- meister
- Thank you received: 339
09 Apr 2023 11:34 #268663
by meister
Replied by meister on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
my c skills are a little rusty and i can not compile your code on Linux,
but i thing something like this is a little bit faster (no funtion calls).
and i think disabling all IRQ's is not a good idea
[/code]
__disable_irq();
// then move the data
for (int i = 0; i < BUFFER_SIZE; i++)
rxData.rxBuffer = rxBuffer.rxBuffer;
// re-enable thread interrupts
__enable_irq();
[code]
void makeSteps()
static int8_t i;
static int32_t stepNow;
// loop through the step generators
for (i = 0; i <= JOINTS; i++)
stepNow = 0;
isEnabled[i] = ((rxData.jointEnable & (1 << i)) != 0);
if (isEnabled[i] == true)
frequencyCommand[i] = rxData.jointFreqCmd[i];
DDSaddValue[i] = frequencyCommand[i] * frequencyScale;
stepNow = DDSaccumulator[i];
DDSaccumulator[i] += DDSaddValue[i];
stepNow ^= DDSaccumulator[i];
stepNow &= (1L << STEPBIT);
rawCount[i] = DDSaccumulator[i] >> STEPBIT;
if (DDSaddValue[i] > 0)
isForward[i] = true;
else
isForward[i] = false;
if (stepNow)
// GPIO_PinWrite(STEP_PORT, dirPin[i], isForward[i]);
if (isForward[i] == true) {
base->DR_SET = (1<<dirPin[i]);
} else {
base->DR_CLEAR = (1<<dirPin[i]);
// GPIO_PinWrite(STEP_PORT, stepPin[i], 1);
base->DR_SET = (1<<stepPin[i]);
txData.jointFeedback[i] = DDSaccumulator[i];
isStepping[i] = true;
void resetSteps()
static int8_t i;
if (isStepping[i])
// GPIO_PinWrite(STEP_PORT, stepPin[i], 0);
base->DR_CLEAR = (1<<stepPin[i]);
[/code]
__disable_irq();
__enable_irq();
[code]
- cakeslob
- Thank you received: 264
09 Apr 2023 16:37 #268686
by cakeslob
Ohhhhh that looks sweet. The ballscrew/rail size difference was larger than I expected. Beautiful.
The disabling interrupts, Im fairly sure is to correct a bigger issue (i call it melting axis). My new thing is, when in doubt, add deadband and pgain
- meister
09 Apr 2023 16:44 #268688
by meister
i get the compilation work on my system
if i reduce the freq of this threads, the jitter is much much better !
#define PRU_BASEFREQ 20000 // PRU Base thread ISR update frequency (hz)
#define PRU_SERVOFREQ 500 // PRU Servo thread ISR update freqency (hz)
- meister
09 Apr 2023 18:30 #268700
by meister
moving code from servo thread into main loop.
that's much better for me:
--- a/remora-rt1052/source/baseThread.c
+++ b/remora-rt1052/source/baseThread.c
@@ -93,8 +93,8 @@ void updateBaseThread()
void makeSteps()
- int8_t i;
- int32_t stepNow;
+ static int8_t i;
+ static int32_t stepNow;
@@ -123,8 +123,12 @@ void makeSteps()
if (stepNow)
- GPIO_PinWrite(STEP_PORT, dirPin[i], isForward[i]);
- GPIO_PinWrite(STEP_PORT, stepPin[i], 1);
+ if (isForward[i] == true) {
+ STEP_PORT->DR_SET = (1<<dirPin[i]);
+ } else {
+ STEP_PORT->DR_CLEAR = (1<<dirPin[i]);
+ STEP_PORT->DR_SET = (1<<stepPin[i]);
@@ -135,13 +139,13 @@ void makeSteps()
void resetSteps()
- int8_t i;
+ static int8_t i;
if (isStepping[i])
- GPIO_PinWrite(STEP_PORT, stepPin[i], 0);
