 2909 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2909 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 2911 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2911 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 2912 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2912 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 2913 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2913 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2915 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2915 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 2916 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2916 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 2918 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2918 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 2919 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2919 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2920 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2920 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 2922 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2922 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 2923 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2923 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 2924 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2924 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2926 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2926 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 2927 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2927 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 2928 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2928 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 2930 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2930 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2931 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2931 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 2932 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2932 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 2934 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2934 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 2935 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2935 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2936 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2936 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 2938 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2938 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 2939 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2939 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 2941 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2941 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2942 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2942 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 2943 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2943 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 2945 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2945 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 2946 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2946 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2947 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2947 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 2949 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2949 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 2950 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2950 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 2951 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2951 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2953 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2953 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 2954 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2954 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 2955 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2955 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 2957 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2957 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2958 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2958 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 2960 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2960 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 2961 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2961 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 2962 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2962 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2964 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2964 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 2965 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2965 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 2966 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2966 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 2968 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2968 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2969 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2969 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 2970 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2970 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 2972 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2972 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 2973 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2973 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2974 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2974 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 2976 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2976 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 2977 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2977 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 2978 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2978 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2980 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2980 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 2981 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2981 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 2983 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2983 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 2984 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2984 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2985 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2985 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 2987 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2987 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 2988 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2988 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 2989 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2989 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2991 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2991 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 2992 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2992 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 2993 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2993 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 2995 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2995 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 2996 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2996 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 2997 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2997 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 2999 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 2999 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3000 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3000 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3001 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3001 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3003 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3003 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3004 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3004 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3005 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3005 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3007 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3007 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3008 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3008 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3010 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3010 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3011 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3011 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3012 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3012 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3014 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3014 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3015 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3015 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3016 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3016 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3018 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3018 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3019 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3019 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3020 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3020 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3022 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3022 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3023 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3023 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3024 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3024 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3026 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3026 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3027 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3027 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3028 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3028 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3030 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3030 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3031 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3031 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3033 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3033 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3034 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3034 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3035 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3035 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3037 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3037 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3038 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3038 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3039 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3039 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3041 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3041 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3042 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3042 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3043 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3043 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3045 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3045 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3046 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3046 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3047 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3047 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3049 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3049 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3050 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3050 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3051 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3051 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3053 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3053 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3054 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3054 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3056 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3056 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3057 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3057 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3058 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3058 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3060 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3060 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3061 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3061 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3062 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3062 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3064 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3064 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3065 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3065 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3066 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3066 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3068 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3068 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3069 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3069 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3070 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3070 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3072 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3072 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3073 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3073 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3074 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3074 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3076 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3076 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3077 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3077 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3078 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3078 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3080 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3080 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3081 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3081 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3082 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3082 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3084 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3084 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3085 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3085 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3087 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3087 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3088 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3088 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3089 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3089 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3091 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3091 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3092 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3092 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3093 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3093 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3095 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3095 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3096 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3096 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3097 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3097 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3099 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3099 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3100 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3100 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3102 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3102 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3103 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3103 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3104 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3104 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3106 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3106 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3107 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3107 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3108 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3108 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3110 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3110 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3111 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3111 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3112 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3112 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3114 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3114 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3115 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3115 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3116 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3116 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3118 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3118 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3119 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3119 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3121 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3121 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3122 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3122 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3123 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3123 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3125 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3125 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3126 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3126 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3127 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3127 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3129 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3129 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3130 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3130 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3131 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3131 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3133 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3133 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3134 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3134 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3135 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3135 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3137 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3137 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3138 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3138 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3139 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3139 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3141 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3141 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3142 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3142 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3144 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3144 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3145 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3145 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3146 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3146 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3148 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3148 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3149 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3149 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3150 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3150 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3152 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3152 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3153 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3153 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3155 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3155 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3156 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3156 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3157 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3157 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3159 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3159 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3160 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3160 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3161 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3161 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3163 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3163 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3164 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3164 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3165 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3165 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3167 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3167 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3168 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3168 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3169 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3169 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3171 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3171 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3172 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3172 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3173 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3173 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3175 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3175 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3176 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3176 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3178 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3178 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3179 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3179 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3180 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3180 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3182 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3182 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3183 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3183 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3184 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3184 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3186 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3186 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3187 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3187 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3188 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3188 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3190 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3190 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3191 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3191 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3192 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3192 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3194 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3194 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3195 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3195 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3196 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3196 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3198 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3198 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3199 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3199 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3200 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3200 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3202 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3202 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3203 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3203 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3205 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3205 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3206 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3206 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3207 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3207 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3209 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3209 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3210 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3210 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3211 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3211 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3213 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3213 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3214 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3214 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3215 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3215 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3217 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3217 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3218 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3218 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3219 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3219 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3221 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3221 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3222 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3222 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3223 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3223 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3225 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3225 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3226 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3226 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3227 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3227 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3229 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3229 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3230 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3230 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3232 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3232 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3233 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3233 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3234 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3234 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3236 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3236 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3237 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3237 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3238 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3238 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3240 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3240 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3241 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3241 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3243 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3243 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3244 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3244 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3245 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3245 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3247 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3247 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3248 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3248 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3249 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3249 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3251 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3251 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3252 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3252 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3253 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3253 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3255 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3255 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3256 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3256 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3257 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3257 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3259 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3259 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3260 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3260 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3261 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3261 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3263 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3263 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3264 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3264 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3265 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3265 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3267 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3267 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3268 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3268 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3270 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3270 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3271 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3271 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3272 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3272 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3274 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3274 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3275 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3275 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3276 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3276 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3278 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3278 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3279 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3279 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3280 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3280 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3282 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3282 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3283 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3283 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3284 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3284 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3286 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3286 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3287 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3287 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3288 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3288 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3290 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3290 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3291 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3291 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3293 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3293 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3294 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3294 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3295 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3295 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3297 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3297 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3298 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3298 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3299 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3299 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3301 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3301 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3302 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3302 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3303 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3303 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3305 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3305 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3306 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3306 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3307 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3307 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3309 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3309 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3310 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3310 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3311 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3311 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3313 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3313 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3314 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3314 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3315 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3315 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3317 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3317 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3318 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3318 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3320 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3320 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3321 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3321 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3322 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3322 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3324 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3324 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3325 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3325 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3326 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3326 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3328 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3328 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3329 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3329 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3330 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3330 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3332 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3332 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3333 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3333 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3334 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3334 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3336 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3336 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3337 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3337 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3338 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3338 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3340 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3340 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3341 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3341 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3342 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3342 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3344 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3344 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3345 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3345 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3347 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3347 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3348 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3348 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3349 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3349 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3351 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3351 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3352 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3352 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3353 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3353 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3355 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3355 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3356 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3356 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3357 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3357 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3359 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3359 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3360 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3360 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3361 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3361 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3363 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3363 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3364 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3364 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3365 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3365 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3367 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3367 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3368 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3368 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3369 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3369 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3371 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3371 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3372 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3372 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3373 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3373 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3375 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3375 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3376 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3376 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3378 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3378 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3379 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3379 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3380 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3380 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3382 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3382 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3383 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3383 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3384 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3384 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3386 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3386 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3387 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3387 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3388 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3388 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3390 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3390 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3391 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3391 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3392 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3392 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3394 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3394 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3395 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3395 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3396 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3396 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3398 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3398 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3399 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3399 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3400 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3400 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3402 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3402 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3403 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3403 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3405 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3405 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3406 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3406 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3407 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3407 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3409 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3409 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3410 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3410 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3411 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3411 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3413 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3413 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3414 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3414 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3415 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3415 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3417 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3417 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3418 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3418 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3419 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3419 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3421 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3421 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3422 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3422 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3423 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3423 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3425 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3425 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3426 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3426 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3428 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3428 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3429 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3429 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3430 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3430 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3432 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3432 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3433 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3433 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3434 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3434 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3436 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3436 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3437 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3437 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3438 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3438 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3440 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3440 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3441 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3441 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3442 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3442 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3444 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3444 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3445 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3445 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3446 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3446 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3448 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3448 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3449 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3449 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3450 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3450 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3452 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3452 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3453 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3453 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3455 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3455 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3456 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3456 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3457 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3457 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3459 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3459 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3460 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3460 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3461 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3461 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3463 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3463 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3464 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3464 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3465 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3465 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3467 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3467 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3468 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3468 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3469 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3469 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3471 