Remora - ethernet NVEM cnc board
20 Jun 2022 20:21 #245496
by viewtop1
Replied by viewtop1 on topic Remora - ethernet NVEM cnc board
Really Great work.
Is there a difference between the "Original" Remora and the NVEM version? Does the NVEM support QEI encoder?
22 Jun 2022 22:41 #245620
Replied by andypugh on topic Remora - ethernet NVEM cnc board
I have been following this with interest, but with a drawer full of Mesa cards and no new machine builds on the horizon I have not tried it.
But if you want it in the main repository, let's go for it.
The following user(s) said Thank You: Domi
25 Jun 2022 22:03 #245882
by scotta
Replied by scotta on topic Remora - ethernet NVEM cnc board
The main difference is that the "original" Remora uses an SPI interface. The NVEM version uses Ethernet. On the NVEM there is only one set of IO that is connected to a Timer with suitable pins. So we could get the QEI going on those pins. It would be suitable for a high speed spindle encoder.Really Great work.
25 Jun 2022 22:05 #245883
by scotta
Hi Andy, that would be great! The number of boards might even grow.I have been following this with interest, but with a drawer full of Mesa cards and no new machine builds on the horizon I have not tried it.
25 Jun 2022 22:11 #245885
by scotta
I've been contacted regarding Remora for the Digital Dream EC500 controller board and was sent some pictures. The EC500 looks to be very similar to the NVEM but running a STM32F407. It is a 24V IO card which would suit using normal industrial sensors etc.
I'm going to try and help get this running on his board in Brazil from the other side of the world. Let's see how this goes.
The following user(s) said Thank You: kwarup
07 Jul 2022 06:14 - 07 Jul 2022 06:15 #246778
by Jan R.
Replied by Jan R. on topic Remora - ethernet NVEM cnc board
I have NVEM V2 running on Mach3 and I'm thinking about maybe trying this firmware on my router. The biggest issue I have with NVEM V2 under Mach3 is the probing isnt working as it should. I'm totally blank when it come's LinuxCNC, but I have been thinking about trying it out for a long time now. So maybe this is the time to do that.
1. Is probing an issue with this firmware?
2. My router is using 2 motors for the Y-axis. Is that gonna be problematic?
Cheers
Jan Rune
Cheers
Jan Rune
Last edit: 07 Jul 2022 06:15 by Jan R..
07 Jul 2022 06:38 #246781
by scotta
Hi Jan, you might need to come and join us and start using LinuxCNC. There is a bit of a learning curve but nothing to difficult.
I use probing extensively with Remora firmware running on other boards, SKR2 etc. So I would not foresee any issues.
LinuxCNC is super flexible and configurable and supports multiple joints per axis like gantry routers. Individual limit / home switches can be used for each Y axis joint
forum.linuxcnc.org/49-basic-configuratio...o-square-the-machine
07 Jul 2022 20:51 #246834
by Bari
Replied by Bari on topic Remora - ethernet NVEM cnc board
HEY CHINA!!
If you are reading this, please copy this and sell us boards preloaded with Remora vs Mach3 firmware. It runs on Linux so you can even save $1 on a copy of a copy of Window$.
- Thank you received: 6092
07 Jul 2022 21:12 #246837
Replied by tommylight on topic Remora - ethernet NVEM cnc board
Interesting, but there are rarely spammers from there here on this forum, all we get is essay, girls, and occasional machines.HEY CHINA!!
![:) :)](/media/kunena/emoticons/smile.png)
11 Jul 2022 06:06 #247056
by fintech
Replied by fintech on topic Remora - ethernet NVEM cnc board
Does anybody have a NVEM V2 6 axis factory backup? Looking for a factory .bin. My controller is not responding.
Time to create page: 0.244 seconds
