Remora - ethernet NVEM cnc board
Update to above, remora-ec500.hal revised to 'loadrt remora-eth-3.0' (and commented out mpg in remora-ec500.ini).
Linuxcnc starts with only the usual 'Unexpected realtime delay on task 0 with period 1000000'.
EC300 LEDs ON and understood are: SYSTEM 24V, IO COM+ and CONN.
EC300 LEDs ON and not understood are: OT4, OT6, OT7, OT9 & OT10, also spindle INDEX.
Toggling the E-stop turns the 'CONN' LED on/off; is this an indication of proper firmware function?
Now to try connecting stepper drivers.
xxx.bin to xxx JSON config.txt that you upload. Folders with correct files and compiled halcomponent according to board in linuxcnc machine folders.
remora-nv is for NVEM not ECxxx series.
Make sure you use correct repo files correct for your board version/model
I found an old version of debian buster I am trying to install remora on a NVEM rt1052
when I run the following command (sudo python -m pip install -U pyocd) I have an error message
File "/tmp/pip-build-env-slocJp/lib/python2.7/site-packages/setuptools /__init__.py", line 162, in setup
return distutils.core.setup(**attrs)
File "/usr/lib/python2.7/distutils/core.py", line 151, in setup
dist.run_commands()
File "/usr/lib/python2.7/distutils/dist.py", line 953, in run_commands
self.run_command(cmd)
File "/usr/lib/python2.7/distutils/dist.py", line 972, in run_command
cmd_obj.run()
File "/tmp/pip-build-env-slocJp/lib/python2.7/site-packages/setuptools /command/egg_info.py", line 296, in run
self.find_sources()
File "/tmp/pip-build-env-slocJp/lib/python2.7/site-packages/setuptools /command/egg_info.py", line 303, in find_sources
mm.run()
File "/tmp/pip-build-env-slocJp/lib/python2.7/site-packages/setuptools /command/egg_info.py", line 534, in run
self.add_defaults()
File "/tmp/pip-build-env-slocJp/lib/python2.7/site-packages/setuptools /command/egg_info.py", line 570, in add_defaults
sdist.add_defaults(self)
File "/tmp/pip-build-env-slocJp/lib/python2.7/site-packages/setuptools /command/py36compat.py", line 36, in add_defaults
self._add_defaults_ext()
File "/tmp/pip-build-env-slocJp/lib/python2.7/site-packages/setuptools /command/py36compat.py", line 120, in _add_defaults_ext
self.filelist.extend(build_ext.get_source_files())
File "/tmp/pip-install-fRSXV5/pyyaml/setup.py", line 201, in get_sourc e_files
self.cython_sources(ext.sources, ext)
File "/usr/lib/python2.7/distutils/cmd.py", line 105, in __getattr__
raise AttributeError, attr
AttributeError: cython_sources
Command "python setup.py egg_info" failed with error code 1 in /tmp/pip-inst all-fRSXV5/pyyaml/
manu@raspberrypi:~ $
Does uploading JSON require remora components installed with halcompile command.
Somehow I am unable to connect to board after uploading JSON config for stm32
This give me error due to incorrect pin assignment
I have try number of eth cables and devices. Since I have uploaded incorrect config I am unable to fix it.
I have uploaded new .bin with CMSIS but JSON config have stayed old.
Please help.
You dont need the remora component installed to run the config tool.
I dont know if there is a bootloader or anything on these chips, but writing the new firmware wont overwrite the config, you will probably need to do either a full chip erase, or erase the sectors where the config is stored.
I believe all names should match name with chip,board from start:
To a degree, they should match. I dont know all the names for this project, but I am under the impression that the STM32 versions and the RT1052 versions of the board share the same name.
remora-nv is for the stm32 versions
remora eth 3.0 is for the RT1052 versions
as far as I can tell
Ok I was wrong thinking this would default config but I have not found info on how erasing it can be done. I used MCUXide but not sure if there is option to use when flashing firmware so it remove bad config.You dont need the remora component installed to run the config tool.
I have been through rpi3, rpi4, debian12 on linuxcnc pc and various repos to look for eth connection and failed greatly to access 10.10.10.10 ip which I managed before.
Now I have no idea where to find problem. RPI repo does not have buster release anymore therefore following manual on remora-docs.readthedocs.io/en/latest/sof...ry-pi-linuxcnc-image is near impossible.
command:sudo apt-get install linux-image-4.19.71-rt24-v7l+
don't work after all steps above in mentioned manual!
Im not firmiliar with the RT1052 version, but if its like the stm32 version, you probably need to do some kind of fullchip erase, but I dont know very much about the rt1052
For installing linuxcnc RPI image refere here. it is premade with linuxcnc installed.
do this for installing Rpi linuxcnc, the other section is old and no longer used.
"Deprecated instructions preserved for posterity"
after you have a linuxcnc install working, you need to install the component depending on which board you are running
remora-docs.readthedocs.io/en/latest/sof...mp-installation.html
then you need to configure your ethernet ip
remora-docs.readthedocs.io/en/latest/sof...hernet-software.html
Any thoughts would be appreciated.
I think I might have resolved this or just found a different issue
Warren
raf1110, thank youI believe all names should match name with chip,board from start:
"remora eth 3.0 is for the RT1052 versions"
cakeslob, thank you