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3471 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3472 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3472 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3473 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3473 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3475 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3475 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3476 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3476 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3478 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3478 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3479 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3479 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3480 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3480 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3482 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3482 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3483 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3483 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3484 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3484 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3486 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3486 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3487 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3487 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3489 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3489 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3490 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3490 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3491 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3491 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3493 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3493 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3494 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3494 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3495 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3495 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3497 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3497 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3498 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3498 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3499 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3499 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3501 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3501 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3502 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3502 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3503 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3503 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3505 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3505 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3506 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3506 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3507 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3507 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3509 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3509 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3510 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3510 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3511 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3511 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3513 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3513 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3514 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3514 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3516 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3516 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3517 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3517 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3518 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3518 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3520 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3520 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3521 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3521 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3522 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3522 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3524 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3524 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3525 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3525 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3526 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3526 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3528 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3528 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3529 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3529 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3530 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3530 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3532 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3532 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3533 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3533 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3534 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3534 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3536 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3536 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3537 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3537 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3538 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3538 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3540 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3540 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3541 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3541 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3543 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3543 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3544 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3544 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3545 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3545 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3547 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3547 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3548 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3548 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3549 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3549 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3551 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3551 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3552 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3552 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3553 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3553 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3555 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3555 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3556 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3556 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3557 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3557 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3559 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3559 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3560 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3560 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3561 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3561 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3563 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3563 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3564 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3564 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3565 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3565 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3567 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3567 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3568 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3568 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3570 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3570 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3571 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3571 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3572 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3572 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3574 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3574 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3575 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3575 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3576 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3576 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3578 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3578 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3579 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3579 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3580 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3580 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3582 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3582 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3583 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3583 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3584 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3584 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3586 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3586 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3587 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3587 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3588 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3588 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3590 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3590 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3591 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3591 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3592 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3592 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3594 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3594 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3595 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3595 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3597 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3597 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3598 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3598 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3599 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3599 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3601 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3601 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3602 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3602 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3603 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3603 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3605 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3605 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3606 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3606 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3607 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3607 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3609 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3609 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3610 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3610 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3611 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3611 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3613 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3613 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3614 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3614 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3615 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3615 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3617 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3617 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3618 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3618 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3619 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3619 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3621 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3621 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3622 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3622 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3624 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3624 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3625 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3625 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3626 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3626 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3628 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3628 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3629 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3629 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3630 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3630 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3632 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3632 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3633 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3633 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3634 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3634 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3636 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3636 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3637 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3637 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3638 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3638 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3640 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3640 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3641 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3641 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3642 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3642 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3644 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3644 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3645 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3645 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3647 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3647 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3648 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3648 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3649 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3649 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3651 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3651 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3652 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3652 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3653 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3653 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3655 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3655 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3656 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3656 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3657 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3657 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3659 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3659 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3660 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3660 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3661 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3661 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3663 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3663 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3664 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3664 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3665 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3665 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3667 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3667 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3668 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3668 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3669 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3669 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3671 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3671 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3672 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3672 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3673 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3673 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3675 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3675 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3676 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3676 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3678 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3678 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3679 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3679 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3680 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3680 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3682 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3682 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3683 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3683 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3684 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3684 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3686 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3686 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3687 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3687 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3688 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3688 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3690 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3690 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3691 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3691 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3692 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3692 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3694 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3694 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3695 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3695 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3696 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3696 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3698 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3698 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3699 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3699 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3701 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3701 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3702 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3702 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3703 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3703 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3705 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3705 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3706 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3706 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3707 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3707 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3709 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3709 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3710 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3710 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3711 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3711 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3713 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3713 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3714 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3714 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3716 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3716 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3717 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3717 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3718 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3718 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3720 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3720 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3721 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3721 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3722 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3722 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3724 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3724 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3725 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3725 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3726 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3726 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3728 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3728 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3729 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3729 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3730 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3730 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3732 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3732 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3733 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3733 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3735 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3735 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3736 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3736 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3737 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3737 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3739 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3739 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3740 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3740 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3741 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3741 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3743 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3743 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3744 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3744 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3746 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3746 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3747 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3747 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3748 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3748 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3750 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3750 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3751 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3751 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3752 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3752 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3754 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3754 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3755 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3755 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3756 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3756 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3758 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3758 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3759 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3759 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3760 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3760 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3762 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3762 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3763 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3763 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3764 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3764 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3766 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3766 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3767 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3767 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3768 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3768 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3770 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3770 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3771 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3771 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3773 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3773 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3774 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3774 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3775 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3775 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3777 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3777 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3778 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3778 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3779 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3779 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3781 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3781 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3782 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3782 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3783 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3783 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3785 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3785 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3786 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3786 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3787 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3787 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3789 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3789 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3790 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3790 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3791 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3791 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3793 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3793 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3794 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3794 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3796 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3796 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3797 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3797 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3798 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3798 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3800 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3800 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3801 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3801 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3802 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3802 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3804 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3804 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3805 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3805 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3806 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3806 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3808 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3808 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3809 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3809 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3810 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3810 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3812 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3812 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3813 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3813 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3814 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3814 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3816 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3816 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3817 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3817 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3819 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3819 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3820 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3820 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3821 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3821 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3823 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3823 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3824 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3824 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3825 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3825 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3827 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3827 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3828 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3828 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3829 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3829 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3831 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3831 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3832 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3832 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3834 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3834 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3835 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3835 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3836 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3836 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3838 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3838 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3839 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3839 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3840 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3840 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3842 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3842 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3843 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3843 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3844 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3844 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3846 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3846 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3847 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3847 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3848 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3848 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3850 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3850 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3851 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3851 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3852 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3852 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3854 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3854 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3855 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3855 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3856 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3856 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3858 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3858 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3859 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3859 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3861 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3861 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3862 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3862 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3863 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3863 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3865 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3865 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3866 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3866 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3867 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3867 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3869 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3869 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3870 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3870 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3871 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3871 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3873 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3873 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3874 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3874 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3875 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3875 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3877 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3877 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3878 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3878 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3879 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3879 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3881 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3881 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3882 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3882 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3883 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3883 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3885 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3885 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3886 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3886 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3888 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3888 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3889 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3889 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3890 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3890 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3892 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3892 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3893 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3893 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3894 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3894 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3896 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3896 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3897 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3897 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3898 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3898 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3900 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3900 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3901 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3901 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3902 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3902 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3904 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3904 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3905 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3905 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3906 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3906 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3908 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3908 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3909 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3909 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3910 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3910 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3912 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3912 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3913 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3913 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3915 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3915 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3916 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3916 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3917 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3917 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3919 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3919 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3920 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3920 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3921 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3921 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3923 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3923 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3924 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3924 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3925 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3925 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3927 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3927 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3928 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3928 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3929 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3929 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3931 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3931 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3932 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3932 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3933 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3933 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3935 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3935 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3936 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3936 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3938 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3938 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3939 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3939 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3940 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3940 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3942 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3942 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3943 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3943 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3944 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3944 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3946 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3946 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3947 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3947 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3948 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3948 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3950 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3950 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3951 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3951 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3952 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3952 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3954 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3954 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3955 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3955 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3956 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3956 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3958 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3958 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3959 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3959 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3960 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3960 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3962 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3962 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3963 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3963 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3965 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3965 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3966 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3966 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3967 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3967 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3969 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3969 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3970 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3970 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3971 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3971 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3973 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3973 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3974 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3974 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3975 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3975 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3977 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3977 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3978 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3978 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3979 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3979 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3981 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3981 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3982 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3982 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3983 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3983 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3985 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3985 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3986 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3986 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3988 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3988 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3989 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3989 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3990 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3990 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3992 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3992 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3993 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3993 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 3994 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3994 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3996 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3996 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3997 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3997 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 3998 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 3998 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4000 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4000 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4001 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4001 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4003 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4003 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4004 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4004 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4005 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4005 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4007 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4007 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4008 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4008 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4009 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4009 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4011 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4011 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4012 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4012 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4013 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4013 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4015 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4015 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4016 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4016 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4017 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4017 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4019 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4019 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4020 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4020 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4021 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4021 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4023 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4023 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4024 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4024 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4026 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4026 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4027 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4027 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4028 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4028 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4030 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4030 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4031 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4031 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4032 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4032 