+ STEP_PORT->DR_CLEAR = (1<<stepPin[i]);
diff --git a/remora-rt1052/source/configuration.h b/remora-rt1052/source/configuration.h
index 9482d64..5d7d9a2 100644
--- a/remora-rt1052/source/configuration.h
+++ b/remora-rt1052/source/configuration.h
@@ -1,8 +1,8 @@
#ifndef CONFIGURATION_H
#define CONFIGURATION_H
-#define PRU_BASEFREQ 40000 // PRU Base thread ISR update frequency (hz)
-#define PRU_SERVOFREQ 1000 // PRU Servo thread ISR update freqency (hz)
+#define PRU_BASEFREQ 60000 // PRU Base thread ISR update frequency (hz)
+#define PRU_SERVOFREQ 10 // PRU Servo thread ISR update freqency (hz)
#define STEPBIT 22 // bit location in DDS accum
#define STEP_MASK (1L<<STEPBIT)
diff --git a/remora-rt1052/source/ethernet.c b/remora-rt1052/source/ethernet.c
index bb9d591..866b88e 100644
--- a/remora-rt1052/source/ethernet.c
+++ b/remora-rt1052/source/ethernet.c
@@ -127,13 +127,11 @@ void udp_data_callback(void *arg, struct udp_pcb *upcb, struct pbuf *p, const ip
// ensure an atomic access to the rxBuffer
// disable thread interrupts
__disable_irq();
- for (int i = 0; i < BUFFER_SIZE; i++)
- rxData.rxBuffer[i] = rxBuffer.rxBuffer[i];
+ memcpy(rxData.rxBuffer, rxBuffer.rxBuffer, BUFFER_SIZE);
__enable_irq();
diff --git a/remora-rt1052/source/remora-rt1052.c b/remora-rt1052/source/remora-rt1052.c
index 549d54d..74cc253 100644
--- a/remora-rt1052/source/remora-rt1052.c
+++ b/remora-rt1052/source/remora-rt1052.c
@@ -207,6 +207,10 @@ int main(void)
EthernetTasks();
+ readInputs();
+ setOutputs();
diff --git a/remora-rt1052/source/remora.h b/remora-rt1052/source/remora.h
index 7f9e1b5..00af8b9 100644
--- a/remora-rt1052/source/remora.h
+++ b/remora-rt1052/source/remora.h
@@ -5,6 +5,8 @@
#pragma pack(push, 1)
typedef union
// this allow structured access to the incoming SPI data without having to move it
diff --git a/remora-rt1052/source/servoThread.c b/remora-rt1052/source/servoThread.c
index 49648f2..f923e4a 100644
--- a/remora-rt1052/source/servoThread.c
+++ b/remora-rt1052/source/servoThread.c
@@ -136,10 +136,10 @@ void configServoThread()
void updateServoThread()
monitorEthernet();
- readInputs();
- setOutputs();
+ //readInputs();
+ //setOutputs();
updatePWM();
- updateNVMPG();
+ //updateNVMPG();
- zmrdko
- Thank you received: 46
09 Apr 2023 21:40 - 09 Apr 2023 21:41 #268716
by zmrdko
Replied by zmrdko on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
Is anybody else experiencing slow approach to exact position as well on ec500? (rt1052)
Last edit: 09 Apr 2023 21:41 by zmrdko.
- scotta
- Thank you received: 472
09 Apr 2023 22:24 #268720
by scotta
Have you tried increasing the P gain to see if that removes the "jitter".
This breaks the intent of Remora which runs two threads, one which is in sync with LinuxCNC. The servo thread. No need to read inputs / set output and process Ethernet (which won't be present) faster than needed to match the 1000ms LinuxCNC thread.moving code from servo thread into main loop.
