12 Nov 2023 22:18 #285208 by cakeslob
Yes of course, follow the files
[/quote]
I think you are using an outdated version of the component. Work is being done to make everything easier, but until then, install this component and change your hal file from remora-eth to remora-nv
github.com/scottalford75/Remora-NVEM/tre...Components/Remora-nv
The following user(s) said Thank You: FCS Industrial
13 Nov 2023 01:31 #285220 by FCS Industrial
Replied by FCS Industrial on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
Thank you very much cakeslob, it completely solved the problem.
I am very grateful for the response.
13 Nov 2023 08:54 #285242 by manager12345
Replied by manager12345 on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
With this error, but now I have a new problem that I can't write the bin file. Does anyone have any ideas on how to do this via j-link?
13 Nov 2023 22:02 #285317 by hanskuster
Replied by hanskuster on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
although Your response was not meant to my question, I tried the remora-nv component from Remora-NVEM.
Now the inputs and outputs are working!
But the stepper motor still doesn't move :-(
Any other ideas?
Regards, Hans
14 Nov 2023 03:18 #285331 by FCS Industrial
Cakeslob, could you answer a question please?
What is the maximum frequency in kz that the NVEM STM32F207 board can reach with the remora firmware?
14 Nov 2023 04:52 - 14 Nov 2023 05:01 #285342 by cakeslob
Im not to sure for the 207, but I dont think it will be too much more than 40k
Ok, that is a good start. So the board is connecting to linuxcnc. When you jog in linuxcnc, does it move in the preview screen?
, edit, Hans, what is this here?
[EMCMOT]
EMCMOT = motmod
COMM_TIMEOUT = 1.0
COMM_WAIT = 0.010
BASE_PERIOD = 3000000
SERVO_PERIOD = 3000000
I think it should be something like this
[EMCMOT]
EMCMOT = motmod
COMM_TIMEOUT = 1.0
COMM_WAIT = 0.010
BASE_PERIOD = 0
SERVO_PERIOD = 1000000
I dont think this will fix your problem, but lets start with changing that.
Last edit: 14 Nov 2023 05:01 by cakeslob.
14 Nov 2023 08:37 - 14 Nov 2023 08:59 #285351 by frayja2002
Replied by frayja2002 on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
Just to confirm on this I have flashed another board (with lots of checking) and it does appear that output 13 on my new board is faulty.....
Oh dear China !?!
I was also wondering if I upload a reduced size config file (IE 3 axis instead of 6 axis) does it increase the speed of have some other effect on cycle time?
Alex
Last edit: 14 Nov 2023 08:59 by frayja2002.
14 Nov 2023 10:14 - 14 Nov 2023 10:29 #285357 by andrewt12
Replied by andrewt12 on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
Hi All,
I Have an NVEM with rt1052.
Is it normal for the 12volt outputs to be at ground and the grount to be 12 12volt ? Im talking about the the bottom rows along where all the inputs are.
Also the manual shows to use PNP inductive sensors but the inputs need to be pulled low to get them to trigger. It is completely the opposite to what is shown in the manual.
I can make it work I just find it strange.
Cheers
Edit. Never mind. Worked it out. They changed to NPN inputs on the v5 and reversed the polarity on the output voltages. What crap.
Last edit: 14 Nov 2023 10:29 by andrewt12.
14 Nov 2023 22:09 #285431 by hanskuster
Hi cakeslob,
thanks for having a look into my problem!
The axis move in the preview screen, but the motor doesn't get any signals.
I had an error message for BASE_PERIOD, I don't remember which one, but setting it to the same value like SERVO_PERIOD fixed this for me.
When I had both values to 1'000'000 I constantly got an error message about latency, I should run the latency test, although I switched off all power saving options in the bios.
The latency test gave me results of around 30'000 which should be good.
My goal for now is to make the system moving and then I can check/fix the latency, if that will be an issue.
Regards, Hans
15 Nov 2023 01:19 #285447 by cakeslob
Hey Hans,
Since we are using  external hardware, I dont think that we use a basethread. That is mostly for parallel port setups.
Its good that it shows up in the preview
The following user(s) said Thank You: hanskuster
Time to create page: 0.881 seconds
