Results of latency test, list of computers tested for use with LinuxCNC
5 years 10 months ago #191481 by clifo
LinuxCNC pc tests, version 20200930, started 09.12.2020 06:59:30 ******************************************************************************** General info: , Bios version , dated Chipset: Harddisk is non-rotational, ie. SSD The amount of swap currently used is 0 ================================================================================ CPU related data: model name : Intel(R) Celeron(R) CPU J3455 @ 1.50GHz cpu cores : 4 stepping : 9 cache size : 1024 KB ================================================================================ RAM related data: ================================================================================ GPU related data: product: Intel Corporation product: Caicos [Radeon HD 6450/7450/8450 / R5 230 OEM] configuration: driver=i915 latency=0 configuration: driver=radeon latency=0 ================================================================================ Parallel port related data: number of parallel ports is 1 parport0: PC-style at 0x378, irq 5 [PCSPP,TRISTATE] ================================================================================ Os and desktop related data: PRETTY_NAME="Debian GNU/Linux 10 (buster)" Should the info below not match with your machine, kindly post the output of pstree here, including a brief desciption of your desktop environment, window manager and display manager. Tia https://forum.linuxcnc.org/18-computer/39370-script-for-automated-testing-of-computer-latency Desktop environment : xfce4 Windowmanager : Xfwm4 Displaymanager : lightdm ================================================================================ Kernel related data: Kernel 4.19.152-rtai-amd64 GRUB_CMDLINE_LINUX_DEFAULT="quiet isolcpus=2,3 idle=poll acpi_irq_nobalance noirqbalance lapic intel_idle.maxcstate=0 processor.max_cstate=0 ipv6.disable=1 pci=routeirq " Cpu idle driver: ================================================================================ Kernel modules data: Check if pcspkr is loaded: No, which is good! Check if snd modules are loaded: No, which is good! ================================================================================ Keyboard & Mouse related data: Number of mice: 1 Mouse 0 : ImExPS/2 Generic Explorer Mouse Mice attached to USB: Keyboards attached to USB: ================================================================================ LinuxCNC related data: LinuxCNC version is: ================================================================================ Preparing for latency test: Started glxgears No. 1, 2, 3, 4, 5 .......... Started firefox with 'https://vimeo.com/150574260', WID 44040195 ================================================================================ Latency testing loop started St dec 9 06:59:47 CET 2020, Command for latency test is: su clifo -c "latency-histogram --bbinsize 1000 --base 25000 --sbinsize 1000 --nox 2>&1 | tee -a 1607493569.lat &" should end after St dec 9 08:59:47 CET 2020 ================================================================================ Swap useage: prerun: 0, running: 0 ================================================================================ CPU core temperatures: Core 0: Tmin: 36.0°C, Tmax: 42.0°C, (high = +105.0°C, crit = +105.0°C) Core 1: Tmin: 36.0°C, Tmax: 42.0°C, (high = +105.0°C, crit = +105.0°C) Core 2: Tmin: 33.0°C, Tmax: 39.0°C, (high = +105.0°C, crit = +105.0°C) Core 3: Tmin: 33.0°C, Tmax: 39.0°C, (high = +105.0°C, crit = +105.0°C) ================================================================================ last latency data is as follows:. 7204 secs base min: -4.700 uS max: 4.600 uS sdev: 0.100 uS 7204 secs servo min: -3.700 uS max: 3.800 uS sdev: 0.100 uS
5 years 10 months ago #193142 by faeluke
LinuxCNC pc tests, version 20200930, started 24.12.2020 10:50:50
General info:
Hewlett-Packard, HP Compaq Pro 6300 SFF
Bios version K01 v02.90, dated 07/16/2013
Chipset: Intel Corporation 7 Series/C216
CPU related data:
model name : Intel(R) Core(TM) i7-3770 CPU @ 3.40GHz
cpu cores : 1
stepping : 9
cache size : 8192 KB
RAM related data:
Maximum Capacity: 32 GB
GPU related data:
product: Xeon E3-1200 v2/3rd Gen Core processor Graphics Controller
number of parallel ports is 0
PRETTY_NAME="Linux Mint 20"
forum.linuxcnc.org/18-computer/39370-scr...-of-computer-latency
Desktop environment : gnome
Windowmanager : Metacity (Marco)
Kernel 4.9.0-13-rt-amd64
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash"
Cpu idle driver: intel_idle
Check if snd modules are loaded: Yes, may cause bigger latency.
can probably be disabled in bios, alternatively, you can run
"./block-snd-modules"
which has just now been created for your convenience.