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4034 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4034 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4035 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4035 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4036 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4036 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4038 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4038 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4039 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4039 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4040 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4040 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4042 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4042 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4043 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4043 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4044 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4044 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4046 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4046 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4047 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4047 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4048 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4048 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4050 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4050 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4051 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4051 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4053 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4053 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4054 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4054 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4055 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4055 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4057 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4057 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4058 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4058 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4059 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4059 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4061 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4061 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4062 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4062 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4063 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4063 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4065 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4065 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4066 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4066 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4067 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4067 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4069 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4069 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4070 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4070 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4071 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4071 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4073 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4073 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4074 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4074 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4075 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4075 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4077 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4077 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4078 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4078 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4080 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4080 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4081 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4081 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4082 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4082 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4084 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4084 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4085 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4085 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4087 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4087 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4088 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4088 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4089 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4089 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4091 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4091 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4092 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4092 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4093 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4093 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4095 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4095 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4096 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4096 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4097 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4097 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4099 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4099 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4100 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4100 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4101 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4101 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4103 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4103 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4104 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4104 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4105 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4105 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4107 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4107 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4108 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4108 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4109 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4109 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4111 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4111 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4112 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4112 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4114 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4114 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4115 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4115 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4116 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4116 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4118 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4118 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4119 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4119 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4120 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4120 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4122 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4122 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4123 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4123 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4124 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4124 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4126 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4126 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4127 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4127 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4128 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4128 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4130 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4130 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4131 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4131 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4132 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4132 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4134 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4134 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4135 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4135 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4137 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4137 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4138 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4138 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4139 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4139 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4141 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4141 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4142 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4142 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4143 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4143 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4145 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4145 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4146 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4146 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4147 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4147 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4149 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4149 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4150 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4150 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4151 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4151 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4153 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4153 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4154 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4154 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4155 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4155 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4157 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4157 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4158 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4158 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4159 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4159 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4161 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4161 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4162 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4162 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4164 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4164 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4165 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4165 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4166 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4166 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4168 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4168 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4169 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4169 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4170 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4170 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4172 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4172 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4173 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4173 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4174 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4174 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4176 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4176 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4177 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4177 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4178 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4178 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4180 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4180 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4181 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4181 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4182 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4182 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4184 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4184 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4185 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4185 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4186 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4186 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4188 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4188 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4189 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4189 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4191 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4191 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4192 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4192 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4193 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4193 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4195 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4195 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4196 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4196 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4197 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4197 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4199 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4199 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4200 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4200 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4202 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4202 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4203 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4203 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4204 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4204 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4206 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4206 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4207 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4207 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4208 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4208 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4210 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4210 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4211 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4211 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4212 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4212 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4214 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4214 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4215 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4215 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4216 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4216 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4218 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4218 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4219 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4219 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4220 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4220 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4222 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4222 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4223 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4223 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4225 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4225 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4226 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4226 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4227 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4227 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4229 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4229 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4230 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4230 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4231 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4231 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4233 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4233 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4234 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4234 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4235 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4235 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4237 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4237 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4238 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4238 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4239 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4239 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4241 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4241 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4242 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4242 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4243 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4243 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4245 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4245 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4246 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4246 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4247 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4247 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4249 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4249 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4250 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4250 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4252 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4252 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4253 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4253 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4254 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4254 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4256 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4256 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4257 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4257 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4258 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4258 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4260 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4260 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4261 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4261 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4263 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4263 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4264 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4264 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4265 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4265 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4267 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4267 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4268 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4268 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4269 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4269 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4271 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4271 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4272 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4272 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4273 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4273 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4275 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4275 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4276 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4276 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4277 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4277 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4279 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4279 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4280 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4280 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4281 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4281 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4283 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4283 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4284 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4284 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4285 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4285 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4287 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4287 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4288 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4288 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4289 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4289 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4291 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4291 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4292 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4292 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4293 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4293 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4295 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4295 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4296 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4296 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4298 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4298 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4299 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4299 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4300 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4300 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4302 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4302 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4303 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4303 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4304 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4304 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4306 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4306 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4307 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4307 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4308 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4308 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4310 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4310 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4311 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4311 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4312 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4312 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4314 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4314 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4315 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4315 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4317 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4317 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4318 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4318 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4319 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4319 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4321 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4321 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4322 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4322 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4323 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4323 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4325 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4325 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4326 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4326 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4327 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4327 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4329 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4329 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4330 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4330 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4331 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4331 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4333 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4333 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4334 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4334 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4335 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4335 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4337 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4337 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4338 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4338 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4339 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4339 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4341 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4341 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4342 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4342 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4344 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4344 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4345 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4345 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4346 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4346 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4348 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4348 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4349 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4349 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4350 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4350 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4352 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4352 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4353 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4353 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4354 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4354 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4356 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4356 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4357 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4357 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4358 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4358 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4360 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4360 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4361 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4361 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4362 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4362 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4364 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4364 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4365 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4365 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4366 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4366 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4368 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4368 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4369 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4369 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4371 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4371 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4372 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4372 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4373 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4373 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4375 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4375 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4376 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4376 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4377 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4377 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4379 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4379 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4380 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4380 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4381 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4381 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4383 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4383 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4384 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4384 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4385 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4385 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4387 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4387 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4388 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4388 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4389 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4389 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4391 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4391 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4392 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4392 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4394 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4394 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4395 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4395 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4396 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4396 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4398 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4398 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4399 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4399 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4400 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4400 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4402 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4402 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4403 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4403 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4404 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4404 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4406 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4406 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4407 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4407 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4408 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4408 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4410 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4410 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4411 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4411 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4412 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4412 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4414 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4414 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4415 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4415 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4416 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4416 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4418 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4418 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4419 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4419 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4421 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4421 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4422 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4422 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4423 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4423 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4425 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4425 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4426 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4426 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4427 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4427 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4429 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4429 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4430 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4430 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4431 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4431 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4433 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4433 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4434 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4434 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4436 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4436 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4437 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4437 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4438 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4438 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4440 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4440 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4441 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4441 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4442 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4442 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4444 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4444 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4445 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4445 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4446 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4446 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4448 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4448 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4449 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4449 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4450 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4450 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4452 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4452 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4453 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4453 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4455 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4455 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4456 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4456 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4457 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4457 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4459 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4459 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4460 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4460 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4461 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4461 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4463 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4463 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4464 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4464 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4465 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4465 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4467 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4467 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4468 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4468 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4469 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4469 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4471 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4471 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4472 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4472 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4473 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4473 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4475 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4475 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4476 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4476 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4477 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4477 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4479 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4479 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4480 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4480 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4482 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4482 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4483 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4483 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4484 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4484 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4486 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4486 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4487 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4487 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4488 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4488 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4490 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4490 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4491 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4491 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4492 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4492 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4494 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4494 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4495 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4495 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4496 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4496 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4498 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4498 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4499 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4499 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4500 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4500 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4502 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4502 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4503 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4503 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4504 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4504 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4506 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4506 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4507 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4507 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4509 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4509 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4510 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4510 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4511 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4511 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4513 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4513 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4514 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4514 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4515 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4515 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4517 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4517 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4518 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4518 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4519 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4519 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4521 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4521 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4522 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4522 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4523 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4523 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4525 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4525 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4526 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4526 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4527 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4527 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4529 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4529 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4530 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4530 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4531 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4531 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4533 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4533 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4534 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4534 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4536 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4536 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4537 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4537 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4538 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4538 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4540 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4540 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4541 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4541 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4542 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4542 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4544 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4544 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4545 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4545 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4546 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4546 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4548 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4548 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4549 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4549 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4550 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4550 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4552 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4552 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4553 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4553 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4554 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4554 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4556 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4556 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4557 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4557 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4558 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4558 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4560 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4560 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4561 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4561 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4563 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4563 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4564 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4564 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4565 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4565 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4567 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4567 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4568 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4568 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4569 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4569 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4571 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4571 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4572 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4572 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4573 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4573 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4575 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4575 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4576 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4576 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4577 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4577 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4579 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4579 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4580 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4580 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4581 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4581 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4583 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4583 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4584 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4584 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4585 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4585 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4587 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4587 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4588 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4588 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4590 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4590 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4591 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4591 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4592 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4592 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4594 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4594 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4595 