  • scotta
  • Platinum Member
  • Platinum Member
25 May 2022 15:04 #243802 by scotta
Scott,
Spi vs Ethernet.
I have a Ethernet module that I could connect to my 3d printer main boards. Any advantage vs using spi?
The main one I can think of is the com is less sensitive to interference. And not limited to devices with spi support.
Any other reasons?
The main advantage is being able to use any PC (inc SBC) as we only need an Ethernet port. I'm still working on the W5500 implementation to give ethernet capability for 3D printer boards but it will come with an increased servo period due to the speed of the SPI communication with the board. As you said, the less sensitive interface will help and we will have the ability to move the RPi (or other LinuxCNC capable PC) away from  the 3D printer.
The original Remora SPI concept is still great and works well where appropriate. Rafal in the other thread has done work to reject corrupted packets on the SPI bus, which also raises the question as the applicability of SPI in some environments. With Remora is was really repurposing off the shelf hardware.
Remora-NVEM is a pleasing outcome to give another option for the LinuxCNC community to use readily available hardware.
The following user(s) said Thank You: tommylight, tuzki
26 May 2022 16:42 - 26 May 2022 17:49 #243924 by Domi
I'm just adding trifles. M64P03 and M65P03 still need to be placed in the probe screen V2 file in Macros / manual_change.ngc
    net probe-input motion.probe-input => remora.input.5
    net probe.toolchange-input => remora.input.7
    net flood remora.output.3 iocontrol.0.coolant-flood
    net mist remora.output.4 iocontrol.0.coolant-mist
#   M64P03 ON air blow for toolsensor.M65P03-OFF
    net probe.toolchange.blast motion.digital-out-03 => remora.output.2
I have the tool sensor connected in series with the E-stop so that the tool does not break if it accidentally exceeds a given height.
Last edit: 26 May 2022 17:49 by Domi.
27 May 2022 01:41 #243963 by eng
Could you give me a basic idea, what would be the logic you used to make the dds control along with the interrupts to be able to generate the pulses? I'm trying to understand to study something with esp32.
  • scotta
  • Platinum Member
  • Platinum Member
27 May 2022 03:42 - 27 May 2022 03:42 #243965 by scotta
Hi eng,
No problem, I did see your posts in the ESP32 thread. Below is the data flow. The two threads are essentially timer ISR routines that iterate over a vector of pointers to the base class method of the modules.
The Remora stepgen module evolved from the standard LinuxCNC stepgen.c, with the two halves split between the LinuxCNC component and the controller board. A PID loop was adapted into the stepgen to cope with the time difference between a read and write to the controller board.
The DDS (position) accumulator is at the heart of the make_pulses(). It does two things, the first storing the position (counts) and the other determining when a step should occur by monitoring a step bit (pickoff)
Last edit: 27 May 2022 03:42 by scotta.
The following user(s) said Thank You: Bari, tommylight
29 May 2022 10:01 #244109 by Win_D
Hi Scotta,
The firmware can generate 40khz is maximum? Did we reach the limit or we could increase it higher later on?
As per original Mach 3 can reach up to 200khz, was it because of nature of Mach 3 structure?
  • scotta
  • Platinum Member
  • Platinum Member
30 May 2022 05:28 #244182 by scotta
No we haven't tested the highest step rate as yet. Both the firmware and LinuxCNC component are capable of having configurable thread frequencies just like the SPI version of Remora.
50 or 60khz may be achievable but with the current software step generator 200khz is not likely.
  • scotta
  • Platinum Member
  • Platinum Member
04 Jun 2022 06:30 #244558 by scotta
I've just published the first of hopefully a few videos on setting up Remora-NVEM.
The following user(s) said Thank You: Bari, tjtr33, Clive S, Domi, spdbmp927
04 Jun 2022 13:45 #244575 by Aaroncnc
looks awesome.
I wonder what step generator they are running with mach 3 that they are able to get to 200khz
I seem to remember in an older post there was speculation to double the speed of the unit i thought that would have brought it to 80khz.
  • scotta
  • Platinum Member
  • Platinum Member
04 Jun 2022 22:34 #244588 by scotta
Thanks, and I'd love to know the original step generation scheme as well. I had another look at the decompiled original firmware but it's very challenging to understand.
The Remora-NVEM step generator now runs at the base thread frequency. It use to take two base threads to raise and then lower the step pin. I need to migrate this into the standard Remora code as well.
  • scotta
  • Platinum Member
  • Platinum Member
05 Jun 2022 04:32 #244595 by scotta
Another short video stepping through using the JSON configuration capabilities of Remora.
The following user(s) said Thank You: tommylight, Clive S, spdbmp927, satsuma
Time to create page: 0.597 seconds