Number of mice: 1
Mouse 0 : USB OPTICAL MOUSE
LinuxCNC version is: 2.8.1.13.ga22256354
Started firefox with ' vimeo.com/150574260 ', WID 69206019
su luke -c "latency-histogram --nobase --base 25000 --sbinsize 1000 --nox 2>&1 | tee -a HP6300-2020-12-24.lat &"
Latency testing loop started Thu 24 Dec 2020 10:51:05 AM EST,
should end after Thu 24 Dec 2020 12:51:05 PM EST
Core 0: Tmin: 35.0°C, Tmax: 42.0°C, (high = +85.0°C, crit = +105.0°C)
7200 secs servo min: -37.300 uS max: 24.500 uS sdev: 2.200 uS
7201 secs servo min: -37.300 uS max: 24.500 uS sdev: 2.200 uS
5 years 10 months ago #193176 by seuchato
faeluke wrote: ...
I >think< the 6300 is very similar to the 8300 I tested a couple of months ago. while theser results are good, you might get even better results. Thus, for an inspirations, you could try the cmdline options I did here . First, I'd look into the bios. Kindly aloso state, what options you altered.
greez
chris
5 years 10 months ago - 5 years 10 months ago #193182 by faeluke
Yes, I read through the posts on machines and was about to pull the trigger on an 8300 when Amazon informed me that the machine would come after Christmas. The HP6300 came up in the same search results. I opted for the I7, although I am not sure if it will make difference with everything turned off in the BIOS.
while these results are good, you might get even better results.
I am a noob, so getting this all up and running with Mint on a new PC and posting the results was for me, a Christmas miracle.
I had set multiprocessor -> disabled in the BIOS, Is this the same as running with Isolcpus?
On your machine, BIOS 2.99 appears to have the best numbers. I will update to 2.99 and try that out.
I will also take at modifying the Grub command line to see if I can improve the results further.
Kindly also state, what options you altered.
Are you asking me to post the BIOS settings up to this point or to post the additional changes once I complete additional testing?
Last edit: 5 years 10 months ago by faeluke.
5 years 10 months ago #193221 by seuchato
faeluke wrote: ...I opted for the I7, although I am not sure if it will make difference with everything turned off in the BIOS.
i7s usually have more cache (i7 3770: 8MB, i5 3570: 6 MB), which should/could result in better latency. So, it was a wise decision to take an i7.
... so getting this all up and running with Mint on a new PC and posting the results was for me, a Christmas miracle.
So: congrats! And if you ever were, you are certainly no noob anymore :-)
...I had set multiprocessor -> disabled in the BIOS, Is this the same as running with Isolcpus?
In Bios, the most important part is to disable evrything that smells like power saving and hyperthreading.
while playing with bios version, note: hp says you cannot roll back to an earlier version. Usually because ther seemingly are "security" reasons. Isolcpus does disable cpus, but lets you chose which ones. If you read more, you will see posts where someone got best results isolating the lower cpus and others with isolation the upper cpus. Therefore, I prefore leaving multi core on and use isolcpus. There are machines out there, where isolcpus is of zero effect.
I tried to get a clearcut overview here . That's for a dell optoplex 980 though, but I hope, it is inspiring enough to at least serve as a hint for other pcs.
Greez
chris
The following user(s) said Thank You: faeluke
5 years 10 months ago #193222 by seuchato
tommylight wrote: Set the base period higher than the latency result shows, at least 20 to 30% higher.
Tommy
I will add a hint stating exactly that when a basethread is being used.
greez
chris
