- Thank you received: 3
Project_Hopeless wrote: Dell OptiPlex 9010 i5-3570 CPU 3.40GHz
Linux Buster:
Code:LinuxCNC pc tests, version 20200930, started 28.12.2020 16:43:54 ******************************************************************************** General info: Dell Inc., OptiPlex 9010 Bios version A13, dated 03/27/2013 Chipset: Intel Corporation 7 Series/C216 Harddisk is rotational The amount of swap currently used is 0 ... ================================================================================ Os and desktop related data: PRETTY_NAME="Debian GNU/Linux 10 (buster)" ... Desktop environment : xfce4 Windowmanager : Xfwm4 Displaymanager : lightdm ================================================================================ Kernel related data: Kernel 4.19.0-11-rt-amd64 GRUB_CMDLINE_LINUX_DEFAULT="quiet" Cpu idle driver: intel_idle ================================================================================ Kernel modules data: Check if pcspkr is loaded: Yes, may cause bigger latency. can be eliminated using: sudo echo "install pcspkr /bin/true" >/etc/modprobe.d/pcspkr.conf Check if snd modules are loaded: No, which is good! ... ================================================================================ last latency data is as follows:. 7199 secs servo min: -75.700 uS max: 74.300 uS sdev: 2.900 uS 7199 secs servo min: -75.700 uS max: 74.300 uS sdev: 2.900 uS
Linux Mint:
Code:LinuxCNC pc tests, version 20200930, started 28.12.2020 13:48:40 ******************************************************************************** ... ================================================================================ Os and desktop related data: PRETTY_NAME="Linux Mint 19.2" ... Desktop environment : gnome Windowmanager : Metacity (Marco) Displaymanager : lightdm ================================================================================ Kernel related data: Kernel 4.16.12-rt5-kona-rt GRUB_CMDLINE_LINUX_DEFAULT="quiet splash" Cpu idle driver: intel_idle ================================================================================ Kernel modules data: Check if pcspkr is loaded: No, which is good! Check if snd modules are loaded: No, which is good! ... ================================================================================ last latency data is as follows:. 7202 secs servo min: -96.200 uS max: 108.000 uS sdev: 6.100 uS 7203 secs servo min: -96.200 uS max: 108.000 uS sdev: 6.100 uS
I'd say you got it already, as long as there are no real time delay messages. You might be able to bring these values down, again, see post above.What is a good range?
Even with Buster my numbers seem quite a bit higher relatively speaking than other posts here. I am using the onboard GPU, how much of an impact would that be?
That is valid for base period when using parallel port. Mesa boards do not use base period at all, and the servo period should be left at default 1000000 ( 1 mill ).seuchato wrote: I'd set the value in LinuxCNC to 120 -130% of the obtained latency data ..
Usually AMD/ATI GPU's are OK as they do not care much about compliance to power requirements, but i had a Radeon 7thausandsomething that i literally threw in the trash as it would mess up latency to extreme heights.seuchato wrote: I have seen some Radeon GPU's doing bad stuff to latency too
That is always the best and the only safe way of making sure everything is OK, there is no simple way of reproducing everything that goes on inside a PC with a test.seuchato wrote: "do some real world testing by running the PC on real data, just disconnected from the motors for hours. If there are no " real time delay" messages, you should be fine". I second that.