--- a/remora-rt1052/source/baseThread.c +++ b/remora-rt1052/source/baseThread.c @@ -93,8 +93,8 @@ void updateBaseThread() void makeSteps() { - int8_t i; - int32_t stepNow; + static int8_t i; + static int32_t stepNow; // loop through the step generators for (i = 0; i <= JOINTS; i++) @@ -123,8 +123,12 @@ void makeSteps() if (stepNow) { - GPIO_PinWrite(STEP_PORT, dirPin[i], isForward[i]); - GPIO_PinWrite(STEP_PORT, stepPin[i], 1); + if (isForward[i] == true) { + STEP_PORT->DR_SET = (1<<dirPin[i]); + } else { + STEP_PORT->DR_CLEAR = (1<<dirPin[i]); + } + STEP_PORT->DR_SET = (1<<stepPin[i]); txData.jointFeedback[i] = DDSaccumulator[i]; isStepping[i] = true; } @@ -135,13 +139,13 @@ void makeSteps() void resetSteps() { - int8_t i; + static int8_t i; for (i = 0; i <= JOINTS; i++) { if (isStepping[i]) { - GPIO_PinWrite(STEP_PORT, stepPin[i], 0); + STEP_PORT->DR_CLEAR = (1<<stepPin[i]); } } } diff --git a/remora-rt1052/source/configuration.h b/remora-rt1052/source/configuration.h index 9482d64..5d7d9a2 100644 --- a/remora-rt1052/source/configuration.h +++ b/remora-rt1052/source/configuration.h @@ -1,8 +1,8 @@ #ifndef CONFIGURATION_H #define CONFIGURATION_H -#define PRU_BASEFREQ 40000 // PRU Base thread ISR update frequency (hz) -#define PRU_SERVOFREQ 1000 // PRU Servo thread ISR update freqency (hz) +#define PRU_BASEFREQ 60000 // PRU Base thread ISR update frequency (hz) +#define PRU_SERVOFREQ 10 // PRU Servo thread ISR update freqency (hz) #define STEPBIT 22 // bit location in DDS accum #define STEP_MASK (1L<<STEPBIT) diff --git a/remora-rt1052/source/ethernet.c b/remora-rt1052/source/ethernet.c index bb9d591..866b88e 100644 --- a/remora-rt1052/source/ethernet.c +++ b/remora-rt1052/source/ethernet.c @@ -127,13 +127,11 @@ void udp_data_callback(void *arg, struct udp_pcb *upcb, struct pbuf *p, const ip // ensure an atomic access to the rxBuffer // disable thread interrupts + __disable_irq(); // then move the data - for (int i = 0; i < BUFFER_SIZE; i++) - { - rxData.rxBuffer[i] = rxBuffer.rxBuffer[i]; - } + memcpy(rxData.rxBuffer, rxBuffer.rxBuffer, BUFFER_SIZE); // re-enable thread interrupts __enable_irq(); diff --git a/remora-rt1052/source/remora-rt1052.c b/remora-rt1052/source/remora-rt1052.c index 549d54d..74cc253 100644 --- a/remora-rt1052/source/remora-rt1052.c +++ b/remora-rt1052/source/remora-rt1052.c @@ -207,6 +207,10 @@ int main(void) } EthernetTasks(); + readInputs(); + setOutputs(); + + } } diff --git a/remora-rt1052/source/remora.h b/remora-rt1052/source/remora.h index 7f9e1b5..00af8b9 100644 --- a/remora-rt1052/source/remora.h +++ b/remora-rt1052/source/remora.h @@ -5,6 +5,8 @@ #pragma pack(push, 1) + + typedef union { // this allow structured access to the incoming SPI data without having to move it diff --git a/remora-rt1052/source/servoThread.c b/remora-rt1052/source/servoThread.c index 49648f2..f923e4a 100644 --- a/remora-rt1052/source/servoThread.c +++ b/remora-rt1052/source/servoThread.c @@ -136,10 +136,10 @@ void configServoThread() void updateServoThread() { monitorEthernet(); - readInputs(); - setOutputs(); + //readInputs(); + //setOutputs(); updatePWM(); - updateNVMPG(); + //updateNVMPG(); }[/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i]
- scotta
09 Apr 2023 22:26 #268721
by scotta
Yes, this is solved by adding a Pgain setting. The default gain is 1, increasing it to 10 or more will improve the response of the control loop.Is anybody else experiencing slow approach to exact position as well on ec500? (rt1052)
- scotta
09 Apr 2023 22:31 #268723
by scotta
Did you also change the servo frequency in LinuxCNC and inform the Remora component about the different base thread frequency? If not the frequency command calculations are all out and the control loop will be working harder to compensate for the wacky following error. Changing these settings in the firmware must be mirrored on the LinuxCNC side.i get the compilation work on my system
- frayja2002
- Thank you received: 12
10 Apr 2023 02:46 - 10 Apr 2023 02:54 #268738
by frayja2002
Replied by frayja2002 on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
Just a quick update.
Here is the list of pins i have checked on an RT-1053 based NVEM box.
Scott, could you tell me where (if anywhere) to other output pins go to.
Alex
Alex
Last edit: 10 Apr 2023 02:54 by frayja2002.
The following user(s) said Thank You: cnc-phil
- scotta
10 Apr 2023 06:11 #268743
by scotta
Hi Alex, that's it for the NVEM / EC300. The extra outputs are available on the EC500.Just a quick update.
Alex
Time to create page: 1.110 seconds