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4595 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4596 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4596 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4598 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4598 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4599 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4599 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4600 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4600 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4602 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4602 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4603 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4603 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4604 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4604 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4606 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4606 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4607 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4607 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4608 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4608 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4610 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4610 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4611 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4611 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4612 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4612 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4614 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4614 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4615 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4615 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4617 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4617 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4618 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4618 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4619 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4619 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4621 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4621 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4622 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4622 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4623 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4623 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4625 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4625 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4626 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4626 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4627 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4627 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4629 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4629 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4630 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4630 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4631 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4631 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4633 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4633 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4634 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4634 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4635 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4635 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4637 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4637 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4638 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4638 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4640 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4640 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4641 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4641 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4642 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4642 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4644 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4644 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4645 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4645 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4646 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4646 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4648 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4648 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4649 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4649 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4650 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4650 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4652 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4652 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4653 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4653 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4655 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4655 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4656 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4656 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4657 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4657 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4659 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4659 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4660 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4660 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4661 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4661 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4663 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4663 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4664 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4664 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4665 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4665 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4667 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4667 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4668 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4668 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4669 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4669 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4671 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4671 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4672 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4672 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4673 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4673 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4675 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4675 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4676 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4676 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4677 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4677 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4679 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4679 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4680 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4680 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4681 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4681 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4683 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4683 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4684 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4684 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4686 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4686 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4687 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4687 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4688 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4688 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4690 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4690 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4691 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4691 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4692 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4692 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4694 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4694 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4695 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4695 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4696 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4696 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4698 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4698 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4699 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4699 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4700 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4700 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4702 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4702 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4703 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4703 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4704 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4704 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4706 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4706 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4707 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4707 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4708 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4708 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4710 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4710 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4711 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4711 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4712 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4712 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4714 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4714 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4715 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4715 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4716 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4716 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4718 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4718 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4719 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4719 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4721 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4721 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4722 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4722 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4723 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4723 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4725 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4725 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4726 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4726 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4727 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4727 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4729 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4729 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4730 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4730 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4731 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4731 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4733 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4733 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4734 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4734 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4735 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4735 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4737 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4737 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4738 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4738 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4740 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4740 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4741 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4741 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4742 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4742 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4744 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4744 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4745 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4745 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4746 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4746 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4748 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4748 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4749 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4749 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4750 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4750 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4752 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4752 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4753 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4753 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4754 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4754 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4756 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4756 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4757 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4757 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4758 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4758 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4760 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4760 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4761 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4761 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4762 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4762 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4764 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4764 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4765 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4765 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4767 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4767 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4768 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4768 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4769 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4769 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4771 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4771 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4772 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4772 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4773 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4773 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4775 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4775 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4776 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4776 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4777 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4777 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4779 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4779 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4780 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4780 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4781 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4781 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4783 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4783 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4784 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4784 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4785 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4785 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4787 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4787 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4788 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4788 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4790 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4790 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4791 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4791 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4792 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4792 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4794 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4794 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4795 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4795 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4796 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4796 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4798 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4798 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4799 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4799 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4800 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4800 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4802 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4802 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4803 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4803 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4804 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4804 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4806 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4806 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4807 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4807 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4808 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4808 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4810 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4810 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4811 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4811 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4812 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4812 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4814 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4814 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4815 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4815 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4817 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4817 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4818 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4818 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4819 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4819 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4821 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4821 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4822 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4822 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4823 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4823 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4825 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4825 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4826 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4826 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4827 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4827 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4829 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4829 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4830 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4830 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4831 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4831 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4833 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4833 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4834 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4834 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4835 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4835 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4837 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4837 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4838 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4838 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4839 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4839 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4841 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4841 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4842 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4842 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4844 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4844 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4845 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4845 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4846 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4846 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4848 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4848 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4849 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4849 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4850 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4850 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4852 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4852 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4853 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4853 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4854 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4854 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4856 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4856 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4857 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4857 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4858 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4858 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4860 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4860 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4861 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4861 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4862 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4862 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4864 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4864 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4865 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4865 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4866 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4866 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4868 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4868 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4869 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4869 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4871 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4871 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4872 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4872 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4873 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4873 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4875 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4875 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4876 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4876 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4877 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4877 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4879 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4879 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4880 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4880 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4881 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4881 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4883 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4883 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4884 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4884 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4885 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4885 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4887 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4887 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4888 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4888 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4889 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4889 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4891 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4891 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4892 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4892 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4893 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4893 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4895 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4895 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4896 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4896 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4898 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4898 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4899 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4899 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4900 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4900 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4902 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4902 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4903 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4903 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4904 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4904 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4906 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4906 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4907 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4907 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4908 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4908 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4910 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4910 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4911 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4911 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4912 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4912 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4914 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4914 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4915 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4915 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4916 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4916 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4918 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4918 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4919 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4919 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4920 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4920 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4922 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4922 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4923 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4923 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4925 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4925 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4926 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4926 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4927 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4927 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4929 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4929 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4930 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4930 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4931 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4931 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4933 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4933 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4934 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4934 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4935 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4935 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4937 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4937 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4938 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4938 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4939 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4939 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4941 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4941 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4942 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4942 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4944 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4944 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4945 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4945 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4946 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4946 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4948 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4948 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4949 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4949 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4950 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4950 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4952 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4952 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4953 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4953 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4954 secs base min: -27.000 uS max: 29.900 uS sdev: 4.800 uS 4954 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4956 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 4956 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4957 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 4957 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4958 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 4958 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4960 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 4960 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4961 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 4961 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4963 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 4963 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4964 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 4964 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4965 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 4965 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4967 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 4967 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4968 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 4968 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4969 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 4969 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4971 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 4971 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4972 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 4972 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4973 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 4973 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4975 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 4975 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4976 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 4976 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4977 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 4977 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4979 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 4979 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4980 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 4980 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4981 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 4981 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4983 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 4983 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4984 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 4984 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4986 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 4986 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4987 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 4987 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4988 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 4988 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4990 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 4990 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4991 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 4991 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4992 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 4992 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4994 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 4994 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4995 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 4995 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4996 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 4996 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4998 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 4998 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 4999 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 4999 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5000 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5000 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5002 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5002 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5003 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5003 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5004 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5004 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5006 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5006 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5007 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5007 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5008 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5008 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5010 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5010 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5011 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5011 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5013 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5013 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5014 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5014 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5015 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5015 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5017 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5017 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5018 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5018 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5019 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5019 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5021 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5021 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5022 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5022 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5023 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5023 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5025 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5025 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5026 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5026 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5027 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5027 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5029 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5029 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5030 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5030 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5031 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5031 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5033 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5033 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5034 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5034 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5036 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5036 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5037 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5037 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5038 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5038 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5040 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5040 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5041 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5041 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5042 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5042 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5044 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5044 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5045 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5045 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5046 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5046 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5048 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5048 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5049 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5049 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5050 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5050 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5052 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5052 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5053 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5053 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5054 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5054 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5056 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5056 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5057 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5057 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5058 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5058 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5060 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5060 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5061 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5061 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5063 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5063 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5064 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5064 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5065 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5065 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5067 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5067 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5068 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5068 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5069 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5069 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5071 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5071 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5072 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5072 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5074 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5074 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5075 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5075 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5076 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5076 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5078 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5078 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5079 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5079 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5080 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5080 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5082 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5082 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5083 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5083 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5084 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5084 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5086 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5086 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5087 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5087 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5088 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5088 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5090 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5090 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5091 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5091 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5092 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5092 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5094 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5094 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5095 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5095 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5097 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5097 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5098 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5098 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5099 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5099 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5101 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5101 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5102 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5102 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5103 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5103 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5105 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5105 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5106 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5106 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5107 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5107 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5109 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5109 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5110 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5110 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5111 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5111 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5113 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5113 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5114 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5114 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5115 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5115 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5117 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5117 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5118 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5118 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5119 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5119 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5121 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5121 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5122 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5122 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5124 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5124 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5125 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5125 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5126 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5126 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5128 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5128 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5129 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5129 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5130 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5130 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5132 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5132 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5133 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5133 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5134 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5134 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5136 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5136 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5137 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5137 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5138 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5138 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5140 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5140 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5141 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5141 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5142 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5142 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5144 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5144 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5145 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5145 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5147 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5147 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5148 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5148 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5149 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5149 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5151 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5151 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5152 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5152 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5153 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5153 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5155 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5155 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5156 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5156 