Dell OptiPlex 9010 i5-3570 CPU 3.40GHz
Linux Buster:
LinuxCNC pc tests, version 20200930, started 28.12.2020 16:43:54
General info:
Dell Inc., OptiPlex 9010
Bios version A13, dated 03/27/2013
Chipset: Intel Corporation 7 Series/C216
Harddisk is rotational
The amount of swap currently used is 0
CPU related data:
model name : Intel(R) Core(TM) i5-3570 CPU @ 3.40GHz
cpu cores : 4
stepping : 9
cache size : 6144 KB
RAM related data:
Maximum Capacity: 32 GB
Size: No Module Installed
GPU related data:
product: Xeon E3-1200 v2/3rd Gen Core processor Graphics Controller
configuration: driver=i915 latency=0
Parallel port related data:
number of parallel ports is 0
Os and desktop related data:
PRETTY_NAME="Debian GNU/Linux 10 (buster)"
Should the info below not match with your machine,
kindly post the output of pstree here, including a brief
desciption of your desktop environment, window manager and
display manager. Tia
https://forum.linuxcnc.org/18-computer/39370-script-for-automated-testing-of-computer-latency
Desktop environment : xfce4
Windowmanager : Xfwm4
Displaymanager : lightdm
Kernel related data:
Kernel 4.19.0-11-rt-amd64
GRUB_CMDLINE_LINUX_DEFAULT="quiet"
Cpu idle driver: intel_idle
Kernel modules data:
Check if pcspkr is loaded: Yes, may cause bigger latency.
can be eliminated using:
sudo echo "install pcspkr /bin/true" >/etc/modprobe.d/pcspkr.conf
Check if snd modules are loaded: No, which is good!
Keyboard & Mouse related data:
Number of mice: 1
Mouse 0 : Logitech Optical USB Mouse
Mice attached to USB:
Logitech, Inc. Optical Wheel Mouse
Keyboards attached to USB:
Dell Computer Corp. Keyboard
LinuxCNC related data:
LinuxCNC version is: 2.8.1
Preparing for latency test:
Started glxgears No. 1, 2, 3, 4, 5
Started firefox with 'https://vimeo.com/150574260', WID 33554435
Command for latency test is:
su anto -c "latency-histogram --nobase --sbinsize 1000 --nox 2>&1 | tee -a 1609191832.lat &"
Latency testing loop started Mon 28 Dec 2020 04:44:09 PM EST,
should end after Mon 28 Dec 2020 06:44:09 PM EST
Swap useage: prerun: 0, running: 0
CPU core temperatures:
Core 0: Tmin: 30.0°C, Tmax: 53.0°C, (high = +85.0°C, crit = +105.0°C)
Core 1: Tmin: 33.0°C, Tmax: 56.0°C, (high = +85.0°C, crit = +105.0°C)
Core 2: Tmin: 35.0°C, Tmax: 57.0°C, (high = +85.0°C, crit = +105.0°C)
Core 3: Tmin: 26.0°C, Tmax: 50.0°C, (high = +85.0°C, crit = +105.0°C)
last latency data is as follows:.
7199 secs servo min: -75.700 uS max: 74.300 uS sdev: 2.900 uS
Linux Mint:
LinuxCNC pc tests, version 20200930, started 28.12.2020 13:48:40
General info:
CPU related data:
cpu cores : 4
stepping : 9
RAM related data:
GPU related data:
PRETTY_NAME="Linux Mint 19.2"
Desktop environment : gnome
Windowmanager : Metacity (Marco)
Kernel 4.16.12-rt5-kona-rt
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash"
Check if pcspkr is loaded: No, which is good!
Number of mice: 1
LinuxCNC version is: 2.8.0~pre1
Started firefox with 'https://vimeo.com/150574260', WID 62914563
su anto -c "latency-histogram --nobase --sbinsize 1000 --nox 2>&1 | tee -a 1609181318.lat &"
Latency testing loop started Mon Dec 28 13:48:55 EST 2020,
should end after Mon Dec 28 15:48:55 EST 2020
Core 0: Tmin: 31.0°C, Tmax: 57.0°C, (high = +85.0°C, crit = +105.0°C)
Core 1: Tmin: 36.0°C, Tmax: 59.0°C, (high = +85.0°C, crit = +105.0°C)
Core 2: Tmin: 37.0°C, Tmax: 60.0°C, (high = +85.0°C, crit = +105.0°C)
Core 3: Tmin: 28.0°C, Tmax: 54.0°C, (high = +85.0°C, crit = +105.0°C)
7202 secs servo min: -96.200 uS max: 108.000 uS sdev: 6.100 uS
7203 secs servo min: -96.200 uS max: 108.000 uS sdev: 6.100 uS
What is a good range? Even with Buster my numbers seem quite a bit higher relatively speaking than other posts here. I am using the onboard GPU, how much of an impact would that be?
