20 Jun 2022 20:21 #245496 by viewtop1
Really Great work.
Is there a difference between the "Original" Remora and the NVEM version? Does the NVEM support QEI encoder?
22 Jun 2022 22:41 #245620 by andypugh
I have been following this with interest, but with a drawer full of Mesa cards and no new machine builds on the horizon I have not tried it.
But if you want it in the main repository, let's go for it.
The following user(s) said Thank You: Domi
  • scotta
  • Platinum Member
  • Platinum Member
25 Jun 2022 22:03 #245882 by scotta
Really Great work.
The main difference is that the "original" Remora uses an SPI interface. The NVEM version uses Ethernet. On the NVEM there is only one set of IO that is connected to a Timer with suitable pins. So we could get the QEI going on those pins. It would be suitable for a high speed spindle encoder.
  • scotta
  • Platinum Member
  • Platinum Member
25 Jun 2022 22:05 #245883 by scotta
Hi Andy, that would be great! The number of boards might even grow.
  • scotta
  • Platinum Member
  • Platinum Member
25 Jun 2022 22:11 #245885 by scotta
I've been contacted regarding Remora for the Digital Dream EC500 controller board and was sent some pictures. The EC500 looks to be very similar to the NVEM but running a STM32F407. It is a 24V IO card which would suit using normal industrial sensors etc.
I'm going to try and help get this running on his board in Brazil from the other side of the world. Let's see how this goes.
The following user(s) said Thank You: kwarup
07 Jul 2022 06:14 - 07 Jul 2022 06:15 #246778 by Jan R.
I have NVEM V2 running on Mach3 and I'm thinking about maybe trying this firmware on my router. The biggest issue I have with NVEM V2 under Mach3 is the probing isnt working as it should. I'm totally blank when it come's LinuxCNC, but I have been thinking about trying it out for a long time now. So maybe this is the time to do that.
1. Is probing an issue with this firmware?
2. My router is using 2 motors for the Y-axis. Is that gonna be problematic?
Cheers
Jan Rune
Last edit: 07 Jul 2022 06:15 by Jan R..
  • scotta
  • Platinum Member
  • Platinum Member
07 Jul 2022 06:38 #246781 by scotta
Hi Jan, you might need to come and join us and start using LinuxCNC. There is a bit of a learning curve but nothing to difficult.
I use probing extensively with Remora firmware running on other boards, SKR2 etc. So I would not foresee any issues.
LinuxCNC is super flexible and configurable and supports multiple joints per axis like gantry routers. Individual limit / home switches can be used for each Y axis joint
forum.linuxcnc.org/49-basic-configuratio...o-square-the-machine
07 Jul 2022 20:51 #246834 by Bari
HEY CHINA!!
If you are reading this, please copy this and sell us boards preloaded with Remora vs Mach3 firmware. It runs on Linux so you can even save $1 on a copy of a copy of Window$.
  • Moderator
  • Moderator
07 Jul 2022 21:12 #246837 by tommylight
Replied by tommylight on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
HEY CHINA!!
Interesting, but there are rarely spammers from there here on this forum, all we get is essay, girls, and occasional machines.
11 Jul 2022 06:06 #247056 by fintech
Does anybody have a NVEM V2 6 axis factory backup? Looking for a factory .bin. My controller is not responding.
Time to create page: 0.395 seconds