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5157 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5157 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5159 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5159 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5160 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5160 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5162 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5162 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5163 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5163 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5164 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5164 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5166 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5166 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5167 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5167 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5168 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5168 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5170 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5170 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5171 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5171 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5172 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5172 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5174 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5174 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5175 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5175 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5176 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5176 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5178 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5178 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5179 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5179 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5180 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5180 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5182 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5182 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5183 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5183 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5185 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5185 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5186 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5186 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5187 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5187 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5189 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5189 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5190 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5190 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5191 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5191 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5193 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5193 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5194 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5194 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5195 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5195 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5197 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5197 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5198 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5198 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5199 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5199 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5201 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5201 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5202 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5202 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5203 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5203 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5205 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5205 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5206 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5206 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5208 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5208 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5209 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5209 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5210 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5210 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5212 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5212 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5213 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5213 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5214 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5214 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5216 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5216 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5217 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5217 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5218 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5218 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5220 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5220 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5221 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5221 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5223 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5223 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5224 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5224 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5225 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5225 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5227 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5227 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5228 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5228 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5229 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5229 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5231 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5231 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5232 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5232 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5233 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5233 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5235 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5235 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5236 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5236 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5237 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5237 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5239 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5239 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5240 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5240 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5241 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5241 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5243 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5243 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5244 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5244 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5245 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5245 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5247 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5247 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5248 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5248 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5250 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5250 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5251 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5251 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5252 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5252 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5254 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5254 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5255 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5255 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5256 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5256 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5258 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5258 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5259 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5259 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5260 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5260 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5262 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5262 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5263 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5263 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5264 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5264 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5266 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5266 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5267 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5267 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5268 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5268 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5270 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5270 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5271 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5271 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5272 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5272 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5274 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5274 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5275 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5275 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5277 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5277 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5278 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5278 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5279 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5279 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5281 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5281 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5282 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5282 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5283 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5283 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5285 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5285 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5286 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5286 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5287 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5287 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5289 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5289 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5290 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5290 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5291 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5291 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5293 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5293 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5294 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5294 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5295 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5295 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5297 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5297 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5298 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5298 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5299 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5299 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5301 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5301 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5302 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5302 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5304 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5304 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5305 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5305 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5306 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5306 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5308 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5308 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5309 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5309 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5310 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5310 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5312 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5312 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5313 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5313 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5315 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5315 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5316 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5316 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5317 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5317 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5319 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5319 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5320 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5320 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5321 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5321 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5323 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5323 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5324 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5324 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5325 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5325 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5327 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5327 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5328 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5328 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5329 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5329 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5331 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5331 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5332 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5332 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5333 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5333 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5335 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5335 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5336 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5336 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5338 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5338 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5339 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5339 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5340 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5340 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5342 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5342 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5343 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5343 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5344 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5344 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5346 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5346 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5347 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5347 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5348 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5348 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5350 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5350 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5351 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5351 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5352 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5352 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5354 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5354 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5355 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5355 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5356 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5356 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5358 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5358 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5359 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5359 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5360 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5360 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5362 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5362 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5363 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5363 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5365 secs base min: -27.900 uS max: 30.300 uS sdev: 4.800 uS 5365 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5366 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5366 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5367 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5367 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5369 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5369 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5370 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5370 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5371 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5371 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5373 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5373 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5374 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5374 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5375 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5375 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5377 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5377 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5378 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5378 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5379 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5379 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5381 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5381 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5382 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5382 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5383 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5383 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5385 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5385 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5386 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5386 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5388 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5388 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5389 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5389 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5390 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5390 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5392 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5392 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5393 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5393 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5394 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5394 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5396 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5396 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5397 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5397 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5398 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5398 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5400 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5400 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5401 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5401 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5402 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5402 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5404 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5404 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5405 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5405 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5406 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5406 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5408 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5408 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5409 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5409 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5411 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5411 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5412 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5412 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5413 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5413 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5415 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5415 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5416 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5416 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5417 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5417 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5419 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5419 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5420 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5420 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5421 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5421 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5423 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5423 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5424 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5424 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5426 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5426 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5427 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5427 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5428 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5428 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5430 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5430 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5431 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5431 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5432 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5432 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5434 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5434 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5435 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5435 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5436 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5436 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5438 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5438 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5439 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5439 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5440 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5440 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5442 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5442 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5443 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5443 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5444 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5444 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5446 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5446 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5447 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5447 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5449 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5449 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5450 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5450 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5451 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5451 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5453 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5453 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5454 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5454 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5455 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5455 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5457 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5457 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5458 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5458 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5459 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5459 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5461 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5461 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5462 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5462 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5463 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5463 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5465 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5465 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5466 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5466 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5467 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5467 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5469 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5469 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5470 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5470 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5471 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5471 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5473 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5473 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5474 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5474 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5475 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5475 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5477 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5477 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5478 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5478 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5480 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5480 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5481 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5481 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5482 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5482 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5484 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5484 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5485 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5485 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5486 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5486 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5488 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5488 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5489 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5489 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5490 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5490 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5492 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5492 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5493 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5493 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5494 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5494 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5496 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5496 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5497 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5497 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5498 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5498 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5500 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5500 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5501 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5501 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5502 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5502 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5504 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5504 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5505 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5505 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5507 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5507 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5508 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5508 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5509 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5509 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5511 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5511 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5512 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5512 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5513 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5513 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5515 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5515 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5516 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5516 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5517 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5517 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5519 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5519 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5520 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5520 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5521 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5521 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5523 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5523 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5524 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5524 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5525 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5525 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5527 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5527 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5528 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5528 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5529 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5529 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5531 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5531 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5532 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5532 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5534 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5534 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5535 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5535 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5536 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5536 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5538 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5538 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5539 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5539 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5540 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5540 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5542 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5542 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5543 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5543 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5544 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5544 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5546 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5546 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5547 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5547 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5548 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5548 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5550 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5550 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5551 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5551 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5553 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5553 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5554 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5554 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5555 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5555 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5557 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5557 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5558 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5558 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5559 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5559 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5561 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5561 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5562 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5562 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5563 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5563 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5565 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5565 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5566 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5566 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5567 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5567 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5569 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5569 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5570 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5570 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5572 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5572 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5573 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5573 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5574 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5574 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5576 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5576 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5577 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5577 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5578 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5578 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5580 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5580 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5581 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5581 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5582 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5582 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5584 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5584 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5585 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5585 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5586 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5586 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5588 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5588 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5589 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5589 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5590 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5590 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5592 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5592 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5593 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5593 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5595 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5595 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5596 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5596 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5597 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5597 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5599 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5599 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5600 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5600 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5601 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5601 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5603 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5603 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5604 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5604 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5605 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5605 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5607 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5607 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5608 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5608 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5610 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5610 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5611 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5611 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5612 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5612 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5614 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5614 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5615 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5615 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5616 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5616 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5618 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5618 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5619 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5619 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5620 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5620 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5622 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5622 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5623 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5623 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5624 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5624 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5626 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5626 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5627 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5627 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5628 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5628 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5630 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5630 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5631 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5631 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5633 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5633 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5634 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5634 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5635 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5635 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5637 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5637 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5638 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5638 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5639 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5639 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5641 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5641 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5642 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5642 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5643 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5643 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5645 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5645 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5646 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5646 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5647 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5647 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5649 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5649 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5650 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5650 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5651 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5651 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5653 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5653 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5654 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5654 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5656 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5656 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5657 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5657 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5658 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5658 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5660 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5660 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5661 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5661 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5662 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5662 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5664 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5664 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5665 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5665 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5666 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5666 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5668 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5668 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5669 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5669 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5670 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5670 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5672 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5672 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5673 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5673 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5674 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5674 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5676 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5676 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5677 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5677 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5678 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5678 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5680 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5680 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5681 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5681 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5683 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5683 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5684 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5684 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5685 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5685 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5687 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5687 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5688 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5688 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5689 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5689 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5691 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5691 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5692 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5692 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5693 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5693 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5695 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5695 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5696 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5696 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5697 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5697 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5699 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5699 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5700 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5700 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5701 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5701 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5703 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5703 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5704 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5704 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5705 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5705 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5707 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5707 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5708 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5708 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5709 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5709 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5711 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5711 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5712 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5712 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5714 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5714 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5715 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5715 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5716 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5716 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5718 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5718 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5719 