05 Jan 2024 23:12 #289909 by TimGow
beauxnez, you have checked Scott's YT videos?
06 Jan 2024 01:59 #289916 by cakeslob
Question to the other users, is everyone getting a following error on startup with the new firmware, like user freyja is experiencing?
06 Jan 2024 09:04 - 06 Jan 2024 09:05 #289934 by beauxnez
the card on the video is an EC300, I have an NVEM v5, you absolutely need an RS-232 socket?
I don't understand English and the translation is really not good
Last edit: 06 Jan 2024 09:05 by beauxnez.
06 Jan 2024 19:43 - 06 Jan 2024 20:07 #289990 by raf1110
Hi
I got stuck on serial output:
Remora RT1052 starting
Initializing PHY...
## Entering SETUP state
1. Loading JSON configuration file from Flash memory
Flash storage location is empty - no config file
Using basic default configuration - 3 step generators only
2. Parsing JSON configuration file
Config deserialisation - Deserialization succeeded
3. Configuring threads
Creating thread 40000
Creating thread 1000
4. Loading modules
Creating a std module
Creating an Ethernet communication monitoring module
Creating Pin @
  port = GPIO3
  pin = 0
Base thread object
X - Joint 0 step generator
Creating Pin @
  port = GPIO1
  pin = 22
Creating Pin @
  port = GPIO1
  pin = 17
Base thread object
Y - Joint 1 step generator
Creating Pin @
  port = GPIO1
  pin = 24
Creating Pin @
  port = GPIO1
  pin = 31
Base thread object
Z - Joint 2 step generator
Creating Pin @
  port = GPIO1
  pin = 18
Creating Pin @
  port = GPIO1
  pin = 25
X_Limit
Make Digital Input at pin P4_26
Creating Pin @
  port = GPIO4
  pin = 26
Y_Limit
Make Digital Input at pin P4_27
Creating Pin @
  port = GPIO4
  pin = 27
Z_Limit
Make Digital Input at pin P4_21
Creating Pin @
  port = GPIO4
  pin = 21
## Entering START state
Starting the BASE thread
Registering interrupt for interrupt number = 100
        configuring Timer 1
        timer started
Starting the SERVO thread
Registering interrupt for interrupt number = 101
        configuring Timer 2
        timer started
## Entering IDLE state
I have one stepper connected to X axis output and now I am not sure how to setup machine on EMC2 to have clearly control from UI screen.
Pin 21 seem to be X-in and port 4 is Estop I think.
I have uploaded standard config that is on git fro NVEM v5 rt chip.
Is it possible to use wizard to create setup file?
Last edit: 06 Jan 2024 20:07 by raf1110.
06 Jan 2024 21:21 #290006 by cakeslob
what board are you using?
Did you make this configuration or is it the default?
There is no wizard avaiable, but the the default premade configurations take care of most use cases
07 Jan 2024 13:56 #290095 by raf1110
I have now figure I still need uploading config via PHY and created pins in terminal out are from default config for 3 step generator on 3 axis
Currently I need to figure how to run PHY upload and flash my config for 3axis cnc 3x2 endstop, vfd speed controll and usb xhc wheel. I think wheel can be inserted in custom hal file..ini
Please take a look above mentioned log in my post if pinout naming and ports is relevant to NVEM pinout
08 Jan 2024 04:55 - 08 Jan 2024 04:57 #290177 by wazza77
Hi Scott,I have received an EC500, I flashed it with the 3.1.2.bin using Pyocd it looks like a success on boot up it has lit up 8 LEDs on the io output port see pictures and I received a lot of garbled data on the serial terminal but it might be my settings in real term I can ping the Ec500 and when I toggle emergency stop on LCNC the connect led lights up on EC500 yet to upload my configuration. I am not sure if it is all correct due to LEDs and serial output, are the LEDs meant to light up like this?Warren
Last edit: 08 Jan 2024 04:57 by wazza77.
09 Jan 2024 04:03 #290256 by cakeslob
Download the config files here, and select what ever board you have
github.com/scottalford75/Remora-RT1052-cpp/tree/main/LinuxCNC
Follow the directions here to upload your config over ethernet
remora-docs.readthedocs.io/en/latest/fir...ethernet-config.html
  • scotta
  • Platinum Member
  • Platinum Member
09 Jan 2024 04:56 #290258 by scotta
Hi Warren, looks like some good success. Those lights being lit up on the outputs in due to the default config not configuring those. Once you upload a full config file they will be properly available.
12 Jan 2024 11:25 #290493 by raf1110
Hi
I am bit confused if file LinuxCNC/nvem-rt1052.txt is correct for NVEM rt1052 eth.
In file it states board: EC300.
Is this correct or shoud be board:NVEM?
Time to create page: 0.366 seconds
