09 Sep 2022 23:32 - 09 Sep 2022 23:33 #251583 by RogEnk
Possible to get a clear image of the PHY. It looks to be the same as the earlier NVEM's but it would be good to know.
Sorry Scott, on re-reading that I now interpret you are asking for a better image of the PHY? If so could you explain to this ancient layman what you mean please?
Last edit: 09 Sep 2022 23:33 by RogEnk.
09 Sep 2022 23:42 #251584 by cakeslob
Fairly sure its the ethernet chip here he is looking for
09 Sep 2022 23:42 #251585 by Bari
Maybe a few extra close up pics of the chips that are a bit blurry if possible. Then we can post links to all their data sheets.
  • scotta
  • Platinum Member
  • Platinum Member
09 Sep 2022 23:49 #251586 by scotta
Yes, some good clear images of front and back of board for this part of the board. What I did for the EC500 was to overlay the back and front images in CAD, aligning the vias so that I could then trace the circuit. Some really clear closeup photos would help.
  • scotta
  • Platinum Member
  • Platinum Member
09 Sep 2022 23:52 #251587 by scotta
Looked at J-Link OB and very quickly realized I am out of my depth!
Happy to invest if it helps, any recommendations Scott?
Me too, I've been struggling with the STM32H743, let alone now learning the NXP tool chain.... like anything, one step at a time. Hopefully the J-link is the right programming adaptor as it will take 3 weeks to get to me. A week after the EC300 is due to arrive.
10 Sep 2022 00:13 #251588 by Bari
Starting a parts list of the EC300 here with links to all the data sheets.
github.com/openlunchbox/Remora_EC300
The following user(s) said Thank You: scotta
  • Moderator
  • Moderator
10 Sep 2022 00:55 #251589 by tommylight
Replied by tommylight on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
Here is a good idea for taking good close up shots of electronics boards:
  • scotta
  • Platinum Member
  • Platinum Member
10 Sep 2022 02:05 #251595 by scotta
Hi Scott,
I am lost. After flashing the new Firmware it is not able to ping the EC500.
Flashing the old firmware, still the same error with the nvmpg.
Sorry for this, but i need help to solve the problem.
Thx
Christian
Hi Christian, have you checked that your network adaptor is configured correctly to have an IP address within the same sub net 10.10.10.xx? Assuming you are not going through a router, When you plug the network cable into the controller board and run the ifconfig command from terminal do you see that your adaptor has an IP address?
If you have a good IP address and still no luck pinging, I'd then move on to doing a full chip erase and reflash the firmware.
Hi Scott,
ip address is 10.10.10.1. So i did a full chip erase and reflashed the firmware from this "github.com/scottalford75/Remora-EC500/tree/main/Firmware". A ping on 10.10.10.10 says host unreachable. So i erased the chip once again an flashed the firmware from "github.com/scottalford75/Remora-Novusun/...are/Remora-EC500.bin" And the ping on 10.10.10.10 has good results. But there is still no change with the nvmpg with this version of firmware. I don't know what I'm doing wrong. I am very sorry for causing you such inconveniences.
Christian
Christian,
A few more things to check. Below is my wiring which is known to work. RX <--> TX.
Have you uncommented the line in the INI file to enable the NVMPG?
[HAL]
HALFILE = remora-ec500.hal
# remove comment from next line to enable the NVEM NVMPG
HALFILE = remora-nv-mpg.hal
POSTGUI_HALFILE = postgui_call_list.ha
HALUI = halui
10 Sep 2022 02:29 #251597 by RogEnk
OK these are the three I see as blurred, first is the PHY one.
Second is the three chips to the left of the DC/DC in my original, third is the two chips to the top right of the DC/DC.
I'll borrow my wife's iPhone 13 pro tomorrow and set up lighting so that the text is is better contrasted, and I will do the reverse side of the board.
And I will share a high resolution version from my own forums where I allow 4K
The following user(s) said Thank You: Bari, MX_Master
  • scotta
  • Platinum Member
  • Platinum Member
10 Sep 2022 02:38 #251598 by scotta
Thanks Rog. The PHY is the same as the earlier NVEM's.
Time to create page: 0.976 seconds