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5719 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5720 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5720 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5722 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5722 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5723 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5723 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5724 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5724 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5726 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5726 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5727 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5727 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5728 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5728 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5730 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5730 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5731 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5731 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5733 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5733 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5734 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5734 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5735 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5735 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5737 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5737 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5738 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5738 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5739 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5739 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5741 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5741 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5742 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5742 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5743 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5743 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5745 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5745 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5746 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5746 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5747 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5747 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5749 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5749 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5750 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5750 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5751 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5751 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5753 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5753 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5754 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5754 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5755 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5755 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5757 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5757 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5758 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5758 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5760 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5760 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5761 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5761 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5762 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5762 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5764 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5764 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5765 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5765 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5766 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5766 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5768 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5768 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5769 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5769 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5770 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5770 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5772 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5772 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5773 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5773 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5774 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5774 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5776 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5776 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5777 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5777 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5778 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5778 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5780 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5780 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5781 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5781 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5783 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5783 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5784 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5784 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5785 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5785 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5787 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5787 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5788 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5788 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5789 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5789 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5791 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5791 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5792 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5792 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5793 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5793 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5795 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5795 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5796 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5796 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5797 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5797 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5799 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5799 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5800 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5800 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5801 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5801 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5803 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5803 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5804 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5804 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5805 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5805 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5807 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5807 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5808 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5808 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5810 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5810 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5811 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5811 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5812 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5812 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5814 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5814 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5815 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5815 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5816 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5816 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5818 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5818 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5819 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5819 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5820 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5820 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5822 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5822 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5823 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5823 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5824 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5824 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5826 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5826 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5827 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5827 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5828 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5828 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5830 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5830 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5831 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5831 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5833 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5833 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5834 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5834 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5835 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5835 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5837 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5837 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5838 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5838 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5839 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5839 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5841 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5841 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5842 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5842 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5844 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5844 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5845 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5845 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5846 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5846 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5848 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5848 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5849 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5849 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5850 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5850 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5852 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5852 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5853 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5853 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5854 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5854 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5856 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5856 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5857 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5857 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5858 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5858 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5860 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5860 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5861 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5861 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5862 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5862 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5864 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5864 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5865 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5865 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5866 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5866 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5868 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5868 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5869 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5869 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5871 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5871 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5872 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5872 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5873 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5873 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5875 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5875 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5876 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5876 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5878 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5878 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5879 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5879 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5880 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5880 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5882 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5882 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5883 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5883 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5884 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5884 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5886 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5886 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5887 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5887 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5888 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5888 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5890 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5890 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5891 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5891 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5892 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5892 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5894 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5894 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5895 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5895 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5896 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5896 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5898 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5898 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5899 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5899 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5900 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5900 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5902 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5902 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5903 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5903 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5905 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5905 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5906 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5906 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5907 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5907 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5909 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5909 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5910 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5910 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5911 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5911 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5913 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5913 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5914 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5914 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5915 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5915 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5917 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5917 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5918 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5918 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5919 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5919 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5921 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5921 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5922 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5922 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5923 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5923 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5925 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5925 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5926 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5926 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5928 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5928 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5929 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5929 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5930 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5930 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5932 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5932 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5933 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5933 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5934 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5934 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5936 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5936 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5937 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5937 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5938 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5938 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5940 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5940 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5941 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5941 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5942 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5942 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5944 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5944 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5945 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5945 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5946 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5946 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5948 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5948 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5949 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5949 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5950 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5950 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5952 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5952 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5953 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5953 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5955 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5955 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5956 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5956 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5957 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5957 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5959 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5959 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5960 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5960 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5961 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5961 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5963 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5963 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5964 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5964 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5965 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5965 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5967 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5967 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5968 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5968 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5969 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5969 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5971 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5971 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5972 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5972 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5973 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5973 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5975 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5975 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5976 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5976 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5978 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5978 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5979 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5979 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5980 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5980 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5982 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5982 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5983 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5983 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5984 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5984 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5986 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5986 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5987 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5987 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5988 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5988 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5990 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5990 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5991 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5991 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5992 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5992 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5994 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5994 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5995 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5995 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 5996 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5996 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5998 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5998 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 5999 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 5999 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6000 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6000 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6002 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6002 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6003 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6003 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6005 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6005 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6006 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6006 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6007 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6007 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6009 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6009 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6010 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6010 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6011 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6011 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6013 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6013 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6014 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6014 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6015 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6015 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6017 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6017 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6018 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6018 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6019 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6019 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6021 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6021 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6022 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6022 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6023 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6023 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6025 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6025 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6026 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6026 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6027 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6027 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6029 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6029 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6030 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6030 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6031 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6031 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6033 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6033 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6034 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6034 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6036 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6036 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6037 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6037 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6038 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6038 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6040 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6040 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6041 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6041 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6043 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6043 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6044 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6044 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6045 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6045 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6047 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6047 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6048 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6048 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6049 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6049 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6051 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6051 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6052 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6052 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6053 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6053 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6055 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6055 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6056 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6056 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6057 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6057 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6059 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6059 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6060 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6060 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6061 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6061 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6063 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6063 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6064 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6064 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6065 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6065 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6067 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6067 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6068 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6068 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6070 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6070 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6071 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6071 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6072 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6072 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6074 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6074 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6075 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6075 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6076 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6076 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6078 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6078 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6079 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6079 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6080 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6080 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6082 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6082 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6083 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6083 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6084 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6084 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6086 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6086 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6087 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6087 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6088 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6088 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6090 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6090 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6091 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6091 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6092 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6092 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6094 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6094 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6095 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6095 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6097 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6097 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6098 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6098 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6099 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6099 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6101 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6101 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6102 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6102 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6103 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6103 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6105 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6105 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6106 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6106 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6108 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6108 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6109 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6109 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6110 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6110 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6112 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6112 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6113 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6113 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6114 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6114 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6116 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6116 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6117 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6117 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6118 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6118 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6120 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6120 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6121 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6121 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6122 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6122 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6124 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6124 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6125 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6125 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6126 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6126 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6128 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6128 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6129 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6129 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6130 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6130 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6132 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6132 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6133 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6133 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6135 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6135 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6136 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6136 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6137 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6137 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6139 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6139 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6140 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6140 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6141 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6141 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6143 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6143 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6144 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6144 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6145 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6145 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6147 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6147 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6148 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6148 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6149 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6149 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6151 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6151 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6152 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6152 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6153 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6153 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6155 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6155 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6156 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6156 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6157 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6157 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6159 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6159 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6160 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6160 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6162 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6162 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6163 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6163 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6164 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6164 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6166 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6166 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6167 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6167 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6168 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6168 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6170 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6170 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6171 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6171 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6172 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6172 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6174 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6174 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6175 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6175 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6176 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6176 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6178 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6178 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6179 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6179 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6180 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6180 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6182 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6182 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6183 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6183 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6185 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6185 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6186 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6186 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6187 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6187 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6189 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6189 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6190 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6190 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6191 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6191 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6193 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6193 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6194 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6194 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6195 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6195 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6197 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6197 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6198 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6198 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6199 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6199 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6201 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6201 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6202 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6202 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6203 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6203 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6205 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6205 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6206 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6206 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6207 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6207 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6209 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6209 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6210 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6210 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6212 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6212 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6213 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6213 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6214 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6214 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6216 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6216 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6217 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6217 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6218 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6218 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6220 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6220 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6221 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6221 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6222 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6222 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6224 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6224 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6225 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6225 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6226 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6226 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6228 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6228 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6229 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6229 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6230 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6230 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6232 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6232 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6233 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6233 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6234 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6234 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6236 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6236 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6237 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6237 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6239 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6239 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6240 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6240 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6241 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6241 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6243 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6243 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6244 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6244 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6245 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6245 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6247 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6247 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6248 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6248 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6249 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6249 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6251 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6251 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6252 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6252 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6254 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6254 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6255 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6255 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6256 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6256 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6258 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6258 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6259 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6259 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6260 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6260 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6262 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6262 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6263 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6263 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6264 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6264 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6266 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6266 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6267 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6267 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6268 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6268 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6270 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6270 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6271 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6271 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6273 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6273 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6274 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6274 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6275 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6275 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6277 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6277 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6278 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6278 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6279 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6279 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6281 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6281 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6282 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6282 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6283 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6283 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6285 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6285 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6286 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6286 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6287 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6287 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6289 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6289 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6290 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6290 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6291 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6291 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6293 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6293 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6294 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6294 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6295 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6295 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6297 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6297 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6298 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6298 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6300 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6300 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6301 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6301 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6302 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6302 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6304 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6304 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6305 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6305 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6306 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6306 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6308 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6308 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6309 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6309 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6310 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6310 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6312 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6312 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6313 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6313 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6314 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6314 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6316 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6316 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6317 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6317 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6318 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6318 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6320 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6320 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6321 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6321 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6323 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6323 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6324 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6324 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6325 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6325 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6327 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6327 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6328 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6328 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6329 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6329 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6331 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6331 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6332 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6332 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6334 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6334 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6335 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6335 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6336 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6336 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6338 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6338 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6339 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6339 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6340 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6340 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6342 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6342 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6343 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6343 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6344 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6344 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6346 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6346 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6347 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6347 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6348 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6348 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6350 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6350 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6351 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6351 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6352 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6352 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6354 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6354 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6355 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6355 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6356 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6356 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6358 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6358 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6359 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6359 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6361 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6361 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6362 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6362 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6363 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6363 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6365 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6365 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6366 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6366 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6367 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6367 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6369 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6369 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6370 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6370 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6371 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6371 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6373 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6373 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6374 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6374 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6375 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6375 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6377 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6377 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6378 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6378 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6379 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6379 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6381 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6381 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6382 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6382 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6383 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6383 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6385 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6385 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6386 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6386 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6388 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6388 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6389 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6389 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6390 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6390 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6392 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6392 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6393 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6393 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6394 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6394 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6396 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6396 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6397 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6397 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6398 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6398 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6400 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6400 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6401 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6401 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6402 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6402 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6404 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6404 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6405 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6405 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6406 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6406 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6408 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6408 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6409 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6409 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6411 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6411 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6412 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6412 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6413 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6413 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6415 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6415 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6416 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6416 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6417 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6417 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6419 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6419 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6420 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6420 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6421 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6421 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6423 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6423 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6424 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6424 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6425 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6425 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6427 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6427 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6428 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6428 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6429 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6429 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6431 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6431 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6432 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6432 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6434 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6434 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6435 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6435 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6436 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6436 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6438 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6438 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6439 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6439 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6440 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6440 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6442 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6442 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6443 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6443 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6445 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6445 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6446 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6446 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6447 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6447 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6449 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6449 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6450 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6450 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6451 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6451 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6453 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6453 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6454 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6454 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6455 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6455 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6457 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6457 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6458 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6458 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6459 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6459 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6461 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6461 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6462 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6462 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6463 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6463 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6465 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6465 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6466 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6466 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6467 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6467 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6469 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6469 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6470 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6470 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6472 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6472 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6473 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6473 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6474 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6474 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6476 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6476 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6477 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6477 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6478 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6478 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6480 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6480 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6481 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6481 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6482 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6482 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6484 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6484 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6485 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6485 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6486 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6486 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6488 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6488 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6489 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6489 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6490 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6490 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6492 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6492 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6493 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6493 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6495 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6495 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6496 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6496 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6497 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6497 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6499 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6499 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6500 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6500 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6501 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6501 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6503 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6503 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6504 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6504 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6505 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6505 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6507 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6507 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6508 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6508 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6509 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6509 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6511 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6511 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6512 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6512 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6513 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6513 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6515 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6515 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6516 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6516 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6517 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6517 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6519 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6519 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6520 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6520 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6522 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6522 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6523 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6523 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6524 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6524 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6526 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6526 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6527 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6527 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6528 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6528 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6530 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6530 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6531 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6531 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6532 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6532 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6534 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6534 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6535 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6535 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6537 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6537 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6538 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6538 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6539 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6539 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6541 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6541 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6542 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6542 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6543 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6543 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6545 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6545 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6546 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6546 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6547 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6547 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6549 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6549 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6550 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6550 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6551 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6551 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6553 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6553 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6554 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6554 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6556 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6556 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6557 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6557 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6558 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6558 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6560 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6560 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6561 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6561 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6562 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6562 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6564 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6564 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6565 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6565 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6566 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6566 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6568 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6568 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6569 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6569 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6570 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6570 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6572 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6572 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6573 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6573 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6574 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6574 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6576 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6576 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6577 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6577 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6578 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6578 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6580 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6580 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6581 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6581 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6583 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6583 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6584 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6584 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6585 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6585 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6587 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6587 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6588 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6588 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6589 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6589 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6591 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6591 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6592 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6592 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6593 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6593 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6595 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6595 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6596 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6596 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6597 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6597 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6599 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6599 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6600 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6600 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6601 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6601 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6603 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6603 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6604 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6604 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6605 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6605 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6607 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6607 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6608 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6608 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6610 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6610 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6611 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6611 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6612 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6612 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6614 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6614 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6615 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6615 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6616 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6616 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6618 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6618 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6619 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6619 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6621 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6621 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6622 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6622 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6623 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6623 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6625 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6625 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6626 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6626 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6627 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6627 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6629 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6629 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6630 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6630 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6631 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6631 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6633 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6633 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6634 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6634 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6635 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6635 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6637 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6637 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6638 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6638 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6639 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6639 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6641 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6641 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6642 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6642 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6643 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6643 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6645 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6645 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6646 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6646 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6648 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6648 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6649 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6649 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6650 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6650 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6652 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6652 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6653 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6653 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6654 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6654 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6656 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6656 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6657 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6657 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6658 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6658 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6660 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6660 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6661 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6661 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6662 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6662 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6664 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6664 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6665 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6665 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6666 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6666 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6668 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6668 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6669 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6669 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6670 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6670 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6672 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6672 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6673 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6673 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6675 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6675 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6676 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6676 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6677 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6677 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6679 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6679 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6680 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6680 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6681 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6681 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6683 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6683 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6684 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6684 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6685 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6685 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6687 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6687 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6688 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6688 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6689 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6689 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6691 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6691 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6692 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6692 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6693 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6693 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6695 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6695 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6696 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6696 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6697 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6697 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6699 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6699 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6700 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6700 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6702 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6702 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6703 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6703 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6704 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6704 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6706 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6706 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6707 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6707 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6708 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6708 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6710 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6710 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6711 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6711 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6712 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6712 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6714 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6714 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6715 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6715 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6717 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6717 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6718 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6718 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6719 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6719 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6721 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6721 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6722 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6722 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6723 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6723 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6725 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6725 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6726 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6726 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6727 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6727 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6729 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6729 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6730 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6730 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6731 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6731 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6733 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6733 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6734 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6734 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6736 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6736 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6737 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6737 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6738 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6738 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6740 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6740 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6741 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6741 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6742 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6742 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6744 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6744 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6745 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6745 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6746 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6746 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6748 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6748 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6749 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6749 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6750 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6750 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6752 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6752 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6753 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6753 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6754 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6754 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6756 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6756 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6757 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6757 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6758 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6758 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6760 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6760 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6761 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6761 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6763 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6763 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6764 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6764 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6765 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6765 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6767 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6767 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6768 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6768 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6769 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6769 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6771 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6771 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6772 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6772 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6773 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6773 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6775 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6775 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6776 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6776 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6777 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6777 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6779 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6779 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6780 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6780 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6781 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6781 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6783 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6783 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6784 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6784 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6785 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6785 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6787 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6787 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6788 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6788 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6790 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6790 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6791 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6791 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6792 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6792 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6794 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6794 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6795 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6795 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6796 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6796 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6798 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6798 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6799 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6799 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6800 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6800 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6802 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6802 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6803 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6803 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6804 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6804 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6806 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6806 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6807 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6807 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6808 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6808 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6810 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6810 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6811 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6811 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6812 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6812 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6814 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6814 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6815 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6815 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6817 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6817 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6818 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6818 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6819 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6819 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6821 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6821 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6822 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6822 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6823 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6823 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6825 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6825 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6826 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6826 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6827 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6827 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6829 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6829 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6830 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6830 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6832 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6832 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6833 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6833 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6834 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6834 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6836 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6836 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6837 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6837 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6838 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6838 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6840 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6840 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6841 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6841 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6842 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6842 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6844 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6844 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6845 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6845 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6846 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6846 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6848 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6848 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6849 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6849 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6851 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6851 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6852 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6852 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6853 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6853 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6855 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6855 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6856 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6856 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6857 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6857 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6859 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6859 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6860 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6860 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6861 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6861 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6863 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6863 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6864 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6864 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6865 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6865 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6867 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6867 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6868 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6868 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6869 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6869 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6871 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6871 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6872 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6872 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6873 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6873 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6875 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6875 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6876 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6876 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6878 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6878 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6879 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6879 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6880 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6880 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6882 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6882 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6883 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6883 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6884 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6884 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6886 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6886 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6887 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6887 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6888 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6888 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6890 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6890 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6891 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6891 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6892 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6892 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6894 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6894 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6895 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6895 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6896 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6896 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6898 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6898 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6899 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6899 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6900 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6900 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6902 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6902 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6903 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6903 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6905 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6905 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6906 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6906 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6907 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6907 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6909 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6909 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6910 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6910 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6911 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6911 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6913 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6913 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6914 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6914 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6915 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6915 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6917 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6917 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6918 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6918 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6919 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6919 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6921 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6921 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6922 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6922 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6923 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6923 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6925 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6925 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6926 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6926 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6927 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6927 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6929 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6929 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6930 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6930 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6932 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6932 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6933 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6933 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6934 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6934 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6936 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6936 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6937 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6937 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6938 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6938 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6940 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6940 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6941 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6941 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6942 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6942 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6944 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6944 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6945 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6945 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6946 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6946 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6948 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6948 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6949 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6949 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6950 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6950 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6952 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6952 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6953 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6953 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6954 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6954 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6956 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6956 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6957 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6957 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6959 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6959 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6960 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6960 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6961 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6961 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6963 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6963 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6964 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6964 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6965 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6965 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6967 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6967 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6968 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6968 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6969 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6969 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6971 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6971 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6972 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6972 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6973 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6973 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6975 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6975 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6976 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6976 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6977 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6977 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6979 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6979 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6980 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6980 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6981 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6981 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6983 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6983 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6984 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6984 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6986 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6986 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6987 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6987 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6988 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6988 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6990 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6990 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6991 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6991 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6992 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6992 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6994 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6994 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6995 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6995 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 6997 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6997 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6998 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6998 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 6999 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 6999 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 7001 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 7001 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 7002 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 7002 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 7003 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 7003 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 7005 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 7005 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 7006 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 7006 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 7007 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 7007 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 7009 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 7009 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 7010 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 7010 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 7011 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 7011 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 7013 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 7013 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 7014 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 7014 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 7015 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 7015 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 7017 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 7017 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 7018 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 7018 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 7019 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 7019 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 7021 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 7021 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 7022 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 7022 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 7024 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 7024 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 7025 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 7025 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 7026 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 7026 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 7028 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 7028 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 7029 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 7029 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 7030 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 7030 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 7032 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 7032 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 7033 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 7033 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 7034 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 7034 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 7036 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 7036 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 7037 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 7037 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 7038 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 7038 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 7040 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 7040 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 7041 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 7041 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 7042 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 7042 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 7044 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 7044 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 7045 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 7045 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 7046 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 7046 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 7048 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 7048 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 7049 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 7049 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 7051 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 7051 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 7052 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 7052 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 7053 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 7053 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 7055 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 7055 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 7056 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 7056 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 7057 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 7057 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 7059 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 7059 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 7060 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 7060 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 7061 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 7061 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 7063 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 7063 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 7064 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 7064 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 7066 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 7066 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 7067 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 7067 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 7068 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 7068 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 7070 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 7070 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 7071 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 7071 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 7072 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 7072 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 7074 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 7074 secs servo min: -31.600 uS max: 30.900 uS sdev: 1.600 uS 7075 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 7075 secs servo min: -37.800 uS max: 35.500 uS sdev: 1.600 uS 7076 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 7076 secs servo min: -37.800 uS max: 35.500 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 7078 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 7078 secs servo min: -37.800 uS max: 35.500 uS sdev: 1.600 uS 7079 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 7079 secs servo min: -37.800 uS max: 35.500 uS sdev: 1.600 uS 7080 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 7080 secs servo min: -37.800 uS max: 35.500 uS sdev: 1.600 uS 7082 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 7082 secs servo min: -37.800 uS max: 35.500 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 7083 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 7083 secs servo min: -37.800 uS max: 35.500 uS sdev: 1.600 uS 7085 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 7085 secs servo min: -37.800 uS max: 35.500 uS sdev: 1.600 uS 7086 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 7086 secs servo min: -37.800 uS max: 35.500 uS sdev: 1.600 uS 7087 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 7087 secs servo min: -37.800 uS max: 35.500 uS sdev: 1.600 uS 7089 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 7089 secs servo min: -37.800 uS max: 35.500 uS sdev: 1.600 uS 7090 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 7090 secs servo min: -37.800 uS max: 35.500 uS sdev: 1.600 uS 7091 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 7091 secs servo min: -37.800 uS max: 35.500 uS sdev: 1.600 uS 7093 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 7093 secs servo min: -37.800 uS max: 35.500 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 7094 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 7094 secs servo min: -37.800 uS max: 35.500 uS sdev: 1.600 uS 7095 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 7095 secs servo min: -37.800 uS max: 35.500 uS sdev: 1.600 uS 7097 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 7097 secs servo min: -37.800 uS max: 35.500 uS sdev: 1.600 uS 7098 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 7098 secs servo min: -37.800 uS max: 35.500 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 7099 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 7099 secs servo min: -37.800 uS max: 35.500 uS sdev: 1.600 uS 7101 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 7101 secs servo min: -37.800 uS max: 35.500 uS sdev: 1.600 uS 7102 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 7102 secs servo min: -37.800 uS max: 35.500 uS sdev: 1.600 uS 7103 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 7103 secs servo min: -37.800 uS max: 35.500 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 7105 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 7105 secs servo min: -37.800 uS max: 35.500 uS sdev: 1.600 uS 7106 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 7106 secs servo min: -37.800 uS max: 35.500 uS sdev: 1.600 uS 7107 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 7107 secs servo min: -37.800 uS max: 35.500 uS sdev: 1.600 uS 7109 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 7109 secs servo min: -37.800 uS max: 35.500 uS sdev: 1.600 uS 7110 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 7110 secs servo min: -37.800 uS max: 35.500 uS sdev: 1.600 uS 7112 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 7112 secs servo min: -37.800 uS max: 35.500 uS sdev: 1.600 uS 7113 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 7113 secs servo min: -37.800 uS max: 35.500 uS sdev: 1.600 uS 7114 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 7114 secs servo min: -37.800 uS max: 35.500 uS sdev: 1.600 uS 7116 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 7116 secs servo min: -37.800 uS max: 35.500 uS sdev: 1.600 uS 7117 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 7117 secs servo min: -37.800 uS max: 35.500 uS sdev: 1.600 uS 7118 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 7118 secs servo min: -37.800 uS max: 35.500 uS sdev: 1.600 uS 7120 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 7120 secs servo min: -37.800 uS max: 35.500 uS sdev: 1.600 uS 7121 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 7121 secs servo min: -37.800 uS max: 35.500 uS sdev: 1.600 uS 7122 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 7122 secs servo min: -37.800 uS max: 35.500 uS sdev: 1.600 uS 7124 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 7124 secs servo min: -37.800 uS max: 35.500 uS sdev: 1.600 uS 7125 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 7125 secs servo min: -37.800 uS max: 35.500 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 7126 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 7126 secs servo min: -37.800 uS max: 35.500 uS sdev: 1.600 uS 7128 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 7128 secs servo min: -37.800 uS max: 35.500 uS sdev: 1.600 uS 7129 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 7129 secs servo min: -37.800 uS max: 35.500 uS sdev: 1.600 uS 7130 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 7130 secs servo min: -37.800 uS max: 35.500 uS sdev: 1.600 uS 7132 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 7132 secs servo min: -37.800 uS max: 35.500 uS sdev: 1.600 uS 7133 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 7133 secs servo min: -37.800 uS max: 35.500 uS sdev: 1.600 uS 7134 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 7134 secs servo min: -37.800 uS max: 35.500 uS sdev: 1.600 uS 7136 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 7136 secs servo min: -37.800 uS max: 35.500 uS sdev: 1.600 uS 7137 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 7137 secs servo min: -37.800 uS max: 35.500 uS sdev: 1.600 uS 7139 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 7139 secs servo min: -37.800 uS max: 35.500 uS sdev: 1.600 uS 7140 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 7140 secs servo min: -37.800 uS max: 35.500 uS sdev: 1.600 uS 7141 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 7141 secs servo min: -37.800 uS max: 35.500 uS sdev: 1.600 uS 7143 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 7143 secs servo min: -37.800 uS max: 35.500 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 7144 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 7144 secs servo min: -37.800 uS max: 35.500 uS sdev: 1.600 uS 7145 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 7145 secs servo min: -37.800 uS max: 35.500 uS sdev: 1.600 uS 7147 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 7147 secs servo min: -37.800 uS max: 35.500 uS sdev: 1.600 uS 7148 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 7148 secs servo min: -37.800 uS max: 35.500 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 7149 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 7149 secs servo min: -37.800 uS max: 35.500 uS sdev: 1.600 uS 7151 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 7151 secs servo min: -37.800 uS max: 35.500 uS sdev: 1.600 uS 7152 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 7152 secs servo min: -37.800 uS max: 35.500 uS sdev: 1.600 uS 7153 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 7153 secs servo min: -37.800 uS max: 35.500 uS sdev: 1.600 uS 7155 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 7155 secs servo min: -37.800 uS max: 35.500 uS sdev: 1.600 uS 7156 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 7156 secs servo min: -37.800 uS max: 35.500 uS sdev: 1.600 uS 7157 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 7157 secs servo min: -37.800 uS max: 35.500 uS sdev: 1.600 uS 7159 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 7159 secs servo min: -37.800 uS max: 35.500 uS sdev: 1.600 uS 7160 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 7160 secs servo min: -37.800 uS max: 35.500 uS sdev: 1.600 uS 7161 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 7161 secs servo min: -37.800 uS max: 35.500 uS sdev: 1.600 uS 7163 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 7163 secs servo min: -37.800 uS max: 35.500 uS sdev: 1.600 uS 7164 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 7164 secs servo min: -37.800 uS max: 35.500 uS sdev: 1.600 uS 7166 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 7166 secs servo min: -37.800 uS max: 35.500 uS sdev: 1.600 uS 7167 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 7167 secs servo min: -37.800 uS max: 35.500 uS sdev: 1.600 uS 7168 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 7168 secs servo min: -37.800 uS max: 35.500 uS sdev: 1.600 uS 7170 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 7170 secs servo min: -37.800 uS max: 35.500 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 7171 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 7171 secs servo min: -37.800 uS max: 35.500 uS sdev: 1.600 uS 7172 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 7172 secs servo min: -37.800 uS max: 35.500 uS sdev: 1.600 uS 7174 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 7174 secs servo min: -37.800 uS max: 35.500 uS sdev: 1.600 uS 7175 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 7175 secs servo min: -37.800 uS max: 35.500 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 7176 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 7176 secs servo min: -37.800 uS max: 35.500 uS sdev: 1.600 uS 7178 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 7178 secs servo min: -37.800 uS max: 35.500 uS sdev: 1.600 uS 7179 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 7179 secs servo min: -37.800 uS max: 35.500 uS sdev: 1.600 uS 7180 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 7180 secs servo min: -37.800 uS max: 35.500 uS sdev: 1.600 uS 7182 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 7182 secs servo min: -37.800 uS max: 35.500 uS sdev: 1.600 uS 7183 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 7183 secs servo min: -37.800 uS max: 35.500 uS sdev: 1.600 uS 7184 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 7184 secs servo min: -37.800 uS max: 35.500 uS sdev: 1.600 uS 7186 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 7186 secs servo min: -37.800 uS max: 35.500 uS sdev: 1.600 uS 7187 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 7187 secs servo min: -37.800 uS max: 35.500 uS sdev: 1.600 uS 7189 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 7189 secs servo min: -37.800 uS max: 35.500 uS sdev: 1.600 uS 7190 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 7190 secs servo min: -37.800 uS max: 35.500 uS sdev: 1.600 uS 7191 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 7191 secs servo min: -37.800 uS max: 35.500 uS sdev: 1.600 uS 7193 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 7193 secs servo min: -37.800 uS max: 35.500 uS sdev: 1.600 uS 7194 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 7194 secs servo min: -37.800 uS max: 35.500 uS sdev: 1.600 uS 7195 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 7195 secs servo min: -37.800 uS max: 35.500 uS sdev: 1.600 uS 7197 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 7197 secs servo min: -37.800 uS max: 35.500 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) 7198 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 7198 secs servo min: -37.800 uS max: 35.500 uS sdev: 1.600 uS 7199 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 7199 secs servo min: -37.800 uS max: 35.500 uS sdev: 1.600 uS 7201 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 7201 secs servo min: -37.800 uS max: 35.500 uS sdev: 1.600 uS 7202 secs base min: -31.800 uS max: 32.800 uS sdev: 4.800 uS 7202 secs servo min: -37.800 uS max: 35.500 uS sdev: 1.600 uS Core 0: +30.0°C (high = +76.0°C, crit = +100.0°C) Note: Using POSIX realtime 0 secs base min: -8.100 uS max: 9.900 uS sdev: 0.900 uS 0 secs servo min: -3.300 uS max: 3.600 uS sdev: 1.000 uS 2 secs base min: -13.000 uS max: 13.200 uS sdev: 0.900 uS 2 secs servo min: -13.600 uS max: 9.900 uS sdev: 1.000 uS 3 secs base min: -13.000 uS max: 14.500 uS sdev: 1.000 uS 3 secs servo min: -13.600 uS max: 12.200 uS sdev: 1.000 uS 4 secs base min: -13.600 uS max: 15.600 uS sdev: 1.000 uS 4 secs servo min: -13.600 uS max: 13.200 uS sdev: 1.100 uS 6 secs base min: -13.600 uS max: 15.600 uS sdev: 1.100 uS 6 secs servo min: -13.600 uS max: 13.200 uS sdev: 1.100 uS 7 secs base min: -14.700 uS max: 16.500 uS sdev: 1.100 uS 7 secs servo min: -13.600 uS max: 13.200 uS sdev: 1.100 uS 9 secs base min: -17.700 uS max: 16.500 uS sdev: 1.100 uS 9 secs servo min: -13.600 uS max: 13.200 uS sdev: 1.100 uS 10 secs base min: -17.700 uS max: 16.500 uS sdev: 1.100 uS 10 secs servo min: -13.800 uS max: 13.200 uS sdev: 1.200 uS 11 secs base min: -17.700 uS max: 16.500 uS sdev: 1.100 uS 11 secs servo min: -13.800 uS max: 13.200 uS sdev: 1.100 uS 13 secs base min: -17.700 uS max: 17.900 uS sdev: 1.100 uS 13 secs servo min: -13.800 uS max: 13.200 uS sdev: 1.100 uS 14 secs base min: -17.700 uS max: 17.900 uS sdev: 1.100 uS 14 secs servo min: -13.800 uS max: 13.200 uS sdev: 1.100 uS 15 secs base min: -17.700 uS max: 17.900 uS sdev: 1.100 uS 15 secs servo min: -13.800 uS max: 13.200 uS sdev: 1.100 uS 17 secs base min: -17.700 uS max: 17.900 uS sdev: 1.100 uS 17 secs servo min: -15.000 uS max: 13.200 uS sdev: 1.100 uS 18 secs base min: -17.700 uS max: 17.900 uS sdev: 1.100 uS 18 secs servo min: -15.000 uS max: 13.200 uS sdev: 1.100 uS 19 secs base min: -17.700 uS max: 17.900 uS sdev: 1.100 uS 19 secs servo min: -15.000 uS max: 13.200 uS sdev: 1.100 uS 21 secs base min: -17.700 uS max: 17.900 uS sdev: 1.100 uS 21 secs servo min: -15.000 uS max: 13.200 uS sdev: 1.100 uS 22 secs base min: -17.700 uS max: 17.900 uS sdev: 1.100 uS 22 secs servo min: -15.000 uS max: 13.200 uS sdev: 1.100 uS 23 secs base min: -17.700 uS max: 17.900 uS sdev: 1.100 uS 23 secs servo min: -15.000 uS max: 13.200 uS sdev: 1.100 uS 25 secs base min: -18.000 uS max: 18.600 uS sdev: 1.100 uS 25 secs servo min: -15.000 uS max: 13.200 uS sdev: 1.100 uS 26 secs base min: -18.000 uS max: 18.600 uS sdev: 1.200 uS 26 secs servo min: -15.000 uS max: 13.200 uS sdev: 1.100 uS 27 secs base min: -18.000 uS max: 18.900 uS sdev: 1.200 uS 27 secs servo min: -15.000 uS max: 13.200 uS sdev: 1.100 uS 29 secs base min: -18.000 uS max: 19.300 uS sdev: 1.200 uS 29 secs servo min: -15.000 uS max: 13.800 uS sdev: 1.200 uS 30 secs base min: -18.000 uS max: 19.300 uS sdev: 1.200 uS 30 secs servo min: -15.000 uS max: 13.800 uS sdev: 1.100 uS 31 secs base min: -18.000 uS max: 19.300 uS sdev: 1.200 uS 31 secs servo min: -15.000 uS max: 13.800 uS sdev: 1.200 uS 33 secs base min: -18.000 uS max: 19.300 uS sdev: 1.200 uS 33 secs servo min: -15.000 uS max: 14.000 uS sdev: 1.200 uS 34 secs base min: -18.000 uS max: 19.300 uS sdev: 1.200 uS 34 secs servo min: -15.000 uS max: 14.000 uS sdev: 1.200 uS 35 secs base min: -18.000 uS max: 19.300 uS sdev: 1.200 uS 35 secs servo min: -15.000 uS max: 14.100 uS sdev: 1.200 uS 37 secs base min: -18.000 uS max: 19.300 uS sdev: 1.200 uS 37 secs servo min: -15.000 uS max: 14.100 uS sdev: 1.100 uS 38 secs base min: -18.000 uS max: 19.300 uS sdev: 1.200 uS 38 secs servo min: -15.000 uS max: 14.100 uS sdev: 1.100 uS 39 secs base min: -18.000 uS max: 19.300 uS sdev: 1.200 uS 39 secs servo min: -15.000 uS max: 14.100 uS sdev: 1.100 uS 41 secs base min: -18.000 uS max: 19.300 uS sdev: 1.200 uS 41 secs servo min: -15.000 uS max: 14.100 uS sdev: 1.100 uS 42 secs base min: -18.000 uS max: 19.300 uS sdev: 1.200 uS 42 secs servo min: -15.000 uS max: 14.100 uS sdev: 1.100 uS 43 secs base min: -18.000 uS max: 19.300 uS sdev: 1.200 uS 43 secs servo min: -15.000 uS max: 14.100 uS sdev: 1.100 uS 45 secs base min: -18.000 uS max: 19.300 uS sdev: 1.200 uS 45 secs servo min: -15.000 uS max: 14.100 uS sdev: 1.100 uS 46 secs base min: -18.000 uS max: 19.300 uS sdev: 1.200 uS 46 secs servo min: -15.000 uS max: 14.100 uS sdev: 1.100 uS 47 secs base min: -18.000 uS max: 19.300 uS sdev: 1.200 uS 47 secs servo min: -15.000 uS max: 14.100 uS sdev: 1.100 uS 49 secs base min: -18.000 uS max: 19.300 uS sdev: 1.200 uS 49 secs servo min: -15.000 uS max: 14.100 uS sdev: 1.100 uS 50 secs base min: -18.000 uS max: 19.300 uS sdev: 1.200 uS 50 secs servo min: -15.000 uS max: 14.100 uS sdev: 1.100 uS 51 secs base min: -18.000 uS max: 19.300 uS sdev: 1.200 uS 51 secs servo min: -15.000 uS max: 14.100 uS sdev: 1.100 uS 53 secs base min: -18.000 uS max: 19.300 uS sdev: 1.200 uS 53 secs servo min: -15.000 uS max: 14.100 uS sdev: 1.100 uS 54 secs base min: -18.000 uS max: 19.300 uS sdev: 1.200 uS 54 secs servo min: -15.000 uS max: 14.100 uS sdev: 1.100 uS 55 secs base min: -18.000 uS max: 19.300 uS sdev: 1.200 uS 55 secs servo min: -15.000 uS max: 14.100 uS sdev: 1.100 uS 57 secs base min: -18.000 uS max: 19.300 uS sdev: 1.200 uS 57 secs servo min: -15.000 uS max: 14.100 uS sdev: 1.100 uS 58 secs base min: -18.000 uS max: 19.300 uS sdev: 1.200 uS 58 secs servo min: -15.000 uS max: 14.100 uS sdev: 1.100 uS 59 secs base min: -18.000 uS max: 19.300 uS sdev: 1.200 uS 59 secs servo min: -15.000 uS max: 14.100 uS sdev: 1.100 uS 61 secs base min: -18.000 uS max: 19.300 uS sdev: 1.200 uS 61 secs servo min: -15.000 uS max: 14.100 uS sdev: 1.100 uS 62 secs base min: -18.000 uS max: 19.300 uS sdev: 1.200 uS 62 secs servo min: -15.000 uS max: 14.100 uS sdev: 1.100 uS 63 secs base min: -18.000 uS max: 19.300 uS sdev: 1.100 uS 63 secs servo min: -15.000 uS max: 14.100 uS sdev: 1.100 uS 65 secs base min: -18.000 uS max: 19.300 uS sdev: 1.100 uS 65 secs servo min: -15.000 uS max: 14.100 uS sdev: 1.100 uS 66 secs base min: -18.000 uS max: 19.300 uS sdev: 1.100 uS 66 secs servo min: -15.000 uS max: 14.100 uS sdev: 1.100 uS 67 secs base min: -18.000 uS max: 19.300 uS sdev: 1.100 uS 67 secs servo min: -15.000 uS max: 14.100 uS sdev: 1.100 uS 69 secs base min: -18.000 uS max: 19.300 uS sdev: 1.100 uS 69 secs servo min: -15.000 uS max: 14.100 uS sdev: 1.100 uS 70 secs base min: -18.000 uS max: 19.300 uS sdev: 1.100 uS 70 secs servo min: -15.000 uS max: 14.100 uS sdev: 1.100 uS 71 secs base min: -18.000 uS max: 19.300 uS sdev: 1.100 uS 71 secs servo min: -15.000 uS max: 14.100 uS sdev: 1.100 uS 73 secs base min: -18.000 uS max: 19.300 uS sdev: 1.100 uS 73 secs servo min: -15.000 uS max: 14.100 uS sdev: 1.100 uS 74 secs base min: -18.000 uS max: 19.300 uS sdev: 1.100 uS 74 secs servo min: -15.000 uS max: 14.100 uS sdev: 1.100 uS 75 secs base min: -18.000 uS max: 19.300 uS sdev: 1.100 uS 75 secs servo min: -15.000 uS max: 14.100 uS sdev: 1.100 uS 77 secs base min: -18.000 uS max: 19.300 uS sdev: 1.100 uS 77 secs servo min: -15.000 uS max: 14.100 uS sdev: 1.100 uS 78 secs base min: -18.000 uS max: 19.300 uS sdev: 1.100 uS 78 secs servo min: -15.000 uS max: 14.100 uS sdev: 1.100 uS 79 secs base min: -18.000 uS max: 19.300 uS sdev: 1.100 uS 79 secs servo min: -15.000 uS max: 14.100 uS sdev: 1.100 uS 81 secs base min: -18.000 uS max: 19.300 uS sdev: 1.100 uS 81 secs servo min: -15.000 uS max: 14.100 uS sdev: 1.100 uS 82 secs base min: -18.000 uS max: 19.300 uS sdev: 1.100 uS 82 secs servo min: -15.000 uS max: 14.100 uS sdev: 1.100 uS 83 secs base min: -18.000 uS max: 19.300 uS sdev: 1.100 uS 83 secs servo min: -15.000 uS max: 14.100 uS sdev: 1.100 uS 85 secs base min: -18.000 uS max: 19.300 uS sdev: 1.100 uS 85 secs servo min: -15.000 uS max: 14.100 uS sdev: 1.100 uS 86 secs base min: -18.000 uS max: 19.300 uS sdev: 1.100 uS 86 secs servo min: -15.000 uS max: 14.100 uS sdev: 1.100 uS 87 secs base min: -18.000 uS max: 19.300 uS sdev: 1.100 uS 87 secs servo min: -15.000 uS max: 14.100 uS sdev: 1.100 uS 89 secs base min: -18.000 uS max: 19.300 uS sdev: 1.100 uS 89 secs servo min: -15.000 uS max: 14.100 uS sdev: 1.100 uS 90 secs base min: -18.000 uS max: 19.300 uS sdev: 1.100 uS 90 secs servo min: -15.000 uS max: 14.100 uS sdev: 1.100 uS 91 secs base min: -18.000 uS max: 19.300 uS sdev: 1.100 uS 91 secs servo min: -15.000 uS max: 14.100 uS sdev: 1.100 uS 93 secs base min: -18.000 uS max: 19.300 uS sdev: 1.100 uS 93 secs servo min: -15.000 uS max: 14.100 uS sdev: 1.100 uS 94 secs base min: -18.000 uS max: 19.300 uS sdev: 1.100 uS 94 secs servo min: -15.000 uS max: 14.100 uS sdev: 1.100 uS 95 secs base min: -18.000 uS max: 19.300 uS sdev: 1.100 uS 95 secs servo min: -15.000 uS max: 14.100 uS sdev: 1.100 uS 97 secs base min: -18.000 uS max: 19.300 uS sdev: 1.100 uS 97 secs servo min: -15.000 uS max: 14.100 uS sdev: 1.100 uS 98 secs base min: -18.000 uS max: 19.300 uS sdev: 1.100 uS 98 secs servo min: -15.000 uS max: 14.100 uS sdev: 1.100 uS 99 secs base min: -18.000 uS max: 19.300 uS sdev: 1.100 uS 99 secs servo min: -15.000 uS max: 14.100 uS sdev: 1.100 uS 101 secs base min: -18.000 uS max: 19.300 uS sdev: 1.100 uS 101 secs servo min: -15.000 uS max: 14.100 uS sdev: 1.100 uS 102 secs base min: -18.000 uS max: 19.300 uS sdev: 1.100 uS 102 secs servo min: -15.000 uS max: 15.100 uS sdev: 1.100 uS 103 secs base min: -18.000 uS max: 19.300 uS sdev: 1.100 uS 103 secs servo min: -15.000 uS max: 15.100 uS sdev: 1.100 uS 105 secs base min: -18.000 uS max: 19.300 uS sdev: 1.100 uS 105 secs servo min: -15.000 uS max: 15.100 uS sdev: 1.100 uS 106 secs base min: -18.000 uS max: 19.300 uS sdev: 1.100 uS 106 secs servo min: -15.000 uS max: 15.100 uS sdev: 1.100 uS 107 secs base min: -18.000 uS max: 19.300 uS sdev: 1.100 uS 107 secs servo min: -15.000 uS max: 15.100 uS sdev: 1.100 uS 109 secs base min: -18.000 uS max: 19.300 uS sdev: 1.100 uS 109 secs servo min: -15.000 uS max: 15.100 uS sdev: 1.100 uS 110 secs base min: -18.000 uS max: 19.300 uS sdev: 1.100 uS 110 secs servo min: -15.000 uS max: 15.100 uS sdev: 1.100 uS 111 secs base min: -18.000 uS max: 19.300 uS sdev: 1.100 uS 111 secs servo min: -15.000 uS max: 15.100 uS sdev: 1.100 uS 113 secs base min: -18.000 uS max: 19.300 uS sdev: 1.100 uS 113 secs servo min: -15.000 uS max: 15.100 uS sdev: 1.100 uS 114 secs base min: -18.000 uS max: 19.300 uS sdev: 1.100 uS 114 secs servo min: -15.000 uS max: 15.100 uS sdev: 1.100 uS 115 secs base min: -18.000 uS max: 19.300 uS sdev: 1.100 uS 115 secs servo min: -15.000 uS max: 15.100 uS sdev: 1.100 uS 117 secs base min: -18.000 uS max: 19.300 uS sdev: 1.100 uS 117 secs servo min: -15.000 uS max: 15.100 uS sdev: 1.100 uS 118 secs base min: -18.000 uS max: 19.300 uS sdev: 1.100 uS 118 secs servo min: -15.000 uS max: 15.100 uS sdev: 1.100 uS 119 secs base min: -18.000 uS max: 19.300 uS sdev: 1.100 uS 119 secs servo min: -15.000 uS max: 15.100 uS sdev: 1.100 uS 121 secs base min: -18.000 uS max: 19.300 uS sdev: 1.100 uS 121 secs servo min: -15.000 uS max: 15.100 uS sdev: 1.100 uS 122 secs base min: -18.000 uS max: 19.300 uS sdev: 1.100 uS 122 secs servo min: -15.900 uS max: 17.000 uS sdev: 1.100 uS 123 secs base min: -18.000 uS max: 19.300 uS sdev: 1.100 uS 123 secs servo min: -15.900 uS max: 17.000 uS sdev: 1.100 uS 125 secs base min: -18.000 uS max: 19.300 uS sdev: 1.100 uS 125 secs servo min: -15.900 uS max: 17.000 uS sdev: 1.100 uS 126 secs base min: -18.000 uS max: 19.300 uS sdev: 1.100 uS 126 secs servo min: -15.900 uS max: 17.000 uS sdev: 1.100 uS 128 secs base min: -18.000 uS max: 19.300 uS sdev: 1.100 uS 128 secs servo min: -15.900 uS max: 17.000 uS sdev: 1.100 uS 129 secs base min: -18.000 uS max: 19.300 uS sdev: 1.100 uS 129 secs servo min: -15.900 uS max: 17.000 uS sdev: 1.100 uS
Last edit: 5 years 10 months ago by Clive S.
5 years 10 months ago #191037 by tommylight
That should do nicely for parallel port, if there are no excursions during longer periods of use.
The following user(s) said Thank You: seuchato, Clive S
5 years 10 months ago #191039 by Clive S
tommylight wrote: That should do nicely for parallel port, if there are no excursions during longer periods of use.
That ran for 2 hours
5 years 10 months ago #191043 by tommylight
Nice, but still there are PC's that will under certain circumstances have excursions, so set the base period to 40000 and use LinuxCNC for several hours. If no warnings = nice :)
If warnings, try 50000.
5 years 10 months ago #191184 by macsddau@linuxcnc
my contrib to hardware testing.
LinuxCNC pc tests, version 20200930, started 06.12.2020 00:27:37 ******************************************************************************** General info: ASRock, To Be Filled By O.E.M. Bios version P1.90, dated 05/21/2018 Chipset: Harddisk is non-rotational, ie. SSD The amount of swap currently used is 0 ================================================================================ CPU related data: model name : Intel(R) Celeron(R) CPU J3355 @ 2.00GHz cpu cores : 2 stepping : 9 cache size : 1024 KB ================================================================================ RAM related data: Maximum Capacity: 16 GB Maximum Voltage: 1.5 V Maximum Voltage: Unknown Size: 4096 MB Size: No Module Installed ================================================================================ GPU related data: configuration: driver=i915 latency=0 ================================================================================ Parallel port related data: number of parallel ports is 1 parport0: PC-style at 0x378, irq 5 [PCSPP] ================================================================================ Os and desktop related data: PRETTY_NAME="Debian GNU/Linux 10 (buster)" Should the info below not match with your machine, kindly post the output of pstree here, including a brief desciption of your desktop environment, window manager and display manager. Tia https://forum.linuxcnc.org/18-computer/39370-script-for-automated-testing-of-computer-latency Desktop environment : xfce4 Windowmanager : Xfwm4 Displaymanager : lightdm ================================================================================ Kernel related data: Kernel 4.19.0-13-rt-amd64 GRUB_CMDLINE_LINUX_DEFAULT="quiet isolcpus=1" Cpu idle driver: intel_idle ================================================================================ Kernel modules data: Check if pcspkr is loaded: Yes, may cause bigger latency. can be eliminated using: sudo echo "install pcspkr /bin/true" >/etc/modprobe.d/pcspkr.conf Check if snd modules are loaded: No, which is good! ================================================================================ Keyboard & Mouse related data: Number of mice: 1 Mouse 0 : Genius NetScroll+Mini Traveler Mice attached to USB: KYE Systems Corp. (Mouse Systems) Pocket Mouse LE Keyboards attached to USB: Logitech, Inc. Keyboard K120 ================================================================================ LinuxCNC related data: LinuxCNC version is: 2.8.1.1.g5d082d148 ================================================================================ Preparing for latency test: Started glxgears No. 1, 2, 3, 4, 5 .......... Started firefox with 'https://vimeo.com/150574260', WID 33554718 ================================================================================ Command for latency test is: su cnc -c "latency-histogram --bbinsize 1000 --base 25000 --sbinsize 1000 --nox 2>&1 | tee -a 1607210855.lat &" Latency testing loop started dimanche 6 décembre 2020, 00:27:53 (UTC+0100), should end after dimanche 6 décembre 2020, 02:27:53 (UTC+0100) Useless to proceed, read the relevant part in 1607210855.lat >>>Unexpected realtime delay on task 0 with period 25000<<< ================================================================================ Swap useage: prerun: 0, running: 0 ================================================================================ CPU core temperatures: Core 0: Tmin: 35.0°C, Tmax: 45.0°C, (high = +105.0°C, crit = +105.0°C) Core 2: Tmin: 32.0°C, Tmax: 43.0°C, (high = +105.0°C, crit = +105.0°C) ================================================================================ last latency data is as follows:. 532 secs base min: -19.500 uS max: 21.400 uS sdev: 0.200 uS 532 secs servo min: -16.900 uS max: 17.000 uS sdev: 0.200 uS
Try to use as describe :
Result :
bash: /etc/modprobe.d/pcspkr.conf: Permission non accordée
(sorry in French)
Time to create page: 0.276 seconds
